> Tous les forumsLinux
 d-link airPlus 2.4ghz wireless pci adapter(urgent)
 devilfrank
  Posté le 15/01/2005 @ 23:28
92 Messages
bonjour! j'ai besoin que vous m'aidier svp. bon, j'ai une carte d-link qui rejoint le signal de mon routeur (d-link) sans fil. sur windows aucun prob car j'ai les driver mais sous linux c'est une autre histoire ;-) alors voila j'ai besoin de savoir comment configurer ma carte réseau sans fil et aussi mon réseau sans fil! me faut-il des driver pour linux si oui ou les trouver? merci de votre aide je suis en détresse!
 Afficher le profil de devilfrankEnvoyer un message privé à devilfrank
 Torrent  Posté le 15/01/2005 à 23:41
1079 Messages
Pages de "man wireless" WIRELESS(7) Linux Programmer's Manual WIRELESS(7) NAME wireless - Wireless Tools and Wireless Extensions SYNOPSIS iwconfig iwpriv -a DESCRIPTION The Wireless Extensions is an API allowing you manipulate Wireless LAN networking interfaces. It is composed of a variety of tools and con- figuration files. It is documented in more detail in the Linux Wire- less LAN Howto. The Wireless Tools are used to change the configuration of wireless LAN networking interfaces on The Fly, to get their current configura- tion, to get statistics and Diagnose them. They are described in their own man page, see below for references. Wireless configuration is specific to each Linux distribution. This man page will contain in the future the configuration procedure for a few common distributions. For the time being, check the file DISTRIBU- TIONS.txt included with the Wireless Tools package. Manual page wireless(7) line 1 SUMMARY OF LESS COMMANDS Commands marked with * may be preceded by a number, N. Notes in parentheses indicate the behavior if N is given. h H Display this help. q :q Q :Q ZZ Exit. --------------------------------------------------------------------------- MOVING e ^E j ^N CR * Forward one line (or N lines). y ^Y k ^K ^P * Backward one line (or N lines). f ^F ^V SPACE * Forward one window (or N lines). b ^B ESC-v * Backward one window (or N lines). z * Forward one window (and set window to N). w * Backward one window (and set window to N). ESC-SPACE * Forward one window, but don't stop at end-of-file. d ^D * Forward one half-window (and set half-window to N). u ^U * Backward one half-window (and set half-window to N). ESC-) RightArrow * Left one half screen width (or N positions). ESC-( LeftArrow * Right one half screen width (or N positions). HELP -- Press RETURN for more, or q when done
Afficher le profil de Torrent Voir la configuration de TorrentEnvoyer un message privé à Torrent
  Revenir en haut de la page
 devilfrank  Posté le 16/01/2005 à 00:47
92 Messages
dsl mais je comprend pas l'anglais tu peux tu me traduire en gros ce que ca veux dire merci tu est tres gentil
 abourgeo  Posté le 16/01/2005 à 00:50
1784 Messages
ça semble bien expliqué ici: [url]http://www.wlanfr.net/contenus.php?id=129[/url] si tu ne veux pas utiliser le "cvs", le driver existe aussi en tar.gz: [url]http://www.ivor.it/wireless/acx.html[/url] l'install reprend la "façon de faire" de "ndiswrapper" (autre driver pour wifi sous Linux), c'est à dire qu'il s'appuie sur des binaires pour win$. A priori, tu disposes de ces fichiers, mais WlanFr.net les propose en téléchargement ! On peut donc s'affranchir totalement de win$ !!! ;-)
Afficher le profil de abourgeoEnvoyer un message privé à abourgeo
 devilfrank  Posté le 16/01/2005 à 20:07
92 Messages
merci
Haut de la page
Inscrivez-vous !
- Posez vos questions
- Résolvez vos problèmes
- Aidez les autres
- Suivez vos sujets préférés
TOUT EST GRATUIT !
Je crée mon compte
Vous avez besoin d'aide ?
Les derniers sujets résolus !
 > Tous les forumsLinux
Forum PC Astuces© 1997-2009 WebastucesAller en haut de la page
