> Tous les forumsLinux
 Pas de son, Mandrake 10.1, asus P4P800
 cquad
  Posté le 08/12/2004 @ 19:44
10 Messages
J'ai intallé les drivers alsa 1.0.7 .configure tout se passe bien make tout se compile bien make install tout se passe bien ./snddevices se passe bien par contre /etc/modules.conf est vide, et je ne sais si je dois le remplir si je fait :
alsamixer alsamixer: function snd_ctl_open failed for default: No such device or address
lspcidrake -v | fgrep AUDIO snd-intel8x0 : Intel Corp.|82801EB AC'97 Audio [MULTIMEDIA_AUDIO] (vendor:8086 device:24d5 subv:1043 subd:80f3)
et j'ai : :-(
modprobe snd-intel8x0 WARNING: Error inserting snd (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/acore/snd.ko): Unknown symbol in module, or unknown parameter (see dmesg) WARNING: Error inserting snd-timer (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/acore/snd-timer.ko): Unknown symbol in module, or unknown parameter (see dmesg) WARNING: Error inserting snd-pcm (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/acore/snd-pcm.ko): Unknown symbol in module, or unknown parameter (see dmesg) WARNING: Error inserting snd-ac97-codec (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/pci/ac97/snd-ac97-codec.ko): Unknown symbol in module, or unknown parameter (see dmesg) WARNING: Error inserting snd (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/acore/snd.ko): Unknown symbol in module, or unknown parameter (see dmesg) WARNING: Error inserting snd-timer (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/acore/snd-timer.ko): Unknown symbol in module, or unknown parameter (see dmesg) WARNING: Error inserting snd-pcm (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/acore/snd-pcm.ko): Unknown symbol in module, or unknown parameter (see dmesg) WARNING: Error inserting snd-ac97-codec (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/pci/ac97/snd-ac97-codec.ko): Unknown symbol in module, or unknown parameter (see dmesg) FATAL: Error inserting snd-intel8x0 (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/pci/snd-intel8x0.ko): Unknown symbol in module, or unknown parameter (see dmesg) FATAL: Error running install command for snd-intel8x0
Si quelqu'un a une idée ou une piste pour solutionner mon probleme je vous remercie d'avance. Cédric
 Afficher le profil de cquadEnvoyer un message privé à cquad
 selim,b.  Posté le 08/12/2004 à 19:57
2392 Messages
bonsoir 1. la rem classic: le kernel-source installe? 2. apres ./snddevice tape: [code]chmod a+rw /dev/dsp* /dev/mixer* /dev/sequencer* /dev/midi[/code] 3. je compile tjrs avec: [code]./configure --with-cards=intel8x0 --with-sequencer=yes --with-debug=full --with-debug=detect[/code] 4. compile aussi les alsa-lib ; alsa-oss... 5. verifie/rajoute ces lignes dans /etc/modprobe.conf: [code]alias sound-slot-0 snd-intel8x0 alias snd-0 snd-intel8x0 install snd-intel8x0 /sbin/modprobe --first-time --ignore-install snd-intel8x0 && { /sbin/modprobe snd-pcm-oss; /bin/true; }[/code] D'aucuns rajouteront: [code]remove snd-intel8x0 /sbin/modprobe -r snd-pcm-oss; /sbin/modprobe --first-time -r --ignore-remove snd-intel8x0[/code] 6. reboot..
Afficher le profil de selim,b.Envoyer un message privé à selim,b.
 Revenir en haut de la page
 selim,b.  Posté le 08/12/2004 à 19:59
2392 Messages
re -- par default alsa s'installe en mute. utilise aumix / kmix /alsamixergui pour les reglages de sons
 cquad  Posté le 08/12/2004 à 20:10
10 Messages
1. oui les sources du kernle sont installées 2. je l'avais deja fait , j'ai refait au cas ou .. 3. c'est bien passé 4. je sais pas comment on compile alsa-libb et alsa-oss ? 5. dans /etc/modprobe.conf j'ai :
# This file is autogenerated from /etc/modules.conf using generate-modprobe.conf command alias eth0 sk98lin install scsi_hostadapter /sbin/modprobe ata_piix; /bin/true remove snd-intel8x0 /sbin/modprobe -r snd-pcm-oss; /sbin/modprobe --first-time -r --ignore-remove snd-intel8x0 install snd-intel8x0 /sbin/modprobe --first-time --ignore-install snd-intel8x0 && { /sbin/modprobe snd-pcm-oss; /bin/true; } install usb-interface /sbin/modprobe uhci-hcd; /sbin/modprobe ehci-hcd; /bin/true alias eth1 8139too remove i810_audio /sbin/modprobe --first-time -r --ignore-remove i810_audio install i810_audio /sbin/modprobe --first-time --ignore-install i810_audio # --- BEGIN: Generated by ALSACONF, do not edit. --- # --- ALSACONF verion 1.0.6 --- options snd device_mode=0666 alias snd-card-0 snd-intel8x0 alias sound-slot-0 snd-intel8x0 # --- END: Generated by ALSACONF, do not edit. ---
voili merci bcp de votre aide
 cquad  Posté le 08/12/2004 à 20:12
10 Messages
au lancement de kmix j'ai :
kmix QPixmap: Cannot create a QPixmap when no GUI is being used QPixmap: Cannot create a QPixmap when no GUI is being used QPixmap: Cannot create a QPixmap when no GUI is being used QPixmap: Cannot create a QPixmap when no GUI is being used kbuildsycoca running... kmix: ERROR: Impossible de trouver le mixeur alsa. Veuillez vérifier que la carte son est installée et que le pilote de la carte est chargé. kmix: kmix: ERROR: Impossible de trouver le mixeur alsa. Veuillez vérifier que la carte son est installée et que le pilote de la carte est chargé. kmix: kmix: ERROR: Impossible de trouver le mixeur alsa. Veuillez vérifier que la carte son est installée et que le pilote de la carte est chargé. kmix: kmix: ERROR: Impossible de trouver le mixeur alsa. Veuillez vérifier que la carte son est installée et que le pilote de la carte est chargé. kmix:
 selim,b.  Posté le 08/12/2004 à 20:27
2392 Messages
tu as utilise alsaconf pour remedier... eassaie ceci: 1. sauvegarde le fichier /etc/modprobe.conf (ou cas ca se passe mal) 2. reorganise et garde uniquement:
# This file is autogenerated from /etc/modules.conf using generate-modprobe.conf command alias eth0 sk98lin alias eth1 8139too sound-slot-0 snd-intel8x0 alias snd-0 snd-intel8x0 install scsi_hostadapter /sbin/modprobe ata_piix; /bin/true install snd-intel8x0 /sbin/modprobe --first-time --ignore-install snd-intel8x0 && { /sbin/modprobe snd-pcm-oss; /bin/true; } install usb-interface /sbin/modprobe uhci-hcd; /sbin/modprobe ehci-hcd; /bin/true remove snd-intel8x0 /sbin/modprobe -r snd-pcm-oss; /sbin/modprobe --first-time -r --ignore-remove snd-intel8x0
si ok, rajoute eventuellmnt: install i810_audio /sbin/modprobe --first-time --ignore-install i810_audio remove i810_audio /sbin/modprobe --first-time -r --ignore-remove i810_audio ou compare / adapte au mien (partiel):
alias sound-slot-0 snd-intel8x0 alias snd-0 snd-intel8x0 install snd-intel8x0 /sbin/modprobe --first-time --ignore-install snd-intel8x0 && { /sbin/modprobe snd-pcm-oss; /bin/true; } install usb-interface /sbin/modprobe ohci-hcd; /sbin/modprobe ehci-hcd; /bin/true remove snd-intel8x0 /sbin/modprobe -r snd-pcm-oss; /sbin/modprobe --first-time -r --ignore-remove snd-intel8x0
- Reboot - Si pas ok, supprime les modif et reviens au modprobe.conf sauvegarde.. - POur compiler les alsa-lib /oss: ./configure make make install
 cquad  Posté le 08/12/2004 à 20:55
10 Messages
dans /var/log/messages j'ai une erreur au démarrage :
modprobe: WARNING: Error inserting snd (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/acore/snd.ko): Unknown symbol in module, or unknown parameter (see dmesg) Dec 8 20:18:18 canteleu-3-xxx modprobe: WARNING: Error inserting snd-timer (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/acore/snd-timer.ko): Unknown symbol in module, or unknown parameter (see dmesg) Dec 8 20:18:18 canteleu-3-xxx modprobe: WARNING: Error inserting snd-pcm (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/acore/snd-pcm.ko): Unknown symbol in module, or unknown parameter (see dmesg) Dec 8 20:18:18 canteleu-3-xxx modprobe: WARNING: Error inserting snd-ac97-codec (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/pci/ac97/snd-ac97-codec.ko): Unknown symbol in module, or unknown parameter (see dmesg) Dec 8 20:18:18 canteleu-3-xxx modprobe: WARNING: Error inserting snd (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/acore/snd.ko): Unknown symbol in module, or unknown parameter (see dmesg) Dec 8 20:18:18 canteleu-3-xxx modprobe: WARNING: Error inserting snd-timer (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/acore/snd-timer.ko): Unknown symbol in module, or unknown parameter (see dmesg) Dec 8 20:18:18 canteleu-3-xxx modprobe: WARNING: Error inserting snd-pcm (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/acore/snd-pcm.ko): Unknown symbol in module, or unknown parameter (see dmesg) Dec 8 20:18:18 canteleu-3-xxx modprobe: WARNING: Error inserting snd-ac97-codec (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/pci/ac97/snd-ac97-codec.ko): Unknown symbol in module, or unknown parameter (see dmesg) Dec 8 20:48:06 canteleu-3-xxx modprobe: WARNING: Error inserting snd (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/acore/snd.ko): Unknown symbol in module, or unknown parameter (see dmesg) Dec 8 20:48:06 canteleu-3-xxx modprobe: WARNING: Error inserting snd-timer (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/acore/snd-timer.ko): Unknown symbol in module, or unknown parameter (see dmesg) Dec 8 20:48:06 canteleu-3-xxx modprobe: WARNING: Error inserting snd-pcm (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/acore/snd-pcm.ko): Unknown symbol in module, or unknown parameter (see dmesg) Dec 8 20:48:06 canteleu-3-xxx modprobe: WARNING: Error inserting snd-ac97-codec (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/pci/ac97/snd-ac97-codec.ko): Unknown symbol in module, or unknown parameter (see dmesg) Dec 8 20:48:06 canteleu-3-xxx modprobe: WARNING: Error inserting snd (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/acore/snd.ko): Unknown symbol in module, or unknown parameter (see dmesg) Dec 8 20:48:06 canteleu-3-xxx modprobe: WARNING: Error inserting snd-timer (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/acore/snd-timer.ko): Unknown symbol in module, or unknown parameter (see dmesg) Dec 8 20:48:06 canteleu-3-xxx modprobe: WARNING: Error inserting snd-pcm (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/acore/snd-pcm.ko): Unknown symbol in module, or unknown parameter (see dmesg) Dec 8 20:48:06 canteleu-3-xxx modprobe: WARNING: Error inserting snd-ac97-codec (/lib/modules/2.6.8.1-10mdksmp/kernel/sound/pci/ac97/snd-ac97-codec.ko): Unknown symbol in module, or unknown parameter (see dmesg)
ce qui expliquerais mes problemes ensuite, mais je ne suis pas plus eclairé ... :-(
Modifié par cquad le 08/12/2004 21:59
 selim,b.  Posté le 08/12/2004 à 21:02
2392 Messages
que donnent: [code]grep -i AC97 /usr/src/linux/.config[/code] [code]grep -i snd /usr/src/linux/.config[/code]
 selim,b.  Posté le 08/12/2004 à 21:04
2392 Messages
--et (sous root): [code]lsmod[/code]
 cquad  Posté le 08/12/2004 à 21:05
10 Messages
le premier on a :
[cquad@canteleu-3-xxx cquad]$ grep -i AC97 /usr/src/linux/.config CONFIG_SND_AC97_CODEC=m
2eme :
[cquad@canteleu-3-xxx cquad]$ grep -i snd /usr/src/linux/.config CONFIG_SND=m CONFIG_SND_TIMER=m CONFIG_SND_PCM=m CONFIG_SND_HWDEP=m CONFIG_SND_RAWMIDI=m CONFIG_SND_SEQUENCER=m CONFIG_SND_SEQ_DUMMY=m CONFIG_SND_OSSEMUL=y CONFIG_SND_MIXER_OSS=m CONFIG_SND_PCM_OSS=m CONFIG_SND_SEQUENCER_OSS=y CONFIG_SND_RTCTIMER=m # CONFIG_SND_VERBOSE_PRINTK is not set # CONFIG_SND_DEBUG is not set CONFIG_SND_MPU401_UART=m CONFIG_SND_OPL3_LIB=m CONFIG_SND_OPL4_LIB=m CONFIG_SND_VX_LIB=m CONFIG_SND_DUMMY=m CONFIG_SND_VIRMIDI=m CONFIG_SND_MTPAV=m CONFIG_SND_SERIAL_U16550=m CONFIG_SND_MPU401=m CONFIG_SND_AD1816A=m CONFIG_SND_AD1848=m CONFIG_SND_CS4231=m CONFIG_SND_CS4232=m CONFIG_SND_CS4236=m CONFIG_SND_ES968=m CONFIG_SND_ES1688=m CONFIG_SND_ES18XX=m CONFIG_SND_GUS_SYNTH=m CONFIG_SND_GUSCLASSIC=m CONFIG_SND_GUSEXTREME=m CONFIG_SND_GUSMAX=m CONFIG_SND_INTERWAVE=m CONFIG_SND_INTERWAVE_STB=m CONFIG_SND_OPTI92X_AD1848=m CONFIG_SND_OPTI92X_CS4231=m CONFIG_SND_OPTI93X=m CONFIG_SND_SB8=m CONFIG_SND_SB16=m CONFIG_SND_SBAWE=m CONFIG_SND_SB16_CSP=y CONFIG_SND_WAVEFRONT=m CONFIG_SND_ALS100=m CONFIG_SND_AZT2320=m CONFIG_SND_CMI8330=m CONFIG_SND_DT019X=m CONFIG_SND_OPL3SA2=m CONFIG_SND_SGALAXY=m CONFIG_SND_SSCAPE=m CONFIG_SND_AC97_CODEC=m CONFIG_SND_ALI5451=m CONFIG_SND_ATIIXP=m CONFIG_SND_ATIIXP_MODEM=m CONFIG_SND_AU8810=m CONFIG_SND_AU8820=m CONFIG_SND_AU8830=m CONFIG_SND_AZT3328=m CONFIG_SND_BT87X=m CONFIG_SND_CS46XX=m CONFIG_SND_CS46XX_NEW_DSP=y CONFIG_SND_CS4281=m CONFIG_SND_EMU10K1=m CONFIG_SND_KORG1212=m CONFIG_SND_MIXART=m CONFIG_SND_NM256=m CONFIG_SND_RME32=m CONFIG_SND_RME96=m CONFIG_SND_RME9652=m CONFIG_SND_HDSP=m CONFIG_SND_TRIDENT=m CONFIG_SND_YMFPCI=m CONFIG_SND_ALS4000=m CONFIG_SND_CMIPCI=m CONFIG_SND_ENS1370=m CONFIG_SND_ENS1371=m CONFIG_SND_ES1938=m CONFIG_SND_ES1968=m CONFIG_SND_MAESTRO3=m CONFIG_SND_FM801=m CONFIG_SND_FM801_TEA575X=m CONFIG_SND_ICE1712=m CONFIG_SND_ICE1724=m CONFIG_SND_INTEL8X0=m CONFIG_SND_INTEL8X0M=m CONFIG_SND_SONICVIBES=m CONFIG_SND_VIA82XX=m CONFIG_SND_VX222=m CONFIG_SND_USB_AUDIO=m CONFIG_SND_USB_USX2Y=m CONFIG_SND_VXPOCKET=m CONFIG_SND_VXP440=m CONFIG_SND_PDAUDIOCF=m CONFIG_SOUND_MSNDCLAS=m CONFIG_MSNDCLAS_INIT_FILE="/etc/sound/msndinit.bin" CONFIG_MSNDCLAS_PERM_FILE="/etc/sound/msndperm.bin" CONFIG_SOUND_MSNDPIN=m CONFIG_MSNDPIN_INIT_FILE="/etc/sound/pndspini.bin" CONFIG_MSNDPIN_PERM_FILE="/etc/sound/pndsperm.bin"
Modifié par cquad le 08/12/2004 22:00
 cquad  Posté le 08/12/2004 à 21:07
10 Messages
pour le lsmod :
lsmod Module Size Used by sg 35516 0 fglrx 229884 9 md5 4576 1 ipv6 249412 10 snd-page-alloc 8456 0 af_packet 17864 2 floppy 57168 0 8139too 22816 0 mii 5216 1 8139too sk98lin 168072 1 ide-cd 38528 0 cdrom 38844 1 ide-cd loop 13896 0 nls_iso8859-15 5216 2 ntfs 149980 2 supermount 36528 1 intel-agp 20608 1 agpgart 29036 1 intel-agp usb-storage 67040 0 ov511 81088 0 videodev 8224 1 ov511 tsdev 6848 0 joydev 9056 0 usblp 11936 0 evdev 8672 0 usbhid 43328 0 ehci-hcd 27972 0 uhci-hcd 30448 0 usbcore 107396 8 usb-storage,ov511,usblp,usbhid,ehci-hcd,uhci-hcd genrtc 9112 0 ext3 123496 2 jbd 56600 1 ext3 sd_mod 20096 6 ata_piix 7460 5 libata 39300 1 ata_piix scsi_mod 106788 4 sg,usb-storage,sd_mod,libata
En esperant que ca pourra t'aider
 selim,b.  Posté le 08/12/2004 à 21:15
2392 Messages
lsmod est "vide" de snd.. ce que g dans lsmod:
snd_seq_oss 36352 0 snd_seq_midi_event 7936 1 snd_seq_oss snd_seq 59152 4 snd_seq_oss,snd_seq_midi_event snd_seq_device 9228 2 snd_seq_oss,snd_seq snd_pcm_oss 62376 1 snd_mixer_oss 21120 2 snd_pcm_oss snd_intel8x0 32956 3 snd_ac97_codec 73184 1 snd_intel8x0 snd_pcm 107784 3 snd_pcm_oss,snd_intel8x0,snd_ac97_codec snd_timer 27524 2 snd_seq,snd_pcm snd_page_alloc 10504 2 snd_intel8x0,snd_pcm snd 67076 12 snd_seq_oss,snd_seq_midi_event,snd_seq,snd_seq_device,snd_pcm_oss,snd_mixer_oss,snd_intel8x0,snd_ac97_codec,snd_pcm,snd_timer
Verifie aussi si /lib/modules/2.6.8.1-10mdksmp/kernel/sound/pci/ contient snd-intel8x0.ko Si oui, fais des "modprobe snd-intel8x0.ko"... A mon avis, une recompile se pointe a l'horizon..
 cquad  Posté le 08/12/2004 à 21:23
10 Messages
le fichier snd-intel8x0.ko se trouve bien dans /lib/modules/2.6.8.1-10mdksmp/kernel/sound/pci par contre impossible de faire un modeprob snd-intel8x0.ko
[root@canteleu-3-xxx pci]# modprobe snd-intel8x0.ko FATAL: Module snd-intel8x0.ko not found.
 selim,b.  Posté le 08/12/2004 à 21:24
2392 Messages
si tu decides de recompiler (derniere soluce), sauvegarde le /usr/src/linux/.config [code]cp /usr/src/linux/.config myConfig[/code] (ss root) avant de faire mrproper &/ou utilise l'EXTRA(version) astuce de Paul: http://forum.pcastuces.com/sujet.asp?SUJET_ID=126963
 selim,b.  Posté le 08/12/2004 à 21:29
2392 Messages
sorry tape:
[root@canteleu-x-x-x-x pci]# modprobe snd_intel8x0
( attention : supprime ton IP.. visible:x-x-x-x- )
Modifié par selim,b. le 08/12/2004 21:36
 cquad  Posté le 08/12/2004 à 21:33
10 Messages
oupssss, j'ai jamais recomplilé de noyau, je sais po comment on fait :-(
 cquad  Posté le 08/12/2004 à 21:37
10 Messages
le premier modeprob me mets les memes erreur qu'au démarrage (vue dans /var/log/messages) et le deuxieme connait pas le module intel8x0. en ce qui concerne l'ip ... je sais pas comment changer ca non plus. J'ai des milliards de questions mais je procede dans l'ordre ;-) et puis je ne voudrais pas te monopoliser non plus. pas evident les installs sous linux :-S
 selim,b.  Posté le 08/12/2004 à 21:42
2392 Messages
ok .. laisse tomber la compile..rectifie: - sous root: modprobe snd_intel8x0 Puis recompile alsa-driver : [code]./configure --with-cards=intel8x0 --with-sequencer=yes --with-debug=full --with-debug=detect[/code] make make install ./snddevices chmod a+rw /dev/dsp* /dev/mixer* /dev/sequencer* /dev/midi* - pour les autres: ./configure make make install
 selim,b.  Posté le 08/12/2004 à 21:50
2392 Messages
si pas ok : - soit tu retapes : alsaconf - sois tu rebootes sur le cd ( comme pour une install) .. mais tu demandes juste une mise a jour.. suis bien l'ecran... Et au resume, vers la fin , clic sur le bouton configurer la carte son ( ou qq chose comme).. ca prendra 15 mn.. Je repete: juste une mise a jour.. Tu reviendras a alsa-1.0.6.. - pour ton IP: reedite juste ton post et supprime les nbres...
 cquad  Posté le 08/12/2004 à 22:14
10 Messages
ca n'a rien changé ... :-(
Haut de la page
Inscrivez-vous !
- Posez vos questions
- Résolvez vos problèmes
- Aidez les autres
- Suivez vos sujets préférés
TOUT EST GRATUIT !
Je crée mon compte
Vous avez besoin d'aide ?
Les derniers sujets résolus !
 > Tous les forumsLinux
