| | rjcb | Posté le 23/11/2005 @ 11:42 | Petit astucien
78 Messages
| Salut,
J'ai installé une imprimante sous ma FC4. (HP PSC 1610 multifonctions)
Je précise que le scanner a déja fonctionner avec la meme config mais comme j'ai tous refais sur ma FC4 je passe par la.
La aucun pb. Par contre je voudrais pouvoir scanner: donc j'ai suivi ceci
[url]http://www.bawet.org/article.php3?id_article=48[/url]
et j'ai essayer la deuxième méthode .
J'ai installer tout les packages
Dans le ficiher dll.conf de saned, j'ai décommenter hpoj
Dans le configurateur impression, j'ai séléctionné
ptal:/mlc:USB:PSC_1600 SERIES.
Puis:
[root@RJCSERVEUR ~]# /usr/sbin/ptal-init setup
Stopping the HP OfficeJet Linux driver.
This program manages devices controlled by the HP OfficeJet Linux
driver (hpoj). It attempts to probe your computer for local parallel-
and USB-connected devices, and allows you to specify network addresses
for remote JetDirect-connected devices.
If you experience any difficulties in detecting your device(s), then
refer to the hpoj documentation for troubleshooting information.
Currently defined device names ([*]=default):
"mlc:usb:PSC_1600_series"
Model is "PSC 1600 series".
Serial number is "HU55DDR2HXL0".
Press <Enter> alone to continue, or if you would like to delete
or reconfigure one of the above-listed devices, then enter the
device name to delete here --->
Probe for parallel-connected devices ([y]/n)? n
Probe for USB-connected devices ([y]/n)? y
Probing "/dev/usb/lp0"...
Found "PSC 1600 series"
with serial number "HU55DDR2HXL0".
This device is already set up as "mlc:usb:PSC_1600_series".
Probing "%002%001"...
No device found.
Probing "%001%002"...
No device found.
Probing "%001%001"...
No device found.
Press <Enter> alone to continue, or if you would like to add a
JetDirect-connected device, then enter its dotted-decimal
IP address or hostname here --->
Done updating device configuration files stored under /etc/ptal.
If you make manual changes to those files, then be sure to run
"/usr/sbin/ptal-init start" so they will take effect.
Starting the HP OfficeJet Linux driver.
[root@RJCSERVEUR ~]# /usr/sbin/ptal-init start
[root@RJCSERVEUR ~]# sane-find-scanner
# No SCSI scanners found. If you expected something different, make sure that
# you have loaded a SCSI driver for your SCSI adapter.
# Also you need support for SCSI Generic (sg) in your operating system.
# If using Linux, try "modprobe sg".
found USB scanner (vendor=0x03f0 [HP], product=0x4811 [PSC 1600 series]) at libusb:001:002
# Your USB scanner was (probably) detected. It may or may not be supported by
# SANE. Try scanimage -L and read the backend's manpage.
# Not checking for parallel port scanners.
# Most Scanners connected to the parallel port or other proprietary ports
# can't be detected by this program.
[root@RJCSERVEUR ~]# scanimage -L
No scanners were identified. If you were expecting something different,
check that the scanner is plugged in, turned on and detected by the
sane-find-scanner tool (if appropriate). Please read the documentation
which came with this software (README, FAQ, manpages).
J'ai aussi le choix entre différent drivers pr l'imprimante:
PSC 1600 hpijs (ppd) ou PSC 1600
mon ficihier hp.conf (car la printer est de la marque hp)
#scsi HP
# Uncomment the following if you have "Error during device I/O" on SCSI
# option dumb-read
# The usual place for a SCSI-scanner on Linux
#/dev/scanner
# USB-scanners supported by the hp-backend
# HP ScanJet 4100C
usb 0x03f0 0x0101
# HP ScanJet 5200C
usb 0x03f0 0x0401
# HP ScanJet 62X0C
usb 0x03f0 0x0201
# HP ScanJet 63X0C
usb 0x03f0 0x0601
# HP ScanJet PSC
usb 0x03f0 0x4811
# Uncomment the following if your scanner is connected by USB,
# but you are not using libusb
/dev/usb/scanner0
option connect-device
La je ne sais pas trop les 2 lignes si je dois les décommenter ou pas.
Merci de votre aide
| | Haut de la page |
| | Inscrivez-vous ! |
- Posez vos questions
- Résolvez vos problèmes
- Aidez les autres
- Suivez vos sujets préférés
