> Tous les forumsMultimédia
 Problème de son
 asav
  Posté le 29/05/2006 @ 09:55
22 Messages
Bonjour à tous ! Depuis plusieurs jours je n'ai plus de sons (tant système qu'en voulant écouter des CD audio ). J'ai essayé d'autres hauts parleurs (Labtec) sans résoudre mon problème... Problème de carte son ? de paramétrage ? Apparemment DX Diag ne signale aucune anomalies (voir ci-dessous) Merci de me venir en aide ! DX DiaG ------------------ System Information ------------------ Time of this report: 5/23/2006, 18:23:25 Operating System: Windows XP Professional (5.1, Build 2600) (2600.xpclient.010817-1148) Language: French (Regional Setting: French) System Manufacturer: VIA Technologies, Inc. System Model: VT82C694X BIOS: Award Modular BIOS v6.00PG Processor: Intel Pentium III, ~800MHz Memory: 256MB RAM Page File: 148MB used, 277MB available Windows Dir: C:\WINDOWS DirectX Version: DirectX 9.0b (4.09.0000.0902) DX Setup Parameters: Not found DxDiag Version: 5.03.0001.0902 32bit Unicode ------------ DxDiag Notes ------------ DirectX Files Tab: No problems found. Display Tab 1: No problems found. Sound Tab 1: No problems found. Music Tab: No problems found. Input Tab: No problems found. Network Tab: No problems found. -------------------- DirectX Debug Levels -------------------- Direct3D: 0/4 (n/a) DirectDraw: 0/4 (retail) DirectInput: 0/5 (n/a) DirectMusic: 0/5 (n/a) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail) --------------- Display Devices --------------- Card name: NVIDIA GeForce2 MX/MX 400 Manufacturer: NVIDIA Chip type: GeForce2 MX DAC type: Integrated RAMDAC Device Key: Enum\PCI\VEN_10DE&DEV_0110&SUBSYS_00000000&REV_A1 Display Memory: 32.0 MB Current Mode: 1024 x 768 (32 bit) (60Hz) Monitor: Écran Plug-and-Play Monitor Max Res: 1600,1200 Driver Name: nv4.dll Driver Version: 5.01.2001.1240 (English) DDI Version: 8 Driver Attributes: Final Retail Driver Date/Size: 8/23/2001 18:46:46, 1738496 bytes WHQL Logo'd: n/a WHQL Date Stamp: n/a VDD: n/a Mini VDD: nv4.sys Mini VDD Date: 8/17/2001 21:50:26, 731648 bytes Device Identifier: {D7B71E3E-4250-11CF-6867-D1270FC2C835} Vendor ID: 0x10DE Device ID: 0x0110 SubSys ID: 0x00000000 Revision ID: 0x00A1 Revision ID: 0x00A1 Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D Deinterlace Caps: n/a Registry: OK DDraw Status: Enabled D3D Status: Enabled AGP Status: Enabled DDraw Test Result: Not run D3D7 Test Result: Not run D3D8 Test Result: Not run D3D9 Test Result: Not run ------------- Sound Devices ------------- Description: Creative Sound Blaster PCI Default Sound Playback: Yes Default Voice Playback: Yes Hardware ID: PCI\VEN_1274&DEV_1371&SUBSYS_00000000&REV_07 Manufacturer ID: 1 Product ID: 100 Type: WDM Driver Name: es1371mp.sys Driver Version: 5.01.2501.0000 (English) Driver Attributes: Final Retail WHQL Logo'd: n/a Date and Size: 8/17/2001 21:19:34, 40704 bytes Other Files: Driver Provider: Microsoft HW Accel Level: Full Cap Flags: 0x0 Min/Max Sample Rate: 0, 0 Static/Strm HW Mix Bufs: 0, 0 Static/Strm HW 3D Bufs: 0, 0 HW Memory: 0 Voice Management: No EAX(tm) 2.0 Listen/Src: No, No I3DL2(tm) Listen/Src: No, No Sensaura(tm) ZoomFX(tm): No Registry: OK Sound Test Result: Not run --------------------- Sound Capture Devices --------------------- Description: Creative Sound Blaster PCI Default Sound Capture: Yes Default Voice Capture: Yes Driver Name: es1371mp.sys Driver Version: 5.01.2501.0000 (English) Driver Attributes: Final Retail Date and Size: 8/17/2001 21:19:34, 40704 bytes Cap Flags: 0x0 Format Flags: 0x0 ----------- DirectMusic ----------- DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS DLS Version: 1.00.0016.0002 Acceleration: n/a Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port Creative Sound Blaster PCI, Software (Kernel Mode), Output, DLS, Internal Mappeur MIDI Microsoft [Émulé], Hardware (Not Kernel Mode), Output, No DLS, Internal Microsoft GS Wavetable SW Synth [Émulé], Hardware (Not Kernel Mode), Output, No DLS, Internal Creative Sound Blaster MPU-401 [Émulé], Hardware (Not Kernel Mode), Output, No DLS, External Creative Sound Blaster MPU-401 [Émulé], Hardware (Not Kernel Mode), Input, No DLS, External Registry: OK Test Result: Not run ------------------- DirectInput Devices ------------------- Device Name: Souris Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Device Name: Clavier Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Poll w/ Interrupt: No Registry: OK ----------- USB Devices ----------- + Concentrateur USB racine | Vendor/Product ID: 0x1106, 0x3038 | Matching Device ID: usb\root_hub | Service: usbhub | Driver: usbhub.sys, 8/28/2001 12:00:00, 50688 bytes | Driver: usbd.sys, 8/28/2001 12:00:00, 4736 bytes ---------------- Gameport Devices ---------------- + Creative AudioPCI (ES1371,ES1373) (WDM) | Location: Bus PCI 0, périphérique 12, fonction 0 | Matching Device ID: pci\ven_1274&dev_1371 | Service: es1371 | Driver: es1371mp.sys, 8/17/2001 21:19:34, 40704 bytes | Driver: drmk.sys, 8/17/2001 23:01:20, 57344 bytes | Driver: portcls.sys, 8/18/2001 07:24:38, 135040 bytes | Driver: stream.sys, 12/12/2002 00:14:32, 45696 bytes | Driver: wdmaud.drv, 8/28/2001 12:00:00, 22016 bytes | Driver: ksuser.dll, 12/12/2002 00:14:32, 4096 bytes | +-+ Port jeu pour Creative | | Matching Device ID: *ctl7001 | | Service: gameenum | | Driver: gameenum.sys, 8/17/2001 23:02:32, 9728 bytes ------------ PS/2 Devices ------------ + Clavier standard 101/102 touches ou clavier Microsoft Natural Keyboard PS/2 | Matching Device ID: *pnp0303 | Service: i8042prt | Driver: i8042prt.sys, 8/28/2001 12:00:00, 52608 bytes | Driver: kbdclass.sys, 8/28/2001 12:00:00, 24064 bytes | + Pilote clavier de Terminal Server | Matching Device ID: root\rdp_kbd | Upper Filters: kbdclass | Service: TermDD | Driver: termdd.sys, 8/18/2001 07:38:00, 37896 bytes | Driver: kbdclass.sys, 8/28/2001 12:00:00, 24064 bytes | + Souris compatible PS/2 | Matching Device ID: *pnp0f13 | Service: i8042prt | Driver: i8042prt.sys, 8/28/2001 12:00:00, 52608 bytes | Driver: mouclass.sys, 8/28/2001 12:00:00, 22656 bytes | + Pilote souris de Terminal Server | Matching Device ID: root\rdp_mou | Upper Filters: mouclass | Service: TermDD | Driver: termdd.sys, 8/18/2001 07:38:00, 37896 bytes | Driver: mouclass.sys, 8/28/2001 12:00:00, 22656 bytes ---------------------------- DirectPlay Service Providers ---------------------------- DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900) DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900) DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900) DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900) Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0900) IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0900) Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900) Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900) DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run DirectPlay Test Result: Not run Registry: OK ------------------- DirectPlay Adapters ------------------- DirectPlay8 Modem Service Provider: Creatix V.90 HaM DirectPlay8 Serial Service Provider: COM1 DirectPlay8 Serial Service Provider: COM2 DirectPlay8 Serial Service Provider: COM3 DirectPlay8 TCP/IP Service Provider: IPv4 Loopback Adapter - IPv4 - ----------------------- DirectPlay Voice Codecs ----------------------- Voxware VR12 1.4kbit/s Voxware SC06 6.4kbit/s Voxware SC03 3.2kbit/s MS-PCM 64 kbit/s MS-ADPCM 32.8 kbit/s Microsoft GSM 6.10 13 kbit/s TrueSpeech(TM) 8.6 kbit/s ------------------------- DirectPlay Lobbyable Apps ------------------------- ------------------------ Disk & DVD/CD-ROM Drives ------------------------ Drive: C: Free Space: 7.5 GB Total Space: 11.7 GB File System: NTFS Model: ST320423A Drive: D: Free Space: 4.3 GB Total Space: 7.8 GB File System: FAT32 Model: ST320423A Drive: E: Model: LITEON DVD-ROM LTD122 Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.0000 (French), 8/28/2001 12:00:00, 47488 bytes Drive: F: Model: HP CD-Writer+ 8200a Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.0000 (French), 8/28/2001 12:00:00, 47488 bytes -------------- System Devices -------------- Name: Creatix V.90 HaM Device ID: PCI\VEN_1813&DEV_4000&SUBSYS_00000000&REV_02\3&61AAA01&0&80 Driver: C:\WINDOWS\System32\DRIVERS\ham.sys, 3.26.0005.0000 (English), 4/15/2000 19:30:08, 370507 bytes Driver: C:\WINDOWS\System32\DRIVERS\ambienth.cat, 6/29/1999 16:14:12, 76 bytes Name: Creative AudioPCI (ES1371,ES1373) (WDM) Device ID: PCI\VEN_1274&DEV_1371&SUBSYS_00000000&REV_07\3&61AAA01&0&60 Driver: C:\WINDOWS\system32\drivers\es1371mp.sys, 5.01.2501.0000 (English), 8/17/2001 21:19:34, 40704 bytes Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.0000 (English), 8/17/2001 23:01:20, 57344 bytes Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.0000 (English), 8/18/2001 07:24:38, 135040 bytes Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.0000.0900 (French), 12/12/2002 00:14:32, 45696 bytes Driver: C:\WINDOWS\System32\wdmaud.drv, 5.01.2600.0000 (English), 8/28/2001 12:00:00, 22016 bytes Driver: C:\WINDOWS\System32\ksuser.dll, 5.03.0000.0900 (French), 12/12/2002 00:14:32, 4096 bytes Name: Contrôleur CPU vers AGP VIA Tech Device ID: PCI\VEN_1106&DEV_8598&SUBSYS_00000000&REV_00\3&61AAA01&0&08 Driver: C:\WINDOWS\System32\DRIVERS\VIAAGP.SYS, 5.01.2600.0000 (English), 8/17/2001 22:58:02, 27392 bytes Name: Contrôleur de gestion de l'alimentation VIA Tech Device ID: PCI\VEN_1106&DEV_3057&SUBSYS_00000000&REV_30\3&61AAA01&0&3C Driver: n/a Name: Contrôleur hôte universel USB Rev 5 ou ultérieur VIA Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_10\3&61AAA01&0&3B Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.0000 (English), 8/28/2001 12:00:00, 18944 bytes Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.0000 (English), 8/28/2001 12:00:00, 123264 bytes Driver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (French), 8/23/2001 18:47:20, 70144 bytes Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.0000 (English), 8/28/2001 12:00:00, 50688 bytes Name: Pont CPU vers PCI VIA Tech Device ID: PCI\VEN_1106&DEV_0691&SUBSYS_00000000&REV_C4\3&61AAA01&0&00 Driver: n/a Name: Pont PCI vers ISA VIA Tech Device ID: PCI\VEN_1106&DEV_0686&SUBSYS_00000000&REV_22\3&61AAA01&0&38 Driver: C:\WINDOWS\System32\DRIVERS\isapnp.sys, 5.01.2600.0000 (French), 8/28/2001 12:00:00, 36224 bytes Name: Contrôleur IDE Bus Master VIA Device ID: PCI\VEN_1106&DEV_0571&SUBSYS_00000000&REV_10\3&61AAA01&0&39 Driver: C:\WINDOWS\System32\DRIVERS\viaide.sys, 1.00.0001.0000 (English), 8/28/2001 12:00:00, 4352 bytes Driver: C:\WINDOWS\System32\DRIVERS\pciidex.sys, 5.01.2600.0000 (French), 8/28/2001 12:00:00, 23680 bytes Driver: C:\WINDOWS\System32\DRIVERS\atapi.sys, 5.01.2600.0000 (English), 8/28/2001 12:00:00, 86656 bytes Name: NVIDIA GeForce2 MX/MX 400 Device ID: PCI\VEN_10DE&DEV_0110&SUBSYS_00000000&REV_A1\4&9FD38EF&0&0008 Driver: C:\WINDOWS\System32\DRIVERS\nv4.sys, 5.01.2001.1240 (English), 8/17/2001 21:50:26, 731648 bytes Driver: C:\WINDOWS\System32\nv4.dll, 5.01.2001.1240 (English), 8/23/2001 18:46:46, 1738496 bytes ------------------ DirectX Components ------------------ ddraw.dll: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 284160 bytes ddrawex.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 24064 bytes dxapi.sys: 5.01.2600.0000 English Final Retail 8/28/2001 12:00:00 10496 bytes d3d8.dll: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 1177600 bytes d3d8thk.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 8192 bytes d3d9.dll: 5.03.0001.0902 French Final Retail 5/30/2003 09:00:02 1634304 bytes d3dim.dll: 5.01.2600.0000 English Final Retail 8/28/2001 12:00:00 436224 bytes d3dim700.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 797184 bytes d3dramp.dll: 5.01.2600.0000 English Final Retail 8/28/2001 12:00:00 590336 bytes d3drm.dll: 5.01.2600.0000 English Final Retail 8/28/2001 12:00:00 350208 bytes d3dxof.dll: 5.01.2600.0000 English Final Retail 8/28/2001 12:00:00 47616 bytes d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/28/2001 12:00:00 34816 bytes dplay.dll: 5.00.2134.0001 French Final Retail 8/28/2001 12:00:00 33040 bytes dplayx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 217600 bytes dpmodemx.dll: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 77824 bytes dpwsock.dll: 5.00.2134.0001 English Final Retail 8/28/2001 12:00:00 42768 bytes dpwsockx.dll: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 76800 bytes dplaysvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 28160 bytes dpnsvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 16896 bytes dpnet.dll: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 723968 bytes dpnlobby.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes dpnaddr.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes dpvoice.dll: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 381952 bytes dpvsetup.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 80896 bytes dpvvox.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 112128 bytes dpvacm.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 19968 bytes dpnhpast.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 32768 bytes dpnhupnp.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 68096 bytes dpserial.dll: 5.00.2134.0001 French Final Retail 8/28/2001 12:00:00 54032 bytes dinput.dll: 5.01.2600.1106 French Final Retail 8/29/2002 03:40:00 648704 bytes dinput8.dll: 5.01.2600.1106 French Final Retail 8/29/2002 03:40:00 667648 bytes dimap.dll: 5.01.2600.0000 English Final Retail 8/28/2001 12:00:00 44032 bytes diactfrm.dll: 5.01.2600.0000 French Final Retail 8/28/2001 12:00:00 395264 bytes joy.cpl: 5.01.2600.1106 French Final Retail 8/29/2002 03:41:00 208896 bytes gcdef.dll: 5.01.2600.0000 French Final Retail 8/28/2001 12:00:00 77824 bytes pid.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:41:00 31744 bytes gameenum.sys: 5.01.2600.0000 English Final Retail 8/17/2001 23:02:32 9728 bytes dsound.dll: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 355328 bytes dsound3d.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1294336 bytes dswave.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18432 bytes dsdmo.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 186880 bytes dsdmoprp.dll: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 491520 bytes dmusic.dll: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 116736 bytes dmband.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 27136 bytes dmcompos.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 58368 bytes dmime.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 171520 bytes dmloader.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 33280 bytes dmstyle.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 98816 bytes dmsynth.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 100864 bytes dmscript.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 76800 bytes dx7vb.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 602624 bytes dx8vb.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1189888 bytes dxdiagn.dll: 5.03.0001.0902 French Final Retail 5/30/2003 09:00:02 1675264 bytes mfc40.dll: 4.01.0000.6140 English Final Retail 8/28/2001 12:00:00 924432 bytes mfc42.dll: 6.00.8665.0000 English Beta Retail 8/28/2001 12:00:00 995383 bytes wsock32.dll: 5.01.2600.0000 French Final Retail 8/28/2001 12:00:00 24064 bytes amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 64512 bytes devenum.dll: 6.05.0001.0902 French Final Retail 5/30/2003 09:00:02 132608 bytes dxmasf.dll: 6.04.0009.1121 French Final Retail 7/12/2002 12:14:20 500496 bytes mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 34304 bytes mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 136192 bytes msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 13312 bytes encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18944 bytes qasf.dll: 9.00.0000.2980 English Final Retail 12/11/2002 18:34:40 241664 bytes qcap.dll: 6.05.0001.0900 French Final Retail 12/12/2002 00:14:32 257024 bytes qdv.dll: 6.05.0001.0900 French Final Retail 12/12/2002 00:14:32 311808 bytes qdvd.dll: 6.05.0001.0902 French Final Retail 5/30/2003 09:00:02 449024 bytes qedit.dll: 6.05.0001.0900 French Final Retail 12/12/2002 00:14:32 1798144 bytes qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 733184 bytes quartz.dll: 6.05.0001.0902 French Final Retail 5/30/2003 09:00:02 1962496 bytes strmdll.dll: 4.01.0000.3925 French Final Retail 7/12/2002 12:14:20 251904 bytes iac25_32.ax: 2.00.0005.0053 English Final Retail 8/28/2001 12:00:00 199680 bytes ir41_32.ax: 4.51.0016.0003 English Final Retail 8/28/2001 12:00:00 848384 bytes ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/28/2001 12:00:00 120320 bytes ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/28/2001 12:00:00 338432 bytes ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/28/2001 12:00:00 755200 bytes ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/28/2001 12:00:00 200192 bytes ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/28/2001 12:00:00 183808 bytes ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/28/2001 12:00:00 154624 bytes mswebdvd.dll: 6.05.0001.0900 French Final Retail 12/12/2002 00:14:32 324096 bytes msdvdopt.dll: 5.01.2600.0000 French Final Retail 8/28/2001 12:00:00 75776 bytes ks.sys: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 130304 bytes ksproxy.ax: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 117248 bytes ksuser.dll: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 4096 bytes stream.sys: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 45696 bytes mspclock.sys: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 5248 bytes mspqm.sys: 5.01.2600.0000 French Final Retail 8/23/2001 05:00:00 4608 bytes mskssrv.sys: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 7424 bytes swenum.sys: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 4096 bytes mstee.sys: 5.03.0000.0900 French Final Retail 12/12/2002 00:14:32 5504 bytes bdaplgin.ax: 5.03.0000.0900 French Final Retail 2/17/2003 10:16:26 16896 bytes bdasup.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 11392 bytes msdvbnp.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:26 52224 bytes psisdecd.dll: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 354816 bytes psisrndr.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 30208 bytes ipsink.ax: 5.03.0000.0900 French Final Retail 2/17/2003 10:16:26 14848 bytes mpeg2data.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:26 57856 bytes ndisip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 10112 bytes mpe.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 15104 bytes streamip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 14976 bytes msvidctl.dll: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 1230336 bytes slip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 10880 bytes nabtsfec.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 83968 bytes ccdecode.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 16384 bytes vbisurf.ax: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:30 27648 bytes msyuv.dll: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 16896 bytes kstvtune.ax: 5.03.0001.0902 French Final Retail 6/4/2003 10:30:32 274432 bytes ksxbar.ax: 5.03.0001.0902 English Final Retail 6/4/2003 09:18:28 39424 bytes kswdmcap.ax: 5.03.0000.0900 French Final Retail 2/17/2003 10:16:32 226304 bytes vfwwdm32.dll: 5.01.2600.0000 French Final Retail 8/23/2001 17:47:20 50688 bytes wstcodec.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:32 18688 bytes wstdecod.dll: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:32 47104 bytes msdv.sys: 5.01.2600.0000 English Final Retail 2/17/2003 10:21:50 52096 bytes ------------------ DirectShow Filters ------------------ WDM Streaming VBI Codecs: NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.0000.0900 CC Decoder,0x00200000,2,1,,5.03.0000.0900 WST Codec,0x00200000,1,1,,5.03.0000.0900 DirectShow Filters: WMAudio Decoder DMO,0x00800800,1,1,, WMSpeech Decoder DMO,0x00600800,1,1,, Mpeg4s Decoder DMO,0x00800001,1,1,, WMV Screen decoder DMO,0x00800001,1,1,, WMVideo Decoder DMO,0x00800001,1,1,, Mpeg43 Decoder DMO,0x00800001,1,1,, Mpeg4 Decoder DMO,0x00800001,1,1,, DivX Decoder Filter,0x00800000,1,1,divxdec.ax,6.00.0000.1571 Subtitle Mixer,0x0080000a,2,1,, Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.0001.0902 DV Muxer,0x00400000,0,0,qdv.dll,6.05.0001.0900 Color Space Converter,0x00400001,1,1,quartz.dll,6.05.0001.0902 WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.2980 AVI Splitter,0x00600000,1,1,quartz.dll,6.05.0001.0902 VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.0001.0902 Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055 Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4477 AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900 MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902 Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055 Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4477 MPEG-1 Stream Splitter,0x00600000,1,2,quartz.dll,6.05.0001.0902 SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902 Dump,0x00200000,1,0,dump.ax,8.01.0000.0000 MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050 MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.0001.0900 ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000 Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902 MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.0001.0902 File Source (Netshow URL),0x00400000,0,1,dxmasf.dll,6.04.0009.1121 TC MPEG Encoder,0x00200000,2,2,TCMpegFilter.ax,1.00.0003.0002 DV Splitter,0x00600000,1,2,qdv.dll,6.05.0001.0900 Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4477 Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.0001.0902 Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000 Subtitle Parser,0x00600000,1,1,, Windows Media Multiplexer,0x00600000,1,1,dxmasf.dll,6.04.0009.1121 ASX file Parser,0x00600000,1,1,dxmasf.dll,6.04.0009.1121 ASX v.2 file Parser,0x00600000,1,0,dxmasf.dll,6.04.0009.1121 NSC file Parser,0x00600000,1,1,dxmasf.dll,6.04.0009.1121 ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.0001.0902 Windows Media source filter,0x00600000,0,2,dxmasf.dll,6.04.0009.1121 Video Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902 Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.0001.0902 Video Port Manager,0x00600000,2,1,quartz.dll,6.05.0001.0902 WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.0000.0900 Video Renderer,0x00400000,1,0,quartz.dll,6.05.0001.0902 MPEG PS MULTIPLEXER PIXELA,0x00200000,2,1,PSMulPlx.ax,1.00.0000.0004 DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.00.0000.1571 DivXAntiFreeze,0x00800001,1,1,, WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.2980 VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.0000.0900 Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4477 DivX Demux,0x00600000,1,0,DivXMedia.ax,0.00.0000.0026 File writer,0x00200000,1,0,qcap.dll,6.05.0001.0900 DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.0001.0902 Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.0001.0902 AVI Draw,0x00600064,9,1,quartz.dll,6.05.0001.0902 .RAM file Parser,0x00600000,1,0,dxmasf.dll,6.04.0009.1121 muvee Video Analyser,0x00200000,1,0,mvvanalyse.ax,3.00.0011.0001 muvee Music Analyser,0x00200000,1,0,mvmanalyse.ax,3.00.0011.0001 BMPCapture,0x00200000,1,1,BMPCapture.ax, G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000 MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900 DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.0001.0900 Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053 Windows Media Update Filter,0x00400000,1,0,dxmasf.dll,6.04.0009.1121 ASF DIB Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1121 ASF ACM Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1121 ASF ICM Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1121 ASF URL Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1121 ASF JPEG Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1121 ASF DJPEG Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1121 ASF embedded stuff Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1121 DivX Subtitle Decoder,0x00600000,1,1,DivXMedia.ax,0.00.0000.0026 WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000 SampleGrabber,0x00200000,1,1,qedit.dll,6.05.0001.0900 Null Renderer,0x00200000,1,0,qedit.dll,6.05.0001.0900 MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.0001.0900 IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051 WMP CD Filter,0x00600000,0,1,wmpcd.dll,8.00.0000.4477 Smart Tee,0x00200000,1,2,qcap.dll,6.05.0001.0900 Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.0001.0902 RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.1010 AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902 AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.0001.0902 Morgan Stream Switcher,0x00800003,1,1,, QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.0001.0902 Wave Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902 MIDI Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902 Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902 Lyric Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902 File stream renderer,0x00400000,1,1,quartz.dll,6.05.0001.0902 XML Playlist,0x00400000,1,0,dxmasf.dll,6.04.0009.1121 AVI Mux,0x00200000,1,0,qcap.dll,6.05.0001.0900 Subtitle Dest,0x00200000,1,1,, Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.0001.0902 File Source (Async.),0x00400000,0,1,quartz.dll,6.05.0001.0902 File Source (URL),0x00400000,0,1,quartz.dll,6.05.0001.0902 Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0000 Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.0001.0900 BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.0001.0900 QT Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902 ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0000 Pixela ReSize,0x00200000,1,1,PxReSize.ax,1.00.0000.0001 MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.0001.0902 Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003 Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003 WDM Streaming Tee/Splitter Devices: Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.0000.0900 WDM Streaming Data Transforms: Suppresseur d'écho acoustique (Noyau Microsoft),0x00200000,2,2,,5.03.0000.0900 Synthétiseur de table de sons GC noyau Microsoft,0x00200000,1,1,,5.03.0000.0900 Synthétiseur DLS du noyau Microsoft,0x00200000,1,1,,5.03.0000.0900 Filtre de décodeur DRM (Noyau Microsoft),0x00200000,1,1,,5.03.0000.0900 Video Compressors: WMVideo Encoder DMO,0x00600800,1,1,, MSScreen encoder DMO,0x00600800,1,1,, WMVideo9 Encoder DMO,0x00600800,1,1,, MSScreen 9 encoder DMO,0x00600800,1,1,, DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.0001.0900 Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055 MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.0001.0902 Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.0001.0900 DivX® 6.0 Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900 Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.0001.0900 Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.0001.0900 Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.0001.0900 Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.0001.0900 Codec Intel IYUV,0x00200000,1,1,qcap.dll,6.05.0001.0900 Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900 Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900 Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.0001.0900 Microsoft Vidéo 1,0x00200000,1,1,qcap.dll,6.05.0001.0900 Microsoft Windows Media Video 9,0x00200000,1,1,qcap.dll,6.05.0001.0900 DivX® 6.0 YV12 Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900 Audio Compressors: WM Speech Encoder DMO,0x00600800,1,1,, WMAudio Encoder DMO,0x00600800,1,1,, IAC2,0x00200000,1,1,quartz.dll,6.05.0001.0902 IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902 PCM,0x00200000,1,1,quartz.dll,6.05.0001.0902 Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902 ACELP.net,0x00200000,1,1,quartz.dll,6.05.0001.0902 DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.0001.0902 Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.0001.0902 Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.0001.0902 GSM 6.10,0x00200000,1,1,quartz.dll,6.05.0001.0902 Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.0001.0902 CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902 CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902 MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.0001.0902 Audio Capture Sources: Creative Sound Blaster PCI,0x00200000,0,0,qcap.dll,6.05.0001.0900 Midi Renderers: Creative Sound Blaster MPU-401,0x00200000,1,0,quartz.dll,6.05.0001.0902 Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.0001.0902 Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.0001.0902 WDM Streaming Capture Devices: Creative Sound Blaster MPU-401,0x00200000,2,2,,5.03.0000.0900 Creative Sound Blaster PCI,0x00200000,2,2,,5.03.0000.0900 WDM Streaming Rendering Devices: Creative Sound Blaster MPU-401,0x00200000,2,2,,5.03.0000.0900 Creative Sound Blaster PCI,0x00200000,2,2,,5.03.0000.0900 BDA Rendering Filters: BDA IP Sink,0x00200000,1,1,,5.03.0000.0900 BDA Network Providers: Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900 Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900 Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900 Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900 BDA Transport Information Renderers: BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.0001.0900 MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.0001.0900 WDM Streaming Mixer Devices: Mélangeur audio Wave de noyau Microsoft,0x00200000,2,2,,5.03.0000.0900 WDM Streaming Communication Transforms: Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.0000.0900 Audio Renderers: Creative Sound Blaster PCI,0x00200000,1,0,quartz.dll,6.05.0001.0902 Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.0001.0902 Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.0001.0902 DirectSound: Creative Sound Blaster PCI,0x00200000,1,0,quartz.dll,6.05.0001.0902 WDM Streaming System Devices: Creative Sound Blaster MPU-401,0x00200000,2,2,,5.03.0000.0900 Creative Sound Blaster PCI,0x00200000,10,2,,5.03.0000.0900 BDA Receiver Component: BDA Slip De-Framer,0x00600000,1,1,,5.03.0000.0900
 Afficher le profil de asavEnvoyer un message privé à asav
 jorden  Posté le 29/05/2006 à 10:34
286 Messages
Bonjour Asav, Faut vraiment etre un crack pour decoder ton listing [langue] Mais faisons plus simple,as tu fais les tests proposes par DX Diag et as tu appuyé sur les petits boutons pour tester le son?[rougir]
Afficher le profil de jordenEnvoyer un message privé à jorden
 Revenir en haut de la page
 mimi32140  Posté le 09/06/2006 à 22:33
5309 Messages
Bonsoir Asav tu as un chipset son intégré à la carte-mére ( C-Media CMI8738 Audio Chip ). Ce serait peut-être une solution de le désinstaller par le gestionnaire de périphérique, et le mettre sur " disabled" dans le bios. Il doit se trouver dans la rubrique " Integrated Péripherals" sous des noms comme " on board sound card" ou " on board audio " ou qq chose comme ça. Une fois ceci fait, tu fais échappe, puis F10, puis Yes et Entrée ou télécharge ceci: http://www.zdnet.fr/telecharger/windows/fiche/telecharger/0,39033957,22060460s,00.htm. Tiens moi au courant. Bonne chance.[idee]
Afficher le profil de mimi32140 Voir la configuration de mimi32140Envoyer un message privé à mimi32140
Haut de la page
Inscrivez-vous !
- Posez vos questions
- Résolvez vos problèmes
- Aidez les autres
- Suivez vos sujets préférés
TOUT EST GRATUIT !
Je crée mon compte
Vous avez besoin d'aide ?
Les derniers sujets résolus !
 > Tous les forumsMultimédia
