| jeanboots | Posté le 03/07/2008 @ 11:51 |
14 Messages
| Bo njour à tous,
Voilà, je suis une néophyte et j'ai installé Ubuntu la semaine dernière, terrible et je rame.....
Voilà ce que j'ai pour le moment, pour un scanner epson perfection 2480, et à la commande de application, graphisme, xsane, je n'ai même pas l'ouverture. J'ai certainement du faire de grosses erreurs, quelqu'un pourrait-il m'aider? merci d'avance
Donc voici tout ce que j'ai
jeanboots@jeanboots-laptop:~$ sudo lsusb
[sudo] password for jeanboots:
Bus 003 Device 001: ID 0000:0000
Bus 002 Device 002: ID 04b8:0121 Seiko Epson Corp. Perfection 2480 Photo
Bus 002 Device 001: ID 0000:0000
Bus 001 Device 003: ID 05e3:0702 Genesys Logic, Inc. USB 2.0 IDE Adapter
Bus 001 Device 002: ID 058f:9254 Alcor Micro Corp. Hub
Bus 001 Device 001: ID 0000:0000
jeanboots@jeanboots-laptop:~$ sane-find-scanner
# sane-find-scanner will now attempt to detect your scanner. If the
# result is different from what you expected, first make sure your
# scanner is powered up and properly connected to your computer.
# No SCSI scanners found. If you expected something different, make sure that
# you have loaded a kernel SCSI driver for your SCSI adapter.
found USB scanner (vendor=0x04b8 [EPSON], product=0x0121 [EPSON Scanner]) at libusb:002:002
# Your USB scanner was (probably) detected. It may or may not be supported by
# SANE. Try scanimage -L and read the backend's manpage.
# Not checking for parallel port scanners.
# Most Scanners connected to the parallel port or other proprietary ports
# can't be detected by this program.
# You may want to run this program as root to find all devices. Once you
# found the scanner devices, be sure to adjust access permissions as
# necessary.
jeanboots@jeanboots-laptop:~$ scanimage -L
No scanners were identified. If you were expecting something different,
check that the scanner is plugged in, turned on and detected by the
sane-find-scanner tool (if appropriate). Please read the documentation
which came with this software (README, FAQ, manpages).
jeanboots@jeanboots-laptop:~$ sudo gedit /etc/sane.d/dll.conf
# /etc/sane.d/dll.conf - Configuration file for the SANE dynamic backend loader
# On Debian systems, the dll backend will also look for pieces of configuration
# in the /etc/sane.d/dll.d directory -- packages providing backends should drop
# a config file similar to dll.conf in this directory.
epkowa
# enable the next line if you want to allow access through the network:
net
abaton
agfafocus
apple
avision
artec
artec_eplus48u
as6e
bh
canon
canon630u
#canon_pp
cardscan
coolscan
coolscan2
#dc25
#dc210
#dc240
dell1600n_net
dmc
epjitsu
epson
#epson2
fujitsu
#gphoto2
genesys
gt68xx
hp
hp3900
hpsj5s
hp3500
hp4200
hp5400
hp5590
hpljm1005
hs2p
ibm
leo
lexmark
ma1509
matsushita
microtek
microtek2
mustek
#mustek_pp
mustek_usb
mustek_usb2
nec
niash
pie
pixma
plustek
#plustek_pp
#pnm
qcam
ricoh
s9036
sceptre
sharp
sm3600
sm3840
snapscan
sp15c
#st400
#stv680
tamarack
teco1
teco2
teco3
#test
u12
umax
#umax_pp
umax1220u
v4l
#------------------------------ General -----------------------------------
# Change to the fully qualified filename of your firmware file, if
# firmware upload is needed by the scanner
firmware /etc/sane.d/esfw41.bin
# If not automatically found you may manually specify a device name.
# For USB scanners also specify bus=usb, e.g.
# /dev/usb/scanner0 bus=usb
# For SCSI scanners specify the generic device, e.g. /dev/sg0 on Linux.
# /dev/sg0
# No changes should be necessary below this line
#-------------------------- SCSI scanners ----------------------------------
# These SCSI devices will be probed automatically
scsi AGFA * Scanner
scsi COLOR * Scanner
scsi Color * Scanner
scsi ACERPERI * Scanner
#--------------------------- USB scanners -----------------------------------
# These USB devices will be probed automatically
# (This will currently work only on Linux)
# Benq/Acer/Vuego 310U
usb 0x04a5 0x1a20
usb 0x04a5 0x1a26
# Benq/Acer/Vuego 320U
usb 0x04a5 0x2022
# Benq/Acer/Vuego 620U / 620UT
usb 0x04a5 0x1a2a
usb 0x04a5 0x2040
# Benq/Acer/Vuego 640U
usb 0x04a5 0x2060
# Benq/Acer/Vuego 640BU
usb 0x04a5 0x207e
# Benq/Acer/Vuego 640BT
usb 0x04a5 0x20be
# Benq/Acer/Vuego 1240U
usb 0x04a5 0x20c0
# Benq/Acer/Vuego 3300 / 4300
usb 0x04a5 0x20b0
# Benq/Acer/Vuego 4300
usb 0x04a5 0x20de
# Benq 5000E / 5000U
usb 0x04a5 0x20f8
# Benq 5000
usb 0x04a5 0x20fc
# Benq/Acer 5300
usb 0x04a5 0x20fe
# Benq 5250C
usb 0x04a5 0x2137
# Agfa 1236U
usb 0x06bd 0x0002
# Agfa 1212U
usb 0x06bd 0x0001
usb 0x06bd 0x2061
# Agfa Snapscan e10
usb 0x06bd 0x2093
# Agfa Snapscan e20
usb 0x06bd 0x2091
# Agfa Snapscan e25
usb 0x06bd 0x2095
# Agfa Snapscan e26
usb 0x06bd 0x2097
# Agfa Snapscan e40
usb 0x06bd 0x208d
# Agfa Snapscan e42
usb 0x06bd 0x20ff
# Agfa Snapscan e50
usb 0x06bd 0x208f
# Agfa Snapscan e52
usb 0x06bd 0x20fd
# Epson Perfection 660
usb 0x04b8 0x0114
# Epson Perfection 1670
usb 0x04b8 0x011f
# Epson Perfection 2480
usb 0x04b8 0x0110
# Epson Perfection 3490
usb 0x04b8 0x0122
# Epson Stylus CX-1500
usb 0x04b8 0x080c
| Publicité |
| pcastuces | Posté le 03/07/2008 à 13:22 |
| Bonjour,
A bientôt. |
| mic50 | Posté le 03/07/2008 à 17:04 |
1328 Messages
| Bonjour,
As tu simplement essayé de desinstaller sane et de le reinstaller avec le gestionnaire synaptic ? |
| jeanboots | Posté le 03/07/2008 à 17:17 |
14 Messages
| ok, j'essaie et je te tiens au courant. lequel? libsane ou bien libsane dev ou tout? merci |
| mic50 | Posté le 03/07/2008 à 17:26 |
1328 Messages
| re,
Tu desinstalles tout et tu reinstalles ça dure seulement quelques minutes |
| jeanboots | Posté le 03/07/2008 à 17:36 |
14 Messages
| désolée mais cela n'a rien changé....... le mieux si quelqu'un a le temps, ce serait de m'expliquer pas à pas ce que je dois faire.... il y a tellement de méthode..... mais bon, il faudrait que vous ayez le temps...... |
| mic50 | Posté le 03/07/2008 à 18:02 |
1328 Messages
| Re,
Bon je suis un peu nouveau aussi, normalement tout s'installe seul je ne vais pas t'expliquer d'autres choses je risque de te dire des betises et faire encore pire. Regardes donc sur les forums Ubuntu tu vas certainement y trouver une solution.
Bon courrage  |
| jeanboots | Posté le 03/07/2008 à 19:26 |
14 Messages
| ok, c'est sympa mais c'est un scanner qui n'est pas reconnu directement, ça fait 5 jours que je suis sur la doc et malheureusement, il y a plusieurs méthodes pas évidentes.
Mais déjà si on pouvait me dire de quel côté regarder pourquoi il ne reconnait pas mon scanner? merci |
| Persée | Posté le 03/07/2008 à 21:53 |
233 Messages
| jeanboots | Posté le 04/07/2008 à 11:32 |
14 Messages
| Merci à toi d'avoir regardé les doc pour moi mais hélas, je suis dessus depuis le début ( 7 jours.....) et il y a malheureusement plusieurs méthodes et donc j'ai dû mettre un beau foutoir en tant que néophyte.....
Par contre, pourrais -tu me rendre le service de me dire les différents chemins pour tout désinstaller et tout vérifer et redémarrer à zéro? ou bien ne serait-il pas plus simple de carrément réinstaller Ubuntu pour réinitialiser? merci pour ton attention. |
| jeanboots | Posté le 19/09/2008 à 18:09 |
14 Messages
| Merci à tous pour votre gentillesse. Avec tous ces renseignements, je me suis fait des fiches et finalement , après plusieurs jours , j'ai de la patience, j'y suis arrivée mais hélas, je ne sais pas comment mais en tout cas, cela fonctionne....
Par contre, ce scanner est sensé scanner les Diapos ( je le faisais sous XP) et là, je n'y arrive pas, il scanne trop normalement et l'image est minuscule. Si quelqu'un l'a testé et pourvais éclairer ma lanterne.....Merci |
| Haut de la page |
