| victor21 | Posté le 01/09/2008 @ 11:40 |
62 Messages
| Normal 0 21 false false false FR X-NONE X-NONE MicrosoftInternetExplorer4 <!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:1; mso-generic-font-family:roman; mso-font-format:other; mso-font-pitch:variable; mso-font-signature:0 0 0 0 0 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin-top:0cm; margin-right:0cm; margin-bottom:10.0pt; margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;} p {mso-style-noshow:yes; mso-style-priority:99; mso-margin-top-alt:auto; margin-right:0cm; mso-margin-bottom-alt:auto; margin-left:0cm; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman","serif"; mso-fareast-font-family:"Times New Roman";} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;} .MsoPapDefault {mso-style-type:export-only; margin-bottom:10.0pt; line-height:115%;} @page Section1 {size:612.0pt 792.0pt; margin:70.85pt 70.85pt 70.85pt 70.85pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} -->
table.MsoNormalTable
{mso-style-name:"Tableau Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin-top:0cm;
mso-para-margin-right:0cm;
mso-para-margin-bottom:10.0pt;
mso-para-margin-left:0cm;
line-height:115%;
font-size:11.0pt;
mso-fareast-theme-font:minor-fareast;
mso-hansi-theme-font:minor-latin;}
Depuis quelques jours, la mise à jour de sécurité pour Microsoft Office Power Point 2007 ne s'installe pas et j'obtiens ce message" Code 57 A, Windows Update a rencontré une erreur inconnue".
Conséquence : à chaque arrêt du système, la petite icône des mises à jour apparaît sur le bouton arrêt et essaie d'installer cette mise à jour, en vain.
Avec ou sans antivirus, la mise à jour ne s'installe pas et le même message d'erreur.
Pouvez-vous m'aider afin de corriger ce bug.
Merci à tous.
| Publicité |
| chaseur57150 | Posté le 01/09/2008 à 12:04 |
6562 Messages
| Salut victor21 A tu essayé de faire cette mise a jour via windows update?
Ou essaye en mode sans echec! Modifié par chaseur57150 le 01/09/2008 12:05 |
| mitou03700 | Posté le 25/11/2008 à 13:23 |
327 Messages
| bonjour
bien que le post soit (un peu) ancien
même ennui, précédemment j'avais "interdit" cette mise à jour dans les options de ces mises à jour en échec répétés
mais, mon (dernier ?) neurone a oublié la manip et même en bataillant depuis un bon moment je n'arrive pas à retrouver la méthode
si un bon Docteur veux bien activer mon (dernier ?) neurone
merci d'avance |
| chaseur57150 | Posté le 25/11/2008 à 13:55 |
6562 Messages
| victor21.Windows update, afficher les mises à jours, clic droit sur cette mise à jour, ensuite "masquer cette mise à jour"!
| victor21 | Posté le 25/11/2008 à 14:01 |
62 Messages
| Bonjour,
c'est sympa d'avoir répondu après tant de temps. je n'ai pu résoudre le problème qu'après avoir réinstaller Vista. Tout est OK à présent.
Merci et bonne journée.
victor 21 |
| mitou03700 | Posté le 25/11/2008 à 14:06 |
327 Messages
| bonjour à tous
merci aussi,
les mises à jour (refusées) suite message (idem victor 21), sont , désormais bloquées et ne reviennent plus en propositions répétées
encore merci chasseur
bonne journée |
| chaseur57150 | Posté le 25/11/2008 à 15:29 |
6562 Messages
|  De rien!
| Haut de la page |
