Waaaaaouuuu sympa, rapide Mc Afee, il me répond illico presto mais en anglais.
J'ai compris qu'il me dit en substance de faire une mise à jour et qu'il s'enlèverait automatiquement ? Mais il est dans la quarantaine...
Date : 23/07/2008 22:20:51
Sujet : 4741261 - VSO AVERT Submission
AVERT Labs - Beaverton
Current Scan Engine Version:5200.2160
Current DAT Version:5345.0000
Thank you for your submission.
Analysis ID: 4741261
File Name Findings Detection Type Extra
ag0f3od3.exe |current detection |downloader.gen.a |Trojan |no
current detection [ag0f3od3.exe]
The file received is infected and can be detected and removed with our current DAT
files and engine. It is recommended that you update your DAT and engine files and scan
your computer again.
If you are not seeing this with the product you are using, please speak with technical
support so that they can help you determine the cause of this discrepancy.
To find detailed information about viruses and other malware, please review AVERT’s
Virus Information Library:
In order to get the fastest possible response, you may wish to submit future
virus-samples to:
In most cases it can respond almost instantly with a solution. This may also be the
best option if you are having a problem with gateway scanners stripping your sample
submission.
If you believe your computer is infected, but are unsure which files should be
submitted to AVERT for review, please visit:
For other virus-related information, please review the AVERT homepage at:
Support –
Virus Research accepts file-samples for analysis and possible inclusion into AV
signature DAT sets. We are also prepared to answer general virus questions. All
product-related questions and comments can be addressed through technical support and
customer service, including:
* Product installation and update questions
* Product usage questions
* Specific operating system/version questions
* Assistance with detection and cleaning or removal of viruses or trojans
Use the following link to update your DAT and scan engine to the most current version:
Use the following links to reach online technical support for McAfee products -
Corporate Customers:
Single User/Retail Customers:
Note –
Due to the prevalence of network gateway AV products, it is important that all
submissions be zipped and the zip file password-protected (password - infected). Some
products will reject an email that contains a virus that is not sent in this way. In
addition, often we receive a file that appears not to have been infected, to find
later that the file was infected when it left the sender, and was cleaned somewhere
along the line.
Regards,
McAfee AVERT tm
A division of McAfee, Inc
