 ** Votre ordi est-il espionné par l'Etat ?Sujet résolu
X13
  Posté le 20/11/2014 @ 18:45
jujube2
 Posté le 20/11/2014 à 19:14
tient, un activiste....
danee
 Posté le 21/11/2014 à 08:32
bizarre, le source code fait 458 Ko, et le programme compilé fait 26.5 Mo , en générale la source est plus volumineuse que le programme compilé ...
il s'exécute pendant 30 min ... ce qui donne beaucoup de temps pour faire des choses pas très recommandables ....
on nous prend vraiment pour des cons ...
edit: une bizarrerie de plus, j'ai voulu le compresser avec 7zip... impossible , il est déjà compressé par une compression interne, mais impossible de savoir quelle ...
Modifié par danee le 21/11/2014 08:53
danee
 Posté le 21/11/2014 à 09:33
Detekt
Detekt is a Python tool that relies on Yara, Volatility and Winpmem to scan the memory of a running Windows system (currently supporting Windows XP to Windows 8 both 32 and 64 bit and Windows 8.1 32bit).
Detekt tries to detect the presence of pre-defined patterns that have been identified through the course of our research to be unique identifiers that indicate the presence of a given malware running on the computer. Currently it is provided with patterns for:
- DarkComet RAT
- XtremeRAT
- BlackShades RAT
- njRAT
- FinFisher FinSpy
- HackingTeam RCS
- ShadowTech RAT
- Gh0st RAT
Beware that it is possible that Detekt may not successfully detect the most recent versions of those malware families. Indeed, some of them will likely be updated in response to this release in order to remove or change the patterns that we identified. In addition, there may be existing versions of malware, from these families or from other providers, which are not detected by this tool. If Detekt does not find anything, this unfortunately cannot be considered a clean bill of health.
If you encounter samples of such families that are not successfully detected, please open a ticket. In addition, please let us know if you find instances of false positives.
, si j'ai bien compris il cherche ce quelques malware en mémoire... 30min pour scanner la mémoire bizarre ...
X13
 Posté le 23/11/2014 à 22:45
149,99 €Ecran 24 pouces ViewSonic VX2458-C-MHD (incurvé, FullHD, 144Hz, 1ms) à 149,99 €
Valable jusqu'au 22 Septembre
Darty fait une promotion sur l'écran 24 pouces ViewSonic VX2458-C-MHD qui passe à 149,99 €. On le trouve ailleurs à partir de 170 €. Cet écran dédié aux joueurs dispose d'une dalle incurvée FullHD 1 ms à 144 Hz, un filtre lumière bleue et de la technologie anti scintillement Flicker Free. Il est compatible FreeSync, GSync et a des entrées HDMI, DP et DVI. Il intègre des haut-parleurs.
99,99 €SSD Interne M.2 NVMe Silicon Power 1 To à 99,99 €
Amazon fait une promotion sur le SSD Interne M.2 NVMe Silicon Power 1 To qui passe à 99,99 € livré gratuitement. Ce SSD offre des taux de transfert de 2200 Mo /s en lecture et 1600 Mo/s en écriture. Une excellente affaire pour ce SSD 3D Nand garanti 5 ans.
19,99 €Clé USB 3.0 Philips Flash Drive Vivid Edition 128 Go à 19,99 €
Valable jusqu'au 20 Septembre
Amazon fait une promotion sur la clé USB 3.0 Philips Flash Drive Vivid Edition 128 Go qui passe à 19,99 € alors qu'on la trouve ailleurs autour de 30 €. La livraison en relais colis est gratuite.
Detekt, un outil pour détecter si un votre ordinateur est espionné,
ordi très lent, merci pour votre aide
Petits dysfonctionnement - Etat de mon ordi ?
Doute sur état de l'ordi
ou en est mon ordi...et le votre?
Ad-aware ET Spybot dans votre ordi ?
Ad-Aware : Supprimer les espions de votre ordi !
ordi ralenti, questions ...
ordi hyper lent
pas d'antivirus sur mon ordi
Plus de sujets relatifs à ** Votre ordi est-il espionné par l''Etat ?
