 A-squared: malware dans Netcraft Toolbar
betacorne
  Posté le 12/05/2006 @ 08:12
Bonjour à tous, J'ai nouvellement installé l'anti-spyware a-squared (a2) sur mon PC. Voici son premier rapport:
a-squared Report Scan Started: 12.05.2006 08:04:07 Scan Finished: 12.05.2006 08:05:17 Scanning Time: 0h 1min 9sec Scanned Files: 43100 Infected Files: 24 Nom du fichier Diagnostic C:\Program Files\netcraft toolbar Trace.Directory.Netcraft Toolbar C:\Program Files\netcraft toolbar\jendarex.dll Trace.File.Netcraft Toolbar C:\Program Files\netcraft toolbar\jendarex.html Trace.File.Netcraft Toolbar C:\Program Files\netcraft toolbar\localblock.dat Trace.File.Netcraft Toolbar C:\Program Files\netcraft toolbar\logo.bmp Trace.File.Netcraft Toolbar C:\Program Files\netcraft toolbar\menu.xml Trace.File.Netcraft Toolbar C:\Program Files\netcraft toolbar\nctb.dll Trace.File.Netcraft Toolbar C:\Program Files\netcraft toolbar\netcraft.xml Trace.File.Netcraft Toolbar C:\Program Files\netcraft toolbar\retrievepage.dll Trace.File.Netcraft Toolbar C:\Program Files\netcraft toolbar\updater.exe Trace.File.Netcraft Toolbar C:\Program Files\netcraft toolbar\xss.dat Trace.File.Netcraft Toolbar Value: HKEY_CURRENT_USER\Software\Netcraft\Toolbar\Logo --> LastModified Trace.Registry.Netcraft Toolbar Value: HKEY_CURRENT_USER\Software\Netcraft\Toolbar\Menu --> LastModified Trace.Registry.Netcraft Toolbar Value: HKEY_CURRENT_USER\Software\Netcraft\Toolbar\Settings --> GUID Trace.Registry.Netcraft Toolbar Value: HKEY_CURRENT_USER\Software\Netcraft\Toolbar\Settings --> LastCheckedDLL Trace.Registry.Netcraft Toolbar Value: HKEY_CURRENT_USER\Software\Netcraft\Toolbar\Settings --> LastCheckedLBF Trace.Registry.Netcraft Toolbar Value: HKEY_CURRENT_USER\Software\Netcraft\Toolbar\Settings --> LastCheckedLogo Trace.Registry.Netcraft Toolbar Value: HKEY_CURRENT_USER\Software\Netcraft\Toolbar\Settings --> LastCheckedMenu Trace.Registry.Netcraft Toolbar Value: HKEY_CURRENT_USER\Software\Netcraft\Toolbar\Settings --> LastCheckedNetcraftMenu Trace.Registry.Netcraft Toolbar Value: HKEY_CURRENT_USER\Software\Netcraft\Toolbar\Settings --> LastCheckedXSS Trace.Registry.Netcraft Toolbar Value: HKEY_CURRENT_USER\Software\Netcraft\Toolbar\Settings --> Licensed Trace.Registry.Netcraft Toolbar Value: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Toolbar --> {D554D8FC-B36D-4BB4-93DB-4A3394D505E3} Trace.Registry.Netcraft Toolbar Value: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{00F87673-B929-4644-9322-7243E8289B54} --> DisplayName Trace.Registry.Netcraft Toolbar Value: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{00F87673-B929-4644-9322-7243E8289B54} --> EstimatedSize Trace.Registry.Netcraft Toolbar
Après avoir effacé ces "malware", la barre Netcraft Tollbal sur IE ne fonctionne plus, évidemment ! Que penser de ces vrais ou faux malwares ? Merci de votre réponse.
Modifié par betacorne le 12/05/2006 08:14
P.SCD
 Posté le 12/05/2006 à 08:37
Bonjour à tous [hello] La question a été évoquée en détail: https://forum.pcastuces.com/sujet.asp?SUJET_ID=192760&Page=9 Il ne s'agirait donc pas vraiment d'un spyware ou malware mais, c'est un log. particulièrement indiscret et à ce titre, A-squared le classe donc dans les indésirables. J'ai résumé au mieux, consulte le topic en lien pour te faire une idée préçise... En ce qui me concerne, je n'ai pas gardé...[chinois] @+
Modifié par P.SCD le 12/05/2006 08:37
betacorne
 Posté le 12/05/2006 à 08:49
Merci P.SCD, J'ai donc désisntallé la Netcraft Toolbar sur IE et sur Firefox par précaution. Il n'y a plus qu'à attendre une alternative !
Modifié par betacorne le 12/05/2006 08:49
P.SCD
 Posté le 12/05/2006 à 09:21
Re. De rien betacorne. Tu as bien fait de poser la question car avec A2, il faut interpréter les résultats. A2 en effet considère souvent plus les potentialités d'un logiciel et même d'un éditeur plutôt que sa malfaisance réelle. Il semble par exemple refuser tout ce qui est P2P, Incredimail, MSN je crois etc... (qui sont en effet pour le moins des nids à problèmes de sécurité [feroce]) Un cas entre autres: Nirsoft: Cet éditeur produit des outils puissants et utiles mais qui pourraient s'avérer nuisibles entre certaines mains (Mise en clair de mots de passe, liste de ports, etc...) Et bien tous ses produits sont blackboulés... [nonnon] Donc, on est souvent appelé à faire des choix en cas de positifs (vrais ou faux). [chinois]
99,99 €Souris sans fil Logitech G Pro X Superlight à 99,99 €
Valable jusqu'au 04 Décembre
Amazon fait une promotion sur la souris sans fil Logitech G Pro X Superlight qui passe à 99,99 € au lieu de 120 €. Cette souris pèse moins de 63 grammes et offre un glissement sans la moindre friction. Équipée du capteur optique Hero de 25000 dpi, la souris Pro X Superlight transmet chaque mouvement, et ce, avec une précision et une réactivité optimales, quelle que soit la vitesse.
149,96 €Ecran PC 23.8 pouces Dell S2422HG (incurvé, FullHD, VA, 165 Hz, 1 ms, FreeSync) à 149,96 € (via ODR)
LDLC  fait une promotion sur l'écran PC 23.8 pouces Dell S2422HG qui passe à 199,96 € au lieu de 220 € ailleurs. Or Dell rembourse actuellement 50 € sur cet écran qui vous reviendra à 149,96 € après remboursement.
Cet écran possède une dalle incurvée VA Full HD (1920x1080) à 165 Hz et avec un temps de réponse de 1 ms. Il est compatible FreeSync (et GSync via Adaptive Sync). La hauteur et l'inclinaison de l'écran sont réglables. 2 ports HDMI et 1 port DP.
28,99 €Clavier sans fil Microsoft All in One avec pad intégré à 28,99 €
Valable jusqu'au 03 Décembre
Amazon fait une promotion sur le clavier Microsoft All in One qui passe à 28,99 € au lieu de 39 €. Ce clavier sans fil (jusqu'à 9 mètres) est idéal pour piloter un ordinateur à distance puisqu'il intègre un touchpad pour contrôler également la souris. Léger, solide et résistant aux éclaboussures, il comporte de nombreuses touches multimédia personnalisables. Il est garanti 3 ans. La livraison est gratuite.
Malware dans fichier proposé par pcastuces
Malware dans "a Tube Catcher"
Encore du ASK Toolbar dans mon moulin!
Comment désinstaller Ask Toolbar dans IE8 ?
Malware dans Speccy?
Ask Toolbar dans Avira + questions Avast et AVG
Malware dans 360desktop 0.8.5.2084 ???
Présence de Ask Toolbar, dans mes programmes-
a-squared anti malware
a-squared Anti-Malware 3.5 version complète gratui
Plus de sujets relatifs à A-squared: malware dans Netcraft Toolbar
