> Tous les forums > Forum Autres langages
 aide débutant sql
computer60
  Posté le 28/10/2015 @ 12:00
Nouvelle astucienne
Nous voudrions signer une zone en négative suivant une condition dans sql le
début de notre syntaxe est comme ci dessous :
SELECT FACTUP00.TYPE_FACTURE, FACTUP00.INTERNE, FACTUP00.DATE_FACTURE, FACTUP01.INTERNE, FACTUP01.MNT_1_RUB, FACTUP01.CD_RUB
FROM S651C3FE.RESEAUF.FACTUP00 FACTUP00, S651C3FE.RESEAUF.FACTUP01 FACTUP01
WHERE FACTUP00.INTERNE = FACTUP01.INTERNE AND ((FACTUP00.DATE_FACTURE=20151027))
TYPE_FACTURE MNT_1_RUB
F4174682015102741746846,511010
F4174682015102741746823,341016
F4174682015102741746811,941025
F41746820151027417468183,001259
F4174682015102741746855,001269
F417468201510274174689,521881
F4174682015102741746832,541920
F4174682015102741746843,011921
F4174682015102741746811,041922
F4174682015102741746865,681924
F41746820151027417468238,001991
F417468201510274174683,941994
F4174542015102741745423,341015
F41745420151027417454202,001269
F417454201510274174548,081881
F417454201510274174541,851884
F417454201510274174543,501885
F4174542015102741745413,881916
F4174542015102741745453,601917
F4174542015102741745447,671973
F41745420151027417454124,541977
F4174542015102741745457,961978
F41745420151027417454202,001991
F41745420151027417454-118,991993
F41743620151027417436514,092358
F4174362015102741743631,312594
F4174362015102741743657,272881
F417436201510274174365,282884
F4174362015102741743610,032885
F41743620151027417436192,962910
F41743620151027417436502,082924
F41743620151027417436456,602955
F4174362015102741743623,342956
F4174362015102741743672,822957
F4174362015102741743672,822964
F4174362015102741743623,342970
F41743620151027417436545,402991
F41743620151027417436-798,562993
F4174652015102741746531,321010
F4174652015102741746523,341016
F4174652015102741746510,651025
A41746520151027417465103,531300
F4174652015102741746516,001351
F4174652015102741746510,871881
F4174652015102741746523,341920
F4174652015102741746557,041921
F4174652015102741746510,651922
F4174652015102741746554,881924
F41746520151027417465103,531991
F41746520151027417465-107,691994
A41746520151027417465,601999
Ou doit on se placer et quelle fonction peut on utiliser suivant la condition suivante
si zone type_facture = a A mettre la zone MNT_1_1RUB en négatif ?
Merci pour votre aide
Titus68
 Posté le 28/10/2015 à 13:09
Si c'est pour avoir le signe - à l'affichage, çà dépend du moteur de base de données :
- sous oracle, il y a la fonction decode :
DECODE(FACTUP00.TYPE_FACTURE,'a',FACTUP01.MNT_1_RUB*-1,FACTUP01.MNT_1_RUB) remplacer FACTUP01.MNT_1_RUB sans la select par çà
Cà équivaut à : si FACTUP00.TYPE_FACTURE = 'a' alors FACTUP01.MNT_1_RUB*-1 (on multiplie par -1) sinon on affichage FACTUP01.MNT_1_RUB tel quel
http://docs.oracle.com/cd/B19306_01/server.102/b14200/functions040.htm
- sous sqlserver : çà doit être avec CASE ..
CASE FACTUP00.TYPE_FACTURE
	WHEN'a'THENFACTUP01.MNT_1_RUB*-1ELSEFACTUP01.MNT_1_RUBEND IF
Sinon si c'est une zone à modifier dans la base, utiliser la fonction UPDATE :
UPDATE
651C3FE.RESEAUF.FACTUP01 set FACTUP01.MNT_1_RUB = FACTUP01.MNT_1_RUB *-1 where ...
Modifié par Titus68 le 28/10/2015 13:27
computer60
 Posté le 28/10/2015 à 14:22
Nouvelle astucienne
Merci Titus68
Nous avons essayé en incluant la fonction update en fin mais nous avons des messages d'erreur:
UPDATE 651C3FE.RESEAUF.FACTUP01 set FACTUP01.MNT_1_RUB = FACTUP01.MNT_1_RUB *-1
Le message est le suivant :
SQL0199 le mot clé update est mal placée
___________________________
Et avec l'autre fonction placée au même endroit nous le message suivant :
idem le mot clé case est mal placée
Peux tu nous dire ou nous devons se placer et manque t'il des virgules ou des parenthèses et doit on tout coller oui oui
nous sommes vraiment des débutantes....
Merci de votre aide
Titus68
 Posté le 28/10/2015 à 14:55
En fait soit vous voulez faire une requête pour afficher : SELECT (dans ce cas le montant sera bien affiché avec le négatif mais il ne sera pas modifié dans la table)
soit une requête pour mettre à jour le montant dans la table 51C3FE.RESEAUF.FACTUP01, (mais après çà va modifier le montant dans la table : c'est ce que vous voulez).
Pour l'ordre update je n'ai indiqué que le début car je ne sais pas exactement ce que vous voulez faire.
Pour l'update çà doit être :
Avant l'update, je vous conseille quand même de faire une sauvegarde de la table :
651C3FE.RESEAUF.FACTUP01 par :
create table 651C3FE.RESEAUF.FACTUP01_SVG as select * from 651C3FE.RESEAUF.FACTUP01
puis
UPDATE 651C3FE.RESEAUF.FACTUP01 set S651C3FE.RESEAUF.FACTUP01.MNT_1_RUB = S651C3FE.RESEAUF.FACTUP01.MNT_1_RUB *-1 where S651C3FE.RESEAUF.FACTUP01.INTERNE in (SELECT INTERNE FROM S651C3FE.RESEAUF.FACTUP00 WHERE DATE_FACTURE=20151027)
l'ordre (SELECT ... 20151027) va donc sélectionner tous les INTERNE dont la date est 27/10/2015) et passer la liste des INTERNE à l'ordre UPDATE par S651C3FE.RESEAUF.FACTUP01.INTERNE in (SELECT INTERNE
J'espère que c'est juste. La syntaxe dépend sans doute du moteur de base de données que vous avez (là c'est pour Oracle), à voir ... J'espère aussi que vous avez les droits sur la table pour faire des UPDATE et un CREATE TABLE au niveau du schéma.
Modifié par Titus68 le 28/10/2015 14:58
computer60
 Posté le 28/10/2015 à 15:23
Nouvelle astucienne
Merci pour le retour
si on comprend bien quand vous parlez de table se sont les fichiers?
Dans ce cas nous on ne veut que afficher le négatif dans la zone montant rubrique comment doit on procéder svp?
Titus68
 Posté le 28/10/2015 à 16:01
C'est un peu çà mais pas exactement car parfois un seul fichier peut contenir un schéma (généralement un nom d'utilisateur) qui lui-même contient des tables qui elles mêmes ont des colonnes.
Dans une table on peut stocker des infos (par exemple des données d'une facture), dans une autre table les infos du client... tout dépend comment le schéma de la base a été conçu par le développeur.
tout dépend aussi du type de base de données :
- pour oracle, sqlserver on regroupe les tables dans un fichier (mais on peut aussi regrouper en n fichiers de x tables).
- pour mysql, c'est différent.
Voir :
https://fr.wikipedia.org/wiki/Base_de_donn%C3%A9es
Sinon pour les tables des SELECT ne font qu'extraire les infos, les UPDATE, DELETE ... modifient le contenu des tables.
Essayer :
SELECT FACTUP00.TYPE_FACTURE, FACTUP00.INTERNE, FACTUP00.DATE_FACTURE, FACTUP01.INTERNE, DECODE(FACTUP00.TYPE_FACTURE,'a',FACTUP01.MNT_1_RUB*-1,FACTUP01.MNT_1_RUB), FACTUP01.CD_RUB
Dans votre cas il semble déjà que les infos des factures sont éclatées dans 2 tables différentes : FACTUP01 et FACTUP00 probablement FACTUP00 pour l'entête de la facture (n° client, date de la facture et un n° de facture (INTERNE) et une autre table FACTUP01 pour les lignes des articles de la facture (je suppose). Pour faire le lien entre les 2 tables : il y a la zone INTERNE (peut-être un n° de facture ?)
Il faudrait me dire à quel type de bases vous vous connectez : oracle, mysql, sqlserver ou mssql, sqlite, ...
Modifié par Titus68 le 28/10/2015 16:06
computer60
 Posté le 28/10/2015 à 16:22
Nouvelle astucienne
merci
Nous avons pris toute la syntaxe ci dessous et relancer et nous avons un autre message
qui te dis:
SQL0204 DECODE de type *N dans *LIBL non trouvé
et nous sommes sur Microsoft Query!!!
Merci pour ton aide
Titus68
 Posté le 28/10/2015 à 16:40
J'aurais pensé à toutes sauf celle-là, je n'utilise pas mais essayer avec
SELECT FACTUP00.TYPE_FACTURE, FACTUP00.INTERNE, FACTUP00.DATE_FACTURE, FACTUP01.INTERNE, SWTICH(FACTUP00.TYPE_FACTURE = 'a',FACTUP01.MNT_1_RUB*-1,FACTUP01.MNT_1_RUB), FACTUP01.CD_RUB
Si çà marche pas, essayer peut-être avec :
FACTUP00.TYPE_FACTURE = "a" (" à la place de ')
Modifié par Titus68 le 28/10/2015 16:50
Titus68
 Posté le 28/10/2015 à 16:48
Anonyme,
Ils ont peut-être réussi à hacker un serveur ... m...e ma carte de crédit !
Modifié par Titus68 le 28/10/2015 16:51
Titus68
 Posté le 28/10/2015 à 17:15
Rectificatif c'est pas SWTICH mais SWITCH
35,99 €Souris sans fil Logitech G305 à 35,99 €
Valable jusqu'au 24 Février
Amazon fait une belle promotion sur la nouvelle souris sans fil Logitech G G305 qui passe à 35,99 € livrée gratuitement alors qu'on la trouve ailleurs autour de 50 €. Cette souris vous offre des performances sans fil de niveau professionnel et une fiabilité inégalée surpassant même certaines des meilleures souris gaming filaire. Dotée du capteur HERO, vous allez connaitre une précision exceptionnelle grâce à sa sensibilité pouvant aller jusqu'à 12 000 dpi.
113,60 €SSD SanDisk Ultra 3D 1 To à 113,60 €
Valable jusqu'au 22 Février
En cette période de forte remontée des prix des SSD, Amazon fait une belle promotion sur le SSD SanDisk Ultra 3D d'une capacité de 1 To qui passe à 113,60 € livré gratuitement. On le trouve ailleurs autour de 160 €. Une bonne affaire pour ce SSD performant qui offre des débits de 560 Mo/s en lecture et 530 Mo/s en écriture. Cette version est garantie 3 ans.
20,45 €Carte mémoire microSDXC UHS-I SanDisk A1 Ultra 128 Go à 20,45 €
Valable jusqu'au 26 Février
Amazon propose actuellement la carte mémoire microSDXC UHS-I SanDisk A1 Ultra 128 Go à 20,45 € livrée gratuitement. Cette carte mémoire offre des vitesses jusqu'à 100 Mo/s et est idéale pour les téléphones, caméras et appareils photo HD. Elle est certifiée GoPro et Switch.
Aide port serie et à la programmation
jeux android kill shot de l'aide svp
Aide pour un programme simple en C++
Aide POur initiation a SQL ( oracle 10G)
DEMANDE AIDE
demande d'aide pour un petit script
[C] Pb utilisation de malloc (débutant)
Convertir un fichier d'aide .HLP en .HTML par
quel SGBD apprendre pour debutant ?
Aide à la réalisation d'un programme
Plus de sujets relatifs à aide débutant sql
 > Tous les forums > Forum Autres langages
