 aide pour raccordement carte mere asusSujet résolu
lio26
  Posté le 20/12/2008 @ 07:23
bonjour,
J'ai besoin d'aide pour raccorder ma carte mere Normal 0 21 false false false FR X-NONE X-NONE <!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:0; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:-1610611985 1107304683 0 0 159 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin-top:0cm; margin-right:0cm; margin-bottom:10.0pt; margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:12.0pt; mso-bidi-font-size:10.0pt; font-family:"Times New Roman","serif"; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-font-kerning:12.0pt; mso-fareast-language:EN-US;} a:link, span.MsoHyperlink {mso-style-noshow:yes; mso-style-priority:99; color:blue; text-decoration:underline; text-underline:single;} a:visited, span.MsoHyperlinkFollowed {mso-style-noshow:yes; mso-style-priority:99; color:purple; mso-themecolor:followedhyperlink; text-decoration:underline; text-underline:single;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; font-size:12.0pt; mso-ansi-font-size:12.0pt; mso-bidi-font-size:10.0pt; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-font-kerning:12.0pt; mso-fareast-language:EN-US;} .MsoPapDefault {mso-style-type:export-only; margin-bottom:10.0pt; line-height:115%;} @page Section1 {size:612.0pt 792.0pt; margin:70.85pt 70.85pt 70.85pt 70.85pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} ASUS P5QL Pro (C2D + DDR2 + PCI-E)
ex. savoir quelle est le plus et le moins des connexions power led entre le noir et le vert
et rouge et noir .
Si je suis en sata .je n'ai pas besoin de raccorder la nasse fournie .
Et d'autre question si possible ...
lio26
 Posté le 20/12/2008 à 07:25
Et pourquoi ca me marque toutes ces ligne quand je m'ai un message
tiobilout
 Posté le 20/12/2008 à 08:23
et rouge et noir .
Le - est toujours le noir.
Concernant la question sur le SATA, je n'ai pas compris ta phrase ( la nasse )
Tu dois connecter une alimentation et le câble de données.
lio26
 Posté le 20/12/2008 à 09:46
RE
La nasse ! je veux dire les cordon plat et tres large fourni avec .
es ce que j'en es besoin ?
cote cartez il y a les fiches mais cote CD ET Disk dur il n' y a rien ( je crois )
donc j'ai brancher alim + sata !
es bon ?
merci
tiobilout
 Posté le 20/12/2008 à 09:51
cordon plat el large ==== la nappe ...
Ben non, si tu te en SATA, pas besoin, tu ne peux pas les brancher de toute façon.
lio26
 Posté le 20/12/2008 à 10:45
ok merci !!!
Gratuit3 mois d'abonnement à Amazon Music Unlimited gratuits
Valable jusqu'au 15 Janvier
Amazon vous permet d'essayer son service de streaming musical pendant 3 mois gratuitement. Avec Amazon Music Unlimited, accédez à plus de 50 millions de titres, sans publicité et en illimité sur tous vos appareils : smartphone, tablette, PC/Mac, Fire, Alexa. Vous avez même la possibilité de télécharger vos playlists pour des écoutes hors connexion. A la fin de ces 3 mois, vous pourrez basculer vers l'offre payante à 9,99 € / mois ou bien arrêter sans frais le service. A noter l'existence d'une offre famille à 14,99 € / mois qui permet jusqu'à 6 utilisateurs d'écouter leur musique à tout moment et sur leurs appareils préférés. Vous pouvez annuler l'abonnement à tout moment. L'offre se termine ce soir. Ne tardez pas !
89,99 €Kit de démarrage Ordinateur Raspberry Pi 4 Type B 4 Go à 89,99 € (via coupon)
Valable jusqu'au 17 Janvier
Amazon fait une vente flash sur un kit de démarrage Raspberry Pi 4 Type B 4 Go qui passe à 89,99 € via un coupon de réduction de 20 € à appliquer sur la page du produit. On le trouve ailleurs à partir de 120 €. Pour rappel, la nouvelle version de ce mini ordinateur dispose d'un processeur ARM Quad Core à 1.5 GHz, de 4 Go  de mémoire, d'un lecteur de carte microSD, de 4 ports USB (dont 2 USB 3.0), Ethernet et HDMI. Il intègre le WiFi et le Bluetooth. Il permet l'exécution de Windows 10, Linux, le décodage de flux Blu-Ray en 1080p ainsi que l'émulation d'anciennes consoles de jeux. Si vous voulez bidouiller et explorer la programmation informatique, le Raspberry Pi est une excellente base ! C'est aussi une bonne solution pour se créer un système domotique avec Domoticz et Jeedom, Media Center avec OpenElec et Kodi ou un système de jeux retro avec Recallbox ou RetroPie.
Ce kit de démarrage comporte en plus du Raspberry Pi 4 : une alimentation française 3 A avec interrupteurun boîtier et une carte mémoire 32 Go préchargée avec la distribution NOOBS, un lecteur de carte mémoire, des dissipateurs thermiques, un ventilateur et un câble HDMI. La livraison est gratuite.
Valable jusqu'au 16 Janvier
quelle carte mère pour remplacer cm asus P6X58D-E
Carte usb 3 pour Carte Mère Asus
cherche carte mère pour portable Asus F9S
quelle carte vidéo pour un carte mère ASUS P5W De
Batterie pour carte mère ASUS A7N266-VM
Quel Bios pour la Carte mère Asus P5GC MX V ?
besoin d'aide pour brancher carte mere
[Aide svp]carte mère HS ASUS A8N32 SLI DELUXE
quelle pross pour ma carte mere asus ?
Aide pour carte mère
Plus de sujets relatifs à aide pour raccordement carte mere asus
