 AOMEI Backupper 2.5.0
Le Guermeur
  Posté le 20/03/2015 @ 09:27
http://www.backup-utility.com/free-backup-software.html Version 2.5. standard
A mon grand étonnement la licence Pro gratuite de la version 2.2.0 a été acceptée Version Pro 2.5:http://www.backup-utility.com/professional.html
[2015-03-19] New Features in AOMEI Backupper 2.5
  • Added universal restore: allow you to restore a system backup image created on one computer to another with different/dissimilar hardware.
  • Added system restore and system clone between GPT and MBR disk: enable you to restore/clone system from MBR (BIOS-based) disk to GPT (UEFI-based) disk and vice versa under native Windows environment and Windows PE bootable environment (Linux bootable environment is not yet supported), while ensuring that system is able to boot properly.
  • Added an option on schedule backup advanced settings: allow you to more clearly choose whether or not to automatically perform missed scheduled backup tasks in the next system startup.
  • Optimized PXE network booting: add HTTP method to speed up the downloading of image file.
  • Optimized email notifications: add computer name into message and improve AOMEI SMTP server to ensure that all notifications are delivered successfully.
  • Fixed issue: after performing a schedule backup task, the tray icon sometimes is unable to quit normally or no window display when clicking the tray icon.
  • Fixed bug: the program always prompts you to enter the new username and password of shared network folder or NAS after modifying the old ones.
http://www.colok-traductions.com/Colok_Traductions_downloads_file_423.html et sa traduction en FR par colok
Modifié par Le Guermeur le 18/04/2015 15:53
Manette Xbox Series sans fil à 39,99 €
39,99 € 59,99 € -33% @Cdiscount
Cdiscount fait une promotion sur la manette Xbox Series sans fil qui passe à 39,99 € au lieu de 59,99 €. Vous pouvez l'utiliser également sans fil sur PC grâce au Bluetooth (ou en filaire avec un câble USB C).
Voir le bon plan
Tapis de souris Corsair MM300 PRO (93x30 cm) à 24,99 €
24,99 € 34,99 € -29% @Amazon
Amazon fait une promotion sur le tapis de souris Corsair MM300 PRO Extended qui passe à 24,99 € au lieu de 34,99 €. Ce tapis de souris extra large mesure 93 x 30 cm et vous permettra de couvrir votre bureau et disposer dessus votre clavier et votre souris qui ne risquera plus de sortir du tapis. Le tapis résiste à l'eau, peut être lavé et possède des contours cousus pour éviter l'effilochement.
Voir le bon plan
Chaise de bureau ergonomique Songmics à 63,96 €
63,96 € 90 € -29% @Amazon
Amazon fait une promotion sur la chaise de bureau Songmics OBN37BK qui passe à 63,96 € livrée gratuitement, au lieu de 90 €. Cette chaise en tissu maillé est ajustable en hauteur, possède une assise rembourrée, un support lombaire et des accoudoirs rabattables.
Voir le bon plan
Console Microsoft Xbox Series S + EA Sports FC 24 à 269,99 €
269,99 € 299,99 € -10% @Amazon
Amazon fait une belle promotion sur la console Xbox Series S avec le jeu EA Sports FC 24 à télécharger à 269,99 € au lieu de 299,99 €. Avec la Microsoft Xbox Series S, bénéficiez des performances de nouvelle génération dans la Xbox la plus compacte jamais conçue à ce jour. Avec des mondes plus dynamiques en 1440p, des temps de chargement réduits grâce à son SSD interne de 512 Go, la Xbox Series S offre une expérience unique.
Le pack Chasseur doré avec neuf produits cosmétiques en jeu et de monnaie virtuelle pour Fortnite, Rocket League et Fall Guys est également fourni.
Voir le bon plan
Ecran 32 pouces incurvé Viewsonic VX3218 (FHD, 165 Hz, 1 ms) à 184,99 €
184,99 € 269 € -31% @Cdiscount
Cdiscount fait une belle promotion sur l'écran 32 pouces incurvé Viewsonic VX3218 qui passe à 184,99 € avec le code 15DES149 alors qu'on le trouve ailleurs à partir de 269 €. Cet écran dispose d'une dalle VA Full HD  (1920x1080) à 165 Hz avec un temps de réponse de 1 ms. Il est compatible Adaptive Sync. Au niveau connectique, vous trouverez une entrée DP et deux entrées HDMI. Une très bonne affaire.
Voir le bon plan
Ecran PC 28 pouces Samsung U28R550 (4K, IPS, 4 ms, HDR10) à 184,99 €
Cdiscount fait une promotion sur l'écran PC 28 pouces Samsung U28R550 qui passe à 184,99 € avec le code 15DES149. On le trouve ailleurs à partir de 269 €. Cet écran dispose d'une dalle IPS 4K UHD (3840x2160) sans bordure. Grâce à la fonction PBP, vous pourrez afficher en même temps le contenu de 2 sources différentes (2 HDMI et DP). Il est compatible HDR10.
Voir le bon plan
AOMEI Backupper update
AOMEI Backupper Pro 2.5 complet gratuit.
Complément pour Aoméi Backupper
***Tuto Aoméi Backupper Free/Pro 2.5***
Aomei Backupper Professional 2.2 gratuit sur Windows'deal
AOMEI Créer DVD bootable quelle marche à suivre?
AOMEI-Partition-Assistant-Professional-Edition-Giveaway AOMEI Partition As
Créer une partition avec AOMEÎ en vidéo
AOMEI Partition Assistant Professional 5.6 (100% Discount)
AOEMI Backupper pro 2.5 refuse les restaurations
Plus de sujets relatifs à AOMEI Backupper 2.5.0
