 après remplacement OpenOffice par LibreOfficeSujet résolu
gildo
  Posté le 28/02/2011 @ 16:16
Tout le monde,
Je viens de remplacer OpenOffice par LibreOffice et ReCleaner me signale comme nouveau ce
quiest ci-dessous:
RegCleaner 4.3 by Jouni Vuorio, translation by Jean Balczesak
Auteur : OpenOffice.org
Logiciel : LibreOffice
Age : Nouveau
Si vous choisissez de supprimer ces éléments, les clés suivantes seront supprimées
HKEY_CLASSES_ROOT\Software\OpenOffice.org\LibreOffice
HKEY_CLASSES_ROOT\office.Extension.1
HKEY_CLASSES_ROOT\opendocument.CalcDocument.1\shell\open\command
HKEY_CLASSES_ROOT\opendocument.CalcTemplate.1\shell\open\command
HKEY_CLASSES_ROOT\opendocument.DatabaseDocument.1\shell\open\command
HKEY_CLASSES_ROOT\opendocument.DrawDocument.1\shell\open\command
HKEY_CLASSES_ROOT\opendocument.DrawTemplate.1\shell\open\command
HKEY_CLASSES_ROOT\opendocument.ImpressDocument.1\shell\open\command
HKEY_CLASSES_ROOT\opendocument.ImpressTemplate.1\shell\open\command
HKEY_CLASSES_ROOT\opendocument.MathDocument.1\shell\open\command
HKEY_CLASSES_ROOT\opendocument.WriterDocument.1\shell\open\command
HKEY_CLASSES_ROOT\opendocument.WriterGlobalDocument.1\shell\open\command
HKEY_CLASSES_ROOT\opendocument.WriterTemplate.1\shell\open\command
HKEY_CLASSES_ROOT\opendocument.WriterWebDocument.1\shell\open\command
HKEY_CLASSES_ROOT\opendocument.WriterWebTemplate.1\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Doc\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Docm\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Docx\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Dot\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Dotm\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Dotx\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Pot\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Potm\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Potx\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Pps\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Ppt\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Pptm\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Pptx\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Rtf\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Xls\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Xlsb\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Xlsm\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Xlsx\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Xlt\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Xltm\shell\open\command
HKEY_CLASSES_ROOT\OpenOffice.org.Xltx\shell\open\command
HKEY_CLASSES_ROOT\soffice.StarCalcDocument.6\shell\open\command
HKEY_CLASSES_ROOT\soffice.StarCalcTemplate.6\shell\open\command
HKEY_CLASSES_ROOT\soffice.StarDrawDocument.6\shell\open\command
HKEY_CLASSES_ROOT\soffice.StarDrawTemplate.6\shell\open\command
HKEY_CLASSES_ROOT\soffice.StarImpressDocument.6\shell\open\command
HKEY_CLASSES_ROOT\soffice.StarImpressTemplate.6\shell\open\command
HKEY_CLASSES_ROOT\soffice.StarMathDocument.6\shell\open\command
HKEY_CLASSES_ROOT\soffice.StarWriterDocument.6\shell\open\command
HKEY_CLASSES_ROOT\soffice.StarWriterGlobalDocument.6\shell\open\command
HKEY_CLASSES_ROOT\soffice.StarWriterTemplate.6\shell\open\command
Et aussi:
Auteur : LibreOffice
Age : Nouveau
HKEY_LOCAL_MACHINE\Software\LibreOffice\LibreOffice\3.3
N'y-a-t'il pas doublon?????
Dois-je garder ce qui se rapporte à Open???
Merci pour vos avis.
Bonne fin de journée.
marc2247
 Posté le 28/02/2011 à 18:02
Bonsoir gildo,
Sur le site de LibreOffice, il est conseillé vivement de désinstaller OpenOffice avant d'installer LibreOffice. Dans ton cas, j'en conclus que tout ce qui se rapporte à OpenOffice est de trop.
Pour ma part, j'ai installé ce matin la version LibreOffice 3.3.1 sur la version précédente LibreOffice 3.3 RC sans problème et j'avais déjà installé la 3.3 RC précédemment à la place d'OpenOffice mais en désinstallant cette dernière avec nettoyage au préalable.
Attend d'autres avis plus autorisés que le mien.
@ plus.
gildo
 Posté le 01/03/2011 à 11:42
{#}, marc2247,{#}
Merci pour ton intervention, mais j'ai désinstallé Open avec revo uninstaller, méthode complète, j'ai fait un nettoyage avec Ccleaner et redémarré mon ordi.
En fait je remarque que Open Libre fait référence à Open, voir image:
Je n'arrive pas à insérer l'image sur le site ImageShack le direct link est en grisé!!
A plus tard.
Bonne journée.
gildo
 Posté le 01/03/2011 à 15:26
Re,
Voici l'image!!!
Libre aurait-il garder un lien "affectif" avec open???
gildo
 Posté le 01/03/2011 à 17:14
Re,,
J'ai fait une recherche avec xp voici ce qu'il me trouve si je lui demande de rechercher Open:
Puis supprimer tout ce qui se rapporte à OPEN????
Encore merci par avance pour l'aide.
Bonne soirée.
gildo
 Posté le 02/03/2011 à 15:03
{#}, Tout le monde,{#}
Bon, j'ai supprimé tout ce qui avait OpenOffice, depuis la recherche windows, et Libre ne sans porte pas plus mal!!!!{#}
Donc je marque résolu.
Bonne fin dejournée.
28,94 €Clé USB Sandisk Ultra Go 128 Go à double connectique USB 3.1 Type A et C à 28,94 €
Valable jusqu'au 12 Mai
Amazon fait une promotion sur la clé USB Sandisk Ultra Go 256 Go à double connectique USB 3.1 Type A et C qui passe à 28,94 €. Cette clé USB  dispose d'un connecteur USB Type C et d'un connecteur classique de type A. Grâce à elle, transférez en toute simplicité et rapidement (jusqu'à 150 Mo/s) vos fichiers entre vos smartphones, tablettes et ordinateurs. On la trouve ailleurs à plus de 60 €.
249,99 €SSD externe portable USB 3.1 SanDisk Extreme 2 To à 249,99 €
Valable jusqu'au 11 Mai
Amazon fait une promotion sur le SSD externe portable USB 3.1 SanDisk Extreme 2 To qui passe à 249,99 € livré gratuitement alors qu'on le trouve à 300 € ailleurs. Le disque SSD SanDisk Extreme portable est plus de deux fois plus petit que la taille de votre smartphone et fournit jusqu'à 5 fois la vitesse d'un disque dur portable. Apprenez à travailler en quelques secondes, transférez de grandes bibliothèques de vidéos et de photos à des vitesses pouvant atteindre 550 Mo/s. Vous ne craindrez pas de l'emporter partout avec vous grâce à sa conception robuste et résistante avec un coeur de SSD résistant aux chocs. Le logiciel SanDisk inclu SecureAccess peut crypter vos fichiers personnels. Garantie 3 ans. Résiste à l'eau (IP55). Interface : USB 3.1 Type A et C.
149,95 €Ecran 23,8 pouces Acer EG240YPbipx (FullHD, IPS, 1ms, 165 Hz, FreeSync) à 149,95 €
Valable jusqu'au 16 Mai
LDLC fait une promotion sur l'écran 23,8 pouces Acer EG240YPbipx qui passe à 149,95 € alors qu'on le trouve ailleurs à partir de 200 €. Cet écran dédié aux joueurs dispose d'une dalle IPS Full HD de 1920x1080 pixels. Grâce à sa compatibilité Freesync (165 Hz) et son temps de réponse rapide de 1 ms, ce moniteur Acer offre une excellente fluidité d'affichage. Interfaces : 2 x HDMI, DP (1.2), Sortie de ligne audio.
LibreOffice ou OpenOffice ?
Openoffice ou Libreoffice
Mise en forme avec OpenOffice et LibreOffice
Différence Openoffice, Libreoffice et Staroffice
Apache OpenOffice ou LibreOffice ?
B50525 = Remplacement automatique des renvois ?
[De OpenOffice tableur vers HTML]
OpenOffice : supprimer page blanche
Récupérer une macro apres enregistrement en xls
Plus de sujets relatifs à après remplacement OpenOffice par LibreOffice
