 Clés registre inféctées 2010
craimon
  Posté le 24/06/2010 @ 17:52
bonjour,
voila scan avec spybot j ai trouver ceci :
rapport de spybot :
Win32.PornPopUp: Cookie traceur (Firefox: Administrateur (default)) (Cookie, nothing done)
--- Spybot - Search & Destroy version: 1.6.2 (build: 20090126) ---
2009-01-26 blindman.exe (1.0.0.8)
2009-01-26 SDFiles.exe (1.6.1.7)
2009-01-26 SDMain.exe (1.0.0.6)
2009-01-26 SDShred.exe (1.0.2.5)
2009-01-26 SDUpdate.exe (1.6.0.12)
2009-01-26 SpybotSD.exe (1.6.2.46)
2009-03-05 TeaTimer.exe (1.6.6.32)
2009-06-20 unins000.exe (51.49.0.0)
2009-01-26 Update.exe (1.6.0.7)
2009-07-28 advcheck.dll (1.6.3.17)
2007-04-02 aports.dll (2.1.0.0)
2008-06-14 DelZip179.dll (1.79.11.1)
2009-01-26 SDHelper.dll (1.6.2.14)
2008-06-19 sqlite3.dll
2009-01-26 Tools.dll (2.1.6.10)
2009-01-16 UninsSrv.dll (1.0.0.0)
2010-06-16 Includes\Adware.sbi (*)
2010-06-22 Includes\AdwareC.sbi (*)
2010-01-25 Includes\Cookies.sbi (*)
2009-11-03 Includes\Dialer.sbi (*)
2010-06-22 Includes\DialerC.sbi (*)
2010-01-25 Includes\HeavyDuty.sbi (*)
2009-05-26 Includes\Hijackers.sbi (*)
2010-06-22 Includes\HijackersC.sbi (*)
2010-06-22 Includes\iPhone.sbi (*)
2010-01-20 Includes\Keyloggers.sbi (*)
2010-06-22 Includes\KeyloggersC.sbi (*)
2004-11-29 Includes\LSP.sbi (*)
2010-06-01 Includes\Malware.sbi (*)
2010-06-22 Includes\MalwareC.sbi (*)
2010-05-18 Includes\PUPS.sbi (*)
2010-06-23 Includes\PUPSC.sbi (*)
2010-01-25 Includes\Revision.sbi (*)
2009-01-13 Includes\Security.sbi (*)
2010-06-22 Includes\SecurityC.sbi (*)
2008-06-03 Includes\Spybots.sbi (*)
2008-06-03 Includes\SpybotsC.sbi (*)
2010-06-16 Includes\Spyware.sbi (*)
2010-06-22 Includes\SpywareC.sbi (*)
2010-03-08 Includes\Tracks.uti
2010-06-01 Includes\Trojans.sbi (*)
2010-06-22 Includes\TrojansC-02.sbi (*)
2010-06-22 Includes\TrojansC-03.sbi (*)
2010-06-22 Includes\TrojansC-04.sbi (*)
2010-06-22 Includes\TrojansC-05.sbi (*)
2010-06-22 Includes\TrojansC.sbi (*)
2008-03-04 Plugins\Chai.dll
2008-03-05 Plugins\Fennel.dll
2008-02-26 Plugins\Mate.dll
2007-12-24 Plugins\TCPIPAddress.dllbot :
ET SCAN AVEC GLARY UTILIES J4AI TROUVER :
hkey_classes_root\application.reference\shellex\contextmenuhandlers{90AA3A4E-1CBA-4233-B8BB-535773D48449} CETTE CL2 DU REGISTRE POINTE VERS LA CLSID MANQUANTE{MEME CODE QUE DANS LA PRECEDENTE PHRASE }
que faut il faire ? pouvez vous m aider ?!!
d avance merci ;-)
Modifié par craimon le 24/06/2010 23:36
craimon
 Posté le 24/06/2010 à 18:33
et peut me conseil pour des logiciels plus performent
craimon
 Posté le 24/06/2010 à 19:52
pouvez vous m'aider a resoudre mes problome informatique merci d'avance {#}
craimon
 Posté le 24/06/2010 à 20:07
merci pour ta reponse mais j ai Malwarebytes regard le rapport : peut tu m' aider ?pour mes probleme merci d'ance
Malwarebytes' Anti-Malware 1.45
www.malwarebytes.org
Version de la base de données: 4029
Windows 5.1.2600 Service Pack 3
Internet Explorer 8.0.6001.18702
24/06/2010 12:52:02
mbam-log-2010-06-24 (12-52-02).txt
Type d'examen: Examen complet (C:\|D:\|E:\|)
Elément(s) analysé(s): 172798
Temps écoulé: 36 minute(s), 2 seconde(s)
Processus mémoire infecté(s): 0
Module(s) mémoire infecté(s): 0
Clé(s) du Registre infectée(s): 0
Valeur(s) du Registre infectée(s): 1
Elément(s) de données du Registre infecté(s): 2
Dossier(s) infecté(s): 0
Fichier(s) infecté(s): 0
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\forceclassiccontrolpanel (Hijack.ControlPanelStyle) -> No action taken.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\FirewallDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> No action taken.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\UpdatesDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> No action taken.
craimon
 Posté le 24/06/2010 à 21:05
confirmation de quoi ?
craimon
 Posté le 24/06/2010 à 22:13
spybot a suprimer ce qu'il vait trouver plus de menace ok
glary lui toujours le meme chose comment faire ?
je vient de le mettre a jour rapport est :
Malwarebytes' Anti-Malware 1.46
Version de la base de données: 4235
24/06/2010 22:09:06
mbam-log-2010-06-24 (22-09-06).txt
Elément(s) analysé(s): 188831
Temps écoulé: 37 minute(s), 10 seconde(s)
Anonyme
 Posté le 24/06/2010 à 22:34
craimon
Pour etre aider, il faut respecter quelques régles de base de PCastuces.
Peux tu commencer par là s'il t plait.
1- Dans ton premier message clique sur la feuille blanche avec un crayon et modifie ton titre:
"Clés registre inféctées"
2- Suis ce tuto de nardino, écrit sur papier ou imprimer,en cas de doutes reviens poser tes questions avant toute manipulation hasardeuse.
https://forum.pcastuces.com/aide_au_diagnostic_un_pc_infecte_pcastuces-f25s17490.htm
3- Poste les rapports et attend patiement qu'un membre GS te donne la suite.
bonne continuation
craimon
 Posté le 24/06/2010 à 23:34
ok s il y a une prochaine fois je ferais cela les choses correctement !!
en a tant aider moi merci d'avance
craimon
 Posté le 25/06/2010 à 10:09
bonjour avez vous trouver un truc pour m'aider !!? merci d'avance :-)
Anonyme
 Posté le 25/06/2010 à 11:07
craimon
Bah oui
tu attends quoi pour poster les rapports démandés dans mon post plus haut.
Tant que tu ne fais pas ça, on ne peux pas deviner ce que ton pc as.
Je te remets le lien,tu cliques dessus et tu fais un RSIT tu postes log.txt et info.txt ainsi que une analyse Malwarebytes (mettre à jour avant le scan) le tout est en images
Bonne continuation
craimon
 Posté le 25/06/2010 à 11:51
info.txt logfile of random's system information tool 1.06 2010-06-25 11:33:37
======Uninstall list======
-->C:\Documents and Settings\All Users\Application Data\DivX\DivX7\DivX Converter\DivXConverterUninstall.exe /CONVERTER
-->MsiExec /X{A7E07C2B-2220-4415-87E3-784D5814BC93}
-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{15B3F9F8-4CF9-452A-9AF2-AA8553765DA7}\setup.exe" -l0x40c
-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{2C81600D-D6C7-4687-9362-DD4A78B3483E}\setup.exe" -l0x40c
-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{513D9FB1-27A2-44E4-8F2D-77A6737921A5}\setup.exe" -l0x40c
-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{63A317D0-60A6-43FC-848A-9FE4A53B29CE}\setup.exe" -l0x40c
-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{6BE926E5-66F4-4166-A5E5-E14D7A165BBD}\setup.exe" -l0x40c
-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{88B1984E-36F0-47B8-B8DC-728966807A9C}\SETUP.EXE" -l0x40c
-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{A82F10CB-18B5-4EAC-AEF2-FA49CD565626}\setup.exe" -l0x40c
-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{D5BA7C09-E523-478C-9C37-A1D86C76383E}\setup.exe" -l0x40c
-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{EAF97B2C-0B9B-403C-829C-EF8099237DA9}\setup.exe" -l0x40c
-->rundll32.exe setupapi.dll,InstallHinfSection DefaultUninstall 132 C:\WINDOWS\INF\PCHealth.inf
3ivx D4 4.5.1 (remove only)-->"C:\Program Files\3ivx\3ivx D4 4.5.1\uninstall.exe"
AC-3 ACM Decompressor-->C:\WINDOWS\system32\rundll32.exe setupapi,InstallHinfSection DefaultUninstall 132 C:\WINDOWS\INF\AC3ACM.inf
AC3Filter (remove only)-->C:\Program Files\MUSK Codec Pack v6\\AC3 Filter\INST\uninstall.exe
Adobe Flash Player 10 ActiveX-->C:\WINDOWS\system32\Macromed\Flash\uninstall_activeX.exe
Adobe Flash Player 10 Plugin-->C:\WINDOWS\system32\Macromed\Flash\FlashUtil10h_Plugin.exe -maintain plugin
Adobe Flash Player 9 ActiveX-->C:\WINDOWS\system32\Macromed\Flash\FlashUtil9b.exe -uninstallDelete
Adobe Reader 9.3.2 - Français-->MsiExec.exe /I{AC76BA86-7AD7-1036-7B44-A93000000001}
Advanced Video FX Engine-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{D5BA7C09-E523-478C-9C37-A1D86C76383E}\setup.exe" -l0x40c /remove
AMD Processor Driver-->C:\Program Files\InstallShield Installation Information\{C151CE54-E7EA-4804-854B-F515368B0798}\setup.exe -runfromtemp -l0x040c -removeonly
Apple Application Support-->MsiExec.exe /I{553255F3-78FD-40F1-A6F8-6882140265FE}
Archiveur WinRAR-->C:\Program Files\WinRAR\uninstall.exe
Assistant de connexion Windows Live-->MsiExec.exe /I{D3116CC7-24DC-4CA3-9CE1-23FED836E9F2}
avast! Antivirus-->C:\Program Files\Alwil Software\Avast4\aswRunDll.exe "C:\Program Files\Alwil Software\Avast4\Setup\setiface.dll",RunSetup
Brother MFL-Pro Suite-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\PROFES~1\RunTime\11\00\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{9A912C12-A7DA-44D7-BD57-5CA85E2F33E1}\Setup.exe" -l0x40c Brunin03.dll -removeonly
CCleaner (remove only)-->"C:\Program Files\CCleaner\uninst.exe"
CDBurnerXP-->"C:\Program Files\CDBurnerXP\unins000.exe"
Configuration DivX-->C:\Documents and Settings\All Users\Application Data\DivX\Setup\DivXSetup.exe /uninstall /bundleGroupId divx.com
ConvertHelper 2.2-->"C:\Program Files\ConvertHelper\unins000.exe"
Correctif pour Lecteur Windows Media 11 (KB939683)-->"C:\WINDOWS\$NtUninstallKB939683$\spuninst\spuninst.exe"
Correctif pour Windows XP (KB952287)-->"C:\WINDOWS\$NtUninstallKB952287$\spuninst\spuninst.exe"
Correctif pour Windows XP (KB961118)-->"C:\WINDOWS\$NtUninstallKB961118$\spuninst\spuninst.exe"
Correctif pour Windows XP (KB970653-v3)-->"C:\WINDOWS\$NtUninstallKB970653-v3$\spuninst\spuninst.exe"
Correctif pour Windows XP (KB976098-v2)-->"C:\WINDOWS\$NtUninstallKB976098-v2$\spuninst\spuninst.exe"
Correctif pour Windows XP (KB979306)-->"C:\WINDOWS\$NtUninstallKB979306$\spuninst\spuninst.exe"
Correctif pour Windows XP (KB981793)-->"C:\WINDOWS\$NtUninstallKB981793$\spuninst\spuninst.exe"
Creative Live! Cam Center-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{6BE926E5-66F4-4166-A5E5-E14D7A165BBD}\setup.exe" -l0x40c /remove
Creative Live! Cam Manager-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{15B3F9F8-4CF9-452A-9AF2-AA8553765DA7}\setup.exe" -l0x40c /remove
Creative Live! Cam Video IM Driver (1.00.07.00)-->C:\WINDOWS\CtDrvIns.exe -uninstall -script VF0220.uns -unsext NT -plugin V0220Pin.dll -pluginres CtCamPin.crl
Creative Photo Calendar-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{2C81600D-D6C7-4687-9362-DD4A78B3483E}\setup.exe" -l0x40c /remove
Creative Photo Manager-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{513D9FB1-27A2-44E4-8F2D-77A6737921A5}\setup.exe" -l0x40c /remove
Creative Software AutoUpdate-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{88B1984E-36F0-47B8-B8DC-728966807A9C}\SETUP.EXE" -l0x40c /remove
Creative System Information-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{63A317D0-60A6-43FC-848A-9FE4A53B29CE}\setup.exe" -l0x40c /remove
DivX Codec-->C:\Documents and Settings\All Users\Application Data\DivX\DivX7\DivX Codec\DivXCodecUninstall.exe /CODEC
DivX Converter-->C:\Documents and Settings\All Users\Application Data\DivX\DivX7\DivX Converter\DivXConverterUninstall.exe /CONVERTER
DivX Plus DirectShow Filters-->C:\Documents and Settings\All Users\Application Data\DivX\DivX7\DivX Plus DirectShow Filters\DivXDSFiltersUninstall.exe /DSFILTERS
Glary Utilities 2.10.0.622-->"C:\Program Files\Glary Utilities\unins000.exe"
Google Gmail Notifier-->"C:\Program Files\Google\Gmail Notifier\UninstallGmail.exe"
Hotfix for Microsoft .NET Framework 3.5 SP1 (KB953595)-->C:\WINDOWS\system32\msiexec.exe /package {CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9} /uninstall /qb+ REBOOTPROMPT=""
Hotfix for Microsoft .NET Framework 3.5 SP1 (KB958484)-->C:\WINDOWS\system32\msiexec.exe /package {CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9} /uninstall {A7EEA2F2-BFCD-4A54-A575-7B81A786E658} /qb+ REBOOTPROMPT=""
Hotfix for Windows Media Format 11 SDK (KB929399)-->"C:\WINDOWS\$NtUninstallKB929399$\spuninst\spuninst.exe"
HP Flat Panel Monitor INF Software 3.00-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{EBA0C587-D976-4D71-8976-0743EDE14F10}\Setup.exe" -l0x40c
Installation Windows Live-->C:\Program Files\Windows Live\Installer\wlarp.exe
Installation Windows Live-->MsiExec.exe /I{46ABBC54-1872-4AA3-95E2-F2C063A63F31}
Installer Yahoo! Messenger-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{EAF97B2C-0B9B-403C-829C-EF8099237DA9}\setup.exe" -l0x40c /remove
Java(TM) 6 Update 20-->MsiExec.exe /X{26A24AE4-039D-4CA4-87B4-2F83216020FF}
Junk Mail filter update-->MsiExec.exe /I{E2DFE069-083E-4631-9B6C-43C48E991DE5}
Lecteur Windows Media 11-->"C:\Program Files\Windows Media Player\Setup_wm.exe" /Uninstall
LiveUpdate 3.2 (Symantec Corporation)-->"C:\Program Files\Symantec\LiveUpdate\LSETUP.EXE" /U
Ma-Config.com-->MsiExec.exe /X{6C4D4FC0-467B-4BD7-8D11-50E49B2770D2}
Magic ISO Maker v5.3 (build 0214)-->C:\PROGRA~1\MagicISO\UNWISE.EXE C:\PROGRA~1\MagicISO\INSTALL.LOG
MagicDisc 2.5.79-->C:\PROGRA~1\MAGICD~1\UNWISE.EXE C:\PROGRA~1\MAGICD~1\INSTALL.LOG
Malwarebytes' Anti-Malware-->"C:\Program Files\Malwarebytes' Anti-Malware\unins000.exe"
Manuel d'utilisation de Creative Live! Cam Video IM (Français)-->C:\WINDOWS\IsUn040c.exe -f"C:\Program Files\Creative\Creative Live! Cam Video IM\Manuel d'utilisation de Creative Live! Cam Video IM\French\CTManual.isu"
Messager Wanadoo-->C:\PROGRA~1\MESSAG~1\Uninstall.exe
Microsoft .NET Framework 2.0 Service Pack 2-->MsiExec.exe /I{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}
Microsoft .NET Framework 3.0 Service Pack 2-->MsiExec.exe /I{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}
Microsoft .NET Framework 3.5 SP1-->C:\WINDOWS\Microsoft.NET\Framework\v3.5\Microsoft .NET Framework 3.5 SP1\setup.exe
Microsoft .NET Framework 3.5 SP1-->MsiExec.exe /I{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}
Microsoft Choice Guard-->MsiExec.exe /X{F0E12BBA-AD66-4022-A453-A1C8A0C4D570}
Microsoft Compression Client Pack 1.0 for Windows XP-->"C:\WINDOWS\$NtUninstallMSCompPackV1$\spuninst\spuninst.exe"
Microsoft Office Excel Viewer 2003-->MsiExec.exe /I{9084040C-6000-11D3-8CFE-0150048383C9}
Microsoft Office PowerPoint Viewer 2003-->MsiExec.exe /X{90AF040C-6000-11D3-8CFE-0150048383C9}
Microsoft Office Word Viewer 2003-->MsiExec.exe /I{9085040C-6000-11D3-8CFE-0150048383C9}
Microsoft Search Enhancement Pack-->MsiExec.exe /X{4CBA3D4C-8F51-4D60-B27E-F6B641C571E7}
Microsoft Silverlight-->MsiExec.exe /X{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}
Microsoft User-Mode Driver Framework Feature Pack 1.7-->"C:\WINDOWS\$NtUninstallWudf01007$\spuninst\spuninst.exe"
Microsoft Visual C++ 2005 ATL Update kb973923 - x86 8.0.50727.4053-->MsiExec.exe /X{770657D0-A123-3C07-8E44-1C83EC895118}
Microsoft Visual C++ 2005 Redistributable-->MsiExec.exe /X{837b34e3-7c30-493c-8f6a-2b0f04e2912c}
Microsoft Visual C++ 2008 ATL Update kb973924 - x86 9.0.30729.4148-->MsiExec.exe /X{002D9D5E-29BA-3E6D-9BC4-3D7D6DBC735C}
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17-->MsiExec.exe /X{9A25302D-30C0-39D9-BD6F-21E6EC160475}
Mise à jour critique pour Lecteur Windows Media 11 (KB959772)-->"C:\WINDOWS\$NtUninstallKB959772_WM11$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Lecteur Windows Media (KB952069)-->"C:\WINDOWS\$NtUninstallKB952069_WM9$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Lecteur Windows Media (KB954155)-->"C:\WINDOWS\$NtUninstallKB954155_WM9$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Lecteur Windows Media (KB968816)-->"C:\WINDOWS\$NtUninstallKB968816_WM9$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Lecteur Windows Media (KB973540)-->"C:\WINDOWS\$NtUninstallKB973540_WM9$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Lecteur Windows Media (KB978695)-->"C:\WINDOWS\$NtUninstallKB978695_WM9$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Lecteur Windows Media 11 (KB936782)-->"C:\WINDOWS\$NtUninstallKB936782_WMP11$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Lecteur Windows Media 11 (KB954154)-->"C:\WINDOWS\$NtUninstallKB954154_WM11$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows Internet Explorer 7 (KB938127-v2)-->"C:\WINDOWS\ie7updates\KB938127-v2-IE7\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows Internet Explorer 7 (KB969897)-->"C:\WINDOWS\ie7updates\KB969897-IE7\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows Internet Explorer 8 (KB969897)-->"C:\WINDOWS\ie8updates\KB969897-IE8\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows Internet Explorer 8 (KB971961)-->"C:\WINDOWS\ie8updates\KB971961-IE8\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows Internet Explorer 8 (KB972260)-->"C:\WINDOWS\ie8updates\KB972260-IE8\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows Internet Explorer 8 (KB974455)-->"C:\WINDOWS\ie8updates\KB974455-IE8\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows Internet Explorer 8 (KB976325)-->"C:\WINDOWS\ie8updates\KB976325-IE8\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows Internet Explorer 8 (KB978207)-->"C:\WINDOWS\ie8updates\KB978207-IE8\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows Internet Explorer 8 (KB981332)-->"C:\WINDOWS\ie8updates\KB981332-IE8\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows Internet Explorer 8 (KB982381)-->"C:\WINDOWS\ie8updates\KB982381-IE8\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB923561)-->"C:\WINDOWS\$NtUninstallKB923561$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB938464-v2)-->"C:\WINDOWS\$NtUninstallKB938464-v2$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB941569)-->"C:\WINDOWS\$NtUninstallKB941569$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB946648)-->"C:\WINDOWS\$NtUninstallKB946648$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB950760)-->"C:\WINDOWS\$NtUninstallKB950760$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB950762)-->"C:\WINDOWS\$NtUninstallKB950762$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB950974)-->"C:\WINDOWS\$NtUninstallKB950974$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB951066)-->"C:\WINDOWS\$NtUninstallKB951066$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB951376-v2)-->"C:\WINDOWS\$NtUninstallKB951376-v2$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB951748)-->"C:\WINDOWS\$NtUninstallKB951748$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB952004)-->"C:\WINDOWS\$NtUninstallKB952004$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB952954)-->"C:\WINDOWS\$NtUninstallKB952954$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB954459)-->"C:\WINDOWS\$NtUninstallKB954459$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB954600)-->"C:\WINDOWS\$NtUninstallKB954600$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB955069)-->"C:\WINDOWS\$NtUninstallKB955069$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB956572)-->"C:\WINDOWS\$NtUninstallKB956572$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB956744)-->"C:\WINDOWS\$NtUninstallKB956744$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB956802)-->"C:\WINDOWS\$NtUninstallKB956802$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB956803)-->"C:\WINDOWS\$NtUninstallKB956803$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB956844)-->"C:\WINDOWS\$NtUninstallKB956844$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB957097)-->"C:\WINDOWS\$NtUninstallKB957097$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB958644)-->"C:\WINDOWS\$NtUninstallKB958644$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB958687)-->"C:\WINDOWS\$NtUninstallKB958687$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB958869)-->"C:\WINDOWS\$NtUninstallKB958869$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB959426)-->"C:\WINDOWS\$NtUninstallKB959426$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB960225)-->"C:\WINDOWS\$NtUninstallKB960225$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB960803)-->"C:\WINDOWS\$NtUninstallKB960803$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB960859)-->"C:\WINDOWS\$NtUninstallKB960859$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB961371)-->"C:\WINDOWS\$NtUninstallKB961371$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB961373)-->"C:\WINDOWS\$NtUninstallKB961373$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB961501)-->"C:\WINDOWS\$NtUninstallKB961501$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB968537)-->"C:\WINDOWS\$NtUninstallKB968537$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB969059)-->"C:\WINDOWS\$NtUninstallKB969059$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB969898)-->"C:\WINDOWS\$NtUninstallKB969898$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB969947)-->"C:\WINDOWS\$NtUninstallKB969947$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB970238)-->"C:\WINDOWS\$NtUninstallKB970238$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB970430)-->"C:\WINDOWS\$NtUninstallKB970430$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB971468)-->"C:\WINDOWS\$NtUninstallKB971468$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB971486)-->"C:\WINDOWS\$NtUninstallKB971486$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB971557)-->"C:\WINDOWS\$NtUninstallKB971557$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB971633)-->"C:\WINDOWS\$NtUninstallKB971633$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB971657)-->"C:\WINDOWS\$NtUninstallKB971657$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB972270)-->"C:\WINDOWS\$NtUninstallKB972270$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB973346)-->"C:\WINDOWS\$NtUninstallKB973346$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB973354)-->"C:\WINDOWS\$NtUninstallKB973354$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB973507)-->"C:\WINDOWS\$NtUninstallKB973507$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB973525)-->"C:\WINDOWS\$NtUninstallKB973525$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB973869)-->"C:\WINDOWS\$NtUninstallKB973869$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB973904)-->"C:\WINDOWS\$NtUninstallKB973904$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB974112)-->"C:\WINDOWS\$NtUninstallKB974112$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB974318)-->"C:\WINDOWS\$NtUninstallKB974318$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB974392)-->"C:\WINDOWS\$NtUninstallKB974392$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB974571)-->"C:\WINDOWS\$NtUninstallKB974571$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB975025)-->"C:\WINDOWS\$NtUninstallKB975025$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB975467)-->"C:\WINDOWS\$NtUninstallKB975467$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB975560)-->"C:\WINDOWS\$NtUninstallKB975560$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB975561)-->"C:\WINDOWS\$NtUninstallKB975561$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB975562)-->"C:\WINDOWS\$NtUninstallKB975562$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB975713)-->"C:\WINDOWS\$NtUninstallKB975713$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB977165)-->"C:\WINDOWS\$NtUninstallKB977165$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB977816)-->"C:\WINDOWS\$NtUninstallKB977816$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB977914)-->"C:\WINDOWS\$NtUninstallKB977914$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB978037)-->"C:\WINDOWS\$NtUninstallKB978037$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB978251)-->"C:\WINDOWS\$NtUninstallKB978251$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB978262)-->"C:\WINDOWS\$NtUninstallKB978262$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB978338)-->"C:\WINDOWS\$NtUninstallKB978338$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB978542)-->"C:\WINDOWS\$NtUninstallKB978542$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB978601)-->"C:\WINDOWS\$NtUninstallKB978601$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB978706)-->"C:\WINDOWS\$NtUninstallKB978706$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB979309)-->"C:\WINDOWS\$NtUninstallKB979309$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB979482)-->"C:\WINDOWS\$NtUninstallKB979482$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB979559)-->"C:\WINDOWS\$NtUninstallKB979559$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB979683)-->"C:\WINDOWS\$NtUninstallKB979683$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB980195)-->"C:\WINDOWS\$NtUninstallKB980195$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB980218)-->"C:\WINDOWS\$NtUninstallKB980218$\spuninst\spuninst.exe"
Mise à jour de sécurité pour Windows XP (KB980232)-->"C:\WINDOWS\$NtUninstallKB980232$\spuninst\spuninst.exe"
Mise à jour pour Windows Internet Explorer 8 (KB971180)-->"C:\WINDOWS\ie8updates\KB971180-IE8\spuninst\spuninst.exe"
Mise à jour pour Windows Internet Explorer 8 (KB976662)-->"C:\WINDOWS\ie8updates\KB976662-IE8\spuninst\spuninst.exe"
Mise à jour pour Windows Internet Explorer 8 (KB976749)-->"C:\WINDOWS\ie8updates\KB976749-IE8\spuninst\spuninst.exe"
Mise à jour pour Windows Internet Explorer 8 (KB980182)-->"C:\WINDOWS\ie8updates\KB980182-IE8\spuninst\spuninst.exe"
Mise à jour pour Windows XP (KB898461)-->"C:\WINDOWS\$NtUninstallKB898461$\spuninst\spuninst.exe"
Mise à jour pour Windows XP (KB951978)-->"C:\WINDOWS\$NtUninstallKB951978$\spuninst\spuninst.exe"
Mise à jour pour Windows XP (KB955759)-->"C:\WINDOWS\$NtUninstallKB955759$\spuninst\spuninst.exe"
Mise à jour pour Windows XP (KB955839)-->"C:\WINDOWS\$NtUninstallKB955839$\spuninst\spuninst.exe"
Mise à jour pour Windows XP (KB961503)-->"C:\WINDOWS\$NtUninstallKB961503$\spuninst\spuninst.exe"
Mise à jour pour Windows XP (KB967715)-->"C:\WINDOWS\$NtUninstallKB967715$\spuninst\spuninst.exe"
Mise à jour pour Windows XP (KB968389)-->"C:\WINDOWS\$NtUninstallKB968389$\spuninst\spuninst.exe"
Mise à jour pour Windows XP (KB971737)-->"C:\WINDOWS\$NtUninstallKB971737$\spuninst\spuninst.exe"
Mise à jour pour Windows XP (KB973687)-->"C:\WINDOWS\$NtUninstallKB973687$\spuninst\spuninst.exe"
Mise à jour pour Windows XP (KB973815)-->"C:\WINDOWS\$NtUninstallKB973815$\spuninst\spuninst.exe"
Mozilla Firefox (3.6.4)-->C:\Program Files\Mozilla Firefox\uninstall\helper.exe
MSVC80_x86_v2-->MsiExec.exe /I{6D3245B1-8DB8-4A23-9CD2-2C90F40ABAF6}
MSVCRT-->MsiExec.exe /I{22B775E7-6C42-4FC5-8E10-9A5E3257BD94}
MUSK Codec Pack v6.0-->"C:\Program Files\MUSK Codec Pack v6\unins000.exe"
Nero OEM-->C:\Program Files\Ahead\nero\uninstall\UNNERO.exe /UNINSTALL
Nokia Connectivity Cable Driver-->MsiExec.exe /I{6869591A-7DD8-46D2-837F-57CBF7358955}
Norton Ghost-->MsiExec.exe /I{B0255743-165B-4BD5-8DA8-37DFB9930012}
NVIDIA Drivers-->C:\WINDOWS\system32\nvuninst.exe UninstallGUI
NVIDIA PhysX v8.09.04-->MsiExec.exe /X{A7E07C2B-2220-4415-87E3-784D5814BC93}
O&O Defrag Professional-->MsiExec.exe /I{9BF0F3CE-4964-4E4E-9BF6-DEC77FE86DEA}
On2 VP7 Personal Edition-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{DD0DDC9E-2ED4-44DD-B461-0EFC126813A0}\Setup.exe" -l0x9
OpenOffice.org 3.1-->MsiExec.exe /I{B2E581DB-C4DD-432C-AC84-ED761AC056BC}
Orange - Logiciels Internet-->C:\Program Files\OrangeHSS\installation\core\Installgui.exe -u
Outil de téléchargement Windows Live-->MsiExec.exe /I{205C6BDD-7B73-42DE-8505-9A093F35A238}
Package de pilotes Windows - Nokia pccsmcfd (08/22/2008 7.0.0.0)-->C:\PROGRA~1\DIFX\B4723E9A0713E5B1\dpinst.exe /u C:\WINDOWS\system32\DRVSTORE\pccsmcfd_A3B3916E5D8138F59EE218321B27B044D3B18294\pccsmcfd.inf
PC Connectivity Solution-->MsiExec.exe /I{6E0352EE-6F0D-4FBC-B1B8-4FF032C78BE0}
PowerDVD-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{6811CAA0-BF12-11D4-9EA1-0050BAE317E1}\Setup.exe" -uninstall
QuickTime Alternative 1.56-->"C:\Program Files\MUSK Codec Pack v6\QT\INST\unins000.exe"
RDesc 2.31-->"C:\RDesc\unins000.exe"
Realtek High Definition Audio Driver-->RunDll32 C:\PROGRA~1\FICHIE~1\INSTAL~1\PROFES~1\RunTime\11\50\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}\SETUP.EXE" -l0x40c -removeonly
Segoe UI-->MsiExec.exe /I{A1F66FC9-11EE-4F2F-98C9-16F8D1E69FB7}
SightSpeed-->C:\Program Files\SightSpeed\uninst.exe
Spelling Dictionaries Support For Adobe Reader 9-->MsiExec.exe /I{AC76BA86-7AD7-5464-3428-900000000004}
Spybot - Search & Destroy-->"C:\Program Files\Spybot - Search & Destroy\unins000.exe"
System Requirements Lab-->C:\Program Files\SystemRequirementsLab\Uninstall.exe
Unlocker 1.8.7-->C:\Program Files\Unlocker\uninst.exe
Update for Microsoft .NET Framework 3.5 SP1 (KB963707)-->C:\WINDOWS\system32\msiexec.exe /package {CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9} /uninstall {B2AE9C82-DC7B-3641-BFC8-87275C4F3607} /qb+ REBOOTPROMPT=""
VC80CRTRedist - 8.0.50727.4053-->MsiExec.exe /I{5EE7D259-D137-4438-9A5F-42F432EC0421}
VLC media player 1.0.1-->C:\Program Files\VideoLAN\VLC\uninstall.exe
Windows Internet Explorer 8-->"C:\WINDOWS\ie8\spuninst\spuninst.exe"
Windows Live Call-->MsiExec.exe /I{82C7B308-0BDD-49D8-8EA5-9CD3A3F9DF41}
Windows Live Communications Platform-->MsiExec.exe /I{ED00D08A-3C5F-488D-93A0-A04F21F23956}
Windows Live FolderShare-->MsiExec.exe /X{2075CB0A-D26F-4DAA-B424-5079296B43BA}
Windows Live Mail-->MsiExec.exe /I{5DD76286-9BE7-4894-A990-E905E91AC818}
Windows Live Messenger-->MsiExec.exe /X{770F1BEC-2871-4E70-B837-FB8525FFA3B1}
Windows Media Format 11 runtime-->"C:\Program Files\Windows Media Player\wmsetsdk.exe" /UninstallAll
Windows Media Format 11 runtime-->"C:\WINDOWS\$NtUninstallWMFDist11$\spuninst\spuninst.exe"
Windows Media Player 11-->"C:\WINDOWS\$NtUninstallwmp11$\spuninst\spuninst.exe"
Windows Media Player Firefox Plugin-->MsiExec.exe /I{69FDFBB6-351D-4B8C-89D8-867DC9D0A2A4}
Xvid 1.2.1 final uninstall-->"C:\Program Files\MUSK Codec Pack v6\XviD\INST\unins000.exe"
======Hosts File======
127.0.0.1 www.007guard.com
127.0.0.1 007guard.com
127.0.0.1 008i.com
127.0.0.1 www.008k.com
127.0.0.1 008k.com
127.0.0.1 www.00hq.com
127.0.0.1 00hq.com
127.0.0.1 010402.com
127.0.0.1 www.032439.com
127.0.0.1 032439.com
======Security center information======
AV: avast! antivirus 4.8.1368 [VPS 100624-1]
======System event log======
Computer Name: PC
Event Code: 51
Message: Une erreur a été détectée sur le périphérique \Device\Harddisk2\D au cours d'une opération de pagination.
Record Number: 15798
Source Name: Disk
Time Written: 20100602002619.000000+120
Event Type: Avertissement
User:
Computer Name: PC
Event Code: 51
Record Number: 15797
Source Name: Disk
User:
Computer Name: PC
Event Code: 51
Record Number: 15796
Source Name: Disk
User:
Computer Name: PC
Event Code: 51
Record Number: 15795
Source Name: Disk
User:
Computer Name: PC
Event Code: 51
Record Number: 15794
Source Name: Disk
User:
=====Application event log=====
Computer Name: PC
Event Code: 101
Message: Niveau d'information : success
L'exécution suivante a été planifiée pour intervenir approximativement à 2:26 AM.
Record Number: 5262
Source Name: Automatic LiveUpdate Scheduler
Time Written: 20100313220733.000000+060
Event Type: Informations
User: AUTORITE NT\SYSTEM
Computer Name: PC
Event Code: 101
LiveUpdate automatique a terminé.
Record Number: 5261
Computer Name: PC
Event Code: 101
Le Planificateur a lancé LiveUpdate automatique.
Record Number: 5260
Time Written: 20100313220723.000000+060
Computer Name: PC
Event Code: 101
L'exécution suivante a été planifiée pour intervenir approximativement à 10:07 PM.
Record Number: 5259
Time Written: 20100313182547.000000+060
Computer Name: PC
Event Code: 101
Record Number: 5258
======Environment variables======
"ComSpec"=%SystemRoot%\system32\cmd.exe
"Path"=C:\Program Files\PC Connectivity Solution\;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;C:\Program Files\Fichiers communs\DivX Shared\
"windir"=%SystemRoot%
"FP_NO_HOST_CHECK"=NO
"OS"=Windows_NT
"PROCESSOR_ARCHITECTURE"=x86
"PROCESSOR_LEVEL"=15
"PROCESSOR_IDENTIFIER"=x86 Family 15 Model 107 Stepping 2, AuthenticAMD
"PROCESSOR_REVISION"=6b02
"NUMBER_OF_PROCESSORS"=2
"PATHEXT"=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
"TEMP"=%SystemRoot%\TEMP
"TMP"=%SystemRoot%\TEMP
-----------------EOF-----------------
craimon
 Posté le 25/06/2010 à 11:53
Logfile of random's system information tool 1.07 (written by random/random)
Run by Administrateur at 2010-06-25 11:33:26
Microsoft Windows XP Professionnel Service Pack 3
System drive C: has 293 GB (96%) free of 305 GB
Total RAM: 2047 MB (63% free)
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 11:33:36, on 25/06/2010
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v8.00 (8.00.6001.18702)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\RTHDCPL.EXE
C:\WINDOWS\system32\RUNDLL32.EXE
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\PROGRA~1\MESSAG~1\StartMessager.exe
C:\Program Files\Microsoft IntelliType Pro\type32.exe
C:\Program Files\Microsoft IntelliPoint\point32.exe
C:\Program Files\Google\Gmail Notifier\gnotify.exe
C:\Program Files\Norton Ghost\Agent\VProTray.exe
C:\Program Files\Unlocker\UnlockerAssistant.exe
C:\Program Files\Creative\Creative Live! Cam\VideoFX\StartFX.exe
C:\WINDOWS\V0220Mon.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\OrangeHSS\Launcher\Launcher.exe
C:\Program Files\Fichiers communs\Java\Java Update\jusched.exe
C:\Program Files\DivX\DivX Update\DivXUpdate.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Messenger\msmsgs.exe
C:\Program Files\Windows Live\Messenger\msnmsgr.exe
C:\Program Files\Creative\Creative Live! Cam\Live! Cam Manager\CTLCMgr.exe
C:\PROGRA~1\FICHIE~1\France Telecom\Shared Modules\AlertModule\0\AlertModule.exe
C:\Program Files\MagicDisc\MagicDisc.exe
C:\Program Files\OpenOffice.org 3\program\soffice.exe
C:\PROGRA~1\FICHIE~1\France Telecom\Shared Modules\FTRTSVC\0\FTRTSVC.exe
C:\Program Files\Java\jre6\bin\jqs.exe
C:\Program Files\OpenOffice.org 3\program\soffice.bin
C:\Program Files\CDBurnerXP\NMSAccessU.exe
C:\Program Files\Norton Ghost\Agent\VProSvc.exe
C:\WINDOWS\system32\nvsvc32.exe
C:\Program Files\OO Software\Defrag\oodag.exe
C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
C:\Program Files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe
C:\Program Files\OrangeHSS\systray\systrayapp.exe
C:\Program Files\Windows Live\Contacts\wlcomm.exe
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\WINDOWS\system32\wbem\wmiapsrv.exe
C:\Program Files\OrangeHSS\Deskboard\deskboard.exe
C:\Program Files\OrangeHSS\connectivity\connectivitymanager.exe
C:\Program Files\OrangeHSS\connectivity\CoreCom\CoreCom.exe
C:\Program Files\OrangeHSS\connectivity\CoreCom\OraConfigRecover.exe
C:\PROGRA~1\FICHIE~1\France Telecom\Shared Modules\FTCOMModule\0\FTCOMModule.exe
C:\Program Files\Mozilla Firefox\firefox.exe
C:\Program Files\Mozilla Firefox\plugin-container.exe
C:\Documents and Settings\Administrateur\Mes documents\Téléchargements\RSIT.exe
C:\Program Files\trend micro\Administrateur.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://search.ke.voila.fr/S/voila?kw=
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = www.orange.fr
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Liens
R3 - URLSearchHook: Search Class - {08C06D61-F1F3-4799-86F8-BE1A89362C85} - C:\Program Files\OrangeHSS\SearchURLHook\SearchPageURL.dll
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Fichiers communs\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O2 - BHO: (no name) - {5C255C8A-E604-49b4-9D64-90988571CECB} - (no file)
O2 - BHO: Search Helper - {6EBF7485-159F-4bff-A14F-B9E3AAC4465B} - C:\Program Files\Microsoft\Search Enhancement Pack\Search Helper\SEPsearchhelperie.dll
O2 - BHO: Programme d'aide de l'Assistant de connexion Windows Live - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Fichiers communs\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [RTHDCPL] RTHDCPL.EXE
O4 - HKLM\..\Run: [Alcmtr] ALCMTR.EXE
O4 - HKLM\..\Run: [WinSys2] C:\WINDOWS\system32\winsys2.exe
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [MessagerStarter Wanadoo] C:\PROGRA~1\MESSAG~1\StartMessager.exe Messager Wanadoo
O4 - HKLM\..\Run: [type32] "C:\Program Files\Microsoft IntelliType Pro\type32.exe"
O4 - HKLM\..\Run: [IntelliPoint] "C:\Program Files\Microsoft IntelliPoint\point32.exe"
O4 - HKLM\..\Run: [{0228e555-4f9c-4e35-a3ec-b109a192b4c2}] C:\Program Files\Google\Gmail Notifier\gnotify.exe
O4 - HKLM\..\Run: [BluetoothAuthenticationAgent] rundll32.exe bthprops.cpl,,BluetoothAuthenticationAgent
O4 - HKLM\..\Run: [BrMfcWnd] C:\Program Files\Brother\Brmfcmon\BrMfcWnd.exe /AUTORUN
O4 - HKLM\..\Run: [SetDefPrt] C:\Program Files\Brother\Brmfl06a\BrStDvPt.exe
O4 - HKLM\..\Run: [ControlCenter3] C:\Program Files\Brother\ControlCenter3\brctrcen.exe /autorun
O4 - HKLM\..\Run: [Norton Ghost 12.0] "C:\Program Files\Norton Ghost\Agent\VProTray.exe"
O4 - HKLM\..\Run: [UnlockerAssistant] "C:\Program Files\Unlocker\UnlockerAssistant.exe" -H
O4 - HKLM\..\Run: [ORAHSSSessionManager] "C:\Program Files\OrangeHSS\SessionManager\SessionManager.exe"
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files\Fichiers communs\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKLM\..\Run: [AVFX Engine] C:\Program Files\Creative\Creative Live! Cam\VideoFX\StartFX.exe
O4 - HKLM\..\Run: [V0220Mon.exe] C:\WINDOWS\V0220Mon.exe
O4 - HKLM\..\Run: [OODefragTray] C:\Program Files\OO Software\Defrag\oodtray.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Fichiers communs\Java\Java Update\jusched.exe"
O4 - HKLM\..\Run: [DivXUpdate] "C:\Program Files\DivX\DivX Update\DivXUpdate.exe" /CHECKNOW
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\Windows Live\Messenger\msnmsgr.exe" /background
O4 - HKCU\..\Run: [Creative Live! Cam Manager] "C:\Program Files\Creative\Creative Live! Cam\Live! Cam Manager\CTLCMgr.exe"
O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SERVICE LOCAL')
O4 - HKUS\S-1-5-19\..\RunOnce: [nltide_3] rundll32 advpack.dll,LaunchINFSectionEx nLite.inf,C,,4,N (User 'SERVICE LOCAL')
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SERVICE RÉSEAU')
O4 - HKUS\S-1-5-20\..\RunOnce: [nltide_3] rundll32 advpack.dll,LaunchINFSectionEx nLite.inf,C,,4,N (User 'SERVICE RÉSEAU')
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\S-1-5-18\..\RunOnce: [nltide_3] rundll32 advpack.dll,LaunchINFSectionEx nLite.inf,C,,4,N (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user')
O4 - HKUS\.DEFAULT\..\RunOnce: [nltide_3] rundll32 advpack.dll,LaunchINFSectionEx nLite.inf,C,,4,N (User 'Default user')
O4 - Startup: MagicDisc.lnk = C:\Program Files\MagicDisc\MagicDisc.exe
O4 - Startup: OpenOffice.org 3.1.lnk = C:\Program Files\OpenOffice.org 3\program\quickstart.exe
O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra button: Wanadoo - {1462651F-F4BA-4C76-A001-C4284D0FE16E} - http://www.wanadoo.fr (file missing) (HKCU)
O15 - Trusted Zone: http://*.mappy.com
O15 - Trusted Zone: http://*.orange.fr
O15 - Trusted Zone: http://rw.search.ke.voila.fr
O15 - Trusted Zone: http://orange.weborama.fr
O16 - DPF: {F6ACF75C-C32C-447B-9BEF-46B766368D29} (Creative Software AutoUpdate Support Package) - http://ccfiles.creative.com/Web/softwareupdate/su2/ocx/15112/CTPID.cab
O22 - SharedTaskScheduler: Pré-chargeur Browseui - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\system32\browseui.dll
O22 - SharedTaskScheduler: Démon de cache des catégories de composant - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\system32\browseui.dll
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - ALWIL Software - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: avast! Antivirus - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
O23 - Service: Service d'administration du Gestionnaire de disque logique (dmadmin) - Unknown owner - C:\WINDOWS\System32\dmadmin.exe
O23 - Service: Journal des événements (Eventlog) - Unknown owner - C:\WINDOWS\system32\services.exe
O23 - Service: France Telecom Routing Table Service (FTRTSVC) - Unknown owner - C:\PROGRA~1\FICHIE~1\France Telecom\Shared Modules\FTRTSVC\0\FTRTSVC.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Fichiers communs\InstallShield\Driver\1150\Intel 32\IDriverT.exe
O23 - Service: Service COM de gravage de CD IMAPI (ImapiService) - Unknown owner - C:\WINDOWS\system32\imapi.exe
O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
O23 - Service: Ma-Config Service (maconfservice) - Unknown owner - C:\Program Files\ma-config.com\maconfservice.exe
O23 - Service: Partage de Bureau à distance NetMeeting (mnmsrvc) - Unknown owner - C:\WINDOWS\system32\mnmsrvc.exe
O23 - Service: NMSAccessU - Unknown owner - C:\Program Files\CDBurnerXP\NMSAccessU.exe
O23 - Service: Norton Ghost - Symantec Corporation - C:\Program Files\Norton Ghost\Agent\VProSvc.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
O23 - Service: O&O Defrag - O&O Software GmbH - C:\Program Files\OO Software\Defrag\oodag.exe
O23 - Service: Planificateur LiveUpdate automatique - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
O23 - Service: Plug-and-Play (PlugPlay) - Unknown owner - C:\WINDOWS\system32\services.exe
O23 - Service: Gestionnaire de session d'aide sur le Bureau à distance (RDSessMgr) - Unknown owner - C:\WINDOWS\system32\sessmgr.exe
O23 - Service: Carte à puce (SCardSvr) - Unknown owner - C:\WINDOWS\System32\SCardSvr.exe
O23 - Service: ServiceLayer - Nokia - C:\Program Files\PC Connectivity Solution\ServiceLayer.exe
O23 - Service: Journaux et alertes de performance (SysmonLog) - Unknown owner - C:\WINDOWS\system32\smlogsvc.exe
O23 - Service: Cliché instantané de volume (VSS) - Unknown owner - C:\WINDOWS\System32\vssvc.exe
O23 - Service: Carte de performance WMI (WmiApSrv) - Unknown owner - C:\WINDOWS\system32\wbem\wmiapsrv.exe
O23 - Service: Service Partage réseau du Lecteur Windows Media (WMPNetworkSvc) - Unknown owner - C:\Program Files\Windows Media Player\WMPNetwk.exe
End of file - 12963 bytes
======Scheduled tasks folder======
C:\WINDOWS\tasks\Ad-Aware Update (Daily 1).job
C:\WINDOWS\tasks\Ad-Aware Update (Daily 2).job
C:\WINDOWS\tasks\Ad-Aware Update (Daily 3).job
C:\WINDOWS\tasks\Ad-Aware Update (Daily 4).job
C:\WINDOWS\tasks\Ad-Aware Update (Weekly).job
C:\WINDOWS\tasks\GlaryInitialize.job
======Registry dump======
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{18DF081C-E8AD-4283-A596-FA578C2EBDC3}]
Adobe PDF Link Helper - C:\Program Files\Fichiers communs\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll [2010-04-04 75200]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{53707962-6F74-2D53-2644-206D7942484F}]
Spybot-S&D IE Protection - C:\PROGRA~1\SPYBOT~1\SDHelper.dll [2009-01-26 1879896]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{5C255C8A-E604-49b4-9D64-90988571CECB}]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{6EBF7485-159F-4bff-A14F-B9E3AAC4465B}]
Search Helper - C:\Program Files\Microsoft\Search Enhancement Pack\Search Helper\SEPsearchhelperie.dll [2009-05-19 137600]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{9030D464-4C02-4ABF-8ECC-5164760863C6}]
Programme d'aide de l'Assistant de connexion Windows Live - C:\Program Files\Fichiers communs\Microsoft Shared\Windows Live\WindowsLiveLogin.dll [2009-02-17 408440]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{DBC80044-A445-435b-BC74-9C25C1C588A9}]
Java(tm) Plug-In 2 SSV Helper - C:\Program Files\Java\jre6\bin\jp2ssv.dll [2010-05-03 41760]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{E7E6F031-17CE-4C07-BC86-EABFE594F69C}]
JQSIEStartDetectorImpl Class - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll [2010-05-03 79648]
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run]
"NvCplDaemon"=C:\WINDOWS\system32\NvCpl.dll [2008-10-07 13574144]
"nwiz"=nwiz.exe /install []
"RTHDCPL"=C:\WINDOWS\RTHDCPL.EXE [2008-12-09 18063872]
"Alcmtr"=C:\WINDOWS\ALCMTR.EXE [2008-06-19 57344]
"WinSys2"=C:\WINDOWS\system32\winsys2.exe [2008-10-21 208896]
"NvMediaCenter"=C:\WINDOWS\system32\NvMcTray.dll [2008-10-07 86016]
"avast!"=C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe [2009-11-25 81000]
"NeroFilterCheck"=C:\WINDOWS\system32\NeroCheck.exe [2001-07-09 155648]
"MessagerStarter Wanadoo"=C:\PROGRA~1\MESSAG~1\StartMessager.exe [2003-04-04 32768]
"type32"=C:\Program Files\Microsoft IntelliType Pro\type32.exe [2003-05-16 114688]
"IntelliPoint"=C:\Program Files\Microsoft IntelliPoint\point32.exe [2003-05-16 163840]
"{0228e555-4f9c-4e35-a3ec-b109a192b4c2}"=C:\Program Files\Google\Gmail Notifier\gnotify.exe [2005-07-15 479232]
"BluetoothAuthenticationAgent"=bthprops.cpl,,BluetoothAuthenticationAgent []
"BrMfcWnd"=C:\Program Files\Brother\Brmfcmon\BrMfcWnd.exe [2006-03-28 622592]
"SetDefPrt"=C:\Program Files\Brother\Brmfl06a\BrStDvPt.exe [2005-01-26 49152]
"ControlCenter3"=C:\Program Files\Brother\ControlCenter3\brctrcen.exe [2006-04-10 61440]
"Norton Ghost 12.0"=C:\Program Files\Norton Ghost\Agent\VProTray.exe [2007-03-28 2037352]
"UnlockerAssistant"=C:\Program Files\Unlocker\UnlockerAssistant.exe [2008-05-02 15872]
"ORAHSSSessionManager"=C:\Program Files\OrangeHSS\SessionManager\SessionManager.exe [2008-06-10 107248]
"Adobe Reader Speed Launcher"=C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe [2010-04-04 36272]
"Adobe ARM"=C:\Program Files\Fichiers communs\Adobe\ARM\1.0\AdobeARM.exe [2010-03-24 952768]
"AVFX Engine"=C:\Program Files\Creative\Creative Live! Cam\VideoFX\StartFX.exe [2006-06-09 24576]
"V0220Mon.exe"=C:\WINDOWS\V0220Mon.exe [2006-05-16 28672]
"OODefragTray"=C:\Program Files\OO Software\Defrag\oodtray.exe [2009-09-26 2524416]
"SunJavaUpdateSched"=C:\Program Files\Fichiers communs\Java\Java Update\jusched.exe [2010-02-18 248040]
"DivXUpdate"=C:\Program Files\DivX\DivX Update\DivXUpdate.exe [2010-06-03 1144104]
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run]
"CTFMON.EXE"=C:\WINDOWS\system32\ctfmon.exe [2008-04-13 15360]
"MSMSGS"=C:\Program Files\Messenger\msmsgs.exe [2008-04-13 1695232]
"msnmsgr"=C:\Program Files\Windows Live\Messenger\msnmsgr.exe [2009-07-26 3883856]
"Creative Live! Cam Manager"=C:\Program Files\Creative\Creative Live! Cam\Live! Cam Manager\CTLCMgr.exe [2006-05-31 143360]
C:\Documents and Settings\Administrateur\Menu Démarrer\Programmes\Démarrage
MagicDisc.lnk - C:\Program Files\MagicDisc\MagicDisc.exe
OpenOffice.org 3.1.lnk - C:\Program Files\OpenOffice.org 3\program\quickstart.exe
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\WgaLogon]
C:\WINDOWS\system32\WgaLogon.dll [2009-03-10 265088]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad]
WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll [2006-10-18 133632]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\{1a3e09be-1e45-494b-9174-d7385b45bbf5}]
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"dontdisplaylastusername"=0
"legalnoticecaption"=
"legalnoticetext"=
"shutdownwithoutlogon"=1
"undockwithoutlogon"=1
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\explorer]
"NoDriveTypeAutoRun"=4
"ForceClassicControlPanel"=1
"NoSMConfigurePrograms"=1
"NoDriveAutoRun"=4294963135
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\explorer]
"HonorAutoRunSetting"=
[HKEY_LOCAL_MACHINE\system\currentcontrolset\services\sharedaccess\parameters\firewallpolicy\standardprofile\authorizedapplications\list]
"%windir%\Network Diagnostic\xpnetdiag.exe"="%windir%\Network Diagnostic\xpnetdiag.exe:*:Enabled:@xpsp3res.dll,-20000"
"%windir%\system32\sessmgr.exe"="%windir%\system32\sessmgr.exe:*:enabled:@xpsp2res.dll,-22019"
"C:\Program Files\ma-config.com\maconfservice.exe"="C:\Program Files\ma-config.com\maconfservice.exe:LocalSubNet:Enabled:maconfservice"
"C:\Program Files\OrangeHSS\Connectivity\ConnectivityManager.exe"="C:\Program Files\OrangeHSS\Connectivity\ConnectivityManager.exe:*:enabled:CSS"
"C:\Program Files\Windows Live\Sync\WindowsLiveSync.exe"="C:\Program Files\Windows Live\Sync\WindowsLiveSync.exe:*:Disabled:Windows Live FolderShare"
"C:\Program Files\Windows Live\Messenger\wlcsdk.exe"="C:\Program Files\Windows Live\Messenger\wlcsdk.exe:*:Enabled:Windows Live Call"
"C:\Program Files\Windows Live\Messenger\msnmsgr.exe"="C:\Program Files\Windows Live\Messenger\msnmsgr.exe:*:Enabled:Windows Live Messenger"
"C:\Program Files\Fichiers communs\Nokia\Service Layer\A\nsl_host_process.exe"="C:\Program Files\Fichiers communs\Nokia\Service Layer\A\nsl_host_process.exe:*:Enabled:Nokia Service Layer Host Process "
"C:\Program Files\SightSpeed\SightSpeed.exe"="C:\Program Files\SightSpeed\SightSpeed.exe:*:Enabled:SightSpeed"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\services\sharedaccess\parameters\firewallpolicy\domainprofile\authorizedapplications\list]
"C:\Program Files\Windows Live\Sync\WindowsLiveSync.exe"="C:\Program Files\Windows Live\Sync\WindowsLiveSync.exe:*:Enabled:Windows Live FolderShare"
======List of files/folders created in the last 1 months======
2010-06-25 11:31:15 ----D---- C:\rsit
2010-06-25 11:31:15 ----D---- C:\Program Files\trend micro
2010-06-24 17:34:07 ----D---- C:\Program Files\Glary Utilities
2010-06-23 10:29:31 ----SHD---- C:\Config.Msi
2010-06-11 11:04:06 ----HDC---- C:\WINDOWS\$NtUninstallKB980218$
2010-06-11 11:03:46 ----HDC---- C:\WINDOWS\$NtUninstallKB980195$
2010-06-11 11:03:42 ----HDC---- C:\WINDOWS\$NtUninstallKB979559$
2010-06-11 11:02:16 ----HDC---- C:\WINDOWS\$NtUninstallKB978695_WM9$
2010-06-11 11:02:13 ----HDC---- C:\WINDOWS\$NtUninstallKB979482$
2010-06-11 11:02:07 ----HDC---- C:\WINDOWS\$NtUninstallKB975562$
2010-06-10 21:31:47 ----D---- C:\downloads
2010-06-10 21:31:39 ----D---- C:\RDesc
2010-06-09 14:11:39 ----D---- C:\Program Files\Lavasoft
2010-06-03 10:34:07 ----D---- C:\Documents and Settings\All Users\Application Data\Lavasoft
2010-05-26 11:12:59 ----D---- C:\Documents and Settings\Administrateur\Application Data\FireShot
2010-05-26 10:07:15 ----HDC---- C:\WINDOWS\$NtUninstallKB981793$
======List of files/folders modified in the last 1 months======
2010-06-25 11:32:32 ----D---- C:\WINDOWS\Prefetch
2010-06-25 10:58:51 ----D---- C:\WINDOWS\Temp
2010-06-25 10:49:26 ----A---- C:\WINDOWS\NeroDigital.ini
2010-06-25 02:39:50 ----N---- C:\WINDOWS\SchedLgU.Txt
2010-06-25 02:39:49 ----D---- C:\WINDOWS\system32\CatRoot2
2010-06-24 21:31:10 ----D---- C:\Program Files\Malwarebytes' Anti-Malware
2010-06-24 21:31:07 ----D---- C:\WINDOWS\system32\drivers
2010-06-24 21:21:01 ----D---- C:\Documents and Settings\Administrateur\Application Data\vlc
2010-06-24 21:20:34 ----D---- C:\Documents and Settings\Administrateur\Application Data\dvdcss
2010-06-24 21:07:15 ----D---- C:\Documents and Settings\All Users\Application Data\Spybot - Search & Destroy
2010-06-24 17:34:10 ----SD---- C:\WINDOWS\Tasks
2010-06-23 22:28:28 ----D---- C:\WINDOWS\system32
2010-06-23 22:28:28 ----D---- C:\Program Files\Mozilla Firefox
2010-06-23 12:02:45 ----D---- C:\WINDOWS\Microsoft.NET
2010-06-23 12:02:43 ----RSD---- C:\WINDOWS\assembly
2010-06-23 10:30:45 ----SHD---- C:\WINDOWS\Installer
2010-06-23 10:30:13 ----A---- C:\WINDOWS\system32\PerfStringBackup.INI
2010-06-23 10:29:59 ----D---- C:\WINDOWS\WinSxS
2010-06-13 16:16:19 ----AD---- C:\Documents and Settings\All Users\Application Data\TEMP
2010-06-13 15:12:23 ----HD---- C:\WINDOWS\inf
2010-06-11 14:36:33 ----D---- C:\WINDOWS\Debug
2010-06-11 11:04:08 ----RSHDC---- C:\WINDOWS\system32\dllcache
2010-06-11 11:03:46 ----HD---- C:\WINDOWS\$hf_mig$
2010-06-11 11:03:37 ----D---- C:\Program Files\Internet Explorer
2010-06-11 11:03:32 ----D---- C:\WINDOWS\ie8updates
2010-06-09 14:57:09 ----DC---- C:\WINDOWS\system32\DRVSTORE
2010-06-05 11:18:26 ----D---- C:\Documents and Settings\All Users\Application Data\DivX
2010-06-05 11:14:28 ----D---- C:\Program Files\Fichiers communs\DivX Shared
2010-06-05 11:14:28 ----D---- C:\Program Files\DivX
2010-06-04 18:02:16 ----D---- C:\Program Files\Microsoft Silverlight
2010-06-04 10:40:39 ----SD---- C:\Documents and Settings\All Users\Application Data\Microsoft
2010-06-03 10:26:39 ----D---- C:\Program Files\Fichiers communs
2010-05-28 21:37:34 ----A---- C:\WINDOWS\system32\MRT.exe
======List of drivers (R=Running, S=Stopped, 0=Boot, 1=System, 2=Auto, 3=Demand, 4=Disabled)======
R1 Aavmker4;avast! Asynchronous Virus Monitor; C:\WINDOWS\system32\drivers\Aavmker4.sys [2009-11-25 27408]
R1 AmdK8;Pilote de processeur AMD; C:\WINDOWS\system32\DRIVERS\AmdK8.sys [2006-07-01 43520]
R1 aswSP;avast! Self Protection; C:\WINDOWS\system32\drivers\aswSP.sys [2009-09-15 114768]
R1 aswTdi;avast! Network Shield Support; C:\WINDOWS\system32\drivers\aswTdi.sys [2009-11-25 48560]
R2 aswFsBlk;aswFsBlk; C:\WINDOWS\system32\DRIVERS\aswFsBlk.sys [2009-09-15 20560]
R2 aswMon2;avast! Standard Shield Support; C:\WINDOWS\system32\drivers\aswMon2.sys [2009-09-15 94160]
R2 v2imount;Symantec V2i Mount Driver; C:\WINDOWS\system32\DRIVERS\v2imount.sys [2007-03-28 37864]
R3 aswRdr;aswRdr; C:\WINDOWS\system32\drivers\aswRdr.sys [2009-11-25 23120]
R3 GEARAspiWDM;GearAspiWDM; C:\WINDOWS\system32\DRIVERS\GEARAspiWDM.sys [2007-03-28 15664]
R3 HDAudBus;Pilote de bus Microsoft UAA pour High Definition Audio; C:\WINDOWS\system32\DRIVERS\HDAudBus.sys [2008-04-13 144384]
R3 IntcAzAudAddService;Service for Realtek HD Audio (WDM); C:\WINDOWS\system32\drivers\RtkHDAud.sys [2008-12-11 4959232]
R3 mcdbus;Driver for MagicISO SCSI Host Controller; C:\WINDOWS\system32\DRIVERS\mcdbus.sys [2007-09-05 92544]
R3 nv;nv; C:\WINDOWS\system32\DRIVERS\nv4_mini.sys [2008-10-07 6133856]
R3 NVENETFD;NVIDIA nForce Networking Controller Driver; C:\WINDOWS\system32\DRIVERS\NVENETFD.sys [2006-11-27 58368]
R3 nvnetbus;NVIDIA Network Bus Enumerator; C:\WINDOWS\system32\DRIVERS\nvnetbus.sys [2006-11-27 19968]
R3 PCANDIS5;PCANDIS5 NDIS Protocol Driver; \??\C:\WINDOWS\system32\PCANDIS5.SYS []
R3 Point32;Microsoft IntelliPoint Filter Driver; C:\WINDOWS\system32\DRIVERS\point32.sys [2003-05-16 19072]
R3 usbehci;Pilote miniport de contrôleur d'hôte amélioré Microsoft USB 2.0; C:\WINDOWS\system32\DRIVERS\usbehci.sys [2008-04-13 30208]
R3 usbhub;Concentrateur USB2; C:\WINDOWS\system32\DRIVERS\usbhub.sys [2008-04-13 59520]
R3 usbohci;Pilote miniport de contrôleur hôte ouvert USB Microsoft; C:\WINDOWS\system32\DRIVERS\usbohci.sys [2008-04-13 17152]
R3 USBSTOR;Pilote de stockage de masse USB; C:\WINDOWS\system32\DRIVERS\USBSTOR.SYS [2008-04-13 26368]
S2 ADILOADER;General Purpose USB Driver (adildr.sys); C:\WINDOWS\System32\Drivers\adildr.sys []
S3 adiusbaw;USB ADSL WAN Adapter; C:\WINDOWS\system32\DRIVERS\adiusbaw.sys []
S3 BrScnUsb;Brother USB Still Image driver; C:\WINDOWS\system32\DRIVERS\BrScnUsb.sys [2004-10-15 15295]
S3 BthEnum;Pilote de bloc de demande Bluetooth; C:\WINDOWS\system32\DRIVERS\BthEnum.sys [2008-04-13 17024]
S3 BTHMODEM;Pilote de communications modem Bluetooth; C:\WINDOWS\system32\DRIVERS\bthmodem.sys [2008-04-13 37888]
S3 BthPan;Périphérique Bluetooth (réseau personnel); C:\WINDOWS\system32\DRIVERS\bthpan.sys [2008-04-13 101120]
S3 BTHPORT;Pilote de port Bluetooth; C:\WINDOWS\System32\Drivers\BTHport.sys [2008-06-14 272768]
S3 BTHUSB;Pilote USB radio Bluetooth; C:\WINDOWS\System32\Drivers\BTHUSB.sys [2008-04-13 18944]
S3 CCDECODE;Décodeur sous-titre fermé; C:\WINDOWS\system32\DRIVERS\CCDECODE.sys [2008-04-13 17024]
S3 driverhardwarev2;driverhardwarev2; \??\C:\Program Files\ma-config.com\Drivers\driverhardwarev2.sys []
S3 gdrv;gdrv; \??\C:\WINDOWS\gdrv.sys []
S3 HidUsb;Pilote de classe HID Microsoft; C:\WINDOWS\system32\DRIVERS\hidusb.sys [2008-04-13 10368]
S3 MSTEE;Convertisseur en T/site-à-site de répartition Microsoft; C:\WINDOWS\system32\drivers\MSTEE.sys [2008-04-13 5504]
S3 NABTSFEC;Codec NABTS/FEC VBI; C:\WINDOWS\system32\DRIVERS\NABTSFEC.sys [2008-04-13 85248]
S3 NdisIP;Connection TV/vidéo Microsoft; C:\WINDOWS\system32\DRIVERS\NdisIP.sys [2008-04-13 10880]
S3 PCAMPR5;PCAMPR5 NDIS Protocol Driver; \??\C:\WINDOWS\system32\PCAMPR5.SYS []
S3 pccsmcfd;PCCS Mode Change Filter Driver; C:\WINDOWS\system32\DRIVERS\pccsmcfd.sys [2008-08-26 18816]
S3 RFCOMM;Périphérique Bluetooth (TDI protocole RFCOMM); C:\WINDOWS\system32\DRIVERS\rfcomm.sys [2008-04-13 59136]
S3 SLIP;Détrameur décalage BDA; C:\WINDOWS\system32\DRIVERS\SLIP.sys [2008-04-13 11136]
S3 StarOpen;StarOpen; C:\WINDOWS\system32\drivers\StarOpen.sys [2009-09-28 7168]
S3 streamip;BDA IPSink; C:\WINDOWS\system32\DRIVERS\StreamIP.sys [2008-04-13 15232]
S3 usbccgp;Pilote parent générique USB Microsoft; C:\WINDOWS\system32\DRIVERS\usbccgp.sys [2008-04-13 32128]
S3 usbprint;Classe d'imprimantes USB Microsoft; C:\WINDOWS\system32\DRIVERS\usbprint.sys [2008-04-13 25856]
S3 V0220Dev;Live! Cam Video IM; C:\WINDOWS\system32\DRIVERS\V0220Dev.sys [2006-05-24 145472]
S3 V0220Vfx;V0220VFX; C:\WINDOWS\system32\DRIVERS\V0220Vfx.sys [2006-03-24 6272]
S3 VProEventMonitor;Symantec Event Monitor Driver; C:\WINDOWS\system32\DRIVERS\vproeventmonitor.sys [2007-03-28 14072]
S3 WimFltr;WimFltr; C:\WINDOWS\system32\DRIVERS\wimfltr.sys [2007-03-28 128104]
S3 WSTCODEC;Codec Teletext standard; C:\WINDOWS\system32\DRIVERS\WSTCODEC.SYS [2008-04-13 19200]
S3 WudfRd;Windows Driver Foundation - User-mode Driver Framework Reflector; C:\WINDOWS\system32\DRIVERS\wudfrd.sys [2008-01-18 83328]
S4 IntelIde;IntelIde; C:\WINDOWS\system32\drivers\IntelIde.sys []
======List of services (R=Running, S=Stopped, 0=Boot, 1=System, 2=Auto, 3=Demand, 4=Disabled)======
R2 aswUpdSv;avast! iAVS4 Control Service; C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe [2009-11-25 18752]
R2 avast! Antivirus;avast! Antivirus; C:\Program Files\Alwil Software\Avast4\ashServ.exe [2009-11-25 138680]
R2 BthServ;Bluetooth Support Service; C:\WINDOWS\system32\svchost.exe [2008-04-13 14336]
R2 FTRTSVC;France Telecom Routing Table Service; C:\PROGRA~1\FICHIE~1\France Telecom\Shared Modules\FTRTSVC\0\FTRTSVC.exe [2008-06-20 65536]
R2 JavaQuickStarterService;Java Quick Starter; C:\Program Files\Java\jre6\bin\jqs.exe [2010-05-03 153376]
R2 NMSAccessU;NMSAccessU; C:\Program Files\CDBurnerXP\NMSAccessU.exe [2009-09-06 71096]
R2 Norton Ghost;Norton Ghost; C:\Program Files\Norton Ghost\Agent\VProSvc.exe [2007-03-28 3290728]
R2 NVSvc;NVIDIA Display Driver Service; C:\WINDOWS\system32\nvsvc32.exe [2008-10-07 163908]
R2 O&O Defrag;O&O Defrag; C:\Program Files\OO Software\Defrag\oodag.exe [2009-09-26 1488128]
R2 Planificateur LiveUpdate automatique;Planificateur LiveUpdate automatique; C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe [2007-09-26 554352]
R2 SeaPort;SeaPort; C:\Program Files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe [2009-05-19 240512]
R2 WudfSvc;Windows Driver Foundation - User-mode Driver Framework; C:\WINDOWS\system32\svchost.exe [2008-04-13 14336]
R3 avast! Mail Scanner;avast! Mail Scanner; C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe [2009-11-25 254040]
S3 aspnet_state;ASP.NET State Service; C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_state.exe [2008-07-25 34312]
S3 clr_optimization_v2.0.50727_32;.NET Runtime Optimization Service v2.0.50727_X86; C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorsvw.exe [2008-07-25 69632]
S3 FontCache3.0.0.0;Windows Presentation Foundation Font Cache 3.0.0.0; c:\WINDOWS\Microsoft.NET\Framework\v3.0\WPF\PresentationFontCache.exe [2008-07-29 46104]
S3 IDriverT;InstallDriver Table Manager; C:\Program Files\Fichiers communs\InstallShield\Driver\1150\Intel 32\IDriverT.exe [2005-11-14 69632]
S3 idsvc;Windows CardSpace; c:\WINDOWS\Microsoft.NET\Framework\v3.0\Windows Communication Foundation\infocard.exe [2008-07-29 881664]
S3 LiveUpdate;LiveUpdate; C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE [2007-09-26 2999664]
S3 maconfservice;Ma-Config Service; C:\Program Files\ma-config.com\maconfservice.exe [2009-05-29 234864]
S3 ose;Office Source Engine; C:\Program Files\Fichiers communs\Microsoft Shared\Source Engine\OSE.EXE [2003-07-28 89136]
S3 ServiceLayer;ServiceLayer; C:\Program Files\PC Connectivity Solution\ServiceLayer.exe [2009-10-27 657408]
S3 WMPNetworkSvc;Service Partage réseau du Lecteur Windows Media; C:\Program Files\Windows Media Player\WMPNetwk.exe [2006-11-03 918016]
S4 NetTcpPortSharing;Net.Tcp Port Sharing Service; c:\WINDOWS\Microsoft.NET\Framework\v3.0\Windows Communication Foundation\SMSvcHost.exe [2008-07-29 132096]
craimon
 Posté le 25/06/2010 à 11:54
mis a jour de malware ..... fait des que le scan est fini je le poste
Anonyme
 Posté le 25/06/2010 à 12:15
@ craimon
question:
ton windows est légal ? (modifié/cracké)
Modifié par Anonyme le 25/06/2010 12:16
craimon
 Posté le 25/06/2010 à 12:20
rapport malware......!!!
Malwarebytes' Anti-Malware 1.46
www.malwarebytes.org
Version de la base de données: 4237
Windows 5.1.2600 Service Pack 3
Internet Explorer 8.0.6001.18702
25/06/2010 12:19:34
mbam-log-2010-06-25 (12-19-34).txt
Type d'examen: Examen complet (C:\|D:\|E:\|)
Elément(s) analysé(s): 187403
Temps écoulé: 35 minute(s), 33 seconde(s)
Processus mémoire infecté(s): 0
Module(s) mémoire infecté(s): 0
Clé(s) du Registre infectée(s): 0
Valeur(s) du Registre infectée(s): 1
Elément(s) de données du Registre infecté(s): 2
Dossier(s) infecté(s): 0
Fichier(s) infecté(s): 0
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\forceclassiccontrolpanel (Hijack.ControlPanelStyle) -> No action taken.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\FirewallDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> No action taken.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\UpdatesDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> No action taken.
Anonyme
 Posté le 25/06/2010 à 12:23
salut.
peux tu répondre a ma question précedente ?
Anonyme
 Posté le 25/06/2010 à 12:25
australien a écrit :
@ craimon
question:
australien
tu penses bien que Oui, sinon il ne venait pas sur PCastuces demander de l'aide,puisque il sais qu' ici aucune aide en cas de piratage
Ps: je sors avant de me faire {#} par d'autres
Anonyme
 Posté le 25/06/2010 à 12:29
Bonjour Choupettes.
je sais encore lire un rapport et ma question n'est pas anodine.
il ne faut pas étre si crédule, tu veux savoir le nombre de sujets sur PCA ou l'on voit des Windows illégals ?
sur ce bon appêtit et @+
Modifié par Anonyme le 25/06/2010 12:30
craimon
 Posté le 25/06/2010 à 12:32
il y a un ans le mec qui ma fait mon nouveaux pc ma remis windows et avant il ete sur mon vieux pc j avais eu un probleme et un pote ma reinstaller le tous alors apres !!! de tous façon j ai telephoner a Microsoft pour avoir la cle license je ne suis pas un expert en informatique a ce sujet
Anonyme
 Posté le 25/06/2010 à 12:35
Bonjour Choupettes.
australien
{#}{#} je n'ai pas su te faire rire décidement je ne suis pas drôle(peut-etre un peu trop carré)
Je sais trés bien que tu sais lire les rapports ,et moi j'avais trés bien compris le pourquoi de ta réponse
Bon appétit à toi aussi
Anonyme
 Posté le 25/06/2010 à 12:47
Le Che a écrit :
je serais un peu de l'avis du kangourou
choupettes
le che
moi je ne contredis pas notre Kangouru,et j'oserai pas le faire, mais il ne m'a pas compris
Alors Kangouru
Anonyme
 Posté le 25/06/2010 à 12:53
re-
Quelque fois vous pouvez avoir ce genre de Windows sans le savoir car vous avez acheté votre PC avec un Windows non activé.
Par mesure d’économie certains vendeurs activent TOUS leurs Windows avec la même clé.
Si vous êtes dans ce cas vous pouvez le signaler à Microsoft :Comment reconnaître un logiciel Microsoft original
1) relance malwarebytes et supprimes les détections.
2) fait une analyse en ligne ESET Online Scanner / nouvelle version - Tutoriel
3) contacte microsoft pour obtenir une nouvelle clé de licence.
Si tu n'as pas de licence, achete-en une chez Microsoft et de préférence demande avec un CD d’installation original.
pour le reste, je ne peux rien pour toi.
bonne journée
Modifié par Anonyme le 25/06/2010 12:58
craimon
 Posté le 25/06/2010 à 12:58
je vous remerci de votre aides {#}
tu peut me conseil pour des logiciels pour mieux me proteger mon pc {#}
Anonyme
 Posté le 25/06/2010 à 13:07
préoccupe toi d'abord de mon dernier message.
il est illusoire de croire a la protection d'un Windows de la sorte.
il ne sera pas dit que je n'ai pas répondu a tes attentes malgrés tout
Sécuriser son PC +WIFI +désinstallation kit orange (Merci Philae)
bonne continuation
philae
 Posté le 02/07/2010 à 21:20
Grande Maîtresse astucienne
bonsoir tlm,
commencer par avoir un windows légal
86,99 €Alimentation Seasonic G12 GC 850W Plus Gold à 86,99 €
Valable jusqu'au 19 Juin
RueDuCommerce propose actuellement la bonne alimentation Seasonic G12 GC 850W Plus Gold à 86,99 €. On la trouve habituellement à partir de 105 €. L'alimentation est garantie 5 ans.
199,99 €Ecran PC 27 pouces Dell S2721DS (QHD, IPS, 75 Hz) à 199,99 €
Valable jusqu'au 18 Juin
Fnac fait une promotion sur l'écran PC 27 pouces Dell S2721DS qui passe à 199,99 € au lieu de plus de 250 € ailleurs. L'écran à cadre fin dispose d'une dalle IPS QHD (2560x1440 pixels) à 75 Hz. Il est compatible Freesync et dispose de 2 prises HDMI et 1 prise DP. Il dispose de haut-parleurs intégrés (2x3W) et son pied est réglable en hauteur.
199,99 €Ecran ultra large LG 29 pouces 29WL500-B à 199,99 €
Boulanger propose actuellement l'écran 29 pouces LG 29WL500-B à 199,99 € livré gratuitement alors qu'on le trouve à partir de 229 € ailleurs. Cet écran ultra large est au format 21/9, possède une dalle IPS et offre une résolution de 2560 x 1080 pixels. Avec lui, vous pourrez bénéficier d'une plus grande immersion dans les jeux et les films. Cet écran est compatible FreeSync.
clés de registre infectées avis
cles registre infectees
Clés de Régistre Infectées
Supprimer clés de registre?
RogueKiller impossible de supprimer des clés registre
MalwareByte trouve deux clés de registre
Clés de registre qui ne veulent pas se supprimer
Clés "invisibles" dans le Registre ???
Reperer les clés du registre XP
Plus de sujets relatifs à Clés registre inféctées 2010
