 Configuration de kannel avec dlr-storage= Mysql
kyessouk
  Posté le 21/03/2011 @ 12:06
Bonjour a tous , Je suis entrain de configurer kannel avec mysql. Apres installation et confuguration complete et apres lancement de kannel par http; le message suivant m'est retourne:Not routable. Do not try again. Je ne 7 pqs donc koi faire. kelk1 pour m'qider SVP.. Voici mon fichier de configuration SMSconf: # CORE group = core admin-port = 13000 smsbox-port = 13001 admin-password = xxxxxx log-file ="/tmp/kannel.log" log-level = 1 box-deny-ip = "*.*.*.*" box-allow-ip = "192.168.1.115" dlr-storage = mysql #Identifies the SMS Center group group = smsc #Tells kannel that we are going to use mobile as smsc smsc = at smsc-id = 2700 #allowed-smsc-id = "+22995355306" #denied-smsc-id = fake connect-allow-ip = 192.168.1.115 preferred-smsc-id= +22995355306 reroute = true reroute-smsc-id = "+22995355306" reroute-receiver = "+22995355306" reroute-dlr = true allowed-prefix= "+229" #Sets the modem type to auto modemtype = auto msg-id-type=0x03 #Identifies the modem device = /dev/ttyACM0 connect-allow-ip = 192.168.1.115 #It should be your mobile number my-number = 95355306 log-level = 1 #It should be changed to work for your mobile group = modems id = nokia name = "Nokia 2700" detect-string = "Nokia" init-string = "ATZ" init-string = "AT Q0 V1 E1 S0=0 &C1 &D2 +FCLASS=0" # SMSBOX SETUP group = smsbox bearerbox-host = 192.168.1.115 sendsms-port = 13013 global-sender = "+22995355306" log-file = "/tmp/smsbox.log" log-level = 0 # SEND­SMS USERS group = sendsms-user username = xxxxx password = xxxxxx concatenation = true dlr-url=http%3A//192.168.1.115/dlr.php%3Fstatus%3D%25A%26answer%3D%25d #dlr-mask = 1 + 2 + 4 + 8 + 16 #can send a longer text message about 3 smses ( 3*160) max-messages = 10 # SERVICES group = sms-service # keyword = nop keyword-regex = .* catch-all= yes max-messages= 5 #get-­url = "http://%S" get-­url = "&dlrmask=31&dlrurl=http://localhost/dlr.php?type=%d&id=$id" #get-url= http://192.168.1.115/websms/inc/dlr.php?user=hesystem&password=abdel&to=%p&message=%a #get-url= http://192.168.1.115:13013/cgi-bin/sendsms?username=hesystem&password=abdel&to=%p&text=%a #( Note­> Do not use " " unless u will get error) #get­url = "http://192.168.11.119/sms?phone=%p&text=%a" #­­­ mysql connection group = mysql-connection id = mydlrdb host = 192.168.1.115 username = xxxx password = xxxxx database = dlr max-connections = 1 #­­­­ DLR table structure group = dlr-db id = mydlrdb table = dlr field-smsc = smsc field-timestamp = ts field-destination = destination field-source = source field-service = service field-url = url field-mask = mask field-status = status field-boxc-id = boxc et voici le statu de kannel: ie kan je fais ceci: http://192.168.1.115:13000/status?password=xxxxxx jai ceki suit: Kannel bearerbox version `1.4.3'. Build `Mar 17 2011 19:57:40', compiler `4.5.1 20100924 (Red Hat 4.5.1-4)'. System Linux, release 2.6.35.11-83.fc14.i686, version #1 SMP Mon Feb 7 07:04:18 UTC 2011, machine i686. Hostname 192.168.1.115, IP 192.168.1.115. Libxml version 2.7.7. Compiled with MySQL 5.1.55, using MySQL 5.1.55. Using native malloc. Status: running, uptime 0d 0h 41m 18s WDP: received 0 (0 queued), sent 0 (0 queued) SMS: received 1 (0 queued), sent 0 (0 queued), store size -1 SMS: inbound (0.00,0.00,0.00) msg/sec, outbound (0.00,0.00,0.00) msg/sec DLR: 1 queued, using mysql storage Box connections: smsbox:(none), IP 192.168.1.115 (0 queued), (on-line 0d 0h 40m 44s) SMSC connections: 2700 AT2[2700] (online 2470s, rcvd 0, sent 0, failed 0, queued 0 msgs) kan je fais : http://192.168.1.115:13013/cgi-bin/sendsms?username=hesystem&password=abdel&to=95325672&text=Bonjour+abdel+message+de+kannel&smsc-id=2700&dlr-mask=31&dlr-url=http%3A//192.168.1.115/dlr.php%3Fstatus%3D%25A%26answer%3D%25d jqi ce ki suit ; Not routable. Do not try again. voici le contenu de mon bearbox: [1] 2251 stop: missing job name Try `stop --help' for more information. [root@192 gw]# 2011-03-21 11:52:14 [2251] [0] INFO: Debug_lvl = 1, log_file = , log_lvl = 0 2011-03-21 11:52:14 [2251] [0] INFO: MYSQL: Connected to server at 192.168.1.115. 2011-03-21 11:52:14 [2251] [0] INFO: MYSQL: server version 5.1.55, client version 5.1.55. 2011-03-21 11:52:14 [2251] [0] INFO: DLR using storage type: mysql 2011-03-21 11:52:14 [2251] [0] INFO: Added logfile `/tmp/kannel.log' with level `1'. 2011-03-21 11:52:14 [2251] [0] INFO: SSL not supported, no SSL initialization done. 2011-03-21 11:52:14 [2251] [0] INFO: HTTP: Opening server at port 13000. 2011-03-21 11:52:14 [2251] [0] INFO: BOXC: 'smsbox-max-pending' not set, using default (100). 2011-03-21 11:52:14 [2251] [0] INFO: Set SMS resend frequency to 60 seconds. 2011-03-21 11:52:14 [2251] [0] INFO: SMS resend retry set to unlimited. 2011-03-21 11:52:14 [2251] [0] INFO: DLR rerouting for smsc id enabled. 2011-03-21 11:52:14 [2251] [0] INFO: AT2[2700]: configuration doesn't show modemtype. will autodetect 2011-03-21 11:52:14 [2251] [6] INFO: AT2[2700]: opening device 2011-03-21 11:52:14 [2251] [0] INFO: ---------------------------------------- 2011-03-21 11:52:14 [2251] [0] INFO: Kannel bearerbox II version 1.4.3 starting 2011-03-21 11:52:14 [2251] [0] INFO: MAIN: Start-up done, entering mainloop 2011-03-21 11:52:15 [2251] [6] INFO: AT2[2700]: speed set to 115200 2011-03-21 11:52:17 [2251] [6] INFO: AT2[2700]: Closing device 2011-03-21 11:52:17 [2251] [6] INFO: AT2[2700]: detect speed is 115200 2011-03-21 11:52:17 [2251] [6] INFO: AT2[2700]: opening device 2011-03-21 11:52:18 [2251] [6] INFO: AT2[2700]: speed set to 115200 2011-03-21 11:52:20 [2251] [6] INFO: AT2[2700]: Closing device 2011-03-21 11:52:20 [2251] [6] INFO: AT2[2700]: opening device 2011-03-21 11:52:20 [2251] [6] INFO: AT2[2700]: Logging in 2011-03-21 11:52:21 [2251] [6] INFO: AT2[2700]: init device 2011-03-21 11:52:21 [2251] [6] INFO: AT2[2700]: speed set to 115200 2011-03-21 11:52:22 [2251] [6] INFO: AT2[2700]: AT SMSC successfully opened. bearerbox -v 1 ./smsbox -v 1 smskannel.conf & [2] 2262 [root@192 gw]# 2011-03-21 11:52:48 [2262] [0] INFO: Debug_lvl = 1, log_file = , log_lvl = 0 2011-03-21 11:52:48 [2262] [0] INFO: Starting to log to file /tmp/smsbox.log level 0 2011-03-21 11:52:48 [2262] [0] INFO: Added logfile `/tmp/smsbox.log' with level `0'. 2011-03-21 11:52:48 [2262] [0] INFO: Service global sender set as '+22995355306' 2011-03-21 11:52:48 [2262] [0] INFO: HTTP: Opening server at port 13013. 2011-03-21 11:52:48 [2262] [0] INFO: Set up send sms service at port 13013 2011-03-21 11:52:48 [2251] [5] INFO: Client connected from 2011-03-21 11:52:48 [2262] [0] INFO: Connected to bearerbox at 192.168.1.115 port 13001. 2011-03-21 12:33:23 [2262] [3] INFO: smsbox: Got HTTP request from 2011-03-21 12:33:23 [2262] [3] INFO: sendsms used by 2011-03-21 12:33:23 [2262] [3] INFO: sendsms sender: (192.168.1.115) to: msg: 2011-03-21 12:33:23 [2251] [8] WARNING: Cannot find SMSCConn for message to , rejected. 2011-03-21 12:33:23 [2251] [8] WARNING: Message rejected by bearerbox, no router! 2011-03-21 12:33:23 [2262] [4] INFO: Starting delivery report from 2011-03-21 12:33:24 [2262] [3] INFO: smsbox: Got HTTP request from 2011-03-21 12:33:27 [2262] [3] INFO: smsbox: Got HTTP request from 2011-03-21 12:43:57 [2262] [3] INFO: smsbox: Got HTTP request from 2011-03-21 12:43:57 [2262] [3] INFO: sendsms used by 2011-03-21 12:43:57 [2262] [3] INFO: sendsms sender: (192.168.1.115) to: msg: 2011-03-21 12:43:57 [2251] [8] WARNING: Cannot find SMSCConn for message to , rejected. 2011-03-21 12:43:57 [2251] [8] WARNING: Message rejected by bearerbox, no router! 2011-03-21 12:43:57 [2262] [4] INFO: Starting delivery report from SVP kelk1 pour m'aider. voici mon mail: kyessouf@yahoo.fr
Valable jusqu'au 19 Janvier
Le vendeur sérieux LicenSE-ONLine propose sur Amazon la clé d'activation pour Windows 10 professionnel en français 32 bits / 64 bits à 14,90 €. Cette clé livrée par email fonctionne avec l'outil d'installation et de création de support de Microsoft que vous pouvez télécharger ici ou directement avec l'ISO de Windows 10 Pro. De quoi installer légalement Windows 10 Pro sur un PC. Pour en savoir plus sur l'achat et l'installation d'une clé OEM de Windows 10, suivez les indications de notre dossier pratique.
Notez que vous pourrez également passer à Windows 11 gratuitement avec cette clé.
SOLDESLes soldes d'hiver 2022
Valable jusqu'au 08 Février
Les soldes commencent ce Mercredi 12 Janvier dans la plupart des départements Retrouvez ici la liste des pages dédiées à cet évènement chez les différents revendeurs high-tech afin de trouver la bonne affaire qui vous intéresse. Nous vous proposerons aussi les bons plans que nous aurons dénichés.
269,99 €Casque sans fil Bose Headphones 700 à 269,99 €
Valable jusqu'au 17 Janvier
Cdiscount fait une promotion sur l'excellent casque sans fil Bose Headphones 700 qui passe à 269,99 € au lieu de 290 €. En plus d'un son incroyable, ce casque offre 11 niveaux de réduction active de bruit vous permettent de profiter de la musique, des podcasts, des vidéos et des appels, sans distraction. Un système de microphones révolutionnaire s’adapte aux environnements bruyants et venteux afin de restituer votre voix avec une clarté incroyable lors de vos appels. Vous permet également d'accéder facilement aux assistant vocaux Google et Alexa. Autonomie jusqu'à 20 heures.
configuration de kannel
configuration mysql sur opensuse 11
configuration kannel
Configuration wifi (avec l'aide de madwifi)
[Mdk10.1] Alias avec Postfix et Mysql
Problème configuration de MySQL
Solution d'un cas de polices aliasées avec fontconfig-infinality
Problème de boot avec handy linux
pb avec ma sours souris
Plus de sujets relatifs à Configuration de kannel avec dlr-storage= Mysql
