 Posté le 01/06/2009 @ 01:39 |
| salut , je demande de l'aide a resoudre les problemes de mon pc
Logfile of Trend Micro HijackThis v2.0.2 Scan saved at 23:30:09, on 31/05/2009 Platform: Windows XP SP3 (WinNT 5.01.2600) MSIE: Internet Explorer v8.00 (8.00.6001.18702) Boot mode: Normal
Running processes: C:\WINDOWS\System32\smss.exe C:\WINDOWS\system32\winlogon.exe C:\WINDOWS\system32\services.exe C:\WINDOWS\system32\lsass.exe C:\WINDOWS\system32\svchost.exe C:\WINDOWS\System32\svchost.exe C:\WINDOWS\system32\spoolsv.exe C:\Program Files\Java\jre6\bin\jqs.exe C:\Program Files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe C:\WINDOWS\system32\svchost.exe C:\WINDOWS\system32\SearchIndexer.exe C:\WINDOWS\system32\wbem\wmiapsrv.exe C:\WINDOWS\Explorer.EXE C:\Program Files\QuickTime\qttask.exe C:\Program Files\Real\RealOne Player\realplay.exe C:\WINDOWS\system32\ctfmon.exe C:\Program Files\Windows Live\Messenger\msnmsgr.exe C:\Program Files\Eraser\eraser.exe C:\Program Files\Menara\dslmon.exe C:\Program Files\Windows Desktop Search\WindowsSearch.exe C:\Documents and Settings\hp\Application Data\Microsoft\Notification de cadeaux MSN\lsnfier.exe C:\Program Files\Windows Live\Contacts\wlcomm.exe C:\DOCUME~1\hp\LOCALS~1\Temp\winjpjxm.exe C:\DOCUME~1\hp\LOCALS~1\Temp\winjnary.exe C:\Program Files\internet explorer\iexplore.exe C:\Program Files\internet explorer\iexplore.exe C:\Program Files\Windows Live\Toolbar\wltuser.exe C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.bladinet.net/ R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157 R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896 R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896 R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Liens O2 - BHO: Aide pour le lien d'Adobe PDF Reader - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Fichiers communs\Adobe\Acrobat\ActiveX\AcroIEHelper.dll O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Fichiers communs\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - (no file) O2 - BHO: (no name) - {5C255C8A-E604-49b4-9D64-90988571CECB} - (no file) O2 - BHO: Search Helper - {6EBF7485-159F-4bff-A14F-B9E3AAC4465B} - C:\Program Files\Microsoft\Search Enhancement Pack\Search Helper\SEPsearchhelperie.dll O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre6\bin\ssv.dll O2 - BHO: Programme d'aide de l'Assistant de connexion Windows Live - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Fichiers communs\Microsoft Shared\Windows Live\WindowsLiveLogin.dll O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.1.1309.3572\swg.dll O2 - BHO: Google Dictionary Compression sdch - {C84D72FE-E17D-4195-BB24-76C02E2E7C4E} - C:\Program Files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll O2 - BHO: Windows Live Toolbar Helper - {E15A8DC0-8516-42A1-81EA-DC94EC1ACF10} - C:\Program Files\Windows Live\Toolbar\wltcore.dll O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll O3 - Toolbar: &Windows Live Toolbar - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - C:\Program Files\Windows Live\Toolbar\wltcore.dll O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime O4 - HKLM\..\Run: [RealTray] C:\Program Files\Real\RealOne Player\realplay.exe SYSTEMBOOTHIDEPLAYER O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\Windows Live\Messenger\msnmsgr.exe" /background O4 - HKCU\..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe O4 - HKCU\..\Run: [Eraser] C:\Program Files\Eraser\eraser.exe -hide O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM') O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user') O4 - Startup: Notification de cadeaux MSN.lnk = C:\Documents and Settings\hp\Application Data\Microsoft\Notification de cadeaux MSN\lsnfier.exe O4 - Global Startup: DSLMON.lnk = C:\Program Files\Menara\dslmon.exe O4 - Global Startup: Windows Search.lnk = C:\Program Files\Windows Desktop Search\WindowsSearch.exe O7 - HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System, DisableRegedit=1 O8 - Extra context menu item: Add to Windows &Live Favorites - http://favorites.live.com/quickadd.aspx O8 - Extra context menu item: E&xporter vers Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000 O8 - Extra context menu item: Ouvrir dans un nouvel onglet d'arrière-plan - res://C:\Program Files\Windows Live Toolbar\Components\fr-fr\msntabres.dll.mui/229?8f4ca0d0e1e64f9880ca97f50b1810a0 O8 - Extra context menu item: Ouvrir dans un nouvel onglet de premier plan - res://C:\Program Files\Windows Live Toolbar\Components\fr-fr\msntabres.dll.mui/230?8f4ca0d0e1e64f9880ca97f50b1810a0 O9 - Extra button: Ajout Direct - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll O9 - Extra 'Tools' menuitem: &Ajout Direct dans Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll O9 - Extra button: Recherche - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL O9 - Extra button: Real.com - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\system32\Shdocvw.dll O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe (file missing) O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe (file missing) O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe O10 - Unknown file in Winsock LSP: c:\windows\system32\nwprovau.dll O16 - DPF: CabBuilder - http://kiw.imgag.com/imgag/kiw/toolbar/download/InstallerControl.cab O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204 O16 - DPF: {1851174C-97BD-4217-A0CC-E908F60D5B7A} (Hewlett-Packard Online Support Services) - http://h50203.www5.hp.com/HPISWeb/Customer/cabs/HPISDataManager.CAB O16 - DPF: {67DABFBF-D0AB-41FA-9C46-CC0F21721616} - http://go.divx.com/plugin/DivXBrowserPlugin.cab O16 - DPF: {73ECB3AA-4717-450C-A2AB-D00DAD9EE203} (GMNRev Class) - http://h20270.www2.hp.com/ediags/gmn2/install/HPProductDetection2.cab O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} (Java Runtime Environment 1.6.0) - http://javadl.sun.com/webapps/download/AutoDL?BundleId=24931 O16 - DPF: {BDBDE413-7B1C-4C68-A8FF-C5B2B4090876} (F-Secure Online Scanner 3.3) - http://support.f-secure.com/ols/fscax.cab O16 - DPF: {C237A80A-4C55-4C68-BAA9-CBE4408D12B2} (F-Secure Online Scanner 4.0 Launcher) - http://download.sp.f-secure.com/ols/f-secure-rtm/resources/fslauncher.cab O16 - DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/MessengerStatsPAClient.cab56907.cab O17 - HKLM\System\CCS\Services\Tcpip\..\{71BA674A-663F-49DA-92FE-8E035C1A530A}: NameServer = 196.217.246.210 212.217.1.4 O18 - Protocol: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\PROGRA~1\FICHIE~1\Skype\SKYPE4~1.DLL O18 - Filter: x-sdch - {B1759355-3EEC-4C1E-B0F1-B719FE26E377} - C:\Program Files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll O23 - Service: AG Windows Service (AGWinService) - Unknown owner - C:\Program Files\AGI\common\win32\PythonService.exe (file missing) O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Fichiers communs\InstallShield\Driver\11\Intel 32\IDriverT.exe O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe O23 - Service: Remote Packet Capture Protocol v.0 (experimental) (rpcapd) - CACE Technologies - C:\Program Files\WinPcap\rpcapd.exe O23 - Service: VNC Server (winvnc) - Unknown owner - C:\Program Files\TightVNC\WinVNC.exe (file missing)
-- End of file - 9244 bytes
Posté le 01/06/2009 à 10:29 |
Grand Maître astucien | Bonjour.
Une remarque importante : Je ne vois pas la présence d'un antivirus sur ce rapport ! Pour cette ligne : O7 - HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System, DisableRegedit=1 Est-ce toi qui a bloqué l'accès au registre ? Si ce n'est pas le cas il faut la fixer avec Hijackthis. Ainsi que cette ligne O16 - DPF: CabBuilder - http://kiw.imgag.com/imgag/kiw/toolbar/download/InstallerControl.cab
Tu lances Hijackthis par Do a system scan only et tu coches ces deux lignes, puis clic sur Fix checked.
Seconde remarque : Tu ne nous donnes pas beaucoup d'indications sur la teneur de tes problèmes, cela peut aider aussi pour diagnostiquer.
Télécharge Antivir Free d'Avira http://dl1.avgate.net/down/windows/antivir_workstation_winu_fr_h.exe Clique sur fichier antivir_workstation_winu_fr_h.exe pour l'installer. Mets-le à jour. Dans Configuration, coche Mode Expert en haut à gauche. Clique sur Scanner, sur Recherche et sur Actions en cas de résultat positif. Dans la partie droite coche Automatique et Copier le fichier dans la quarantaine avant l'action. Dans Action principale avec le menu par la flèche choisis réparer Dans Action secondaire renommer. Tu valides tout ces choix par OK. Tu cliques sur l'icône du bureau pour le lancer ou sur celle près de l'horloge. A gauche dans Aperçu > Etat, tu cliques sur Contrôler syst.maintenant. L'analyse peut durée une heure ou plus selon la taille de tes données. Quand la barre de progression sera à 100% tu cliques sur Rapport. Tu fais un copier-coller de la totalité dans ta réponse puis tu le fermes et tu cliques sur Arrêter. Tu le retrouveras dans Aperçu > Rapports > Recherche avec la date correspondante. Double-clique dessus et ensuite sur Rapport pour l'ouvrir.
Rappel pour copier coller: CTRL+A pour tout sélectionner CTRL+C pour copier CTRL+V pour coller dans la réponse
Tu joindras un nouveau rapport Hijackthis. @+ |
Posté le 02/06/2009 à 03:06 |
| salut , en executant la premiere etape jé recu le message suivant : la modification du registre est interdite .
jé pas pu telecharger avira , je telecharge le fichier , mais une fois que je veux l'installer ; et en appuyant sur executer , tout disparait , et je ne le trouve nul part.
Logfile of Trend Micro HijackThis v2.0.2 Scan saved at 01:06:10, on 02/06/2009 Platform: Windows XP SP3 (WinNT 5.01.2600) MSIE: Internet Explorer v8.00 (8.00.6001.18702) Boot mode: Normal
Running processes: C:\WINDOWS\System32\smss.exe C:\WINDOWS\system32\winlogon.exe C:\WINDOWS\system32\services.exe C:\WINDOWS\system32\lsass.exe C:\WINDOWS\system32\svchost.exe C:\WINDOWS\System32\svchost.exe C:\WINDOWS\system32\spoolsv.exe C:\Program Files\Java\jre6\bin\jqs.exe C:\Program Files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe C:\WINDOWS\system32\svchost.exe C:\WINDOWS\system32\SearchIndexer.exe C:\WINDOWS\system32\wbem\wmiapsrv.exe C:\WINDOWS\Explorer.EXE C:\Program Files\QuickTime\qttask.exe C:\Program Files\Real\RealOne Player\realplay.exe C:\WINDOWS\system32\ctfmon.exe C:\Program Files\Windows Live\Messenger\msnmsgr.exe C:\Program Files\Eraser\eraser.exe C:\Program Files\Windows Desktop Search\WindowsSearch.exe C:\Documents and Settings\hp\Application Data\Microsoft\Notification de cadeaux MSN\lsnfier.exe C:\Program Files\Windows Live\Contacts\wlcomm.exe C:\Program Files\internet explorer\iexplore.exe C:\Program Files\internet explorer\iexplore.exe C:\Program Files\Windows Live\Toolbar\wltuser.exe C:\DOCUME~1\hp\LOCALS~1\Temp\qjrhka.exe C:\DOCUME~1\hp\LOCALS~1\Temp\winarcr.exe C:\WINDOWS\system32\WISPTIS.EXE C:\DOCUME~1\hp\LOCALS~1\Temp\winfkbhs.exe C:\DOCUME~1\hp\LOCALS~1\Temp\winjdfobg.exe C:\DOCUME~1\hp\LOCALS~1\Temp\winolhv.exe C:\DOCUME~1\hp\LOCALS~1\Temp\tfdna.exe C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.bladinet.net/ R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157 R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896 R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896 R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Liens O2 - BHO: Aide pour le lien d'Adobe PDF Reader - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Fichiers communs\Adobe\Acrobat\ActiveX\AcroIEHelper.dll O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Fichiers communs\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - (no file) O2 - BHO: (no name) - {5C255C8A-E604-49b4-9D64-90988571CECB} - (no file) O2 - BHO: Search Helper - {6EBF7485-159F-4bff-A14F-B9E3AAC4465B} - C:\Program Files\Microsoft\Search Enhancement Pack\Search Helper\SEPsearchhelperie.dll O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre6\bin\ssv.dll O2 - BHO: Programme d'aide de l'Assistant de connexion Windows Live - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Fichiers communs\Microsoft Shared\Windows Live\WindowsLiveLogin.dll O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.1.1309.3572\swg.dll O2 - BHO: Google Dictionary Compression sdch - {C84D72FE-E17D-4195-BB24-76C02E2E7C4E} - C:\Program Files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll O2 - BHO: Windows Live Toolbar Helper - {E15A8DC0-8516-42A1-81EA-DC94EC1ACF10} - C:\Program Files\Windows Live\Toolbar\wltcore.dll O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll O3 - Toolbar: &Windows Live Toolbar - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - C:\Program Files\Windows Live\Toolbar\wltcore.dll O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime O4 - HKLM\..\Run: [RealTray] C:\Program Files\Real\RealOne Player\realplay.exe SYSTEMBOOTHIDEPLAYER O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\Windows Live\Messenger\msnmsgr.exe" /background O4 - HKCU\..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe O4 - HKCU\..\Run: [Eraser] C:\Program Files\Eraser\eraser.exe -hide O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM') O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user') O4 - Startup: Notification de cadeaux MSN.lnk = C:\Documents and Settings\hp\Application Data\Microsoft\Notification de cadeaux MSN\lsnfier.exe O4 - Global Startup: DSLMON.lnk = C:\Program Files\Menara\dslmon.exe O4 - Global Startup: Windows Search.lnk = C:\Program Files\Windows Desktop Search\WindowsSearch.exe O7 - HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System, DisableRegedit=1 O8 - Extra context menu item: Add to Windows &Live Favorites - http://favorites.live.com/quickadd.aspx O8 - Extra context menu item: E&xporter vers Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000 O8 - Extra context menu item: Ouvrir dans un nouvel onglet d'arrière-plan - res://C:\Program Files\Windows Live Toolbar\Components\fr-fr\msntabres.dll.mui/229?8f4ca0d0e1e64f9880ca97f50b1810a0 O8 - Extra context menu item: Ouvrir dans un nouvel onglet de premier plan - res://C:\Program Files\Windows Live Toolbar\Components\fr-fr\msntabres.dll.mui/230?8f4ca0d0e1e64f9880ca97f50b1810a0 O9 - Extra button: Ajout Direct - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll O9 - Extra 'Tools' menuitem: &Ajout Direct dans Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll O9 - Extra button: Recherche - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL O9 - Extra button: Real.com - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\system32\Shdocvw.dll O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe (file missing) O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe (file missing) O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe O10 - Unknown file in Winsock LSP: c:\windows\system32\nwprovau.dll O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204 O16 - DPF: {1851174C-97BD-4217-A0CC-E908F60D5B7A} (Hewlett-Packard Online Support Services) - http://h50203.www5.hp.com/HPISWeb/Customer/cabs/HPISDataManager.CAB O16 - DPF: {67DABFBF-D0AB-41FA-9C46-CC0F21721616} - http://go.divx.com/plugin/DivXBrowserPlugin.cab O16 - DPF: {73ECB3AA-4717-450C-A2AB-D00DAD9EE203} (GMNRev Class) - http://h20270.www2.hp.com/ediags/gmn2/install/HPProductDetection2.cab O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} (Java Runtime Environment 1.6.0) - http://javadl.sun.com/webapps/download/AutoDL?BundleId=24931 O16 - DPF: {BDBDE413-7B1C-4C68-A8FF-C5B2B4090876} (F-Secure Online Scanner 3.3) - http://support.f-secure.com/ols/fscax.cab O16 - DPF: {C237A80A-4C55-4C68-BAA9-CBE4408D12B2} (F-Secure Online Scanner 4.0 Launcher) - http://download.sp.f-secure.com/ols/f-secure-rtm/resources/fslauncher.cab O16 - DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/MessengerStatsPAClient.cab56907.cab O17 - HKLM\System\CCS\Services\Tcpip\..\{71BA674A-663F-49DA-92FE-8E035C1A530A}: NameServer = 62.251.229.223 62.251.229.237 O18 - Protocol: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\PROGRA~1\FICHIE~1\Skype\SKYPE4~1.DLL O18 - Filter: x-sdch - {B1759355-3EEC-4C1E-B0F1-B719FE26E377} - C:\Program Files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll O23 - Service: AG Windows Service (AGWinService) - Unknown owner - C:\Program Files\AGI\common\win32\PythonService.exe (file missing) O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Fichiers communs\InstallShield\Driver\11\Intel 32\IDriverT.exe O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe O23 - Service: Remote Packet Capture Protocol v.0 (experimental) (rpcapd) - CACE Technologies - C:\Program Files\WinPcap\rpcapd.exe O23 - Service: VNC Server (winvnc) - Unknown owner - C:\Program Files\TightVNC\WinVNC.exe (file missing)
-- End of file - 9315 bytes
Posté le 02/06/2009 à 03:19 |
| les problemes que je rencontre avec mon ordi sont les suivants :
1/ quand je l'allume y a un message qui apparait:
* Surabaya in my birthday Don't kill me, i'm just send message from your computer Terima kasih telah menemaniku walaupun hanya sesaat, tapi bagiku sangat berarti Maafkan jika kebahagiaan yang kuminta adalah teman sepanjang hidupku Seharusnya aku mengerti bahwa keberadaanku bukanlah disisimu, hanyalah lamunan dalam sesal Untuk kekasih yang tak kan pernah kumiliki 3r1k1m0 * ou je dois cliquer pour continuer.
2/ impossible a acceder au c:/
3/ des programmes que j'ai desinstaller et que je trouve toujours des traces.
4/ au niveau du telechargement des problemes que j'ai rencontré avec avira par exemple
5/ demmarage et execution un peu lente de mon ordi
6/ j'arrive pas et je ne sais pas comment installer des mises a jours a mon modem sagem
je crois que cé tout , merci |
Posté le 02/06/2009 à 10:45 |
A partir d'un autre pc, si tu en as la possibilité, tu télécharges CCleaner et Avira Antivir.
Tu transfères les fichiers d'installations sur ton pc et tu coupes la connexion en débranchant ton modem par exemple.
Tu installes les deux programmes et tu redémarres.
CCleaner Slim
Clique sur : CCleaner v2.20.9250- Slim / No Toolbar / 979 KB / Download now...(en bas). Installes-le. Dans Options, Avancé, tu retires la coche devant : Effacer uniquement les fichiers, du dossier temp de Windows, plus vieux que 48 heures
AntiVir Personal
Une fois rdémarré :
Tu nettoies les fichiers temporaires avec CCleaner.
Dans la page principale, (clic sur le pinceau à gauche), clique sur Analyse Une fois celle-ci terminée, clique sur Lancer le nettoyage et confirme la suppression des fichiers.
Pour Antivir
Tu te reconnectes. Tu fais un copier-coller de la totalité dans ta réponse puis tu le fermes et tu cliques sur Arrêter. Tu le retrouveras dans Aperçu > Rapports > Recherche avec la date correspondante. Double-clique dessus et ensuite sur Rapport pour l'ouvrir.
- CTRL+A pour tout sélectionner
- CTRL+C pour copier
- CTRL+V pour coller dans la réponse
Posté le 02/06/2009 à 21:38 |
| resalut , impossible de telecharger avira |
Posté le 02/06/2009 à 21:42 |
Grand Maître astucien | Bonsoir.
Même à partir d'un autre pc ?
Posté le 03/06/2009 à 22:43 |
| salut jé telecharger avira personnel et graver sur un cd , depuis un cyber. mais une fois chez moi jé constaté que cé compressé , je l'ouvre et il y a plein de trucs qui s'affichent . je fais comment pour l'installer ? |
Posté le 03/06/2009 à 23:49 |
Il suffit de mettre les setup téléchargés sur une clé USB par exemple, si tu passes par un cyber café.
Il faut la vacciner au paravant.
Vaccin USB (Gof)
Posté le 04/06/2009 à 03:20 |
| Avira Premium Security Suite Updater
Creation time: Thu Jun 04 00:48:19 2009
Operating system: Windows XP (Service Pack 3) [5.1.2600]
Product information: Product version: 9.0.0.327 Updater: C:\Program Files\Avira\AntiVir Desktop\update.exe 09.00.00.32
Temp Directory: C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\ Backup folder: C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\BACKUP\ Installation Directory: C:\Program Files\Avira\AntiVir Desktop\ Updater folder: C:\Program Files\Avira\AntiVir Desktop\ AppData folder: C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\
[UPD] [INFO] Checking whether newer files are available. [UPD] [INFO] Select update server 'http://62.146.87.171/update'. [UPD] [INFO] Downloading of 'http://62.146.87.171/update/idx/master.idx' to 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\idx\master.idx'. [UPD] [INFO] Downloading of 'http://62.146.87.171/update/idx/wks_avira-win32-en-isec.idx' to 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\idx\wks_avira-win32-en-isec.idx'. [UPD] [INFO] Downloading of 'http://62.146.87.171/update/idx/wks_avira-win32-en-isec.info.gz' to 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\idx\wks_avira-win32-en-isec.info.gz'. [UPD] [INFO] Downloading of 'http://62.146.87.171/update/idx/webcat-common-int.info.gz' to 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\idx\webcat-common-int.info.gz'. [UPD] [INFO] Downloading of 'http://62.146.87.171/update/idx/vdf.info.gz' to 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\idx\vdf.info.gz'. [UPD] [INFO] Downloading of 'http://62.146.87.171/update/idx/ave2-win32-int.info.gz' to 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\idx\ave2-win32-int.info.gz'. [UPD] [INFO] Downloading of 'http://62.146.87.171/update/idx/antispam-win32-int.info.gz' to 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\idx\antispam-win32-int.info.gz'. [UPD] [INFO] Downloading of 'http://62.146.87.171/update/idx/specvir-win32-int.info.gz' to 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\idx\specvir-win32-int.info.gz'. [UPD] [INFO] Downloading of 'http://62.146.87.171/update/idx/wks_avira-win32-en-isec-info.info.gz' to 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\idx\wks_avira-win32-en-isec-info.info.gz'. [UPD] [INFO] Compare local files with status of update server [UPD] [INFO] Checking module SELFUPDATE: [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/update.dll' (local, server): 00.01.00.26 < 00.01.00.31 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/update.exe' (local, server): 09.00.00.32 < 09.00.00.46 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/updaterc.dll' (local, server): 09.00.19.00 < 09.00.20.01 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/updgui.dll' (local, server): 09.00.00.05 < 09.00.00.06 [UPD] [INFO] File 'wks_avira/win32/en/isec-nt/antivir.oem' (local, server): 37b5f9a7ce31fca190f2a88d1e8a2ae9 != 42f4cb4e009b3b20282d3aa3e8889f66 [UPD] [INFO] File 'wks_avira/win32/en/isec-nt/rcimage.dll' (local, server): 09.00.00.19 < 09.00.00.22 [UPD] [INFO] File 'wks_avira/win32/en/isec-nt/rctext.dll' (local, server): 09.00.25.00 < 09.00.37.00 [UPD] [INFO] Checking module WEBCAT: [UPD] [INFO] File 'webcat/common/int/webcat0.dat' (local, server): 51ac45a81babceb13a437d9d39c6d07a != 45d3393a6230b4163bef72a7fefa329d [UPD] [INFO] File 'webcat/common/int/webcat1.dat' (local, server): 70d244c807583935e526dca80c5a15b7 != dff119901565bc2c75487bcc412d977c [UPD] [INFO] File 'webcat/common/int/webcat2.dat' (local, server): 6c47099973b1d0dcdd99f581b31d74b2 != 41da52fc462e612465b7fd1f330e2d51 [UPD] [INFO] File 'webcat/common/int/webcat3.dat' (local, server): 4efe29aa44c7ff4c31ce7512333dae65 != a0ef3c8fecbb1ba8b1b5cd3e2ac55070 [UPD] [INFO] File 'webcat/common/int/webcat4.dat' (local, server): b4eda102ea7a96acda7be0601300f546 != 65e8ea50ebb75cbbb212bdbe09a36b90 [UPD] [INFO] Checking module VDF: [UPD] [INFO] File 'vdf/antivir1.vdf' (local, server): 07.01.01.11 < 07.01.02.12 [UPD] [INFO] File 'vdf/antivir2.vdf' (local, server): 07.01.01.17 < 07.01.04.38 [UPD] [INFO] File 'vdf/antivir3.vdf' (local, server): 07.01.01.20 < 07.01.04.54 [UPD] [INFO] Checking module AVE2: [UPD] [INFO] File 'ave2/win32/int/aecore.dll' (local, server): 08.01.06.03 < 08.01.06.12 [UPD] [INFO] File 'ave2/win32/int/aegen.dll' (local, server): 08.01.01.12 < 08.01.01.44 [UPD] [INFO] File 'ave2/win32/int/aehelp.dll' (local, server): 08.01.02.00 < 08.01.02.02 [UPD] [INFO] File 'ave2/win32/int/aeheur.dll' (local, server): 08.01.00.89 < 08.01.00.12 [UPD] [INFO] File 'ave2/win32/int/aeoffice.dll' (local, server): 08.01.00.33 < 08.01.00.36 [UPD] [INFO] File 'ave2/win32/int/aepack.dll' (local, server): 08.01.03.05 < 08.01.03.18 [UPD] [INFO] File 'ave2/win32/int/aescn.dll' (local, server): 08.01.01.06 < 08.01.02.03 [UPD] [INFO] File 'ave2/win32/int/aescript.dll' (local, server): 08.01.01.39 < 08.01.02.00 [UPD] [INFO] File 'ave2/win32/int/aeset.dat' (local, server): 08.02.00.70 < 08.02.00.18 [UPD] [INFO] File 'ave2/win32/int/aevdf.dll' (local, server): 08.01.01.00 < 08.01.01.01 [UPD] [INFO] File 'ave2/win32/int/unacev2.dll' (local, server): 02.06.00.00 < 02.06.00.02 [UPD] [INFO] Checking module ANTISPAM: [UPD] [INFO] File 'antispam/win32/int/antispam.dll' (local, server): 09.00.00.05 < 09.00.00.08 [UPD] [INFO] File 'antispam/win32/int/global_words.db' (local, server): aee4a15e478d793962a46134e0f70a71 != d31abb27fa4d0851a06ddcc49d5d1742 [UPD] [INFO] File 'antispam/win32/int/settings.db' (local, server): 60b9aec02e61658a207406d03b3dc7d5 != 25301a75e90893edcc5650b2ba8ea9d3 [UPD] [INFO] Checking module AVREP_NT: [UPD] [INFO] Checking module MAIN: [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/avarkt.dll' (local, server): 01.00.00.23 < 09.00.00.03 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/avconfig.dll' (local, server): 09.00.00.22 < 09.00.00.31 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/avconfig.exe' (local, server): 09.00.00.16 < 09.00.00.21 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/avconfigrc.dll' (local, server): 09.00.04.00 < 09.00.04.03 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/avesvc.dll' (local, server): 09.00.02.02 < 09.00.02.03 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/avfwim.inf' (local, server): 98ca5c6e70a88cab84e4990f7a2382b2 != 4bb41834c04f5c25b2a8aef0d782c6a1 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/avfwot.inf' (local, server): f189c49ba13e135a12102f58f21bb09e != 4f42245f83d4bb4cec4d11133002a68f [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/avfwsvc.exe' (local, server): 09.03.00.06 < 09.03.11.06 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/avgnt.exe' (local, server): 09.00.00.10 < 09.00.00.12 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/avguard.exe' (local, server): 09.00.01.25 < 09.00.01.26 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/avmailc.exe' (local, server): 08.00.01.17 < 09.00.01.08 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/avmailcr.dll' (local, server): 08.00.17.00 < 09.00.02.00 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/avscan.dll' (local, server): 09.00.02.00 < 09.00.03.00 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/avscan.exe' (local, server): 09.00.02.03 < 09.00.03.05 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/avsda.dll' (local, server): 08.00.02.02 < 09.00.00.01 [UPD] [INFO] The file 'wks_avira/win32/en/basic-nt/avupgsvc.exe' has been marked with the IGNORE flag and is therefore not included. [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/avwebgrd.exe' (local, server): 09.00.02.00 < 09.00.03.00 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/avwmi.dll' (local, server): 09.00.18.01 < 09.00.19.00 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/ccev.dll' (local, server): 09.00.00.12 < 09.00.00.13 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/ccfw.dll' (local, server): 09.00.10.00 < 09.00.22.00 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/ccfwgnt.dll' (local, server): 09.00.10.00 < 09.00.22.00 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/ccfwitf.dll' (local, server): 09.00.10.00 < 09.00.22.00 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/ccfwrc.dll' (local, server): 09.00.10.00 < 09.00.22.00 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/ccgen.dll' (local, server): 09.00.00.29 < 09.00.00.35 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/ccgenrc.dll' (local, server): 09.00.14.00 < 09.00.17.01 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/ccgrdrc.dll' (local, server): 09.00.04.00 < 09.00.06.02 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/ccmgrdrc.dll' (local, server): 09.00.01.01 < 09.00.03.01 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/ccmguard.dll' (local, server): 09.00.00.08 < 09.00.00.13 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/ccprofil.dll' (local, server): 09.00.00.13 < 09.00.00.15 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/ccquamgr.dll' (local, server): 09.00.00.11 < 09.00.00.13 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/ccquarc.dll' (local, server): 09.00.01.00 < 09.00.02.00 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/ccscanrc.dll' (local, server): 09.00.06.00 < 09.00.06.01 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/ccsched.dll' (local, server): 09.00.00.20 < 09.00.00.21 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/ccupdrc.dll' (local, server): 09.00.06.00 < 09.00.06.01 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/cfglib.dll' (local, server): 09.00.00.08 < 09.00.00.11 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/fact.exe' (local, server): 09.00.00.18 < 09.00.00.20 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/factrc.dll' (local, server): 09.00.16.00 < 09.00.17.01 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/guardgui.exe' (local, server): 09.00.02.01 < 09.00.03.00 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/libiconv2.dll' (local, server): 01.09.02.17 < 01.11.00.00 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/luke.dll' (local, server): 09.00.02.02 < 09.00.03.02 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/mapiaddr.exe' (local, server): 09.00.00.04 < 09.00.00.05 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/mgrs.dll' (local, server): 09.00.00.03 < 09.00.00.04 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/netsf_m.inf' (local, server): 21c60c9f2129ed0508102a39565cf77c != fb201a752e248be50444ab2e3b5ecb97 [UPD] [INFO] The file 'wks_avira/win32/en/basic-nt/presetup.exe' has been marked with the IGNORE flag and is therefore not included. [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/rscdwrc.dll' (local, server): 09.00.00.00 < 09.00.00.01 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/sched.exe' (local, server): 09.00.00.01 < 09.00.00.06 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/setup.dll' (local, server): 09.00.05.00 < 09.00.08.01 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/setup.exe' (local, server): 09.00.00.14 < 09.00.00.23 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/usrreq.exe' (local, server): 09.00.10.00 < 09.00.22.00 [UPD] [INFO] The file 'wks_avira/win32/en/basic-nt/vcredist_x86.exe' has been marked with the IGNORE flag and is therefore not included. [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/webprot.dll' (local, server): 09.00.03.00 < 09.00.04.00 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/xp/avfw.cat' (local, server): 8e33f369599a6a02bb8911815888155b != cde808ea677bab7fc6ca2a8e6d46472d [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/xp/avfw_m.cat' (local, server): fff7c544e385c5e0932e238be149035a != e7f50b78390f66cb7cff330169bd40d2 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/xp/avfwim.sys' (local, server): 09.03.00.06 < 09.03.03.06 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/xp/avfwot.sys' (local, server): 09.03.00.06 < 09.03.11.06 [UPD] [INFO] The file 'wks_avira/win32/en/basic-nt/xp/avgntflt.inf' has been marked with the IGNORE flag and is therefore not included. [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/xp/avgntflt.sys' (local, server): 09.00.03.07 < 09.00.03.12 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/xp/fwinst.exe' (local, server): 09.01.01.06 < 09.03.12.06 [UPD] [INFO] File 'wks_avira/win32/en/isec-nt/alertcat.htm' (local, server): 0aad6ec9190daa741d814e2db83da4e7 != 9155c3bef4487907113f3aa6b59efa51 [UPD] [INFO] File 'wks_avira/win32/en/isec-nt/avevtrc.dll' (local, server): 09.00.03.00 < 09.00.03.01 [UPD] [INFO] File 'wks_avira/win32/en/isec-nt/build.dat' (local, server): 09.00.00.32 < 09.00.00.36 [UPD] [INFO] File 'wks_avira/win32/en/isec-nt/ccplg.xml' (local, server): ee468b3bea0bc636b6135b3101f90eac != d36029fd5f2418ed9eba2249c83dd39e [UPD] [INFO] The file 'wks_avira/win32/en/isec-nt/filelist.ini' has been marked with the IGNORE flag and is therefore not included. [UPD] [INFO] The file 'wks_avira/win32/en/isec-nt/product.ini' has been marked with the IGNORE flag and is therefore not included. [UPD] [INFO] File 'wks_avira/win32/en/isec-nt/rchelp.dll' (local, server): 08.00.00.01 < 09.00.00.01 [UPD] [INFO] File 'wks_avira/win32/en/isec-nt/sweb.zip' (local, server): cc7a8532824aa89a18bbc74e4589cb3a != 79598fef28f50088809a07012e7a9e84 [UPD] [INFO] File 'wks_avira/win32/en/isec-nt/sysscan.avp' (local, server): 4b5826b991e34a711a397a31b037e601 != fb4c8faf6ad1e20505311d17b644cd5f [UPD] [INFO] File 'wks_avira/win32/en/isec-nt/weblink.url' (local, server): e9bbf34aa3d0391b6815c0efcda1dd77 != 896c237e1ae924b02e7a00ebf730514a [UPD] [INFO] Checking module COMMAPPDATA_AV: [UPD] [INFO] File'wks_avira/win32/en/basic-nt/addr_file.html' is already installed and is not being updated. [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/md5db.bin' (local, server): bcb541fa52a23f04e0e70d4a7758e9f4 != 69ae0ddd99201a88ca9ccd769cc3e000 [UPD] [INFO] Checking module COMMAPP: [UPD] [INFO] File'wks_avira/win32/en/isec-nt/produpd.avj' is already installed and is not being updated. [UPD] [INFO] File'wks_avira/win32/en/isec-nt/scanjob.avj' is already installed and is not being updated. [UPD] [INFO] File'wks_avira/win32/en/isec-nt/startupd.avj' is already installed and is not being updated. [UPD] [INFO] File'wks_avira/win32/en/isec-nt/updjob.avj' is already installed and is not being updated. [UPD] [INFO] Checking module COMMAPDATA_AV_PROFILES: [UPD] [INFO] File'wks_avira/win32/en/isec-nt/folder.avb' is already installed and is not being updated. [UPD] [INFO] File'wks_avira/win32/en/isec-nt/folder.avp' is already installed and is not being updated. [UPD] [INFO] File'wks_avira/win32/en/isec-nt/mydocs.avb' is already installed and is not being updated. [UPD] [INFO] File'wks_avira/win32/en/isec-nt/mymusic.avb' is already installed and is not being updated. [UPD] [INFO] File'wks_avira/win32/en/isec-nt/mypics.avb' is already installed and is not being updated. [UPD] [INFO] File'wks_avira/win32/en/isec-nt/rootkit.avp' is already installed and is not being updated. [UPD] [INFO] Checking module TEXT: [UPD] [INFO] File 'wks_avira/win32/en/isec-nt/avwin.chm' (local, server): 2a9e6b4e889e0d655ecf6f3e6ff75b4b != 2fa40cc4ce22e791450af6efc7da1043 [UPD] [INFO] File'wks_avira/win32/en/isec-nt/eula.txt' is already installed and is not being updated. [UPD] [INFO] File 'wks_avira/win32/en/isec-nt/readme.txt' (local, server): 1d742544525b7ae9e3d67add08f82f9c != e907399dabe042f6dbfa379592ffe510 [UPD] [INFO] Checking module DRV: [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/xp/avfwim.sys' (local, server): 09.03.00.06 < 09.03.03.06 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/xp/avfwot.sys' (local, server): 09.03.00.06 < 09.03.11.06 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/xp/avgntflt.sys' (local, server): 09.00.03.07 < 09.00.03.12 [UPD] [INFO] File 'wks_avira/win32/en/basic-nt/xp/avipbb.sys' (local, server): 01.00.02.62 < 01.00.02.86 [UPD] [INFO] Checking module PRODINFO: [UPD] [INFO] License file: Evaluation version [UPD] [INFO] 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\BACKUP\' requires 27194130 bytes of free disk space. [UPD] [INFO] 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\' requires 40792202 bytes of free disk space. [UPD] [INFO] 'C:\Program Files\Avira\AntiVir Desktop\' requires 30917359 bytes of free disk space. [UPD] [INFO] Disk space OK. [UPD] [INFO] Drive: C:\, free capacity: 2534273024 bytes. [UPD] [INFO] This update requires a reboot. [UPD] [INFO] Terminating update because system reboot is not permitted.
Summary: ******** 0 Files downloaded 0 Files installed
00:49:09 The update failed! |
Premium Security Suite Report file date: mercredi 3 juin 2009 23:24
Scanning for 1301540 virus strains and unwanted programs.
Licensee : soukaina el ghouati Serial number : 2202166468-ISECE-0001 Platform : Windows XP Windows version : (Service Pack 3) [5.1.2600] Boot mode : Normally booted Username : hp Computer name : HP-7E00783F7641
Version information: BUILD.DAT : 9.0.0.327 29019 Bytes 05/02/2009 07:51:00 AVSCAN.EXE : 9.0.2.3 462593 Bytes 05/02/2009 07:24:57 AVSCAN.DLL : 9.0.2.0 40705 Bytes 05/02/2009 07:29:48 LUKE.DLL : 9.0.2.2 209665 Bytes 30/01/2009 10:51:18 LUKERES.DLL : 9.0.2.0 12033 Bytes 05/02/2009 07:30:15 ANTIVIR0.VDF : 7.1.0.0 15603712 Bytes 27/10/2008 11:14:13 ANTIVIR1.VDF : 7.1.1.113 2817536 Bytes 14/01/2009 08:16:18 ANTIVIR2.VDF : 7.1.1.172 958464 Bytes 23/01/2009 17:18:28 ANTIVIR3.VDF : 7.1.1.204 415744 Bytes 30/01/2009 08:16:10 Engineversion : 8.2.0.70 AEVDF.DLL : 8.1.1.0 106868 Bytes 30/01/2009 09:11:41 AESCRIPT.DLL : 8.1.1.39 344443 Bytes 30/01/2009 09:11:41 AESCN.DLL : 8.1.1.6 127348 Bytes 30/01/2009 09:11:41 AERDL.DLL : 8.1.1.3 438645 Bytes 04/11/2008 14:58:38 AEPACK.DLL : 8.1.3.5 393588 Bytes 09/01/2009 09:16:31 AEOFFICE.DLL : 8.1.0.33 196987 Bytes 10/12/2008 17:44:54 AEHEUR.DLL : 8.1.0.89 1569143 Bytes 30/01/2009 09:11:41 AEHELP.DLL : 8.1.2.0 119159 Bytes 18/11/2008 13:12:11 AEGEN.DLL : 8.1.1.12 328053 Bytes 30/01/2009 09:11:40 AEEMU.DLL : 8.1.0.9 393588 Bytes 14/10/2008 11:05:56 AECORE.DLL : 8.1.6.3 176501 Bytes 30/01/2009 15:46:02 AEBB.DLL : 8.1.0.3 53618 Bytes 14/10/2008 11:05:56 AVWINLL.DLL : 9.0.0.3 18177 Bytes 12/12/2008 08:47:59 AVPREF.DLL : 9.0.0.1 43777 Bytes 05/12/2008 10:32:15 AVREP.DLL : 8.0.0.3 155905 Bytes 02/02/2009 11:37:52 AVREG.DLL : 9.0.0.0 36609 Bytes 05/12/2008 10:32:09 AVARKT.DLL : 1.0.0.23 307457 Bytes 05/12/2008 10:32:14 AVEVTLOG.DLL : 9.0.0.7 167169 Bytes 30/01/2009 10:37:08 SQLITE3.DLL : 3.6.1.0 326401 Bytes 28/01/2009 15:03:49 SMTPLIB.DLL : 9.2.0.25 28417 Bytes 02/02/2009 08:21:33 NETNT.DLL : 9.0.0.0 11521 Bytes 05/12/2008 10:32:10 RCIMAGE.DLL : 9.0.0.19 2901761 Bytes 05/02/2009 07:51:20 RCTEXT.DLL : 9.0.25.0 90369 Bytes 05/02/2009 07:51:23
Configuration settings for the scan: Jobname.............................: Short system scan after installation Configuration file..................: c:\program files\avira\antivir desktop\setupprf.dat Logging.............................: low Primary action......................: interactive Secondary action....................: ignore Scan master boot sector.............: on Scan boot sector....................: on Process scan........................: on Scan registry.......................: on Search for rootkits.................: off Integrity checking of system files..: off Scan all files......................: Intelligent file selection Scan archives.......................: on Recursion depth.....................: 20 Smart extensions....................: on Macro heuristic.....................: on File heuristic......................: medium Deviating risk categories...........: +APPL,+GAME,+JOKE,+PCK,+SPR,
Start of the scan: mercredi 3 juin 2009 23:24
The scan of running processes will be started Scan process 'avscan.exe' - '1' Module(s) have been scanned Scan process 'notepad.exe' - '1' Module(s) have been scanned Scan process 'avconfig.exe' - '1' Module(s) have been scanned Scan process 'notepad.exe' - '1' Module(s) have been scanned Scan process 'sched.exe' - '1' Module(s) have been scanned Scan process 'winmine.exe' - '1' Module(s) have been scanned Scan process 'setup.exe' - '1' Module(s) have been scanned Scan process 'msiexec.exe' - '1' Module(s) have been scanned Scan process 'presetup.exe' - '1' Module(s) have been scanned Scan process 'avira_premium_security_suite_en.exe' - '1' Module(s) have been scanned Scan process 'wlcsdk.exe' - '1' Module(s) have been scanned C:\DOCUME~1\hp\LOCALS~1\Temp\uvmay.exe [DETECTION] Is the TR/Downloader.Gen Trojan Scan process 'uvmay.exe' - '1' Module(s) have been scanned Module is infected -> 'C:\DOCUME~1\hp\LOCALS~1\Temp\uvmay.exe' C:\DOCUME~1\hp\LOCALS~1\Temp\winjxoah.exe [DETECTION] Is the TR/Downloader.Gen Trojan Scan process 'winjxoah.exe' - '1' Module(s) have been scanned Module is infected -> 'C:\DOCUME~1\hp\LOCALS~1\Temp\winjxoah.exe' C:\DOCUME~1\hp\LOCALS~1\Temp\dpsrut.exe [DETECTION] Is the TR/Downloader.Gen Trojan Scan process 'dpsrut.exe' - '1' Module(s) have been scanned Module is infected -> 'C:\DOCUME~1\hp\LOCALS~1\Temp\dpsrut.exe' C:\DOCUME~1\hp\LOCALS~1\Temp\winvqjvnq.exe [DETECTION] Is the TR/Downloader.Gen Trojan Scan process 'winvqjvnq.exe' - '1' Module(s) have been scanned Module is infected -> 'C:\DOCUME~1\hp\LOCALS~1\Temp\winvqjvnq.exe' C:\DOCUME~1\hp\LOCALS~1\Temp\winkemloo.exe [DETECTION] Is the TR/Downloader.Gen Trojan Scan process 'winkemloo.exe' - '1' Module(s) have been scanned Module is infected -> 'C:\DOCUME~1\hp\LOCALS~1\Temp\winkemloo.exe' Scan process 'WISPTIS.EXE' - '1' Module(s) have been scanned Scan process 'wlcomm.exe' - '1' Module(s) have been scanned C:\DOCUME~1\hp\LOCALS~1\Temp\winkdsjk.exe [DETECTION] Is the TR/Downloader.Gen Trojan Scan process 'winkdsjk.exe' - '1' Module(s) have been scanned Module is infected -> 'C:\DOCUME~1\hp\LOCALS~1\Temp\winkdsjk.exe' C:\DOCUME~1\hp\LOCALS~1\Temp\xbnhc.exe [DETECTION] Is the TR/Spy.Gen Trojan Scan process 'xbnhc.exe' - '1' Module(s) have been scanned Module is infected -> 'C:\DOCUME~1\hp\LOCALS~1\Temp\xbnhc.exe' Scan process 'wltuser.exe' - '1' Module(s) have been scanned Scan process 'iexplore.exe' - '1' Module(s) have been scanned Scan process 'iexplore.exe' - '1' Module(s) have been scanned Scan process 'lsnfier.exe' - '1' Module(s) have been scanned Module is infected -> 'C:\Documents and Settings\hp\Application Data\Microsoft\Notification de cadeaux MSN\lsnfier.exe' Scan process 'dslmon.exe' - '1' Module(s) have been scanned Module is infected -> 'C:\Program Files\Menara\dslmon.exe' Scan process 'eraser.exe' - '1' Module(s) have been scanned Module is infected -> 'C:\Program Files\Eraser\eraser.exe' Scan process 'msnmsgr.exe' - '1' Module(s) have been scanned Scan process 'realplay.exe' - '1' Module(s) have been scanned Module is infected -> 'C:\Program Files\Real\RealOne Player\realplay.exe' Scan process 'ctfmon.exe' - '1' Module(s) have been scanned Scan process 'wmiapsrv.exe' - '1' Module(s) have been scanned Scan process 'explorer.exe' - '1' Module(s) have been scanned Scan process 'searchindexer.exe' - '1' Module(s) have been scanned Scan process 'svchost.exe' - '1' Module(s) have been scanned Scan process 'SeaPort.exe' - '1' Module(s) have been scanned Scan process 'jqs.exe' - '1' Module(s) have been scanned Scan process 'svchost.exe' - '1' Module(s) have been scanned Scan process 'spoolsv.exe' - '1' Module(s) have been scanned Scan process 'svchost.exe' - '1' Module(s) have been scanned Scan process 'svchost.exe' - '1' Module(s) have been scanned Scan process 'svchost.exe' - '1' Module(s) have been scanned Scan process 'svchost.exe' - '1' Module(s) have been scanned Scan process 'svchost.exe' - '1' Module(s) have been scanned Scan process 'lsass.exe' - '1' Module(s) have been scanned Scan process 'services.exe' - '1' Module(s) have been scanned Scan process 'winlogon.exe' - '1' Module(s) have been scanned Scan process 'csrss.exe' - '1' Module(s) have been scanned Scan process 'smss.exe' - '1' Module(s) have been scanned Process 'uvmay.exe' has been terminated Process 'winjxoah.exe' has been terminated Process 'dpsrut.exe' has been terminated Process 'winvqjvnq.exe' has been terminated Process 'winkemloo.exe' has been terminated Process 'winkdsjk.exe' has been terminated Process 'xbnhc.exe' has been terminated Process 'lsnfier.exe' has been terminated Process 'dslmon.exe' has been terminated Process 'eraser.exe' has been terminated Process 'realplay.exe' has been terminated C:\DOCUME~1\hp\LOCALS~1\Temp\uvmay.exe [DETECTION] Is the TR/Downloader.Gen Trojan [NOTE] The file was moved to '4a940713.qua'! C:\DOCUME~1\hp\LOCALS~1\Temp\winjxoah.exe [DETECTION] Is the TR/Downloader.Gen Trojan [WARNING] An error has occurred and the file was not deleted. ErrorID: 26004 [WARNING] The source file could not be found. [NOTE] Attempting to perform action using the ARK library. [WARNING] Error in ARK library [NOTE] The file is scheduled for deleting after reboot. C:\DOCUME~1\hp\LOCALS~1\Temp\dpsrut.exe [WARNING] The file could not be opened! C:\DOCUME~1\hp\LOCALS~1\Temp\winvqjvnq.exe [WARNING] The file could not be opened! C:\DOCUME~1\hp\LOCALS~1\Temp\winkemloo.exe [WARNING] The file could not be opened! C:\DOCUME~1\hp\LOCALS~1\Temp\winkdsjk.exe [WARNING] The file could not be opened! C:\DOCUME~1\hp\LOCALS~1\Temp\xbnhc.exe [WARNING] The file could not be opened! C:\Documents and Settings\hp\Application Data\Microsoft\Notification de cadeaux MSN\lsnfier.exe [DETECTION] Contains code of the W32/Sality.AA Windows virus [NOTE] The file is scheduled for deleting after reboot. C:\Program Files\Menara\dslmon.exe [DETECTION] Contains code of the W32/Sality.AA Windows virus [NOTE] The file is scheduled for deleting after reboot. C:\Program Files\Eraser\eraser.exe [DETECTION] Contains code of the W32/Sality.AA Windows virus [NOTE] The file is scheduled for deleting after reboot. C:\Program Files\Real\RealOne Player\realplay.exe [DETECTION] Contains code of the W32/Sality.AA Windows virus [NOTE] The file is scheduled for deleting after reboot.
58 processes with 47 modules were scanned
Starting master boot sector scan:
Start scanning boot sectors:
Starting to scan executable files (registry). C:\Program Files\Messenger\msmsgs.exe [DETECTION] Contains code of the W32/Sality.AA Windows virus C:\Program Files\Messenger\msmsgs.exe [DETECTION] Contains code of the W32/Sality.AA Windows virus C:\Program Files\Menara\dslmon.exe [DETECTION] Contains code of the W32/Sality.AA Windows virus C:\Documents and Settings\hp\Application Data\Microsoft\Notification de cadeaux MSN\lsnfier.exe [DETECTION] Contains code of the W32/Sality.AA Windows virus
The registry was scanned ( '60' files ).
Beginning disinfection: C:\Program Files\Messenger\msmsgs.exe [DETECTION] Contains code of the W32/Sality.AA Windows virus [WARNING] The file was ignored! C:\Program Files\Messenger\msmsgs.exe [DETECTION] Contains code of the W32/Sality.AA Windows virus [WARNING] The file was ignored! C:\Program Files\Menara\dslmon.exe [DETECTION] Contains code of the W32/Sality.AA Windows virus [WARNING] The file was ignored! C:\Documents and Settings\hp\Application Data\Microsoft\Notification de cadeaux MSN\lsnfier.exe [DETECTION] Contains code of the W32/Sality.AA Windows virus [WARNING] The file was ignored!
End of the scan: mercredi 3 juin 2009 23:27 Used time: 02:14 Minute(s)
The scan has been done completely.
0 Scanning directories 633 Files were scanned 21 viruses and/or unwanted programs were found 0 Files were classified as suspicious: 0 files were deleted 0 files were repaired 1 files were moved to quarantine 0 files were renamed 5 Files cannot be scanned 607 Files not concerned 3 Archives were scanned 10 Warnings 6 Notes
The repair notes were written to the file 'C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\PROFILES\AVSCAN-20090603-232725-CAE8CF0B.avp'. |
Posté le 04/06/2009 à 09:29 |
Grand Maître astucien | Bionjour.
Tu as choppé une belle "saleté" .
Si le nettoyage de Antivir te permet d'accéder à davantage de fonction, fais ce qui suit.
IMPORTANT: Sauvegarde rapidement toutes tes données autres que les fichiers exe et assure-toi que tu disposes de moyens de réinstallation du système. CD/DVD d'installation du système ou CD/DVD de restauration (avec les versions préinstallées sur ordinateur d'usine). Ceci en cas de besoin, car la décontamination n'est pas garantie. Ne pas faire de scan avec Bitdefender dans l'état actuel des choses.
- Télécharge la version d'évaluation de Kaspersky Antivirus : http://www.kaspersky.com/fr/trials?chapter=186498689 - Tutorial : http://www.malekal.com/tutorial_Kaspersky_trial.html - Désinstalle Antivir et installe Kaspersky. - Démarre en mode sans échec.
Après la fermeture de la première fenêtre du BIOS, au tout début de la phase de démarrage du PC (boot), appuyer sur F8. Une fenêtre de type DOS s'ouvre, sélectionner Mode sans échec à l'aide des flèches du clavier et cliquer sur Entrée (Enter) Ne t'inquiète pas de l'aspect, Windows démarre avec le minimum nécessaire et peut prendre quelque minutes pour démarrer. Il faut choisir la même session qu'en mode normal et non pas la session Administrateur qui n'apparaît que sous ce mode.
- Démarre Kaspersky à partir du Menu Démarrer - Tous les programmes - Kaspersky Anti-virus - Une icône avec un K grisé apparaît près de l'horloge. - Clique droit sur cette icône, puis "Analyser le Poste de travail" dans le menu contextuel qui s'ouvre. - Le scan de l'ordinateur va démarrer - Le scan terminé, supprime tout ce qui a été détecté. - Créé un rapport à partir du bouton Enregistrer-sous en bas de la fenêtre, enregistre le fichier sous le nom Kaspersky.txt sur ton bureau - Redémarre en mode normal. - Double-clique sur le fichier Kaspersky.txt qui se trouve sur ton bureau et copie-colle le rapport dans ta réponse.
Posté le 07/06/2009 à 00:06 |
| salut jé executé kaspersky en mode sans echec , apres mon ordi ne marchait plus , donc jété forcé de le fomater ,la cé mieux.
mais mon modem de marque sagem fast 800-840 , deconne toujours- non synchroniser- , il doit faire plusieures tentatives , pour se mettre en marche. |
Posté le 07/06/2009 à 00:13 |
