Petit astucien | Bonjour,
Cela fait 3 fois de suite que la gravure de cds audio finit par un echec (évidemment une fois la simulation terminée) et [boom]
J'ai enregistré le dernier log correspondant à ma gravure foireuse.
Le voici :
25.1.2006
CD Audio
18:27:50 #1 CDADOC -1 File Cdadoc.cpp, Line 1465
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 16:27.16, Pause frames: 150, Filters: 1, Name: '01 - 09-15-00 (Part One).mp3'.
Track 02: Length: 06:16.57, Pause frames: 150, Filters: 1, Name: '02 - 09-15-00 (Part Two).mp3'.
Track 03: Length: 20:42.26, Pause frames: 150, Filters: 1, Name: '03 - Rockets Fall On Rockets Fall.mp3'.
Track 04: Length: 21:22.24, Pause frames: 150, Filters: 1, Name: '04 - Motherfucker=Redeemer (Part One).mp3'.
Track 05: Length: 10:10.53, Pause frames: 150, Filters: 1, Name: '05 - Motherfucker=Redeemer (Part Two).mp3'.
Total size: 75:09.26
18:27:50 #2 Text 0 File Burncd.cpp, Line 2948
ASUS CRW-5232AS
FlextraLink activés
18:27:50 #3 Text 0 File Reader.cpp, Line 127
Reader running
18:27:50 #4 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
18:27:50 #5 Text 0 File Writer.cpp, Line 122
Writer ASUS CRW-5232AS running
18:27:50 #6 Text 0 File Burncd.cpp, Line 3233
Turn on Disc-At-Once, using CD-R/RW media
18:27:50 #7 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 338050 ( 75:09.25)
18:27:50 #8 Text 0 File DlgWaitCD.cpp, Line 282
Write in overburning mode: NO (enabled: CD)
18:27:50 #9 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: ASUS CRW-5232AS;
CDR code: 00 97 15 05; OSJ entry from: TDK Corporation
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 0F 05 (LI 97:15.05), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
18:27:50 #10 Text 0 File DlgWaitCD.cpp, Line 448
>>> Protocol of DlgWaitCD activities: <<<
18:27:50 #11 Text 0 File ThreadedTransferInterface.cpp, Line 838
Setup items (after recorder preparation)
0: TRM_AUDIO_NOPRE (01 - 09-15-00 (Part One).mp3)
2 indices, index0 (150) not provided
original disc pos #0 + 74041 (74041) = #74041/16:27.16
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 74041 blocks [ASUS CRW-5232AS]
1: TRM_AUDIO_NOPRE (02 - 09-15-00 (Part Two).mp3)
original disc pos #0 + 28257 (28257) = #28257/6:16.57
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 28257 blocks [ASUS CRW-5232AS]
2: TRM_AUDIO_NOPRE (03 - Rockets Fall On Rockets Fall.mp3)
original disc pos #0 + 93176 (93176) = #93176/20:42.26
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 93176 blocks [ASUS CRW-5232AS]
3: TRM_AUDIO_NOPRE (04 - Motherfucker=Redeemer (Part One).mp3)
original disc pos #0 + 96174 (96174) = #96174/21:22.24
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 96174 blocks [ASUS CRW-5232AS]
4: TRM_AUDIO_NOPRE (05 - Motherfucker=Redeemer (Part Two).mp3)
original disc pos #0 + 45803 (45803) = #45803/10:10.53
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 45803 blocks [ASUS CRW-5232AS]
18:27:50 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [ASUS CRW-5232AS] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 5:
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 174497232, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 174497232 174850032 241310496, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 241310496 241663296 460813248, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 460813248 461166048 687367296, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 687367296 687720096 795448752, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
-150 | lead-in | 0 | 0x01 | 0x00
-150 | 1 | 0 | 0x21 | 0x00
0 | 1 | 1 | 0x21 | 0x00
74041 | 2 | 0 | 0x21 | 0x00
74191 | 2 | 1 | 0x21 | 0x00
102448 | 3 | 0 | 0x21 | 0x00
102598 | 3 | 1 | 0x21 | 0x00
195774 | 4 | 0 | 0x21 | 0x00
195924 | 4 | 1 | 0x21 | 0x00
292098 | 5 | 0 | 0x21 | 0x00
292248 | 5 | 1 | 0x21 | 0x00
338051 | lead-out | 1 | 0x01 | 0x00
18:29:00 #13 Phase 28 File dlgbrnst.cpp, Line 1832
Speed measurement started
18:29:00 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2661
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
18:29:00 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2661
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #74191
18:29:00 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2661
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #102598
18:29:00 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2661
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #195924
18:29:00 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2661
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #292248
18:31:08 #19 Text 0 File WriterStatus.cpp, Line 116
<ASUS CRW-5232AS > start writing Lead-Out at LBA 338051 (52883h), lenght 0 blocks
18:31:08 #20 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
18:31:08 #21 Phase 29 File dlgbrnst.cpp, Line 1781
Speed measurement completed: 40.2x (6 030 Ko/s)
18:31:08 #22 Phase 32 File dlgbrnst.cpp, Line 1832
Simulation started at 40x (6 000 Ko/s)
18:31:08 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2661
18:31:08 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2661
18:31:08 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2661
18:31:08 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2661
18:31:08 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2661
18:31:08 #28 Text 0 File Mmc.cpp, Line 17022
StartDAO : CD-Text - On
18:31:08 #29 Text 0 File Mmc.cpp, Line 21774
Set BUFE: FlextraLink -> ON
18:31:08 #30 Text 0 File Mmc.cpp, Line 17311
CueData, Len=96
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 10 1d 10
21 02 01 00 00 10 1f 10
21 03 00 00 00 16 2f 49
21 03 01 00 00 16 31 49
21 04 00 00 00 2b 20 18
21 04 01 00 00 2b 22 18
21 05 00 00 00 40 38 30
21 05 01 00 00 40 3a 30
01 aa 01 01 00 4b 09 1a
18:34:06 #31 Text 0 File WriterStatus.cpp, Line 116
18:34:06 #32 Text 0 File ThreadedTransfer.cpp, Line 228
18:34:13 #33 Phase 33 File dlgbrnst.cpp, Line 1832
Simulation completed successfully at 40x (6 000 Ko/s)
18:34:14 #34 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 40x (6 000 Ko/s)
18:34:14 #35 Text 0 File ThreadedTransferInterface.cpp, Line 2661
18:34:14 #36 Text 0 File ThreadedTransferInterface.cpp, Line 2661
18:34:14 #37 Text 0 File ThreadedTransferInterface.cpp, Line 2661
18:34:14 #38 Text 0 File ThreadedTransferInterface.cpp, Line 2661
18:34:14 #39 Text 0 File ThreadedTransferInterface.cpp, Line 2661
18:34:14 #40 Text 0 File Mmc.cpp, Line 17022
18:34:14 #41 Text 0 File Mmc.cpp, Line 21774
18:34:14 #42 Text 0 File Mmc.cpp, Line 17311
CueData, Len=96
18:35:46 #43 SCSI -1135 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x0B510000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x01 0x8B 0x2C 0x00 0x00 0x1B 0x00 0x00 0x00
Sense Data: 0xF1 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
18:35:46 #44 CDR -1135 File Writer.cpp, Line 311
Write error
18:35:46 #45 Text 0 File ThreadedTransfer.cpp, Line 228
18:35:46 #46 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
18:35:46 #47 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 40x (6 000 Ko/s)
18:35:46 #48 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
18:35:46 #49 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10/09/1999 12:06:00
File 'Drivers\InCDfs.SYS': Ver=4, 3, 20, 1, size=101504 bytes, created 25/07/2005 11:53:28 (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDpass.SYS': Ver=4, 3, 20, 1, size=29696 bytes, created 25/07/2005 11:53:04 (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDrec.SYS': Ver=4, 3, 20, 1, size=8704 bytes, created 25/07/2005 11:53:30 (InCD4 driver for win NT/2K/XP)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 04/08/2004 06:59:42 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
J'espère que vous pourrez m'aider
Petit astucien | Hello [hello]
J'ai parfois eu le même problème je ne sais pas si va marcher pour toi mais ça vaut tout de même le coup d'essayer.
J'ai désactivé la simulation et depuis toutes mes gravures se terminent avec succès que ce soit à 4x, 8x, 10 ou même 24x! | |||||||
Petit astucien | Bonsoir,
Est ce que ca fait la meme chose si tu choisi d'autre MP3?? ou meme la copie d'un Cd Audio??
Il se peut que un de tes MP3 soit partiellement deterioré... | |||||||
Petit astucien | Ah.. je vois DRM vers la fin du rapport. Tu n'essayerais pas par hasard de graver des fichiers audio protégés par DRM? Si oui je te conseille plutôt d'utiliser le lecteur Windows Media pour graver toutes tes musiques sous licence DRM. | |||||||
Petit astucien | Merci o vous2 pour vos réponses, j'ai donc utilisé le lecteur windows media comme tu me le conseillé web-mao et mon cd a été gravé correctement [smile]
Par contre, comment puis-je savoir pour mes futures gravures si les fichiers audio que je veux graver sont protégés par DRM ?
Ce qui permettrait d'utiliser sans risque Nero ou Media Player...
Sinon pour repondre à Serpinh, je ne me rappelle pas avoir eu ce genre de probleme pour des MP3.
Petit astucien | De rien mounzi [smile]
Pour savoir si un fichier musique est sous licence DRM, en cours de lecture avec le lecteur Windows Media dans la barre affichant les meta-données comme les copyrights, le nom d'artiste et d'album lorsqu'une licence a été acquise "Contenu protégé" apparait dans cette même barre.
En cliquant droit sur un fichier protégé depuis le lecteur puis gauche sur propriétés, tu peux voir les détails de la licence comme le nombre de copie autorisé sur périphérique mobile, de gravure sur CD, etc ...
[img]http://www.web-mao.com/images/forum/wmp_drm_contenuprotege.jpg[/img] | |||||||
Petit astucien | Re,
Alors pour verifier ton hypothèse, j'ai ouvert les fichiers musicaux que j'arrivai pas à graver avec Nero avec Windows Media, mais pendant la lecture il n'y a pas "Contenu protégé" dans la barre des meta-données. Je suis allé également sur les propriétés du fichier et rien concernant la licence...Bref mon problème de gravure a été résolu mais comme je suis curieux ([rougir]) je voulais savoir s'il n'y avait pas une autre possibilité à mon problème que j'aimerais éviter le plus souvent possible...
Merci et encore désolé d'insister
Petit astucien | Alors là je vois pas.
Ca aurait pû être un endommagement de tes fichiers qui ne le sont pas ayant pû les graver avec WMP.
Nero aurait pû ne pas trouver les licences s'ils étaient protégés par DRM qui d'après toi ne le sont pas.
Reste encore l'hypothèse d'une vitesse de gravure trop élevée mais à priori non ce n'est pas ça d'après le rapport pour Nero la gravure à 40x est Ok.
Essayes en choisissant une vitesse de gravure inférieure, 10x par ex. Vérifies aussi que ton CD supporte cette vitesse, L'échec de la simulation vient peut-être de là.
Sinon, je ne vois rien d'autre. [triste]
Si rien ne résoud le problème, essayes en désactivant la simulation. C'est ce que j'ai fais ayant rencontré le même problème et ça l'a résolu sans que ça nuise à la gravure. Sans simulation ça ne change absolument rien je met le CD vierge dans le graveur puis choisis une vitesse 4x, 10x, 24x,.. et je démarre la gravure. En quelques dizaines de min le CD est gravé sans problème, la simulation désactivée.
EDIT: Possible que cela vienne de l'ASPI.
Voir pour une éventuelle mise à jour si le problème persiste. Modifié par Rolive le 26/01/2006 22:30 | |||||||
Petit astucien | A ma connaissance
qu'elle Nero utilises-tu car un Bug ce fait en gravure après la mise à jours de néro avec certain pack 1 de windows XP Home
il y a des infos à ce sujet sur le site de Nero avec le correctif! | |||||||
Petit astucien | Est-ce que tu peux graver des donnés sans problèmes ?
Ton bug est juste pour l'audio ? | |||||||
Petit astucien | total111 a écrit :
Ah bon?? Ca m'intéresse j'utilise également Néro 6. Tu pourrais mettre stp le lien vers la page Néro où ils parlent de ce bug?
Merci!A ma connaissance qu'elle Nero utilises-tu car un Bug ce fait en gravure après la mise à jours de néro avec certain pack 1 de windows XP Home il y a des infos à ce sujet sur le site de Nero avec le correctif! | |||||||
Petit astucien | Merci de vos réponse,
Alors j'utilise Nero 6.6.0.18 et je suis sous Windows XP Pro Service Pack 2.
Par contre, ne gravant pas de données je ne peux vous dire s'il y a le meme problème quand je grave des données.
Concernant les cds que j'utilise, pas de souci, ils peuvent etre gravés en 52X et je ne grave qu'en 40X.
Petit astucien | Bonsoirs à tous
voici le lien qui parle du Bug en question qui correspond à Win XP Pack 2
http://www.nero.com/nero6/fra/Support_News_Service_Pack_2_Inquiries.html
Deplus il y a plein d'info sur divers Bugs avec ses résolutions
A consulter
A+ | |||||||
