 Ecran Bleu - Problème carte réseau?
ckiki44
  Posté le 17/01/2014 @ 14:55
... et maintenant c'est ma tour qui tombe en panne!
Mon PC coupe 1 à 2 fois par jour depuis le début de semaine et j'ai 1 écran bleu.
J'ai pu prendre le diagnostic avec "WHO CRASHED" et voici la réponse :
computer name: PC-DE-CHRISTIAN
windows version: Windows Vista Service Pack 2, 6.0, build: 6002
windows dir: C:\Windows
Hardware: ASUSTeK Computer INC., P5Q-PRO
CPU: GenuineIntel Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz Intel586, level: 6
2 logical processors, active mask: 3
RAM: 4292997120 total
VM: 2147352576, free: 1978417152
________________________________________
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Fri 17/01/2014 13:10:46 GMT your computer crashed
crash dump file: C:\Windows\Minidump\Mini011714-02.dmp
This was probably caused by the following module: l1e60x64.sys (0xFFFFFA6002B57E26)
Bugcheck code: 0xD1 (0x28, 0x2, 0x0, 0xFFFFFA6002B57E26)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\drivers\l1e60x64.sys
product: Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller
company: Atheros Communications, Inc.
description: Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: l1e60x64.sys (Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller, Atheros Communications, Inc.).
Google query: Atheros Communications, Inc. DRIVER_IRQL_NOT_LESS_OR_EQUAL
S'agit-il bien de la Carte Réseau qui serait en cause d'après vous?
J'ai essayé d'avoir un nouveau pilote chez "ATHEROS" mais ils me renvoient sur un site
que mon Antivirus ne veut pas (danger intrusion!)
Que me conseillez vous merci encore
beorcs
 Posté le 17/01/2014 à 15:08
traduction en bon Français universel du rapport de WhoCrashed : .
Le vendredi 17.01.2014 13:10:46 GMT votre ordinateur a planté
fichier de vidage sur incident : C : \ Windows \ Minidump \ Mini011714 - 02.dmp
Cela a été probablement causée par le module suivant: l1e60x64.sys ( 0xFFFFFA6002B57E26 )
Bogue de code : 0xD1 ( 0x28 , 0x2 , 0x0 , 0xFFFFFA6002B57E26 )
Erreur: DRIVER_IRQL_NOT_LESS_OR_EQUAL
Chemin du fichier : C : \ Windows \ system32 \ drivers \ l1e60x64.sys
produit : Atheros AR8121/AR8113/AR8114 PCI- E Ethernet Controller
société: Atheros Communications, Inc.
Description : Atheros AR8121/AR8113/AR8114 PCI- E Ethernet Controller
Contrôle de Bug description: Ceci indique qu'un pilote en mode noyau a tenté d' accéder à la mémoire paginable à un IRQL processus qui était trop élevé .
Cela semble être un bug de pilote logiciel typique et n'est pas susceptible d'être causé par un problème matériel .
Un pilote tiers a été identifié comme la cause probable de cette erreur de système . Il est suggéré que vous regardez
pour une mise à jour pour le pilote suivant : l1e60x64.sys ( Atheros AR8121/AR8113/AR8114 PCI- E Ethernet Controller , Atheros Communications , Inc. ) .
Google requête : Atheros Communications , Inc. DRIVER_IRQL_NOT_LESS_OR_EQUAL
ckiki44
 Posté le 17/01/2014 à 19:28
Si je comprends bien c'est le chat qui se mord la queue! Ce serait donc
une mise à jour du pilote de cette carte qui plante la carte? alors que faire?
Pouvez-vous me confirmer bien qu'il s'agit de la carte réseau?
11gsxr35
 Posté le 17/01/2014 à 21:26
Pouvez-vous me confirmer bien qu'il s'agit de la carte réseau? oui
ckiki44
 Posté le 18/01/2014 à 15:54
Avec cette carte mère P5Q PRO faut-il une carte réseau spéciale? Merci
11gsxr35
 Posté le 18/01/2014 à 16:41
Non,une carte pci classique fera l'affaire.
as tu d'abord tenté une maj des pilotes?
ckiki44
 Posté le 18/01/2014 à 18:30
Oui bien sur - tu peux me confirmer qu'il s'agisse bien d'un problème carte réseau et
que je peux prendre une carte pci ordinaire alors la carte réseau d'origine est intégrée à la carte mère
merci
Constance
 Posté le 18/01/2014 à 19:14
Yo .o/
ckiki44 a écrit :
Ce serait donc une mise à jour du pilote de cette carte qui plante la carte?
Quelle mise à jour ? Tu as installé un mise à jour récemment pour ça ?
Si oui, tu peux toujours remettre le pilote précédent, ou voir si 3DP Net ou le site d'Asus t'en propose d'autres.
Modifié par Constance le 18/01/2014 19:15
Kit de 32 Go (2 x 16 Go) de mémoire DDR5 Corsair Vengeance RGB 6000 MHz CL36
369,99 € 449,95 € -18%
Coupe-branches à crémaillère Fiskars Powergear II (diamètre de coupe 3,5 cm)
27,99 € 39,99 € -30%
Liseuse et carnet de notes Kindle Scribe 10.2 pouces 64 Go + stylet premium
344,99 € 479,99 € -28%
Baskets Homme Skechers Summits
29,56 € 51 € -42%
59,99 € 94,99 € -37%
Graveur laser Creality Falcon A1 10W (caméra, 600 mm/s, ventilateur d'extraction)
369 € 589 € -37%
Ecran bleu Windows = Problème carte graphique ?
Probleme carte reseau
Problème carte graphique ( écran éteint)
Problème possible de pilote carte réseau?
PROBLEME CARTE RESEAU BCM 5701 GIGABIT ETHERNET
probleme ecran bleu clair
Ecran bleu,drivers qui plantent,probleme au demarrage...
bloquage ecran bleu ( problème nvidia FX 5000°
probleme acpi (ecran bleu)
probleme reseau suite a changement carte graphique
Plus de sujets relatifs à Ecran Bleu - Problème carte réseau?
