 Erreur gravage avec nero 6
cocokto
  Posté le 22/05/2006 @ 20:56
Je n'arrive pas à graver sur 1 cd des films sur mon ordi,voici les erreurs qui sont marquées puis le log des erreurs:Merci de m'aider !!!! "write error Invalid write state could not perform EndTrack Burn process failed at 4X600KB/S" .... NT-SPTI used Nero Version: 6.6.1.4 Internal Version: 6, 6, 1, 4d (Nero Express) Recorder: <QSI CDRW/DVD SBW-241> Version: VX11 - HA 1 TA 0 - 6.6.1.4 Adapter driver: <IDE> HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ? CD-ROM: <QSI CDRW/DVD SBW-241>Version: VX11 - HA 1 TA 0 - 6.6.1.4 Adapter driver: <IDE> HA 1 === Scsi-Device-Map === DiskPeripheral : TOSHIBA MK3018GAS atapi Port 0 ID 0 DMA: On CdRomPeripheral : QSI CDRW/DVD SBW-241 atapi Port 1 ID 0 DMA: On === CDRom-Device-Map === QSI CDRW/DVD SBW-241 D: CDRom0 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 57671680 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 383MB (392688kB) Free physical memory: 80MB (82008kB) Memory in use : 79 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 22.5.2006 CD-ROM (ISO) 20:30:03 #1 Text 0 File Isodoc.cpp, Line 6475 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : TAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 20:30:03 #2 Text 0 File Burncd.cpp, Line 3012 QSI CDRW/DVD SBW-241 Super Link activated 20:30:03 #3 Text 0 File ThreadedTransfer.cpp, Line 531 ReadBuffer-Pipe got 56320KB of Memory 20:30:03 #4 Text 0 File Reader.cpp, Line 124 Reader running 20:30:03 #5 Text 0 File Writer.cpp, Line 122 Writer QSI CDRW/DVD SBW-241 running 20:30:03 #6 ISO9660GEN -11 File geniso.cpp, Line 3312 First writeable address = 0 (0x00000000) 20:30:04 #7 Text 0 File Burncd.cpp, Line 3305 Turn on Track-At-Once, using CD-R/RW media 20:30:06 #8 Text 0 File DlgWaitCD.cpp, Line 281 Last possible write address on media: 359848 ( 79:59.73) Last address to be written: 357117 ( 79:23.42) 20:30:06 #9 Text 0 File DlgWaitCD.cpp, Line 293 Write in overburning mode: NO (enabled: CD) 20:30:06 #10 Text 0 File DlgWaitCD.cpp, Line 2612 Recorder: QSI CDRW/DVD SBW-241 20:30:06 #11 Text 0 File DlgWaitCD.cpp, Line 459 >>> Protocol of DlgWaitCD activities: <<< ========================================= 20:30:06 #12 Text 0 File ThreadedTransferInterface.cpp, Line 847 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 357118 (357118) = #357118/79:21.43 relocatable, disc pos for caching/writing not required/ required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 357116 blocks [QSI CDRW/DVD SBW-241] -------------------------------------------------------------- 20:30:06 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1059 Prepare recorder [QSI CDRW/DVD SBW-241] for write in TAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 731684864, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ -150 | lead-in | 0 | 0x41 | 0x00 -150 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 357118 | lead-out | 1 | 0x41 | 0x00 20:30:06 #14 Text 0 File ThreadedTransferInterface.cpp, Line 1127 Removed 2 run-out blocks from end of track 1. Length: 357118 -> 357116. 20:30:06 #15 Text 0 File SCSIPassThrough.cpp, Line 38 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 20:30:06 #16 Text 0 File SCSIPassThrough.cpp, Line 83 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 20:30:06 #17 Phase 24 File dlgbrnst.cpp, Line 1685 Caching of files started 20:30:07 #18 Text 0 File Burncd.cpp, Line 4145 Cache writing successful. 20:30:07 #19 Phase 25 File dlgbrnst.cpp, Line 1685 Caching of files completed 20:30:07 #20 Phase 36 File dlgbrnst.cpp, Line 1685 Burn process started at 4x (600 KB/s) 20:30:08 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2685 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 20:30:08 #22 Text 0 File Mmc.cpp, Line 21840 Set BUFE: Super Link -> ON 20:31:16 #23 SPTI -1135 File SCSIPassThrough.cpp, Line 289 D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x0C Sense Qual: 0x00 CDB Data: 0x2A 00 00 00 42 00 00 00 20 00 00 00 Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 0C Buffer x079c0000: Len x10000 0xFA CF 50 34 8B 87 C1 84 BF 09 6A 01 49 EE B7 EE 0xE5 20 2E 12 D5 81 E1 29 4C 6F F6 7A 03 15 FC 15 0x5C 21 08 32 A9 92 AF 0F 8F E0 F8 7C 24 E8 1F 2E 20:31:16 #24 CDR -1135 File Writer.cpp, Line 311 Write error D: QSI CDRW/DVD SBW-241 20:31:17 #25 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 20:31:17 #26 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 20:31:17 #27 CDR -201 File WriterStatus.cpp, Line 200 Invalid write state D: QSI CDRW/DVD SBW-241 20:31:17 #28 TRANSFER -18 File WriterStatus.cpp, Line 200 Could not perform EndTrack 20:31:17 #29 Text 0 File Mmc.cpp, Line 16608 <QSI CDRW/DVD SBW-241> start Close Session 20:31:18 #30 Phase 38 File dlgbrnst.cpp, Line 1685 Burn process failed at 4x (600 KB/s) Existing drivers: File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 17/11/2005 18:19:28 (Prassi/Veritas driver for win 2K)
stimorol
 Posté le 22/05/2006 à 21:34
remplis ta config stp...consulter l'[url="https://forum.pcastuces.com/aide.asp"]aide du forum[/url] pour cela l'erreur survient-elle avec tous les cd, tout type de fichiers ?
Modifié par stimorol le 22/05/2006 21:36
cocokto
 Posté le 22/05/2006 à 21:50
OK voici et merci : Ordinateur SystÞme d'exploitation Microsoft Windows XP Home Edition Service Pack du systÞme Service Pack 2 Carte mÞre Type de processeur Mobile Intel Pentium 4M, 1800 MHz (4.5 x 400) Nom de la carte mÞre Inconnu MÚmoire systÞme 384 Mo (DDR SDRAM) Moniteur Carte vidÚo GeForce4 420 Go 32M (32 Mo) Carte vidÚo NVIDIA MAP17-232 (32 Mo) Moniteur ?cran Plug-and-Play [NoDB] Stockage Disque dur TOSHIBA MK3018GAS (30 Go, 4200 RPM, Ultra-ATA/100) Lecteur optique QSI CDRW/DVD SBW-241 (DVD:8x, CD:24x/16x/24x DVD-ROM/CD-RW)
jorden
 Posté le 22/05/2006 à 22:43
Bonsoir,pour les problemes de ce style tu as plus de chance de voir aboutir ta requete sur le forum support de nero: http://fr.neroforum.org/index.php [hello]
SSD WD Black SN7100 2 To (PCIe Gen4, NMVe M.2, 7250 Mo/s)
158,90 € 194 € -18%
Enceinte connectée Amazon Echo Pop avec assistant Alexa
24,99 € 34,99 € -29%
Adaptateur Bluetooth 5.0 USB TP-Link UB500
5,99 € 15 € -60%
Carte graphique AMD Radeon RX 7900XTX XFX Speedster Merc310 24 Go
829 € 899 € -8%
Clavier sans fil Logitech Wireless Desktop K400 Plus avec pavé tactile
27,99 € 54,99 € -49%
Clavier SteelSeries Apex 3 RVB
49,95 € 79,99 € -38%
@Cdiscount
gravage dvd impossible avec nero
erreur directshow avec nero recode
Message erreur avec nero vision
gravage d'un diaporama avec son sous néro 7 premiu
Echec de gravage avec néro
problème de gravage avec NERO
erreur 031105 avec NERO
erreur pendant l'encodage avec nero
gravage de cd multicession avec Néro
Graver avec Nero
Plus de sujets relatifs à Erreur gravage avec nero 6
