| Hello Leoburd,
Une seule idée : peut-être en remettant à zéro les associations de fichiers pour le html.
- créer un point de restauration
- sur le bureau, clic droit / nouveau / document-texte - valider par la touche entrée - double-clic sur ce fichier - menu Format : vérifier que "Retour automatique à la ligne" soit bien décoché - copier ce qui suit (sans interligne vide avant Windows Registry Editor Version 5.00)
[HKEY_CLASSES_ROOT\.HTML] "Content Type"="text/html" "PerceivedType"="text" @="htmlfile"
[HKEY_CLASSES_ROOT\.HTML\PersistentHandler] @="{eec97550-47a9-11cf-b952-00aa0051fe20}"
[HKEY_CLASSES_ROOT\htmlfile] @="HTML Document" "FriendlyTypeName"="@ieframe.dll,-912"
[HKEY_CLASSES_ROOT\htmlfile\CLSID] @="{25336920-03F9-11cf-8FD0-00AA00686F13}"
[HKEY_CLASSES_ROOT\htmlfile\DefaultIcon] @="\"%1\""
[HKEY_CLASSES_ROOT\htmlfile\ScriptHostEncode] @="{0CF774D0-F077-11D1-B1BC-00C04F86C324}"
[HKEY_CLASSES_ROOT\htmlfile\shell] @="opennew"
[HKEY_CLASSES_ROOT\htmlfile\shell\Edit] @="&Edit"
[HKEY_CLASSES_ROOT\htmlfile\shell\Edit\command] @="\"C:\\PROGRA~1\\MICROS~2\\OFFICE11\\msohtmed.exe\" %1"
[HKEY_CLASSES_ROOT\htmlfile\shell\open] @="Open in S&ame Window" "MUIVerb"="@ieframe.dll,-5732"
[HKEY_CLASSES_ROOT\htmlfile\shell\open\command] @="\"C:\\Program Files\\Internet Explorer\\IEXPLORE.EXE\" -nohome"
[HKEY_CLASSES_ROOT\htmlfile\shell\open\ddeexec] @="\"file://%1\",,-1,,,,," "NoActivateHandler"=""
[HKEY_CLASSES_ROOT\htmlfile\shell\open\ddeexec\Application] @="IExplore"
[HKEY_CLASSES_ROOT\htmlfile\shell\open\ddeexec\Topic] @="WWW_OpenURL"
[HKEY_CLASSES_ROOT\htmlfile\shell\opennew] "MUIVerb"="@ieframe.dll,-5731" @="&Open"
[HKEY_CLASSES_ROOT\htmlfile\shell\opennew\command] @="\"C:\\Program Files\\Internet Explorer\\IEXPLORE.EXE\" %1"
[HKEY_CLASSES_ROOT\htmlfile\shell\opennew\ddeexec] @="\"%1\",,-1,0,,,," "NoActivateHandler"=""
[HKEY_CLASSES_ROOT\htmlfile\shell\opennew\ddeexec\Application] @="IExplore"
[HKEY_CLASSES_ROOT\htmlfile\shell\opennew\ddeexec\IfExec] @="*"
[HKEY_CLASSES_ROOT\htmlfile\shell\opennew\ddeexec\Topic] @="WWW_OpenURLNewWindow"
[HKEY_CLASSES_ROOT\htmlfile\shell\Print] @="&Print"
[HKEY_CLASSES_ROOT\htmlfile\shell\Print\command] @="\"C:\\PROGRA~1\\MICROS~2\\OFFICE11\\msohtmed.exe\" /p %1"
[HKEY_CLASSES_ROOT\htmlfile\shell\printto]
[HKEY_CLASSES_ROOT\htmlfile\shell\printto\command] @=hex(2):72,00,75,00,6e,00,64,00,6c,00,6c,00,33,00,32,00,2e,00,65,00,78,00,65,\ 00,20,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,00,\ 25,00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,6d,00,73,\ 00,68,00,74,00,6d,00,6c,00,2e,00,64,00,6c,00,6c,00,2c,00,50,00,72,00,69,00,\ 6e,00,74,00,48,00,54,00,4d,00,4c,00,20,00,22,00,25,00,31,00,22,00,20,00,22,\ 00,25,00,32,00,22,00,20,00,22,00,25,00,33,00,22,00,20,00,22,00,25,00,34,00,\ 22,00,00,00
[HKEY_CLASSES_ROOT\htmlfile\shellex]
[HKEY_CLASSES_ROOT\htmlfile\shellex\IconHandler] @="{42042206-2D85-11D3-8CFF-005004838597}"
[HKEY_CLASSES_ROOT\htmlfile\shellex\{8895B1C6-B41F-4C1C-A562-0D564250836F}] @="{f8b8412b-dea3-4130-b36c-5e8be73106ac}"
- menu Fichier / enregistrer sous / où tu veux - à Nom du fichier, taper Fusion1.reg - à Type de fichier, sélectionner "Tous les fichiers" - cliquer sur Enregistrer
- double-clic sur le fichier reg (ou clic droit /ouvrir avec Editeur du registre) et accepter la fusion dans le registre - appuyer sur la touche F5 - si pas de changement, redémarrer le PC. Modifié par Anonyme le 07/01/2010 23:26 |
