 impossible d'imprimer
71gilou
  Posté le 01/04/2019 @ 17:19
Je ne peux plus imprimer de documents persos, ou en ligne, depuis 2 jours, peut-etre suite à une mise à jour ( mais je ne suis pas certain ) par contre je peux toujours scanner un document depuis mon imprimante.
J'ai le message suivant: " il manque un filtre dans l'imprimante "
et le diagnostic ci-dessous
Page 1 (<troubleshoot.SchedulerNotRunning.SchedulerNotRunning object at 0x7fe849207da0>):
{'cups_connection_failure': False}
Page 2 (<troubleshoot.ChoosePrinter.ChoosePrinter object at 0x7fe8491fdcc0>):
{'cups_dest': <cups.Dest EPSON-Epson-Stylus-SX440 (default)>,
'cups_instance': None,
'cups_queue': 'EPSON-Epson-Stylus-SX440',
'cups_queue_listed': True}
Page 3 (<troubleshoot.CheckPrinterSanity.CheckPrinterSanity object at 0x7fe8492076a0>):
{'cups_device_uri_scheme': 'dnssd',
'cups_printer_dict': {'device-uri': 'dnssd://Epson%20Stylus%20SX440._pdl-datastream._tcp.local/',
'printer-info': 'EPSON Epson Stylus SX440',
'printer-is-shared': False,
'printer-location': '',
'printer-make-and-model': 'Epson Stylus SX440 Series - '
'epson-inkjet-printer '
'1.0.0-1lsb3.2 (Seiko Epson '
'Corporation LSB 3.2)',
'printer-state': 3,
'printer-state-message': 'File '
'"/usr/lib/cups/backend/dnssd" '
'not available: No such file '
'or directory',
'printer-state-reasons': ['cups-missing-filter-warning'],
'printer-type': 2273292,
'printer-uri-supported': 'ipp://localhost/printers/EPSON-Epson-Stylus-SX440'},
'cups_printer_remote': False,
'is_cups_class': False,
'local_cups_queue_attributes': {'charset-configured': 'utf-8',
'charset-supported': ['us-ascii', 'utf-8'],
'color-supported': True,
'compression-supported': ['none', 'gzip'],
'copies-default': 1,
'copies-supported': (1, 9999),
'cups-version': '2.1.3',
'document-format-default': 'application/octet-stream',
'document-format-supported': ['application/octet-stream',
'application/pdf',
'application/postscript',
'application/vnd.adobe-reader-postscript',
'application/vnd.cups-pdf',
'application/vnd.cups-pdf-banner',
'application/vnd.cups-postscript',
'application/vnd.cups-raster',
'application/vnd.cups-raw',
'application/x-cshell',
'application/x-csource',
'application/x-perl',
'application/x-shell',
'image/gif',
'image/jpeg',
'image/png',
'image/pwg-raster',
'image/tiff',
'image/urf',
'image/x-bitmap',
'image/x-photocd',
'image/x-portable-anymap',
'image/x-portable-bitmap',
'image/x-portable-graymap',
'image/x-portable-pixmap',
'image/x-sgi-rgb',
'image/x-sun-raster',
'image/x-xbitmap',
'image/x-xpixmap',
'image/x-xwindowdump',
'text/css',
'text/html',
'text/plain'],
'finishings-default': 3,
'finishings-supported': [3],
'generated-natural-language-supported': ['fr-fr'],
'ipp-features-supported': ['subscription-object'],
'ipp-versions-supported': ['1.0',
'1.1',
'2.0',
'2.1'],
'ippget-event-life': 15,
'job-cancel-after-default': 10800,
'job-cancel-after-supported': (0, 2147483647),
'job-creation-attributes-supported': ['copies',
'finishings',
'ipp-attribute-fidelity',
'job-hold-until',
'job-name',
'job-priority',
'job-sheets',
'media',
'media-col',
'multiple-document-handling',
'number-up',
'output-bin',
'orientation-requested',
'page-ranges',
'print-color-mode',
'print-quality',
'printer-resolution',
'sides'],
'job-hold-until-default': 'no-hold',
'job-hold-until-supported': ['no-hold',
'indefinite',
'day-time',
'evening',
'night',
'second-shift',
'third-shift',
'weekend'],
'job-ids-supported': True,
'job-k-limit': 0,
'job-k-octets-supported': (0, 303406456),
'job-page-limit': 0,
'job-priority-default': 50,
'job-priority-supported': [100],
'job-quota-period': 0,
'job-settable-attributes-supported': ['copies',
'finishings',
'job-hold-until',
'job-name',
'job-priority',
'media',
'media-col',
'number-up',
'output-bin',
'page-ranges',
'print-color-mode',
'print-quality',
'sides'],
'job-sheets-default': ('none', 'none'),
'job-sheets-supported': ['none',
'classified',
'confidential',
'form',
'secret',
'standard',
'topsecret',
'unclassified'],
'jpeg-k-octets-supported': (0, 303406456),
'jpeg-x-dimension-supported': (0, 65535),
'jpeg-y-dimension-supported': (1, 65535),
'marker-change-time': 0,
'media-bottom-margin-supported': [296],
'media-col-default': '(unknown IPP value tag '
'0x34)',
'media-col-supported': ['media-bottom-margin',
'media-left-margin',
'media-right-margin',
'media-size',
'media-source',
'media-top-margin',
'media-type'],
'media-default': 'iso_a4_210x297mm',
'media-left-margin-supported': [296, 1997],
'media-right-margin-supported': [296],
'media-size-supported': ['(unknown IPP value '
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)'],
'media-supported': ['iso_a4_210x297mm',
'oe_4x6in_4x6in',
'custom_127x177.94mm_127x177.94mm',
'iso_a6_105x148mm',
'iso_a5_148x210mm',
'jis_b5_182x257mm',
'custom_88.97x127mm_88.97x127mm',
'oe_5x8in_5x8in',
'oe_8x10in_8x10in',
'om_169widesize_101.6x180.59mm',
'custom_100.01x147.99mm_100.01x147.99mm',
'om_envelope--10_104.81x241.3mm',
'om_envelopedl_110x219.99mm',
'om_envelopec-6_113.98x162mm',
'na_letter_8.5x11in',
'na_legal_8.5x14in',
'iso_a3_297x420mm',
'iso_a2_420x594mm',
'jis_b4_257x364mm',
'jis_b3_364x515mm',
'custom_min_89x127mm',
'custom_max_8.5x44in'],
'media-top-margin-supported': [296],
'media-type-supported': ['stationery',
'ematte',
'eultraglossy',
'epremgloss',
'epsglos',
'epentry',
'egcp',
'envelope'],
'multiple-document-handling-supported': ['separate-documents-uncollated-copies',
'separate-documents-collated-copies'],
'multiple-document-jobs-supported': True,
'multiple-operation-time-out': 300,
'multiple-operation-time-out-action': 'process-job',
'natural-language-configured': 'fr-fr',
'notify-attributes-supported': ['printer-state-change-time',
'notify-lease-expiration-time',
'notify-subscriber-user-name'],
'notify-events-default': ['job-completed'],
'notify-events-supported': ['job-completed',
'job-config-changed',
'job-created',
'job-progress',
'job-state-changed',
'job-stopped',
'printer-added',
'printer-changed',
'printer-config-changed',
'printer-deleted',
'printer-finishings-changed',
'printer-media-changed',
'printer-modified',
'printer-restarted',
'printer-shutdown',
'printer-state-changed',
'printer-stopped',
'server-audit',
'server-restarted',
'server-started',
'server-stopped'],
'notify-lease-duration-default': 86400,
'notify-lease-duration-supported': (0,
2147483647),
'notify-max-events-supported': [100],
'notify-pull-method-supported': ['ippget'],
'notify-schemes-supported': ['dbus',
'mailto',
'rss'],
'number-up-default': 1,
'number-up-supported': [1, 2, 4, 6, 9, 16],
'operations-supported': [2,
4,
5,
6,
8,
9,
10,
11,
12,
13,
16,
17,
18,
19,
20,
21,
22,
23,
24,
25,
26,
27,
28,
34,
35,
37,
38,
56,
57,
59,
16385,
16386,
16387,
16388,
16389,
16390,
16391,
16392,
16393,
16394,
16395,
16396,
16397,
16398,
16399,
16423,
14],
'orientation-requested-default': None,
'orientation-requested-supported': [3,
4,
5,
6],
'output-bin-default': 'face-up',
'output-bin-supported': ['face-up'],
'page-ranges-supported': True,
'pages-per-minute': 1,
'pages-per-minute-color': 1,
'pdf-k-octets-supported': (0, 303406456),
'pdf-versions-supported': ['adobe-1.2',
'adobe-1.3',
'adobe-1.4',
'adobe-1.5',
'adobe-1.6',
'adobe-1.7',
'iso-19005-1_2005',
'iso-32000-1_2008',
'pwg-5102.3'],
'pdl-override-supported': ['attempted'],
'port-monitor': 'none',
'port-monitor-supported': ['none'],
'print-color-mode-default': 'color',
'print-color-mode-supported': ['monochrome',
'color'],
'print-quality-default': 4,
'print-quality-supported': [4],
'printer-commands': 'none',
'printer-config-change-date-time': '(IPP_TAG_DATE)',
'printer-config-change-time': 1552391400,
'printer-current-time': '(IPP_TAG_DATE)',
'printer-device-id': 'MFG:EPSON;MDL:Epson '
'Stylus SX440;DES:EPSON '
'Epson Stylus SX440;',
'printer-dns-sd-name': None,
'printer-error-policy': 'retry-job',
'printer-error-policy-supported': ['abort-job',
'retry-current-job',
'retry-job',
'stop-printer'],
'printer-geo-location': '(unknown IPP value '
'tag 0x12)',
'printer-get-attributes-supported': ['document-format'],
'printer-icons': 'http://localhost/icons/EPSON-Epson-Stylus-SX440.png',
'printer-is-accepting-jobs': True,
'printer-make-and-model': 'Epson Stylus SX440 '
'Series - '
'1.0.0-1lsb3.2 '
'(Seiko Epson '
'Corporation LSB '
'3.2)',
'printer-more-info': 'http://localhost/printers/EPSON-Epson-Stylus-SX440',
'printer-name': 'EPSON-Epson-Stylus-SX440',
'printer-op-policy': 'default',
'printer-op-policy-supported': ['authenticated',
'default'],
'printer-organization': '',
'printer-organizational-unit': '',
'printer-resolution-default': (300, 300, 3),
'printer-resolution-supported': [(300,
300,
3)],
'printer-settable-attributes-supported': ['printer-geo-location',
'printer-info',
'printer-location',
'printer-organization',
'printer-organizational-unit'],
'printer-state': 3,
'printer-state-change-date-time': '(IPP_TAG_DATE)',
'printer-state-change-time': 1554131142,
'not available: No '
'such file or '
'directory',
'printer-up-time': 1554131829,
'printer-uri-supported': ['ipp://localhost/printers/EPSON-Epson-Stylus-SX440'],
'printer-uuid': 'urn:uuid:7d0033f3-1864-3f26-4466-3a71099225e7',
'pwg-raster-document-resolution-supported': [(300,
300,
3)],
'pwg-raster-document-sheet-back': 'normal',
'pwg-raster-document-type-supported': ['adobergb-8',
'adobergb-16',
'black-1',
'black-8',
'black-16',
'cmyk-8',
'cmyk-16',
'rgb-8',
'rgb-16',
'sgray-1',
'sgray-8',
'sgray-16',
'srgb-8',
'srgb-16'],
'queued-job-count': 5,
'server-is-sharing-printers': False,
'sides-default': 'one-sided',
'sides-supported': ['one-sided'],
'uri-authentication-supported': ['requesting-user-name'],
'uri-security-supported': ['none'],
'which-jobs-supported': ['completed',
'not-completed',
'aborted',
'all',
'canceled',
'pending',
'pending-held',
'processing',
'processing-stopped']}}
Page 4 (<troubleshoot.CheckPPDSanity.CheckPPDSanity object at 0x7fe849207ac8>):
{'cups_printer_ppd_defaults': {'*GroupColorManagement': {'BrightnessValue': '0',
'ContrastValue': '0',
'CorrectionColor': 'EPSONVivid',
'CyanValue': '0',
'GammaValue': '2.2',
'MagentaValue': '0',
'SaturationValue': '0',
'YellowValue': '0'},
'*GroupMoreOptions': {'MirrorImage': 'Off',
'Rotate180': 'Off'},
'*GroupMultiPage': {'PosterPrinting': 'Off'},
'*GroupPaperQualityOptions': {'Borderless': 'Off',
'Color': 'Color',
'MediaType': 'PLAIN',
'PageRegion': 'A4',
'PageSize': 'A4',
'PrintQuality': 'TextImage'},
'*GroupReduceEnlargeDocument': {'OutputPaper': 'A4',
'ReduceEnlarge': 'Off',
'ScaleRatio': '100'},
'*GroupWatermark': {'ColurWatermark': 'Red',
'DensityWatermark': 'Level4',
'PositionWatermark': 'Center',
'SizeWatermark': '70',
'Watermark': 'None'}},
'cups_printer_ppd_valid': True,
'missing_pkgs_and_exes': ([], [])}
Page 5 (<troubleshoot.LocalOrRemote.LocalOrRemote object at 0x7fe8490f6898>):
{'printer_is_remote': False}
Page 6 (<troubleshoot.PrinterStateReasons.PrinterStateReasons object at 0x7fe8490eca20>):
{'printer-state-message': 'File "/usr/lib/cups/backend/dnssd" not available: '
'No such file or directory',
'printer-state-reasons': ['cups-missing-filter-warning']}
Page 7 (<troubleshoot.PrintTestPage.PrintTestPage object at 0x7fe8490ff128>):
{'test_page_job_status': [(False,
192,
'Situation loyers Hyeres',
'Stopped',
None),
(False,
193,
"Liste d'affaires ",
'Stopped',
None),
(False,
194,
'Recette de Gratin de courgettes : la meilleure '
'recette',
'Stopped',
None),
(False,
190,
'Le printemps arrive, La Sourbère aussi!',
'Stopped',
None),
(False,
191,
'Stopped',
None)],
'test_page_successful': True}
Page 8 (<troubleshoot.Locale.Locale object at 0x7fe84928e940>):
{'printer_page_size': 'A4',
'system_locale_lang': None,
'user_locale_ctype': 'fr_FR',
'user_locale_messages': 'fr_FR'}
Je suis sous linux Mint 18.1; mon imprimant est une epson stylus sx 440 w
Merci par avance de votre aide
Système inconnu
Chrome 71.0.3578.98
 Posté le 01/04/2019 à 21:08
Le sujet a ÚtÚ dÚplacÚ par la modÚration dans le forum Linux qui semble plus adÚquat.
A bient¶t.
Vélo électrique pliant ENGWE P1 (20 pouces, 250W, Shimano 7 vitesses, 100 km) + paniers à 599 €
599 € 800 € -25%
Ecran 24 pouces Viewsonic VA2405 (FullHD, VA, 75 Hz, VGA/HDMI) à 84,99 €
84,99 € 99,99 € -15%
@Cdiscount
Lot de 3 câbles USB C 0,5 mètre Ugreen (compatibles charge rapide 60W, 3A, 20V) à 11,89 €
11,89 € 16,99 € -30%
Rallonge électrique Zenitech 16A, 2x1.5mm² (sans terre) 25 mètres à 23,49 €
23,49 € 41 € -43%
Kit de 32 Go (2 x 16 Go) de mémoire DDR5 Corsair Vengeance 6400 MHz à 114,99 €
114,99 € 140 € -18%
Carte TP-Link Archer TX20E AX1800 PCIe WIFI 6 + Bluetooth 5.2 avec dissipateur à 24,99 €
24,99 € 32,95 € -24%
impossible d'imprimer!
Firefox sur toutes les distros et connexion impossible sur PC A ce matin
Debian9 Impossible de voir mon réseau ( PC de Bureau)
Installation boot-info impossible
Créer/déposer un fichier dans W10 depuis Ubuntu 18.04 impossible
ping et ifconfig impossible avec gnuroot debian
Manjaro, je ne peux plus imprimer
Modem câble Tompson DCM425, impossible connexion par port USB avec Linux
Redémarrage et extinction impossible grrr
Opera, impossible de lire certaine videos
Plus de sujets relatifs à impossible d''imprimer
