 Libre-Office sur carte mére MSI....
philumj
  Posté le 02/01/2019 @ 16:11
Bonjour ,
J'ai un ordinateur de bureau (il est de septembre 2015 ) qui a une carte mère est une MSI H81M-P33 qui tourne avec Win 7 Pro sur lequel je cherche a mettre a jour Libre Office Version 6.0.7 ,mais qui m'est totalement refusé car j'ai un panneau qui s'affiche et qui me dit " Erreur 1303 ".
Pourquoi avec cette carte a la noix la MSI je rencontre ce problème alors qu'avec une carte Gigabyte cela s'installe parfaitement bien et sans problème,cela sur la deuxième unité qui me sert pour mon passe-temps .
Merci par avance et Bonne Année a tout le monde.
Magnan
 Posté le 02/01/2019 à 18:10
Avec Google.fr : Microsoft+error 1303
Réponse :
The error is related to privileges of the user account. The error 1303 occurs if -The SYSTEM group does not have Full Control privileges or The Everyone group does not have Full Control privileges.
Refer to the Microsoft article for more details. The article is for office setup but you may use the steps for resolution to your issue - http://support.microsoft.com/kb/306986
You may try to take the ownership of the folder and then use the steps to grant permission to everyone.
Before taking ownership I would suggest you to create a new restore point so that the system may be reverted back in case of any loss of data or irregular behavior.
Follow the steps in the below link to create a restore point - The System Restore tool uses restore points to return system files and settings to an earlier point in time. You can use it to restore the operating system to a point in time in which you did not experience the problem. To restore back you need to have a restore point available so I would suggest you to create a new restore point before taking ownership of the folder –http://windows.microsoft.com/en-US/windows7/Create-a-restore-point
You may take the ownership of the folder and then use the steps to grant permission to everyone
  • Locate the file or folder on which you want to take ownership in windows explorer
  • Right click on file or folder and select “Properties” from Context Menu
  • Click on Security tab
  • Click on “Advance”
  • Now click on Owner tab in Advance Security Settings for User windows
  • Click on Edit Button and select user from given Change Owner to list if user or group is not in given list then click on other users or groups. Enter name of user/group and click ok.
  • Now select User/group and click apply and ok. (Check “Replace owner on subcontainers and objects” if you have files and folder within selected folder)
  • Click ok when Windows Security Prompt is displayed
  • Now Owner name must have changed.
  • Now click Ok to exist from Properties windows
  • Once you have taken the ownership of file or folder
  • Grant Permissions to everyone-
  • Go to C:\Users\ and then click right click on folder "Your user name" and choose properties.
  • Then go to security tab and click Edit then click Add => Advanced.
  • If you click on advanced now click on Find Now and choose Everyone and click Ok.
  • Then again click Ok and now click on Allow => Full control => Ok.
  • If the issue persists, I would suggest you to create a new use account with administrator rights and then try to perform the changes and check if the steps work for you -http://windows.microsoft.com/en-us/Windows7/Create-a-user-account
    DISCLAIMER: Affecting system settings incorrectly can cause serious problems that may prevent your computer from booting properly or may result in loss of data. Microsoft cannot guarantee that any problems resulting from the configuration of ownership settings can be solved. Modifications of the settings are at your own risk.
    Hope this helps. Let us know the results.Thanks, Meghmala – Microsoft Support
    nainconnu.bis
     Posté le 02/01/2019 à 19:49
    Daneel Olivaw
     Posté le 02/01/2019 à 22:35
    nainconnu.bis a écrit :
    voir pour erreur 1303 avec libre office cliquer ICI
    Personnellement, quand je trouve solvusoft dans les recherches, je n'essaye même pas d'ouvrir la page pour voir ce qu'ils racontent.
    Je n'ai jamais trouvé un seul conseil utile venat d'eux. Ils t'incitent à chaque paragraphe de télécharger leur outil de nettoyage, et les autres conseils, ne servent à rien. C'est les mêmes que tu trouves sur toutes leurs pages, quelque soit l'erreur.
    Modifié par Daneel Olivaw le 02/01/2019 22:37
    104,99 €Disque dur externe portable Western Digital Elements USB 3.0 5 To à 104,99 €
    Valable jusqu'au 03 Mars
    Amazon propose actuellement le disque dur externe portable Western Digital Elements USB 3.0 5 To à 104,99 € livré gratuitement. On le trouve ailleurs à partir de 149 €. Ce disque dur qui tient dans la main est silencieux, ne chauffe pas et dispose d'une connectique USB 3.0 qui vous offrira des transferts rapides. Il est compatible USB 2.0. Une très bonne affaire.
    34,90 €Caméra de surveillance TP-Link Tapo C200 à 34,90 €
    Valable jusqu'au 02 Mars
    Amazon fait une promotion sur la caméra de surveillance TP-Link Tapo C200 qui passe à 34,90 € livrée gratuitement au lieu d'une quarantaine d'euros ailleurs. Cette caméra se connecte à votre réseau en WiFi et peut ensuite être contrôlée à distance. Elle offre une définition FullHD 1080p, la vision nocturne, la détection de mouvements (recevez une notification si quelque chose est détecté), une alarme sonore et visuelle. Le stockage se fait en local sur une carte MicroSD.
    13,99 €Microsoft Office 2019 Professional Plus à 13,99 €
    Le vendeur sérieux Digital FR propose sur Amazon la clé d'activation légale pour Microsoft Office Professionnel 2019 Plus en français à 13,99 €. Cette clé livrée par email vous permettra d'activer Microsoft Office Professionnel 2019 Plus légalement et vous permettra ainsi d'utiliser autant de temps que vous voulez (il s'agit de la version complète et pas d'un abonnement) Word,Excel, PowerPoint, OneNote, Outlook, Publisher et Access 2019 sur un PC. La clé sera à activer sur Office.com où vous pourrez ensuite télécharger toute la suite bureautique. Pour mémoire, Microsoft Office Professionnel 2019 nécessite Windows 10. Sous Windows 7 ou 8, vous devrez vous tourner vers la version 2016. Pour plus d'info sur la procédure, n'hésitez pas à jeter un oeil à notre dossier pratique Acheter une clé OEM d'Office 2019 et l'installer.
    Recherche aide Libre Office
    Images dans libre office
    smiley sur libre office
    Libre Office:version classique ou portable?
    Libre Office et Google drive
    libre office non affichage des courriers précédents
    affichage libre office writer
    Arrière plan celllule libre office
    Libre Office
    Libre Office : échec de la récupération du document
    Plus de sujets relatifs à Libre-Office sur carte mére MSI....
