 mon pc passe tous seul en ecan bleu tout seulSujet résolu
bizule
  Posté le 11/02/2014 @ 10:49
si je reste trop longtemps sans me servir de la sourie ou du clavier mon pc passe en écran bleu et impossible de revenir sur le bureau
redémarrage obligatoire j'ai mis écran de veuille a 1 h
El Magnifico
 Posté le 11/02/2014 à 11:51
Groupe Sécurité
Telecharge ceci pour comprendre le crash : ICI et poste le rapport pour que les astuciens puissent te répondre.
Modifié par El Magnifico le 11/02/2014 11:52
bizule
 Posté le 11/02/2014 à 13:47
j'e pense que c'est bon ???????????????????????????
Welcome to WhoCrashed (HOME EDITION) v 5.00
This program checks for drivers which have been crashing your computer. If your computer has displayed a blue screen of death, suddenly rebooted or shut down then this program will help you find the root cause and possibly a solution.
Whenever a computer suddenly reboots without displaying any notice or blue screen of death, the first thing that is often thought about is a hardware failure. In reality, on Windows most crashes are caused by malfunctioning device drivers and kernel modules. In case of a kernel error, many computers do not show a blue screen unless they are configured for this. Instead these systems suddenly reboot without any notice.
This program will analyze your crash dumps with the single click of a button. It will tell you what drivers are likely to be responsible for crashing your computer. It will report a conclusion which offers suggestions on how to proceed in any situation while the analysis report will display internet links which will help you further troubleshoot any detected problems.
To obtain technical support visit www.resplendence.com/support
Click here to check if you have the latest version or if an update is available.
Just click the Analyze button for a comprehensible report ...
Home Edition Notice
This version of WhoCrashed is free for use at home only. If you would like to use this software at work or in a commercial environment you should get the professional edition of WhoCrashed which allows you to perform more thorough and detailed analysis. It also offers a range of additional features such as remote analysis on remote directories and remote computers on the network.
Click here for more information on the professional edition.
Click here to buy the the professional edition of WhoCrashed.
System Information (local)
computer name: PC-DE-CARLES
windows version: Windows 8 , 6.2, build: 9200
windows dir: C:\WINDOWS
Hardware: NVIDIA, MS-7030
CPU: AuthenticAMD AMD Athlon(tm) 64 Processor 3200+ AMD586, level: 15
1 logical processors, active mask: 1
RAM: 2147012608 total
VM: 2147352576, free: 1933430784
Crash Dump Analysis
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
On Tue 11/02/2014 09:24:43 GMT your computer crashed
crash dump file: C:\WINDOWS\memory.dmp
This was probably caused by the following module: dxgkrnl.sys (dxgkrnl!TdrHistoryUpdate+0x581)
Bugcheck code: 0x116 (0xFFFFFFFF86D60008, 0xFFFFFFFF92140A6C, 0x0, 0xD)
Error: VIDEO_TDR_ERROR
file path: C:\WINDOWS\system32\drivers\dxgkrnl.sys
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: DirectX Graphics Kernel
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
Conclusion
One crash dump has been found and analyzed. No offending third party drivers have been found. Consider using WhoCrashed Professional which offers more detailed analysis using symbol resolution. Also configuring your system to produce a full memory dump may help you.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Modifié par bizule le 11/02/2014 13:48
Ambredoré
 Posté le 11/02/2014 à 14:37
bonjour,
j'ai déjà eu ce problème c'était un problème de pilotes graphiques.
Quelle carte graphique avez-vous?
D'autre part, est-ce que votre pc est de marque ? si oui de quelle marque? Et il faudrait le modèle du pc pour pouvoir télécharger les pilotes windows 8 les plus récents.
Modifié par Ambredoré le 11/02/2014 14:39
bizule
 Posté le 11/02/2014 à 14:52
Ambredoré a écrit :
bonjour,
je crois que tu a la réponse dans ma logithèque monté par un assembleur
Ambredoré
 Posté le 11/02/2014 à 15:10
Très bien eh bien je te propose d'aller télécharger le dernier pilote pour ta carte graphique en allant sur http://www.nvidia.fr/Download/index.aspx?lang=fr et en cliquant sur "Trouve automatiquement les pilotes pour mes produits NVIDIA: " > pilotes graphiques
Ensuite il faut les installer.
bizule
 Posté le 11/02/2014 à 15:58
J'ai du mal a trouver 6800 GT AGP 512MB /128BIT /DDR2 VGA / DVI /TV-OUT
Se message viens souvent vidéo TDR failure
Modifié par bizule le 11/02/2014 18:48
Ambredoré
 Posté le 12/02/2014 à 15:52
bonjour,
as-tu réussi à télécharger tes pilotes en cliquant sur "Trouve automatiquement les pilotes pour mes produits NVIDIA:" > pilotes graphiques ?
bizule
 Posté le 03/04/2014 à 08:47
Désolé du retard j'ai un peu abandonner le pc je suis aller au hasard sur contrôler la compatibilité des programme matériel il semblerai que nivdia et sortie une mise a jour pour cette carte pour w8
du coup tout et ok
Merci a tous pour votre aide
110,94 €SSD WD Blue SN550 1 To (NMVe M.2, 2400 Mo/s) à 110,94 €
Valable jusqu'au 22 Octobre
Amazon fait une promotion sur le SSD WD Blue SN550 1 To (NMVe M.2) qui passe à 110,94 € livré gratuitement alors qu'on le trouve ailleurs à partir de 155 €. Ce SSD utilise une interface M.2 NVMe PCIe Gen3 x 4 pour une connexion simple et des performances exceptionnelles : jusqu’à 2 400 Mo/s en lecture séquentielle et jusqu’à 1 950 Mo/s en écriture séquentielle. Le SSD est doté de la technologie 3D TLC NAND haute densité offrant une endurance d’écriture durable et assorti d’une garantie de cinq ans.
11,97 €Chargeur Varta 4H LCD PLUG + USB + 4 piles rechargeables AA 2100 mAh à 11,97 €
Valable jusqu'au 24 Octobre
Amazon fait une promotion sur le chargeur Varta 4H LCD PLUG qui passe à 11,97 € au lieu de 25 €. Ce chargeur rapide peut charger jusqu'à 4 accus (AA, AAA et 9V) et dispose également d'un port USB pour recharger un appareil mobile ou une batterie externe. Un écran LCD vous indiquera l'avancé de la charge. Il est fourni avec 4 piles rechargeables AA 2100 mAh.
36,99 €Disque dur Western Digital Blue 1 To à 36,99 €
Cdiscount fait une belle promotion sur le disque dur Western Digital Blue 1 To à 36,90 €. Ce disque dur 3.5 pouces SATA III  tourne à 7200 tr/min.
Ordinateur qui s'allume tout seul
Mon ordinateur s'éteint tout seul
publicité arepetion et page internet qui s'ouvre tout seul
Lecteur CD qui démarre tout seul sans CD
pc ce rallume tous seul
Pc qui se déconnecte tout seul
PC redémarre seul
Graver un CD (copie) avec un seul lecteur/graveur
impossible supprime un seul dossier
Ecran s'eteint seul ...
Plus de sujets relatifs à mon pc passe tous seul en ecan bleu tout seul
