Petit astucien | bonjours bonjours!!! je souhaiterai vous envoyer un rapport hijack pour que vous m aidiez a fixer certain trucs!
d avance merci
Petit astucien | et donc voici le rapport hijack en question
Logfile of HijackThis v1.99.0
Scan saved at 15:34:31, on 24/02/2005
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\Microsoft AntiSpyware\gcasServ.exe
C:\PROGRA~1\Alwil Software\Avast4\ashDisp.exe
C:\WINDOWS\system32\RUNDLL32.EXE
C:\WINDOWS\system32\rundll32.exe
C:\Program Files\D-Tools\daemon.exe
C:\Program Files\MSN Messenger\MsnMsgr.Exe
C:\Program Files\Microsoft AntiSpyware\gcasDtServ.exe
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\WINDOWS\system32\nvsvc32.exe
C:\WINDOWS\system32\wscntfy.exe
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
H:\My eBooks\anti spyware\hijack\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = about:blank
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.free.fr/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = res://C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\se.dll/sp.html
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = about:blank
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = about:blank
O4 - HKLM\..\Run: [gcasServ] "C:\Program Files\Microsoft AntiSpyware\gcasServ.exe"
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\Alwil Software\Avast4\ashDisp.exe
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [sp] rundll32 C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\se.dll,DllInstall
O4 - HKLM\..\Run: [DAEMON Tools-1033] "C:\Program Files\D-Tools\daemon.exe" -lang 1033
O4 - HKCU\..\Run: [MsnMsgr] "C:\Program Files\MSN Messenger\MsnMsgr.Exe" /background
O23 - Service: avast! iAVS4 Control Service - Unknown - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: avast! Antivirus - Unknown - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
O23 - Service: avast! Web Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
O23 - Service: Service d'administration du Gestionnaire de disque logique - Unknown - C:\WINDOWS\System32\dmadmin.exe
O23 - Service: Journal des ÚvÚnements - Unknown - C:\WINDOWS\system32\services.exe
O23 - Service: Service COM de gravage de CD IMAPI - Unknown - C:\WINDOWS\system32\imapi.exe
O23 - Service: Partage de Bureau Ó distance NetMeeting - Unknown - C:\WINDOWS\system32\mnmsrvc.exe
O23 - Service: NVIDIA Display Driver Service - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
O23 - Service: Plug-and-Play - Unknown - C:\WINDOWS\system32\services.exe
O23 - Service: Gestionnaire de session d'aide sur le Bureau Ó distance - Unknown - C:\WINDOWS\system32\sessmgr.exe
O23 - Service: Carte Ó puce - Unknown - C:\WINDOWS\System32\SCardSvr.exe
O23 - Service: Journaux et alertes de performance - Unknown - C:\WINDOWS\system32\smlogsvc.exe
O23 - Service: ClichÚ instantanÚ de volume - Unknown - C:\WINDOWS\System32\vssvc.exe
O23 - Service: Carte de performance WMI - Unknown - C:\WINDOWS\system32\wbem\wmiapsrv.exe
Petit astucien | p.s: g deja fais une analyse par moi meme ds laquelle g virÚ quelques b.h.o je pensais que ca suffirrait mais apparement non
Petit astucien | bipbip si tu passe par lÓ aide moi s il te plait, t as l air d etre calÚ. merci d avance | |||||||
Petit astucien | bon les amis y fo que j aille faire des courses je reviens vers 19h j espers que quelqu un aura postÚ une soluce pour moi j en ai marre de reinstaler mon systeme d autant que g xp titanium et que les restaurations systeme sont foireuses donc a banir!
merci a tous ce qui s interresseront a mon chti probleme, a tout a l heure
![]() | Salut lolo a un probleme,
DÚmarrer le logiciel HijackThis [img]http://www.merijn.org/images/hijackthis_big.gif[/img] et lancer un scan "Do a system scan only".
Puis cocher les lignes suivantes (dans HijackThis):
Fermer toutes les fenÛtres Windows, Internet explorer, Outlook,àsauf le logiciel Hijackthis et cliquer sur ½ Fix checked ?
Toujours sur Hijackthis > Config >Misc tools > delete a file on reboot.
Entrer ce chemin:
C:\Documents and Settings\ADMINISTRATEUR\Local Settings\Temp\se.dll
RedÚmarrer en mode sans echec (appuyer sur F8 ou F5 lors du dÚmarrage)
Ensuite aller dans lÆ Explorateur Windows et afficher tous les fichiers cachÚs:
cliquez une fois sur le menu <DÚmarrer> avec le bouton gauche de la souris et dÚplacez le pointeur sur <ParamÞtres>.
Le systÞme ouvre un menu latÚral dans lequel vous devez cliquer une fois sur <Options des dossiers>.
Le systÞme ouvre la fenÛtre <Options des dossiers>.
Cliquez une fois sur lÆonglet <Visualiser> en haut de la fenÛtre.
Vous trouverez une grande bo¯te ÚtiquetÚe <ParamÞtres avancÚs>.
Dans cette bo¯te, il y a trois options qui concernent les fichiers cachÚs : le paramÞtre activÚ par dÚfaut est <Ne pas afficher les fichiers cachÚs ou les fichiers systÞme>.
Cliquez une fois dans le cercle ÚtiquetÚ <Afficher tous les fichiers>, cliquez sur <Appliquer> puis sur <OK>.
et supprimer les fichiers ci dessous si ils sont prÚsent :
C\temp\ <-- supprimer tout le contenu du dossier
C:\windows\temp\ <-- supprimer tout le contenu du dossier
C:\Documents and Settings\Tous les identifiants\Local Settings\Temp\<-- supprimer tout le contenu du dossier
C:\Documents and Settings\ Tous les identifiants\Local Settings\Temporary Internet Files\<-- supprimer tout le contenu du dossier
Fichier temporaire internet:
DÚmarrer/panneau de configuration/options internet
--> button supprimer cookies
--> button supprimer fichier temporaire internet
Fichiers temporaries : DÚmarrer/exÚcuter " CleanMgr "
Cocher tout sauf :
Compression des fichiers non utilisÚs
Fichiers catalogue dÆindexation du contenu
/ OK / OUI
Dans l'Explorateur Windows recacher les fichiers systeme afin de ne pas faire d'erreur a l'avenir:
Retournez Ó la fenÛtre <ParamÞtres de dossier> et sÚlectionnez <Ne pas afficher les fichiers cachÚs ou les fichiers systÞme>.
Puis reviens mettre un rapport Hijackthis [img]http://www.yatoula.com/gif/smiles/smiley_520.gif[/img]
Petit astucien | ok merci bip bip
par contre au redemarage g eu un bip d erreur avec un texte erreur type qui disait c: admin .... chemin acce introuvable ...
et voici le dernier rapport hijack
Scan saved at 20:10:48, on 24/02/2005
Running processes:
Petit astucien | bon aparrament ds ce rapport g toujours le c:/ADMIN... que j avais virÚ. que dois je faire?
Petit astucien | en fait le c:/ADMIN dont je parle c ca:
je l avais deja virÚ et il est de retour comment faire?
![]() | Refait la manip 1 ou 2 fois si il reviens... | |||||||
