 Pac Office 2007 Pro barre des menus
Ventoux91
  Posté le 10/08/2008 @ 14:27
Normal 0 21 false false false FR X-NONE X-NONE MicrosoftInternetExplorer4 <!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:0 0 0 0 0 0 0 0 0 0; mso-font-charset:1; mso-generic-font-family:roman; mso-font-format:other; mso-font-pitch:variable; mso-font-signature:0 0 0 0 0 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin-top:0cm; margin-right:0cm; margin-bottom:10.0pt; margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;} .MsoPapDefault {mso-style-type:export-only; margin-bottom:10.0pt; line-height:115%;} @page Section1 {size:595.3pt 841.9pt; margin:70.85pt 70.85pt 70.85pt 70.85pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} Bonjour,
Un peu d’aide je viens d’installer le Pac Office Pro 2007 et je suis un peu perdu.
Avec Excel comment faire pour désactivé la touche déplacer après validation
Peut-ont remettre l’ancienne barre ( Fichier édition etc. )
Merci de votre aide.
Cordialement, Christian.
sourisdeservice
 Posté le 11/08/2008 à 19:23
  Grande Maîtresse astucienne
C'est quoi tout ce qui précède ton bonjour ?
Nous on a du code, si chez toi il y a une image, il n'y a que toi qui la vois.
Tu dois héberger ton image chez imageshak.us par ex pour y insérer son adresse dans ton post
Tu peux aussi personnaliser une barre de menus
http://www.pcastuces.com:80/newsletter/adj/2300.htm
Modifié par sourisdeservice le 12/08/2008 22:03
239,90 €Smartphone Poco X3 Pro (6,67 pouces 120 Hz, Snapdragon 860, 8 Go/ 256 Go) à 239,90 €
Valable jusqu'au 21 Janvier
Xiaomi fait une belle promotion sur le smartphone Poco X3 Pro qui passe à 239,90 € au lieu de 299 €. Il est équipé du processeur Qualcomm Snapdragon 860 (8 coeurs), de 8 Go de RAM, de 256 Go de stockage et d’un écran de 6,67 pouces ultra fluide 120 Hz.
Il comprend aussi une Quad-Caméra de 48 MP avec IA et une caméra selfie poinçonnée de 20 MP. Il comprend une grande batterie de 5160 mAh, pour une utilisation sur plusieurs jours (supporte la charge rapide de 33W). Le POCO X3 Pro dispose également d'un capteur d’empreinte digitale sur le côté et une prise jack 3,5 mm pour vous permettre de brancher vos haut-parleurs ou vos écouteurs filaires.
Avec GPS, NFC, Bluetooth 5, WiFi, USB C. Le tout tourne sous Android 10.
Notez qu'il a été élu meilleur smartphone à moins de 300 € par le magazine UFC Que Choisir.
La version 6 Go / 128 Go est également en promotion à 209,90 € au lieu de 249,90 €.
91,17 €Webcam Logitech StreamCam à 91,17 €
Valable jusqu'au 22 Janvier
RueDuCommerce fait une promotion sur la Webcam Logitech StreamCam qui passe à 91,17 €. On la trouve ailleurs à partir de 130 €.
La Logitech StreamCam diffuse et enregistre des vidéos saisissantes et réalistes avec des mouvements fluides et des détails nets en Full HD 1080p à 60 fps. De plus, elle offre la possibilité de passer instantanément en mode portrait afin de filmer en format 16:9. Offrant de nombreuses possibilités, elle est idéale pour filmer sur Twitch, Facebook ou encore Instagram.
Intégrant la reconnaissance faciale pilotée par l'IA, vous obtenez une mise au point et une exposition nettes, quelle que soit votre position. L'exposition automatique est réglée avec précision pour vous montrer sous un jour flatteur dans des conditions d'éclairage variées.
999,99 €PC Portable 16.1' HP Victus (FHD, Core i5 11400H, 16Go/512Go,RTX 3600 6Go) à 999,99 €
Valable jusqu'au 24 Janvier
Cdiscount fait une réduction sur le PC Portable 16.1' HP Victus 16-d0206nf qui passe à 999,99 € au lieu de 1200 €.
Il comporte un écran IPS Full HD de 16.1 pouces, un processeur Intel Core i5 11400H, 16 Go de RAM, un SSD NVMe de 512 Go, une carte graphique dédiée GeForce RTX 3600 6 Go, un clavier rétro éclairé, une batterie charge rapide (autonomie 10h).
Le tout tourne sous Windows 10 que vous pourrez passer à Windows 11. Une bonne affaire !
problème barre de menus sous word 2007
Barre des menus Office
Barre de menus dans Excel 2007
Mon Pack Office 2007 serait corrompu !!!!
Réinstaller Office 2007 - Urgent -
Office 2007
office Publisher 2007 - carte de voeux
Comment récupérer la barre d'outils dans Word 2007 ?
Office 2007 avec W8 64 bits:compatible,oui/non?
Plus de sujets relatifs à Pac Office 2007 Pro barre des menus
