 Pas de wifi sur mon pc asus all on one avec linux mintSujet résolu
Pages : [1] 2 3 4 5 ... Fin
Page 1 sur 15 [Fin]
jacqueline47
  Posté le 29/07/2020 @ 14:48
bonjour,
j'ai un pc asus tout en un avec chrome et linux mint mais je ne peux pas travailler en wifi seulement en ethernet;
Voici ce que j'ai sur le teracqueline33@jacqueline33-ET2321I:~$ lspci
00:00.0 Host bridge: Intel Corporation Haswell-ULT DRAM Controller (rev 09)
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 09)
00:03.0 Audio device: Intel Corporation Haswell-ULT HD Audio Controller (rev 09)
00:04.0 Signal processing controller: Intel Corporation Haswell-ULT Thermal Subsystem (rev 09)
00:14.0 USB controller: Intel Corporation 8 Series USB xHCI HC (rev 04)
00:16.0 Communication controller: Intel Corporation 8 Series HECI #0 (rev 04)
00:1b.0 Audio device: Intel Corporation 8 Series HD Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 1 (rev e4)
00:1c.2 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 3 (rev e4)
00:1c.3 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 4 (rev e4)
00:1c.4 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 5 (rev e4)
00:1d.0 USB controller: Intel Corporation 8 Series USB EHCI #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation 8 Series LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 8 Series SATA Controller 1 [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 8 Series SMBus Controller (rev 04)
00:1f.6 Signal processing controller: Intel Corporation 8 Series Thermal (rev 04)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
03:00.0 Network controller: Broadcom Inc. and subsidiaries BCM4352 802.11ac Wireless Network Adapter (rev 03)
04:00.0 VGA compatible controller: NVIDIA Corporation GK208M [GeForce GT 740M] (rev a1)
jacqueline33@jacqueline33-ET2321I:~$ lsub
bash: lsub : commande introuvable
jacqueline33@jacqueline33-ET2321I:~$ lsusb
Bus 001 Device 006: ID 1bcf:2c33 Sunplus Innovation Technology Inc.
Bus 001 Device 005: ID 0457:1016 Silicon Integrated Systems Corp.
Bus 001 Device 004: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 003: ID 13d3:3404 IMC Networks
Bus 001 Device 002: ID 8087:8000 Intel Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
jacqueline33@jacqueline33-ET2321I:~$ ifconfig -a
enp2s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.77 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::f9f:4537:473c:404e prefixlen 64 scopeid 0x20<link>
ether 38:2c:4a:0e:20:ac txqueuelen 1000 (Ethernet)
RX packets 209906 bytes 162163783 (162.1 MB)
RX errors 0 dropped 15309 overruns 0 frame 0
TX packets 165360 bytes 39791472 (39.7 MB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Boucle locale)
RX packets 7207 bytes 809452 (809.4 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 7207 bytes 809452 (809.4 KB)
N'étant sur linux qu'il y a très peu de temps, je ne sais pas comment procédrt
merci pour votre aide
jacqueline47
Système inconnu
Chrome 84.0.4147.105
 Posté le 30/07/2020 à 08:04
Le sujet a été déplacé par la modération dans le forum Linux qui semble plus adéquat.
A bientôt.
enigma7
 Posté le 30/07/2020 à 10:50
Tu as quelle version de Mint ?
Tu as un broadcom, dans un terminal donnes le retour de : lsmod |grep 802
Je n'ai pas de broadcom, regarde ici : https://forums.linuxmint.com/viewtopic.php?t=201688
et ici : https://community.linuxmint.com/tutorial/view/379 semble plus adéquat
Modifié par enigma7 le 30/07/2020 10:56
jacqueline47
 Posté le 30/07/2020 à 12:49
Bonjour et merci
voilà :
$ lsmod |grep 802
cfg80211 704512 0
merci
jacqueline47
 Posté le 30/07/2020 à 13:02
bonjour et merci
voilàjacqueline33@jacqueline33-ET2321I:~$ sudo apt-get mise à jour && sudo apt-get mise à jour
E: L'opération mise n'est pas valable
jacqueline33@jacqueline33-ET2321I:~$ sudo apt-get install b43-fwcutter firmware-b43-installer
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
Les NOUVEAUX paquets suivants seront installés :
0 mis à jour, 2 nouvellement installés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de prendre 30,5 ko dans les archives.
Après cette opération, 131 ko d'espace disque supplémentaires seront utilisés.
Réception de :1 http://archive.ubuntu.com/ubuntu focal/main amd64 b43-fwcutter amd64 1:019-4 [25,7 kB]
Réception de :2 http://archive.ubuntu.com/ubuntu focal/multiverse amd64 firmware-b43-installer all 1:019-4 [4 764 B]
30,5 ko réceptionnés en 0s (198 ko/s)
Préconfiguration des paquets...
Sélection du paquet b43-fwcutter précédemment désélectionné.
(Lecture de la base de données... 334565 fichiers et répertoires déjà installés.)
Préparation du dépaquetage de .../b43-fwcutter_1%3a019-4_amd64.deb ...
Dépaquetage de b43-fwcutter (1:019-4) ...
Sélection du paquet firmware-b43-installer précédemment désélectionné.
Préparation du dépaquetage de .../firmware-b43-installer_1%3a019-4_all.deb ...
Dépaquetage de firmware-b43-installer (1:019-4) ...
Paramétrage de b43-fwcutter (1:019-4) ...
Paramétrage de firmware-b43-installer (1:019-4) ...
No chroot environment found. Starting normal installation
--2020-07-30 12:58:43-- http://www.lwfinger.com/b43-firmware/broadcom-wl-5.100.138.tar.bz2
Résolution de www.lwfinger.com (www.lwfinger.com)… 173.254.30.178
Connexion à www.lwfinger.com (www.lwfinger.com)|173.254.30.178|:80… connecté.
requête HTTP transmise, en attente de la réponse… 200 OK
Taille : 13514651 (13M) [application/x-tar]
Enregistre : «broadcom-wl-5.100.138.tar.bz2»
broadcom-wl-5.100.1 100%[===================>] 12,89M 1,38MB/s ds 11s
2020-07-30 12:58:55 (1,17 MB/s) - «broadcom-wl-5.100.138.tar.bz2» enregistré [13514651/13514651]
broadcom-wl-5.100.138.tar.bz2: Réussi
broadcom-wl-5.100.138/linux/wl_apsta.o
This file is recognised as:
filename : wl_apsta.o
version : 666.2
MD5 : e1b05e268bcdbfef3560c28fc161f30e
Extracting b43/lp0initvals14.fw
Extracting b43/lcn0bsinitvals25.fw
Extracting b43/n0bsinitvals25.fw
Extracting b43/n0bsinitvals17.fw
Extracting b43/ucode17_mimo.fw
Extracting b43/ucode16_lp.fw
Extracting b43/sslpn1initvals27.fw
Extracting b43/lp2bsinitvals19.fw
Extracting b43/sslpn3bsinitvals21.fw
Extracting b43/ucode16_sslpn.fw
ucode time: 01:15:07
Extracting b43/ucode25_lcn.fw
Extracting b43/ucode21_sslpn.fw
Extracting b43/lp0bsinitvals14.fw
Extracting b43/b0g0initvals9.fw
Extracting b43/ucode20_sslpn.fw
Extracting b43/a0g1bsinitvals9.fw
Extracting b43/lp1initvals20.fw
Extracting b43/b0g0bsinitvals13.fw
Extracting b43/lp2initvals19.fw
Extracting b43/n2bsinitvals19.fw
Extracting b43/sslpn4bsinitvals22.fw
Extracting b43/ucode16_sslpn_nobt.fw
ucode date: 2011-02-23
Extracting b43/n1bsinitvals20.fw
Extracting b43/n1initvals20.fw
Extracting b43/b0g0bsinitvals5.fw
Extracting b43/ucode22_sslpn.fw
Extracting b43/b0g0initvals13.fw
Extracting b43/ht0initvals26.fw
Extracting b43/ucode33_lcn40.fw
Extracting b43/sslpn1bsinitvals20.fw
Extracting b43/lcn400bsinitvals33.fw
Extracting b43/ucode14.fw
Extracting b43/a0g0initvals5.fw
Extracting b43/lp1bsinitvals22.fw
Extracting b43/n16initvals30.fw
Extracting b43/lp0bsinitvals16.fw
Extracting b43/lcn1bsinitvals25.fw
Extracting b43/lcn400initvals33.fw
Extracting b43/n0bsinitvals24.fw
Extracting b43/lcn2bsinitvals26.fw
Extracting b43/lcn1initvals26.fw
Extracting b43/n0bsinitvals22.fw
Extracting b43/n18initvals32.fw
Extracting b43/lcn2initvals26.fw
Extracting b43/a0g1bsinitvals5.fw
Extracting b43/n0bsinitvals11.fw
Extracting b43/lcn2initvals24.fw
Extracting b43/lcn0initvals26.fw
Extracting b43/n0absinitvals11.fw
Extracting b43/ucode21_sslpn_nobt.fw
Extracting b43/ucode26_mimo.fw
Extracting b43/n2initvals19.fw
Extracting b43/sslpn3initvals21.fw
Extracting b43/a0g1bsinitvals13.fw
Extracting b43/sslpn4initvals22.fw
Extracting b43/pcm5.fw
Extracting b43/ucode22_mimo.fw
Extracting b43/ucode9.fw
Extracting b43/lcn2initvals25.fw
Extracting b43/lp1initvals22.fw
Extracting b43/sslpn1bsinitvals27.fw
Extracting b43/lcn0initvals24.fw
Extracting b43/ucode32_mimo.fw
Extracting b43/a0g0bsinitvals9.fw
Extracting b43/n18bsinitvals32.fw
Extracting b43/n0initvals24.fw
Extracting b43/n0initvals25.fw
Extracting b43/a0g1initvals5.fw
Extracting b43/ucode24_lcn.fw
Extracting b43/n0initvals17.fw
Extracting b43/n0bsinitvals16.fw
Extracting b43/lp0initvals15.fw
Extracting b43/b0g0initvals5.fw
Extracting b43/ucode20_sslpn_nobt.fw
Extracting b43/lcn1initvals24.fw
Extracting b43/sslpn0initvals16.fw
Extracting b43/a0g1initvals13.fw
Extracting b43/lp1bsinitvals20.fw
Extracting b43/sslpn2initvals19.fw
Extracting b43/a0g1initvals9.fw
Extracting b43/lcn1bsinitvals24.fw
Extracting b43/ucode5.fw
Extracting b43/lcn2bsinitvals24.fw
Extracting b43/lp0bsinitvals13.fw
Extracting b43/n0initvals16.fw
Extracting b43/ucode19_sslpn_nobt.fw
Extracting b43/b0g0bsinitvals9.fw
Extracting b43/ucode11.fw
Extracting b43/lp0initvals16.fw
Extracting b43/ucode16_mimo.fw
Extracting b43/lcn0bsinitvals26.fw
Extracting b43/ht0initvals29.fw
Extracting b43/lcn2bsinitvals25.fw
Extracting b43/a0g0initvals9.fw
Extracting b43/ucode29_mimo.fw
Extracting b43/lcn0bsinitvals24.fw
Extracting b43/ucode19_sslpn.fw
Extracting b43/lcn1initvals25.fw
Extracting b43/ucode30_mimo.fw
Extracting b43/n16bsinitvals30.fw
Extracting b43/ucode25_mimo.fw
Extracting b43/ucode24_mimo.fw
Extracting b43/ucode27_sslpn.fw
Extracting b43/lp0initvals13.fw
Extracting b43/a0g0bsinitvals5.fw
Extracting b43/ht0bsinitvals26.fw
Extracting b43/ucode13.fw
Extracting b43/sslpn2bsinitvals19.fw
Extracting b43/ucode15.fw
Extracting b43/lp0bsinitvals15.fw
Extracting b43/n0initvals11.fw
Extracting b43/lcn0initvals25.fw
Extracting b43/sslpn0bsinitvals16.fw
Extracting b43/sslpn1initvals20.fw
Extracting b43/lcn1bsinitvals26.fw
Extracting b43/n0initvals22.fw
Extracting b43/ht0bsinitvals29.fw
Traitement des actions différées (« triggers ») pour man-db (2.9.1-1) ...
voilà
jacqueline47
 Posté le 30/07/2020 à 13:13
bonjour,
j ai linux MINT 20 cinnamon version 4.6.6
noyau 5.0.42 generic
enigma7
 Posté le 30/07/2020 à 13:36
c'est sudo apt update puis sudo apt ugrade qu'il faut mettre dans le terminal.
Puis tu reboote ton pc, si le wifi ne fonctionne toujours pas, tu refait : lsmod |grep 802
jacqueline47
 Posté le 30/07/2020 à 13:39
la wifi ne fonctionne toujours pas
merci
jacqueline47
 Posté le 30/07/2020 à 14:00
rebonjour
[sudo] Mot de passe de jacqueline33 :
Désolé, essayez de nouveau.
Atteint :1 http://archive.ubuntu.com/ubuntu focal InRelease
Atteint :2 http://dl.google.com/linux/chrome/deb stable InRelease
Atteint :3 http://ppa.launchpad.net/nilarimogard/webupd8/ubuntu focal InRelease
Atteint :4 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Ign :5 http://dl.google.com/linux/earth/deb stable InRelease
Atteint :6 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Atteint :7 http://dl.google.com/linux/earth/deb stable Release
Atteint :8 http://archive.canonical.com/ubuntu focal InRelease
Atteint :9 http://security.ubuntu.com/ubuntu focal-security InRelease
Ign :10 http://packages.linuxmint.com ulyana InRelease
Réception de :11 http://archive.ubuntu.com/ubuntu focal/main Translation-fr [500 kB]
Atteint :12 http://packages.linuxmint.com ulyana Release
Réception de :13 http://archive.ubuntu.com/ubuntu focal/restricted Translation-fr [5 580 B]
Réception de :14 http://archive.ubuntu.com/ubuntu focal/universe Translation-fr [3 497 kB]
Réception de :17 http://archive.ubuntu.com/ubuntu focal/multiverse Translation-fr [97,8 kB]
4 100 ko réceptionnés en 2s (1 721 ko/s)
Tous les paquets sont à jour.
jacqueline33@jacqueline33-ET2321I:~$ sudo apt ugrade
apt
Usage: apt command [options]
apt help command [options]
Commands:
add-repository - Add entries to apt sources.list
autoclean - Erase old downloaded archive files
autoremove - Remove automatically all unused packages
build - Build binary or source packages from sources
build-dep - Configure build-dependencies for source packages
changelog - View a package's changelog
check - Verify that there are no broken dependencies
clean - Erase downloaded archive files
contains - List packages containing a file
content - List files contained in a package
deb - Install a .deb package
depends - Show raw dependency information for a package
dist-upgrade - Upgrade the system by removing/installing/upgrading packages
download - Download the .deb file for a package
edit-sources - Edit /etc/apt/sources.list with your preferred text editor
dselect-upgrade - Follow dselect selections
full-upgrade - Same as 'dist-upgrade'
held - List all held packages
help - Show help for a command
hold - Hold a package
install - Install/upgrade packages
list - List packages based on package names
policy - Show policy settings
purge - Remove packages and their configuration files
recommends - List missing recommended packages for a particular package
rdepends - Show reverse dependency information for a package
reinstall - Download and (possibly) reinstall a currently installed package
remove - Remove packages
search - Search for a package by name and/or expression
show - Display detailed information about a package
showhold - Same as 'held'
showsrc - Display all the source package records that match the given package name
source - Download source archives
sources - Same as 'edit-sources'
unhold - Unhold a package
update - Download lists of new/upgradable packages
upgrade - Perform a safe upgrade
version - Show the installed version of a package
apt
Commands:
jacqueline33@jacqueline33-ET2321I:~$ lsmod igrep 802
Usage: lsmod
Module Size Used by
xfs 1277952 0
jfs 188416 0
nls_utf8 16384 1
udf 118784 1
crc_itu_t 16384 1 udf
rfcomm 81920 16
cmac 16384 3
algif_hash 16384 1
algif_skcipher 16384 1
af_alg 24576 6 algif_hash,algif_skcipher
bnep 24576 2
nls_iso8859_1 16384 1
snd_hda_codec_realtek 122880 1
snd_hda_codec_generic 81920 1 snd_hda_codec_realtek
snd_hda_codec_hdmi 61440 1
ledtrig_audio 16384 2 snd_hda_codec_generic,snd_hda_codec_realtek
snd_hda_intel 53248 4
snd_intel_dspcfg 24576 1 snd_hda_intel
snd_hda_codec 131072 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
x86_pkg_temp_thermal 20480 0
intel_powerclamp 20480 0
snd_hda_core 90112 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
snd_hwdep 20480 1 snd_hda_codec
btusb 57344 0
snd_pcm 106496 4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
coretemp 20480 0
snd_seq_midi 20480 0
snd_seq_midi_event 16384 1 snd_seq_midi
snd_rawmidi 36864 1 snd_seq_midi
uvcvideo 98304 0
snd_seq 69632 2 snd_seq_midi,snd_seq_midi_event
btrtl 24576 1 btusb
videobuf2_vmalloc 20480 1 uvcvideo
btbcm 16384 1 btusb
videobuf2_memops 20480 1 videobuf2_vmalloc
videobuf2_v4l2 24576 1 uvcvideo
snd_seq_device 16384 3 snd_seq,snd_seq_midi,snd_rawmidi
kvm 663552 0
videobuf2_common 49152 2 videobuf2_v4l2,uvcvideo
btintel 24576 1 btusb
snd_timer 36864 2 snd_seq,snd_pcm
mei_hdcp 24576 0
videodev 225280 3 videobuf2_v4l2,uvcvideo,videobuf2_common
bluetooth 581632 41 btrtl,btintel,btbcm,bnep,btusb,rfcomm
mc 53248 4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
mei_me 40960 1
snd 90112 19 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm,snd_rawmidi
intel_rapl_msr 20480 0
eeepc_wmi 16384 0
soundcore 16384 1 snd
ecdh_generic 16384 2 bluetooth
hid_multitouch 28672 0
ecc 28672 1 ecdh_generic
intel_cstate 20480 0
intel_rapl_perf 20480 0
asus_wmi 32768 1 eeepc_wmi
ipmi_devintf 20480 0
joydev 24576 0
input_leds 16384 0
cfg80211 704512 0
ipmi_msghandler 106496 1 ipmi_devintf
mei 106496 3 mei_hdcp,mei_me
processor_thermal_device 24576 0
sparse_keymap 16384 1 asus_wmi
mxm_wmi 16384 0
intel_rapl_common 24576 2 intel_rapl_msr,processor_thermal_device
wmi_bmof 16384 0
ir_rc6_decoder 20480 0
intel_pch_thermal 16384 0
intel_soc_dts_iosf 20480 1 processor_thermal_device
rc_rc6_mce 16384 0
ene_ir 24576 0
rc_core 53248 4 ir_rc6_decoder,rc_rc6_mce,ene_ir
mac_hid 16384 0
int3400_thermal 20480 0
int3402_thermal 16384 0
int340x_thermal_zone 16384 2 int3402_thermal,processor_thermal_device
acpi_thermal_rel 16384 1 int3400_thermal
uas 28672 0
usb_storage 77824 2 uas
sch_fq_codel 20480 2
parport_pc 40960 0
ppdev 24576 0
lp 20480 0
parport 53248 3 parport_pc,lp,ppdev
ip_tables 32768 0
x_tables 40960 1 ip_tables
autofs4 45056 2
btrfs 1253376 0
xor 24576 1 btrfs
zstd_compress 167936 1 btrfs
raid6_pq 114688 1 btrfs
libcrc32c 16384 2 btrfs,xfs
dm_mirror 24576 0
dm_region_hash 20480 1 dm_mirror
dm_log 20480 2 dm_region_hash,dm_mirror
hid_logitech_hidpp 40960 0
hid_logitech_dj 24576 0
hid_generic 16384 0
usbhid 57344 1 hid_logitech_dj
hid 131072 5 usbhid,hid_multitouch,hid_generic,hid_logitech_dj,hid_logitech_hidpp
crct10dif_pclmul 16384 1
crc32_pclmul 16384 0
i915 1986560 18
ghash_clmulni_intel 16384 0
i2c_algo_bit 16384 1 i915
drm_kms_helper 184320 1 i915
aesni_intel 372736 4
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
fb_sys_fops 16384 1 drm_kms_helper
crypto_simd 16384 1 aesni_intel
r8169 90112 0
ahci 40960 2
cryptd 24576 3 crypto_simd,ghash_clmulni_intel
glue_helper 16384 1 aesni_intel
realtek 24576 1
lpc_ich 24576 0
libahci 32768 1 ahci
drm 491520 8 drm_kms_helper,i915
i2c_i801 32768 0
wmi 32768 3 asus_wmi,wmi_bmof,mxm_wmi
video 49152 2 asus_wmi,i915
Usage: lsmod
jacqueline33@jacqueline33-ET2321I:~$ lsmod lgrep 802
Usage: lsmod
jacqueline33@jacqueline33-ET2321I:~$ Lsmod lgrep 802
bash: Lsmod : commande introuvable
Usage: lsmod
Usage: lsmod
Usage: lsmod
jacqueline33@jacqueline33-ET2321I:~$ ismod igrep 802
bash: ismod : commande introuvable
jacqueline33@jacqueline33-ET2321I:~$ lsmod Igrep 802
Usage: lsmod
jacqueline33@jacqueline33-ET2321I:~$ la dernieère commande impossible car je ne sais pas quelle lettre pour ismod ? ou igrep aussi
de plus, cela fait 2 fois que je le rebooterais
donc, merci
voici :
enigma7
 Posté le 30/07/2020 à 14:04
s'il te plaît, recopie ma commande avec la souris, cela éviterai qu'il y ait des erreurs de syntaxe : lsmod | grep 802 (avec ou sans espace après le | d'ailleurs)
Modifié par enigma7 le 30/07/2020 14:06
jacqueline47
 Posté le 30/07/2020 à 14:33
cfg80211              704512  0
enigma7
 Posté le 30/07/2020 à 14:37
arf, il a pas pris
donne le retour de : dmesg -k -l emerg,alert,crit,err,warn dans un terminal
jacqueline47
 Posté le 30/07/2020 à 14:56
jacqueline33@jacqueline33-ET2321I:~$ dmesg -k -l emerg,alert,crit,err,warn
[ 0.033923] DMAR: [Firmware Bug]: Your BIOS is broken; DMAR reported at address 0!
BIOS vendor: American Megatrends Inc.; Ver: 0704; Product Version: 0704
[ 0.100698] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.100742] #3
[ 0.104763] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.397985] Initramfs unpacking failed: Decoding failed
[ 0.452881] platform eisa.0: EISA: Cannot allocate resource for mainboard
[ 0.452882] platform eisa.0: Cannot allocate resource for EISA slot 1
[ 0.452883] platform eisa.0: Cannot allocate resource for EISA slot 2
[ 0.452884] platform eisa.0: Cannot allocate resource for EISA slot 3
[ 0.452885] platform eisa.0: Cannot allocate resource for EISA slot 4
[ 0.452886] platform eisa.0: Cannot allocate resource for EISA slot 5
[ 0.452886] platform eisa.0: Cannot allocate resource for EISA slot 6
[ 0.452887] platform eisa.0: Cannot allocate resource for EISA slot 7
[ 0.452888] platform eisa.0: Cannot allocate resource for EISA slot 8
[ 0.676053] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 0.860691] [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[ 0.861683] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GFX0.DD02._BCL], AE_NOT_FOUND (20190816/psargs-330)
[ 0.861695] No Local Variables are initialized for Method [_BCL]
[ 0.861696] No Arguments are initialized for method [_BCL]
[ 0.861697] ACPI Error: Aborting method \_SB.PCI0.RP05.PEGP.DD02._BCL due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
[ 0.861902] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GFX0.DD02._BCL], AE_NOT_FOUND (20190816/psargs-330)
[ 0.861909] No Local Variables are initialized for Method [_BCL]
[ 0.861910] No Arguments are initialized for method [_BCL]
[ 0.861911] ACPI Error: Aborting method \_SB.PCI0.RP05.PEGP.DD02._BCL due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
[ 11.146761] rc rc0: nonsensical timing event of duration 0
[ 11.146763] rc rc0: two consecutive events of type space
[ 12.206615] kvm: disabled by bios
[ 12.237915] uvcvideo 1-1.7.2:1.0: Entity type for entity Extension 4 was not initialized!
[ 12.237917] uvcvideo 1-1.7.2:1.0: Entity type for entity Extension 3 was not initialized!
[ 12.237918] uvcvideo 1-1.7.2:1.0: Entity type for entity Processing 2 was not initialized!
[ 12.237919] uvcvideo 1-1.7.2:1.0: Entity type for entity Camera 1 was not initialized!
[ 12.258989] kvm: disabled by bios
[ 12.302367] kvm: disabled by bios
[ 12.346329] kvm: disabled by bios
[ 12.889906] bluetooth hci0: Direct firmware load for brcm/BCM20702A1-13d3-3404.hcd failed with error -2
[ 24.548086] kauditd_printk_skb: 22 callbacks suppressed
[ 56.077958] UDF-fs: warning (device sdb): udf_load_vrs: No anchor found
[ 56.088451] UDF-fs: warning (device sdb): udf_load_vrs: No anchor found
[ 56.102818] UDF-fs: warning (device sdb): udf_load_vrs: No anchor found
[ 56.113975] UDF-fs: warning (device sdb): udf_load_vrs: No anchor found
[ 1403.945189] TCP: enp2s0: Driver has suspect GRO implementation, TCP performance may be compromised.
jacqueline47
 Posté le 30/07/2020 à 15:03
bonjour,
le pc que j ai est un pc windows 10
j'avais mis linux mint
plusieurs jours apres, il a planté
j'ai décide de me séparer de windows et je n'ai plus que linux mint
le pire c'est que windows a la wifi et linux avait éthernet, ceci parait quand même bizarre
enigma7
hum ça sent pas bon.
Déjà le kernel 5 dit qu'il y a une erreur dans le bios, il est à jour ?
Ensuite tu as ça : Direct firmware load for brcm/BCM20702A1-13d3-3404.hcd failed with error -2 je ne sais pas si c'est lié.
Ton PC date de quand ?
S'il est assez âgé essayes plutôt un LM 19.1 en usb live (ce qu'il faut toujours faire avant d'installer, c'est fait pour tester !) Là il sera en kernel 4.15
jacqueline47
 Posté le 30/07/2020 à 15:09
bonjour,
mon pc date de 2014, c'est un asus tout en un
suite à mes problèmes avec windows et linux
j'ai décidé d'abandonner windows 10 et me mettre sous linux
l'installation a été faite à l'aide d'une clé usb bootable qu'un informaticien m'a téléchargée et à l'aide de cette clé j'ai installé linux mint
jacqueline47
 Posté le 30/07/2020 à 15:30
pour rentrer dans le bios, il faut dès qu'assus apparait faire f2 et là depuis cette installation je n'y arrive pas
enigma7
 Posté le 30/07/2020 à 17:00
Ok. Pour rentrer dans le bios, c'est spécifique à chaque marque d'ordis et n'as rien à voir avec l'installation de linux (ni de windows d'ailleurs)
Essayes de trouver la notice de ton ordi sur internet si tu ne l'as plus.
Pour faire une autre clé de test linux c'est pas bien compliqué avec rufus. Pour in Mint ancienne sauce :
https://www.linuxmint.com/edition.php?id=261 . Je le répète, avant d'installer un autre linux le tester en live usb
jacqueline47
 Posté le 30/07/2020 à 17:38
bonjour,
comme je vous le disais le bios chez asus est bien F2, mais je n'arrive plus
je vais suivre votre lien et vous tiens au courant
merci pour tout
Logicien
 Posté le 31/07/2020 à 00:51
Linux trouve des erreurs et des bugs dans presque tous les Bios. Ce n'est pas nécessaire de faire des modifications dans le Bios pour ça tant que tout ton matériel est détecté. Tu peux vouloir modifier le Bios pour des raisons comme pour activer la virtualisation, l'économie d'énergie, etc, voir mettre à jour le Bios si tu sais explicitement comment faire.
Avec les cartes sans fil Broadcom c'est impossible qu'elles soient fonctionnelles après l'installation d'une distribution Linux parce-qu'elles requiert du microcode, du firmware propriétaire ou non libre pour fonctionner ce que les distributions ne font pas par défaut. Il faut installer ces paquets soi-même la plupart du temps. C'est ce que tu as fait en installant les paquets qui commencent par b43.
Le module b43 est libre mais peut ne pas bien fonctionner, assure-toi que tous les paquets firmwares avec le mot clé b43 sont bien installés. Il y a le module b43 pour les cartes plus récentes et le module b43legacy pour les cartes sans fil Broadcom plus anciennes.
Il y a une alternative aux modules b43 et b43legacy c'est le module propriétaire de Broadcom nommé wl . Il faut le compiler à l'aide du gestionnaire de paquet. En général il fonctionne bien. C'est important de savoir quel module pilote présentement ta carte sans fil Broadcom, voir à tout moment en faisant
lsmod | grep -i -e b43 -e wl
et
sudo lspci -knn -s 03:00.0
Il ne doit y avoir qu'un seul des modules qui peut piloter ta carte de charger en mémoire soit b43 ou b43legacy ou wl . Si plus d'un d'entre eux s'affiche dans la sortie de la commande lsmod ça crée un conflit. Normalement Linux choisi celui qui va entre b43 et b43legacy. Pour utiliser le module wl il peut falloir blacklister les deux premiers. Sous Debian les paquets à installer pour b43 et b43legacy sont
b43-fwcutter
firmware-b43legacy-installer
Pour le module wl
broadcom-sta-common
broadcom-sta-dkms
broadcom-sta-source
Surveille les messages du noyau Linux après le démarrage pour savoir si tout se passe bien
sudo dmesg | grep -i -e broad -e b43 -e firmware -e wl
Les cartes sans fil Broadcom ne sont pas supportées nativement par Linux dû au microcode et au module propriétaires qu'elles nécessitent pour fonctionner. Une chose est certaine on peut les faire fontionner sous Linux.
Modifié par Logicien le 31/07/2020 01:04
jacqueline47
 Posté le 31/07/2020 à 06:40
voici ce que cela donne :
grep: e: Aucun fichier ou dossier de ce type
grep: wl: Aucun fichier ou dossier de ce type
jacqueline33@jacqueline33-ET2321I:~$ sudo lspci -knn -s o3:OO.O
lspci: -s: Invalid bus number
jacqueline33@jacqueline33-ET2321I:~$ sudo lspci -knn -s 03:00.0
03:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM4352 802.11ac Wireless Network Adapter [14e4:43b1] (rev 03)
Subsystem: AzureWave BCM4352 802.11ac Wireless Network Adapter [1a3b:2123]
Kernel modules: bcma, wl
jacqueline33@jacqueline33-ET2321I:~$ sudo dmesg | grep -i -e broad -e b43 -e firmware -e wl
[ 0.034082] DMAR: [Firmware Bug]: Your BIOS is broken; DMAR reported at address 0!
[ 0.096314] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.134410] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.467057] IPI shorthand broadcast: enabled
[ 0.885758] [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[ 1.341482] usb 1-1.3: Manufacturer: Broadcom Corp
[ 12.017503] ene_ir: Firmware regs: c0 01
[ 13.975138] bluetooth hci0: Direct firmware load for brcm/BCM20702A1-13d3-3404.hcd failed with error -2
merci pour votre aimable aide
j ai quitté windows pour ses bugs
mais je ne croyais pas que linux était si difficile avec toutes ses commandes
je ne sais pas si je vais m'en sortir
jacqueline47
 Posté le 31/07/2020 à 06:50
P.S lorsque j'essaie de rentrer dans le BIOS avec la touche F2 (touche indiquée dans ASUS) et au bon moment je n'y arrive plus
avec windows et linux au départ lorsque j'a'i eu ce pc j'y arrivais sans problème : pourquoi?
merci encore
enigma7
 Posté le 31/07/2020 à 08:03
Le problème de la touche F2 n'as rien à voir ni avec linux ni avec Windows, car cela s'opère AVANT de charger ceux-ci.
N'aurais - tu pas confié ton ordi à une autre personne qui aurai modifié les paramètres de ton Bios ? La solution, on ne peux pas te la donner, il faut que tu recherche la documentation relative à ton ordi. C'est un ordi portable ?
Maintenant pourquoi n'essayes - tu pas le Linux Mint plus ancien comme suggéré?
D'une manière générale , il faut que tu tapes les commandes en entier et sans faute de frappes , c'est pas plus dur que sous windows avec l'invite de commande. dans ton exemple du dessus tu avais 'oublié' dmesg.
jacqueline47
 Posté le 31/07/2020 à 08:51
bonjour et merci
je n'ai jamais confié mon pc asus à quelqu'un
un informaticien que je connais très bien m a créé une clé bootable pour linux mint, et je ne suis plus sous windows 10 par choix
merci j'ai fait comme on me l'a dit plus j ai télécharge mint version plus ancienne.
Où avez vous vu que j'ai oublié dmesg, je viens de regarder et je ne vois pas où je l'ai oublié précédemment
enigma7
 Posté le 31/07/2020 à 10:22
Je cite le message plus haut:
Voici ce que cela donne :
grep: wl: Aucun fichier ou dossier de ce type "
La commande d'origine de Logicien était (en une seule commande!) : sudo dmesg | grep -i -e broad -e b43 -e firmware -e wl mais j'ai vu que tu as corrigé après
C'est un bug répertorié un peu pour toutes les distributions :
https://www.google.fr/search?source=hp&ei=GtYjX7LML4u4lwTfpZD4BQ&q=%22Direct+firmware+load+for+brcm%2FBCM20702A1-13d3-3404.hcd+failed+with+error+-2%22&oq=%22Direct+firmware+load+for+brcm%2FBCM20702A1-13d3-3404.hcd+failed+with+error+-2%22&gs_lcp=CgZwc3ktYWIQA1CGCljNK2DcL2gAcAB4AIABnAGIAfMCkgEDMS4ymAEAoAEBoAECqgEHZ3dzLXdpeg&sclient=psy-ab&ved=0ahUKEwiyweiNiffqAhUL3IUKHd8SBF8Q4dUDCAY&uact=5
Il semblerai qu'il manque le firmware pour le bluetooth , ton chipset doit faire wifi plus bluetooth n'est - ce pas ?
Donnes le retour de :
ls /lib/firmware/brcm
Modifié par enigma7 le 31/07/2020 10:37
jacqueline47
 Posté le 31/07/2020 à 10:43
quant à la ligne que vous me citez elle est bien dans le message du 31 à 6H4
jackline33@jackline33-ET2321I:~$ ls /lib/firmware/brcm
BCM-0bb4-0306.hcd
bcm4329-fullmac-4.bin
bcm43xx-0.fw
bcm43xx_hdr-0.fw
brcmfmac43143.bin
brcmfmac43143-sdio.bin
brcmfmac43236b.bin
brcmfmac43241b0-sdio.bin
brcmfmac43241b4-sdio.bin
brcmfmac43241b5-sdio.bin
brcmfmac43242a.bin
brcmfmac4329-sdio.bin
brcmfmac4330-sdio.bin
brcmfmac4330-sdio.Prowise-PT301.txt
brcmfmac43340-sdio.bin
brcmfmac43340-sdio.meegopad-t08.txt
brcmfmac43340-sdio.pov-tab-p1006w-data.txt
brcmfmac4334-sdio.bin
brcmfmac4335-sdio.bin
brcmfmac43362-sdio.bin
brcmfmac43362-sdio.cubietech,cubietruck.txt
brcmfmac43362-sdio.lemaker,bananapro.txt
brcmfmac4339-sdio.bin
brcmfmac43430a0-sdio.bin
brcmfmac43430a0-sdio.jumper-ezpad-mini3.txt
'brcmfmac43430a0-sdio.ONDA-V80 PLUS.txt'
brcmfmac43430-sdio.AP6212.txt
brcmfmac43430-sdio.bin
brcmfmac43430-sdio.Hampoo-D2D3_Vi8A1.txt
brcmfmac43430-sdio.MUR1DX.txt
brcmfmac43430-sdio.raspberrypi,3-model-b.txt
brcmfmac43455-sdio.bin
'brcmfmac43455-sdio.MINIX-NEO Z83-4.txt'
brcmfmac43455-sdio.raspberrypi,3-model-b-plus.txt
brcmfmac43455-sdio.raspberrypi,4-model-b.txt
brcmfmac4350c2-pcie.bin
brcmfmac4350-pcie.bin
brcmfmac4354-sdio.bin
brcmfmac43569.bin
brcmfmac4356-pcie.bin
brcmfmac4356-pcie.gpd-win-pocket.txt
brcmfmac4356-sdio.bin
brcmfmac43570-pcie.bin
brcmfmac4358-pcie.bin
brcmfmac43602-pcie.ap.bin
brcmfmac43602-pcie.bin
brcmfmac4366b-pcie.bin
brcmfmac4366c-pcie.bin
brcmfmac4371-pcie.bin
brcmfmac4373.bin
brcmfmac4373-sdio.bin
merci
Page 1 sur 15 [Fin]
202,79 €Disque dur externe Western Digital Elements Desktop USB 3.0 12 To à 202,79 € livré
Valable jusqu'au 25 Janvier
Amazon Espagne propose actuellement le disque dur externe Western Digital Elements Desktop USB 3.0 12 To à 196,36 € (avec la TVA ajustée). Comptez 6,43 € pour la livraison en France soit un total de 202,79 € livré. On le trouve ailleurs à partir de 280 €. Ce disque dur dispose d'un grande capacité de stockage (12 To) et d'une connectique USB 3.0 qui vous offrira des transferts rapides. Il est compatible USB 2.0. A l'intérieur, vous trouverez un disque à hélium UltraStar DC HC 520 White (12 To, 5400 tr/min, 256 Mo cache, CMR -> source satdream.tech). Le disque peut être démonté et réutilisé dans un ordinateur, un NAS, etc. Une très bonne affaire
796,84 €PC portable Dell Inspiron 14 2 en 1 (FHD tactile, Ryzen 7 5700U, 16Go/512Go, Windows 11) à 796,84 €
Valable jusqu'au 24 Janvier
Dell fait une promotion sur le PC portable 14 pouces Dell Inspiron 14 7415 qui passe à 796,84 € avec le code DLBINSP2 au lieu de 999 €.
Ce portable possède un écran Full HD tactile que vous plier à 360° pour transformer l'ordinateur en tablette. Il a un processeur AMD Ryzen 7 5700U, 16 Go de RAM et un SSD M.2 NVMe de 512 Go. Le tout tourne sous Windows 11. Au niveau connectique, vous trouverez 2 x USB 3.1, 1xUSB 4.0 Type-C avec DisplayPort et Power Delivery, un port HDMI 1.4b, un lecteur microSD, le WiFi 6 et le bluetooth 5.1. Comptez une autonomie d'une dizaine d'heures. Une excelle affaire !
Pour profiter de l'offre, sélectionnez dans la liste le portable Inspiron 14 2 en 1 à 838,76 € avec la remise immédiate de 160 €. Utilisez le code DLBINSP2 dans votre panier pour passer le prix à 796,84 €.
539,94 €Mini PC MINISFORUM EliteMini X400 (Ryzen 5 Pro 4650G, 16Go RAM, 512Go SSD) à 539,94 €
Valable jusqu'au 23 Janvier
GeekBuying fait une belle promotion le mini PC MINISFORUM EliteMini X400 qui passe à 539,94 € avec le code promo NNNMINISFORUM au lieu de 729 €. Ce mini PC au format NUC d'Intel est extrêmement bien équipé. Il possède un processeur AMD Ryzen 5 Pro 4650G 6 coeurs  (3.6 à 4.4 GHz) avec chip graphique Vega 7, 16 Go de RAM DDR4 et un SSD NVMe de 512 Go. Il dispose d'une connectique complète : un emplacement 2,5 pouces libre (pour ajouter un disque dur ou un SSD supplémentaire), le WiFi6, le bluetooth 5.0, 4 ports USB 3.0, un port HDMI 2.0, un DisplayPort, un port Ethernet Gigabit, un lecteur de carte MicroSD et tourne sous Windows 10 Pro que vous pourrez mettre en français au premier démarrage.
Branchez ce mini PC sur une TV ou un écran et vous avez un ordinateur discret et très performant (bureautique, multimédia, jeux en HD).
Cet ordinateur est expédiée depuis un entrepôt allemand. Vous êtes ainsi certains d'être livré rapidement et de ne pas avoir de douane.
pas de démarrage sur linux mint dans le grub w10/linux mint
Visionner mon PC de bureau (sous Linux) sur ma TV ?
Pas de connexion Wifi après installation Linux Mint 17.1
Pas de son avec linux mint 8 helena
Pc linux connecté mais pas visible sur box orange
probleme de son avec linux mint
linux mint et timeshift - pas de partition linux.
PC qui ne boot pas sur un CD linux
Zedtv ne fonctionne pas avec Linux Mint
DualBoot - Pas de démarrage auto sur W10 après suppression de Linux
Plus de sujets relatifs à Pas de wifi sur mon pc asus all on one avec linux mint
