J'ai été infecté par un 1clickdownloader d'après mon antivirus Avira.
De plus suite à la récupération d'un ami sur azureus ( mea culpa ) , mon pc a était subitement lent , notamment sur internet
même après désinstallation d'azureus.
J'ai passé un coup de MBAM (à jour) voici le rapport:
Malwarebytes Anti-Malware 1.65.1.1000
www.malwarebytes.org
Database version: v2012.12.21.15
Windows 7 x64 NTFS
Internet Explorer 9.0.8112.16421
Emilie
THOMAS-PC [administrator]
21/12/2012 20:53:06
mbam-log-2012-12-21 (20-53-06).txt
Scan type: Full scan (C:\|D:\|F:\|G:\|)
Scan options enabled: Memory | Startup | Registry | File System | Heuristics/Extra | Heuristics/Shuriken | PUP | PUM
Scan options disabled: P2P
Objects scanned: 572777
Time elapsed: 3 hour(s), 6 minute(s),
Memory Processes Detected: 0
(No malicious items detected)
Memory Modules Detected: 0
Registry Keys Detected: 0
Registry Values Detected: 0
Registry Data Items Detected: 0
Folders Detected: 0
Files Detected: 8
C:\Users\Emilie\Desktop\Logiciels\SoftonicDownloader_pour_grisbi.exe (PUP.OfferBundler.ST) -> Quarantined and deleted successfully.
C:\Users\Emilie\Downloads\Fleury Michon.png.exe (Adware.Solimba) -> Quarantined and deleted successfully.
C:\Users\Emilie\Downloads\setup.exe (PUP.BundleInstaller.VG) -> Quarantined and deleted successfully.
C:\Users\Emilie\Downloads\Setup_V17FR.exe (Adware.Toolbar) -> Quarantined and deleted successfully.
C:\Users\Emilie\Downloads\amtlib.dll\32-bit\amtlib.dll (PUP.RiskwareTool.CK) -> Quarantined and deleted successfully.
C:\Users\Emilie\Downloads\amtlib.dll\64-bit\amtlib.dll (PUP.RiskwareTool.CK) -> Quarantined and deleted successfully.
D:\adobe\Adobe After Effects CS6\Support Files\amtlib.dll (PUP.RiskwareTool.CK) -> Quarantined and deleted successfully.
G:\MARIAGE\MUSIQUE DANSE MARIEE\SoftonicDownloader_pour_virtual-dj.exe (PUP.OfferBundler.ST) -> Quarantined and deleted successfully.
(end)
J'ai passé également Emsisoft -> aucun fichiers détectés
J'ai passé également adwcleaner :
# AdwCleaner v2.101 - Rapport créé le 22/12/2012 à 10:43:23
# Mis à jour le 16/12/2012 par Xplode
# Système d'exploitation : Windows 7 Home Premium (64 bits)
# Nom d'utilisateur : Emilie - THOMAS-PC
# Mode de démarrage : Normal
# Exécuté depuis : C:\Users\Emilie\Downloads\adwcleaner.exe
# Option [Suppression]
***** [Services] *****
***** [Fichiers / Dossiers] *****
Dossier Supprimé : C:\Program Files (x86)\FilesFrog Update Checker
Dossier Supprimé : C:\Program Files (x86)\Freecorder
Dossier Supprimé : C:\Program Files (x86)\Perion
Dossier Supprimé : C:\Program Files (x86)\PriceGong
Dossier Supprimé : C:\ProgramData\Babylon
Dossier Supprimé : C:\Users\Emilie\AppData\Local\Conduit
Dossier Supprimé : C:\Users\Emilie\AppData\Local\Freecorder
Dossier Supprimé : C:\Users\Emilie\AppData\Local\Wajam
Dossier Supprimé : C:\Users\Emilie\AppData\LocalLow\BabylonToolbar
Dossier Supprimé : C:\Users\Emilie\AppData\LocalLow\Billeo
Dossier Supprimé : C:\Users\Emilie\AppData\LocalLow\boost_interprocess
Dossier Supprimé : C:\Users\Emilie\AppData\LocalLow\Freecorder
Dossier Supprimé : C:\Users\Emilie\AppData\LocalLow\pdfforge
Dossier Supprimé : C:\Users\Emilie\AppData\LocalLow\Search Settings
Dossier Supprimé : C:\Users\Emilie\AppData\Roaming\Babylon
Dossier Supprimé : C:\Users\Emilie\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\FilesFrog Update Checker
Dossier Supprimé : C:\Users\Emilie\AppData\Roaming\Mozilla\Firefox\Profiles\lvhe5cdc.default\extensions\ffxtlbr@babylon.com
Dossier Supprimé : C:\Users\Emilie\AppData\Roaming\Mozilla\Firefox\Profiles\lvhe5cdc.default\extensions\ffxtlbr@incredibar.com
Dossier Supprimé : C:\Users\Emilie\AppData\Roaming\Search Settings
Dossier Supprimé : C:\Users\Emilie\Documents\Billeo
Dossier Supprimé : C:\Windows\Freecorder
Fichier Supprimé : C:\Program Files (x86)\Mozilla Firefox\searchplugins\babylon.xml
Fichier Supprimé : C:\user.js
Fichier Supprimé : C:\Users\Emilie\AppData\Roaming\Mozilla\Firefox\Profiles\lvhe5cdc.default\searchplugins\MyStart Search.xml
***** [Registre] *****
Clé Supprimée : HKCU\Software\AppDataLow\Software\Freecorder
Clé Supprimée : HKCU\Software\AppDataLow\Software\pdfforge
Clé Supprimée : HKCU\Software\AppDataLow\Toolbar
Clé Supprimée : HKCU\Software\Freecorder
Clé Supprimée : HKCU\Software\IM
Clé Supprimée : HKCU\Software\ImInstaller
Clé Supprimée : HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Search Settings
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{1392B8D2-5C05-419F-A8F6-B9F15A596612}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{E312764E-7706-43F1-8DAB-FCDD2B1E416D}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{F9E4A054-E9B1-4BC3-83A3-76A1AE736170}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{1392B8D2-5C05-419F-A8F6-B9F15A596612}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{E312764E-7706-43F1-8DAB-FCDD2B1E416D}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{F9E4A054-E9B1-4BC3-83A3-76A1AE736170}
Clé Supprimée : HKCU\Software\ResearchNow
Clé Supprimée : HKCU\Software\Search Settings
Clé Supprimée : HKCU\Software\Softonic
Clé Supprimée : HKCU\Software\Somoto
Clé Supprimée : HKCU\Software\SweetIM
Clé Supprimée : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{AFDBDDAA-5D3F-42EE-B79C-185A7020515B}
Clé Supprimée : HKLM\Software\Babylon
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{608D3067-77E8-463D-9084-908966806826}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{BDB69379-802F-4EAF-B541-F8DE92DD98DB}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{D616A4A2-7B38-4DBC-9093-6FE7A4A21B17}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{EA28B360-05E0-4F93-8150-02891F1D8D3C}
Clé Supprimée : HKLM\SOFTWARE\Classes\Conduit.Engine
Clé Supprimée : HKLM\SOFTWARE\Classes\Prod.cap
Clé Supprimée : HKLM\SOFTWARE\Classes\Toolbar.CT1060933
Clé Supprimée : HKLM\SOFTWARE\Classes\Toolbar.CT2765711
Clé Supprimée : HKLM\Software\Conduit
Clé Supprimée : HKLM\Software\Freecorder
Clé Supprimée : HKLM\Software\Iminent
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\incredibar_installer_RASAPI32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\incredibar_installer_RASMANCS
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\IncredibarToolbar_RASAPI32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\IncredibarToolbar_RASMANCS
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\MyBabylontb_RASAPI32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\MyBabylontb_RASMANCS
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{639DDC21-0D09-4A26-A210-E874735D5387}
Clé Supprimée : HKLM\Software\ResearchNow
Clé Supprimée : HKLM\Software\SweetIM
Clé Supprimée : HKLM\Software\Web Assistant
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{1392B8D2-5C05-419F-A8F6-B9F15A596612}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{639DDC21-0D09-4A26-A210-E874735D5387}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Google\Chrome\Extensions\dlnembnfbcpjnepmfjmngjenhhajpdfd
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Google\Chrome\Extensions\jpmbfleldcgkldadpdinhjjopdfpjfjp
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\SearchScopes\{AFDBDDAA-5D3F-42EE-B79C-185A7020515B}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{1392B8D2-5C05-419F-A8F6-B9F15A596612}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{465E08E7-F005-4389-980F-1D8764B3486C}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{889DF117-14D1-44EE-9F31-C5FB5D47F68B}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\FilesFrog Update Checker
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Freecorder Toolbar
Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{F9E4A054-E9B1-4BC3-83A3-76A1AE736170}
Clé Supprimée : HKLM\SOFTWARE\Google\Chrome\Extensions\dlnembnfbcpjnepmfjmngjenhhajpdfd
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{F9E4A054-E9B1-4BC3-83A3-76A1AE736170}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{889DF117-14D1-44EE-9F31-C5FB5D47F68B}
Clé Supprimée : HKLM\SOFTWARE\Web Assistant
Valeur Supprimée : HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser [{1392B8D2-5C05-419F-A8F6-B9F15A596612}]
Valeur Supprimée : HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser [{30F9B915-B755-4826-820B-08FBA6BD249D}]
Valeur Supprimée : HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser [{6ADB0F93-1AA5-4BCF-9DF4-CEA689A3C111}]
Valeur Supprimée : HKCU\Software\Microsoft\Internet Explorer\URLSearchHooks [{E312764E-7706-43F1-8DAB-FCDD2B1E416D}]
Valeur Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks [{1392B8D2-5C05-419F-A8F6-B9F15A596612}]
Valeur Supprimée : HKLM\SOFTWARE\Mozilla\Firefox\extensions [{336D0C35-8A85-403a-B9D2-65C292C39087}]
Valeur Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Toolbar [{1392B8D2-5C05-419F-A8F6-B9F15A596612}]
***** [Navigateurs] *****
-\\ Internet Explorer v9.0.8112.16457
[OK] Le registre ne contient aucune entrée illégitime.
-\\ Mozilla Firefox v3.6.23 (fr)
Nom du profil : default
Fichier : C:\Users\Emilie\AppData\Roaming\Mozilla\Firefox\Profiles\lvhe5cdc.default\prefs.js
C:\Users\Emilie\AppData\Roaming\Mozilla\Firefox\Profiles\lvhe5cdc.default\user.js ... Supprimé !
Supprimée : user_pref("browser.newtab.url", "hxxp://mystart.incredibar.com/mb174?a=6PQF1mTPVE&loc=FF_NT");
Supprimée : user_pref("browser.search.order.1", "Search the web (Babylon)");
Supprimée : user_pref("extensions.BabylonToolbar.admin", false);
Supprimée : user_pref("extensions.BabylonToolbar.aflt", "babsst");
Supprimée : user_pref("extensions.BabylonToolbar.autoRvrt", "false");
Supprimée : user_pref("extensions.BabylonToolbar.babExt", "");
Supprimée : user_pref("extensions.BabylonToolbar.babTrack", "affID=110186&tt=3012_5");
Supprimée : user_pref("extensions.BabylonToolbar.cntry", "FR");
Supprimée : user_pref("extensions.BabylonToolbar.dfltLng", "en");
Supprimée : user_pref("extensions.BabylonToolbar.dfltSrch", true);
Supprimée : user_pref("extensions.BabylonToolbar.envrmnt", "production");
Supprimée : user_pref("extensions.BabylonToolbar.excTlbr", false);
Supprimée : user_pref("extensions.BabylonToolbar.hdrMd5", "9F90414F21E6A70A25D1A18EB52DE1C3");
Supprimée : user_pref("extensions.BabylonToolbar.hmpg", true);
Supprimée : user_pref("extensions.BabylonToolbar.id", "e462fcfc0000000000001a4bd65b6ee2");
Supprimée : user_pref("extensions.BabylonToolbar.instlDay", "15550");
Supprimée : user_pref("extensions.BabylonToolbar.instlRef", "sst");
Supprimée : user_pref("extensions.BabylonToolbar.keyWordUrl", "hxxp://search.babylon.com/?affID=110186&tt=3012_5[...]
Supprimée : user_pref("extensions.BabylonToolbar.lastVrsnTs", "1.5.29.10:08:31");
Supprimée : user_pref("extensions.BabylonToolbar.mntrvrsn", "1.3.0");
Supprimée : user_pref("extensions.BabylonToolbar.newTab", false);
Supprimée : user_pref("extensions.BabylonToolbar.noFFXTlbr", false);
Supprimée : user_pref("extensions.BabylonToolbar.prdct", "BabylonToolbar");
Supprimée : user_pref("extensions.BabylonToolbar.prtnrId", "babylon");
Supprimée : user_pref("extensions.BabylonToolbar.sg", "azb");
Supprimée : user_pref("extensions.BabylonToolbar.smplGrp", "azb");
Supprimée : user_pref("extensions.BabylonToolbar.srcExt", "ss");
Supprimée : user_pref("extensions.BabylonToolbar.tlbrId", "base");
Supprimée : user_pref("extensions.BabylonToolbar.tlbrSrchUrl", "hxxp://www.google.com/search?babsrc=TB_ggl&q=");
Supprimée : user_pref("extensions.BabylonToolbar.vrsn", "1.5.29.1");
Supprimée : user_pref("extensions.BabylonToolbar.vrsnTs", "1.5.29.10:08:31");
Supprimée : user_pref("extensions.BabylonToolbar.vrsni", "1.5.29.1");
Supprimée : user_pref("extensions.BabylonToolbar_i.babExt", "");
Supprimée : user_pref("extensions.BabylonToolbar_i.babTrack", "affID=110186&tt=3012_5");
Supprimée : user_pref("extensions.BabylonToolbar_i.newTab", false);
Supprimée : user_pref("extensions.BabylonToolbar_i.smplGrp", "none");
Supprimée : user_pref("extensions.BabylonToolbar_i.srcExt", "ss");
Supprimée : user_pref("extensions.BabylonToolbar_i.vrsnTs", "1.5.29.10:08:31");
Supprimée : user_pref("extensions.incredibar.admin", false);
Supprimée : user_pref("extensions.incredibar.aflt", "orgnl");
Supprimée : user_pref("extensions.incredibar.cntry", "FR");
Supprimée : user_pref("extensions.incredibar.dfltLng", "");
Supprimée : user_pref("extensions.incredibar.dfltSrch", false);
Supprimée : user_pref("extensions.incredibar.did", "10671");
Supprimée : user_pref("extensions.incredibar.envrmnt", "production");
Supprimée : user_pref("extensions.incredibar.excTlbr", false);
Supprimée : user_pref("extensions.incredibar.hdrMd5", "B78F78956798F8396948A3CA6F656402");
Supprimée : user_pref("extensions.incredibar.hmpg", false);
Supprimée : user_pref("extensions.incredibar.id", "e462fcfc0000000000001a4bd65b6ee2");
Supprimée : user_pref("extensions.incredibar.installerproductid", "26");
Supprimée : user_pref("extensions.incredibar.instlDay", "15551");
Supprimée : user_pref("extensions.incredibar.instlRef", "");
Supprimée : user_pref("extensions.incredibar.lastVrsnTs", "1.5.11.1411:31:00");
Supprimée : user_pref("extensions.incredibar.mntrvrsn", "1.2.0");
Supprimée : user_pref("extensions.incredibar.newTab", false);
Supprimée : user_pref("extensions.incredibar.noFFXTlbr", false);
Supprimée : user_pref("extensions.incredibar.ppd", "7777726");
Supprimée : user_pref("extensions.incredibar.prdct", "incredibar");
Supprimée : user_pref("extensions.incredibar.productid", "26");
Supprimée : user_pref("extensions.incredibar.prtnrId", "Incredibar");
Supprimée : user_pref("extensions.incredibar.sg", "none");
Supprimée : user_pref("extensions.incredibar.smplGrp", "none");
Supprimée : user_pref("extensions.incredibar.tlbrId", "base");
Supprimée : user_pref("extensions.incredibar.tlbrSrchUrl", "hxxp://mystart.Incredibar.com/?a=6PQF1mTPVE&loc=IB_T[...]
Supprimée : user_pref("extensions.incredibar.upn2", "6PQF1mTPVE");
Supprimée : user_pref("extensions.incredibar.upn2n", "92543318686112650");
Supprimée : user_pref("extensions.incredibar.vrsn", "1.5.11.14");
Supprimée : user_pref("extensions.incredibar.vrsnTs", "1.5.11.1411:31:00");
Supprimée : user_pref("extensions.incredibar.vrsni", "1.5.11.14");
Supprimée : user_pref("extensions.incredibar_i.aflt", "orgnl");
Supprimée : user_pref("extensions.incredibar_i.dfltLng", "");
Supprimée : user_pref("extensions.incredibar_i.did", "10671");
Supprimée : user_pref("extensions.incredibar_i.excTlbr", false);
Supprimée : user_pref("extensions.incredibar_i.id", "e462fcfc0000000000001a4bd65b6ee2");
Supprimée : user_pref("extensions.incredibar_i.installerproductid", "26");
Supprimée : user_pref("extensions.incredibar_i.instlDay", "15551");
Supprimée : user_pref("extensions.incredibar_i.instlRef", "");
Supprimée : user_pref("extensions.incredibar_i.ms_url_id", "");
Supprimée : user_pref("extensions.incredibar_i.newTab", false);
Supprimée : user_pref("extensions.incredibar_i.ppd", "7777726");
Supprimée : user_pref("extensions.incredibar_i.prdct", "incredibar");
Supprimée : user_pref("extensions.incredibar_i.productid", "26");
Supprimée : user_pref("extensions.incredibar_i.prtnrId", "Incredibar");
Supprimée : user_pref("extensions.incredibar_i.smplGrp", "none");
Supprimée : user_pref("extensions.incredibar_i.tlbrId", "base");
Supprimée : user_pref("extensions.incredibar_i.tlbrSrchUrl", "hxxp://mystart.Incredibar.com/?a=6PQF1mTPVE&loc=IB[...]
Supprimée : user_pref("extensions.incredibar_i.upn2", "6PQF1mTPVE");
Supprimée : user_pref("extensions.incredibar_i.upn2n", "92543318686112650");
Supprimée : user_pref("extensions.incredibar_i.vrsn", "1.5.11.14");
Supprimée : user_pref("extensions.incredibar_i.vrsnTs", "1.5.11.1411:31:00");
Supprimée : user_pref("extensions.incredibar_i.vrsni", "1.5.11.14");
Supprimée : user_pref("extensions.proxytool.referers", "www.google.com,google.com,yahoo.com,bing.com,ask.com,cur[...]
Supprimée : user_pref("keyword.URL", "hxxp://search.babylon.com/?babsrc=SP_ss&mntrId=e462fcfc0000000000001a4bd65[...]
Supprimée : user_pref("{336D0C35-8A85-403a-B9D2-65C292C39087}.ScriptData_WSG_temp_referer", "hxxp://search.babyl[...]
Supprimée : user_pref("{336D0C35-8A85-403a-B9D2-65C292C39087}.ScriptData_WSG_whiteList", "{\"search.babylon.com\[...]
-\\ Google Chrome v23.0.1271.97
Fichier : C:\Users\Emilie\AppData\Local\Google\Chrome\User Data\Default\Preferences
[OK] Le fichier ne contient aucune entrée illégitime.
-\\ Opera v11.1.1190.0
Fichier : C:\Users\Emilie\AppData\Roaming\Opera\Opera\operaprefs.ini
Supprimée : Home URL=hxxp://mystart.incredibar.com/mb174?a=6PQF1mTPVE&i=26
AdwCleaner[R1].txt - [16937 octets] - [21/12/2012 21:08:14]
AdwCleaner[R2].txt - [15350 octets] - [22/12/2012 00:01:46]
AdwCleaner[S3].txt - [15333 octets] - [22/12/2012 10:43:23]
########## EOF - C:\AdwCleaner[S3].txt - [15394 octets] ##########
Je joins mon rapport ZHPDiag par la suite
En vous remerciant d'avanec pour votre aide
