 PC vers TV avec PS3
flamel
  Posté le 18/09/2016 @ 14:45
Windows 7
Chrome 53.0.2785.116
Pour lire des viceo du PC sur la TV par CPL, j'ai utilisé PS3 Player qui avait bien marché.
Brusquement la liaison a été interompue et je n'arrive pas à la rétablir.
PS3 ne reconnait plus iren et indqie des messages d'erreur que je ne sais pas interpréter.
En voici une copie partielle à la suite d'une nouvelle tentative infructueuse :
INFO 2016-09-18 14:39:35.015 [main] Registering transcoding engine: VLC Video
INFO 2016-09-18 14:39:35.054 [main] Registering transcoding engine: FFmpeg Web Video
INFO 2016-09-18 14:39:35.055 [main] Registering transcoding engine: FFmpeg Web Audio
INFO 2016-09-18 14:39:35.056 [main] Registering transcoding engine: MEncoder Web Video
INFO 2016-09-18 14:39:35.057 [main] Registering transcoding engine: VLC Web Video
INFO 2016-09-18 14:39:35.058 [main] Registering transcoding engine: tsMuxeR
INFO 2016-09-18 14:39:35.058 [main] Registering transcoding engine: Audio High Fidelity
INFO 2016-09-18 14:39:35.059 [main] Registering transcoding engine: VLC Web Audio (Legacy)
INFO 2016-09-18 14:39:35.060 [main] Registering transcoding engine: VLC Web Video (Legacy)
INFO 2016-09-18 14:39:35.060 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO 2016-09-18 14:39:35.061 [main] Registering transcoding engine: dcraw Thumbnailer
INFO 2016-09-18 14:39:35.123 [main] Using address /192.168.1.4 found on network interface: name:eth3 (Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20))
INFO 2016-09-18 14:39:35.123 [main] Created socket: /192.168.1.4:5001
ERROR 2016-09-18 14:39:35.171 [main] A serious error occurred during PMS init
org.jboss.netty.channel.ChannelException: Failed to bind to: /192.168.1.4:5001
at org.jboss.netty.bootstrap.ServerBootstrap.bind(ServerBootstrap.java:303) ~[pms.jar:1.90.1]
at net.pms.network.HTTPServer.start(HTTPServer.java:125) ~[pms.jar:1.90.1]
at net.pms.PMS.init(PMS.java:548) [pms.jar:1.90.1]
at net.pms.PMS.createInstance(PMS.java:872) [pms.jar:1.90.1]
at net.pms.PMS.main(PMS.java:949) [pms.jar:1.90.1]
Caused by: java.net.BindException: Address already in use: bind
at sun.nio.ch.Net.bind0(Native Method) ~[na:1.7.0_25]
at sun.nio.ch.Net.bind(Unknown Source) ~[na:1.7.0_25]
at sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source) ~[na:1.7.0_25]
at sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source) ~[na:1.7.0_25]
at org.jboss.netty.channel.socket.nio.NioServerSocketPipelineSink.bind(NioServerSocketPipelineSink.java:148) ~[pms.jar:1.90.1]
at org.jboss.netty.channel.socket.nio.NioServerSocketPipelineSink.handleServerSocket(NioServerSocketPipelineSink.java:100) ~[pms.jar:1.90.1]
at org.jboss.netty.channel.socket.nio.NioServerSocketPipelineSink.eventSunk(NioServerSocketPipelineSink.java:74) ~[pms.jar:1.90.1]
at org.jboss.netty.channel.Channels.bind(Channels.java:468) ~[pms.jar:1.90.1]
at org.jboss.netty.channel.AbstractChannel.bind(AbstractChannel.java:192) ~[pms.jar:1.90.1]
at org.jboss.netty.bootstrap.ServerBootstrap$Binder.channelOpen(ServerBootstrap.java:348) ~[pms.jar:1.90.1]
at org.jboss.netty.channel.Channels.fireChannelOpen(Channels.java:176) ~[pms.jar:1.90.1]
at org.jboss.netty.channel.socket.nio.NioServerSocketChannel.<init>(NioServerSocketChannel.java:85) ~[pms.jar:1.90.1]
at org.jboss.netty.channel.socket.nio.NioServerSocketChannelFactory.newChannel(NioServerSocketChannelFactory.java:142) ~[pms.jar:1.90.1]
at org.jboss.netty.channel.socket.nio.NioServerSocketChannelFactory.newChannel(NioServerSocketChannelFactory.java:90) ~[pms.jar:1.90.1]
at org.jboss.netty.bootstrap.ServerBootstrap.bind(ServerBootstrap.java:282) ~[pms.jar:1.90.1]
... 4 common frames omitted
Merci si vous pouvez m'aider.
Cordialement.
flamel
 Posté le 20/09/2016 à 15:42
Il 'y a pas beaucoup d’utilisateurs de PS3...
Super_GEGE
 Posté le 22/09/2016 à 17:22
Tu devrais tenter de le désinstaller et le réinstaller.
Tu as peut-être un problème de pare-feu qui bloque ta connexion. Failed to bind to: /192.168.1.4:5001
3ème offert2 jeux de société achetés = le 3ème offert
Valable jusqu'au 02 Novembre
Pour 2 jeux de société achetés sur Amazon parmi une sélection, le 3ème vous est offert. Une très bonne affaire puisque vous trouverez des références comme The Crew, Code Names, Kingdomino, Azul, Dixit, Catan, Splendor, ...
55 €Microphone USB Bird UM1 à 55 €
Valable jusqu'au 31 Octobre
Amazon fait une vente flash sur le Microphone USB Bird UM1 qui passe à 55 € alors qu'on le trouve ailleurs à partir de 69 €. La livraison est gratuite. Le Bird UM1 est un micro de studio d'excellente qualité avec interface USB intégrée. C'est une solution idéale et tout-en-un qui évite d'avoir à acheter un préampli ou une interface audio supplémentaire.  Idéal pour le studio, YouTube ou l'animation de votre blog.
314,81 €Mini PC MINISFORUM UM300 (Ryzen 3 3300U, 16Go RAM, 512 Go SSD) à 314,81 € avec le code BGSEDK
Valable jusqu'au 29 Octobre
Banggood propose actuellement le mini PC MINISFORUM UM300 à 306,63 € avec le code promo BGSEDK. Ce mini PC au format NUC d'Intel possède un processeur Ryzen 3 3300U avec chip graphique Vega 6, 16 Go de RAM DDR4 et un SSD de 512 Go. Il dispose d'une connectique complète : un emplacement 2,5 pouces libre (pour ajouter un disque dur ou un SSD supplémentaire, le WiFi6, le bluetooth 5.1, 3 ports USB 3.1, un port HDMI 2.0, un DisplayPort, deux ports Ethernet Gigabit et tourne sous Windows 10 que vous pourrez mettre en français. Il est livré avec une alimentation européenne. Branchez ce mini PC sur une TV ou un écran et vous avez un ordinateur discret et performant. Comptez 8,18 € pour l'assurance et la livraison soit un total de 314,81 € livré.
