> Tous les forums > Forum Autres langages
 Peut-on corriger ce code erroné ?
tease
  Posté le 15/05/2017 @ 20:28
Bonjour Astuciennes et Astuciens.
J'ai trouvé ce code batch pour masquer un dossier (voir ce lien: http://pc-hacks.blogspot.com/2007/10/lock-folders-without-any-software.html)
Problème 1: Le dossier caché ne réapparaît pas
cls
@echo off
color 9f
title Folder Locker
:option
echo 1.Create folder 2.Lock folder 3.Unlock folder 4.Set password
set/p "option=Please choose option 1-4>"
if %option%==1 goto create
if %option%==2 goto lock
if %option%==3 goto unlock
if %option%==4 goto set
echo Invalid choice
goto option
:create
if exist "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}" (echo You already have a locked folder & goto option)
if not exist "Locker" (md Locker & echo Locker created successfully ) Else (echo Locker folder already exist)
if defined mypass (goto option)
echo This is the first time you run this program please enter a
echo password and log off this user and logon again for the
echo password to take effect.
set /p "long=Set your password>"
reg add "hklm\system\currentcontrolset\control\session manager\environment" /v mypass /d %long% /f
cls
echo Password set successfully
goto option
:lock
if exist "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}" (echo Folder already locked & goto option)
if not exist "Locker" (echo You need to create a folder first & goto Option)
ren Locker "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
attrib +h +s "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
echo Folder Locked Successfully
goto option
:unlock
set x=1
set /a y=y + x
if %y% GTR 3 goto wait
if exist "Locker" (echo No file to unlock & goto option)
if not exist "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}" (echo No file to unlock & goto option)
if not defined mypass (echo You need to set a password & goto option)
set/p "pass=Enter password to unlock folder>"
if not %pass%==%mypass% (echo Invalid password & goto unlock)
attrib -h -s "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
ren "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}" Locker
echo Folder unlocked successfully
goto option
:set
echo 1.Change password 2.Remove password
set /p "short=Please choose option 1-2>"
if %short%==1 goto reset
if %short%==2 goto remove
:reset
echo You have select to change your password if you do not wish
echo to continue please close the command prompt else enter the
echo old password to continue.
set /p "longer=Enter old password>"
if not %longer%==%mypass% (echo Invalid password & goto set)
set /p "longest=Enter new password>"
reg add "hklm\system\currentcontrolset\control\session manager\environment" /v mypass /d %longest% /f
cls
echo Please log off and login again for password to take effect
goto option
:remove
if exist "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}" (echo Please unlock folder before proceed to remove password & goto option)
echo You have select to remove your password if you do not wish
echo old password.
if not %longer%==%mypass% (echo Invalid password & goto remove)
reg delete "hklm\system\currentcontrolset\control\session manager\environment" /v mypass /f
cls
echo Password remove successfully
echo Please log off and login again for password to fully erased from memory
goto option
:wait
cls
echo You have enter an invalid password 3 times in a row please
echo try again.
goto option
Si les lignes en gras sont effacées, le dossier caché réapparaît
cls
@echo off
color 9f
title Folder Locker
:option
echo Invalid choice
goto option
:create
cls
goto option
:lock
goto option
:unlock
set x=1
set /a y=y + x
goto option
:set
:reset
cls
goto option
:remove
echo old password.
cls
goto option
:wait
cls
echo try again.
goto option
Problème 2: Dans le menu du batch, on peut changer ou supprimer le mot de passe (voir l'option 4)
Or cette option ne fonctionne pas
Peut-on corriger ces 2 problèmes ?
Merci de bien vouloir m'aider.
16,99 €Microsoft bluetooth mouse à 16,99 €
Valable jusqu'au 26 Janvier
Amazon fait une promotion sur la souris Microsoft bluetooth mouse qui passe à 16,99 € au lieu de 25 €. La Microsoft Bluetooth Mouse est une souris qui vous suit partout, que ce soit en déplacement, au bureau ou à la maison, elle répond toujours présente. Intégrant un capteur optique de 1000 dpi, elle offre un suivi rapide sur la plupart des surfaces. Sans fil, elle se connecte à votre ordinateur via Bluetooth afin de vous permettre de travailler en toute liberté.
68,28 €Souris Logitech MX Anywhere 3 (Bluetooth, Unifying) à 68,28 € livrée
Amazon Allemagne fait une promotion sur la nouvelle souris sans fil Logitech MX Anywhere 3 qui passe à 63,43 € (avec la TVA ajustée). Comptez 4,85 € pour la livraison en France soit un total de 68,28 € livrée alors qu'on la trouve ailleurs à partir de 90 €. Cette souris que vous pourrez emporter partout avec votre PC ou Mac portable offre une double connectivité sans fil unify ou Bluetooth. Son capteur laser Dark field vous permettra de l'utiliser sur n'importe quelle surface et sa molette débrayable permet un défilement ultra rapide. Prévue pour la polyvalence et la mobilité, vous pouvez appairer cette souris à trois appareils simultanément ! Choisissez ensuite facilement quel appareil contrôler via le curseur placé sous la souris. De plus, grâce au logiciel Logitech Options, copiez-collez des documents et des images d'un ordinateur à l'autre juste avec la souris, même entre MacOS et Windows.
12,54 €Micro clé USB 3.1 Sandisk Ultra Fit 64 Go à 12,54 €
Valable jusqu'au 28 Janvier
Amazon fait une promotion sur la micro clé USB Sandisk Ultra Fit d'une capacité de 64 Go qui passe à 12,54 €. La minuscule taille de cette clé USB va vous permettre de la laisser brancher en permanence sur votre portable, votre TV ou votre autoradio sans qu'elle dépasse de manière disgracieuse. Sa compatibilité USB 3.1 lui permet d'atteindre des débits jusqu'à 130 Mo/s.
code html
Code source programme
parametrage du code java pour imprimer
code résultat sur liste deroulante
Code erreur Windows Live Mail
Cours et exercices corriger de hibernate
code vb pour suppression
code vb permettant d'enregistrer en access
Erreur nouveau projet code::blocks
code en sql
Plus de sujets relatifs à Peut-on corriger ce code erroné ?
 > Tous les forums > Forum Autres langages
