 plugin flash player impossible a installerSujet résolu
Pages : [1] 2 ... Fin
Page 1 sur 2 [Fin]
MAXOU13
  Posté le 02/02/2010 @ 18:45
Bonjour,je n'arrive pas a l'installer le plugin flash player,a chaque fois j'ai droit au cadre:" getplus+(R) a rencontré un problème
et doit fermer" je suis sur Mozilla firefox
merci d'avance
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 18:41:32, on 02/02/2010
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.6000.16981)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\Program Files\Java\jre6\bin\jusched.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Windows Media Player\WMPNSCFG.exe
C:\Program Files\Sony\Sony Picture Utility\PMBCore\SPUVolumeWatcher.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\Java\jre6\bin\jqs.exe
C:\Program Files\ADSL Autoconnect\ADSL Autoconnect.exe
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
C:\WINDOWS\System32\wbem\wmiapsrv.exe
C:\Program Files\Mozilla Firefox 3.1 Beta 3\firefox.exe
C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKCU\Software\Microsoft\Internet Explorer\Search,Default_Search_URL = http://www.hugesearch.net/bar.html
R1 - HKLM\Software\Microsoft\Internet Explorer\SearchURL,(Default) = about:blank
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.1.1309.3572\swg.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe"
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [WMPNSCFG] C:\Program Files\Windows Media Player\WMPNSCFG.exe
O4 - Startup: Outil de détection de support Picture Motion Browser.lnk = C:\Program Files\Sony\Sony Picture Utility\PMBCore\SPUVolumeWatcher.exe
O23 - Service: ADSLAutoconnect - Unknown owner - C:\Program Files\ADSL Autoconnect\ADSL Autoconnect.exe
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - ALWIL Software - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: avast! Antivirus - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
O23 - Service: avast! Web Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\System32\HPZipm12.exe
O24 - Desktop Component 0: (no name) - file:///C:/Documents%20and%20Settings/All%20Users/Application%20Data/Google%20Updater/icons/images_ff.gif
End of file - 3683 bytes
Delta01
 Posté le 02/02/2010 à 19:14
Tu navigues avec Firefox 3.1 version béta et IE 7 ? depuis, il existe Firefox 3.6 et IE 8.
MAXOU13
 Posté le 02/02/2010 à 20:34
Bonsoir, non je navigue avec Firefox 3.6, je me sert plus d' internet explorer
Anonyme
 Posté le 02/02/2010 à 21:25
Hello Maxou,
Getplus peut faire partie d'Adobe et apparemment il n'est pas indispensable. http://www.memoclic.com/forum/96686-getplusr_ocx/
Pour FlashPlayer, comment procèdes-tu pour l'installer ?
MAXOU13
 Posté le 03/02/2010 à 08:32
Bonjour,et merci pour l'info,je l'installe par les plugins de firefox ,je vais déja essayer de virer le get.
Anonyme
 Posté le 03/02/2010 à 08:48
MAXOU13
 Posté le 03/02/2010 à 15:05
Bonjour,(re) encore merci j'ai réussi a réinstallé flash en supriment le get ,j'ai le plugin flash player dans ajouter ou supprimer des programmes,mais sans "la taille" normal ? mes videos s'arête toujours 2 secondes chaque fois c'est gonflant,
il y a seulement celle des guignols sur canal qui marchent correctement, peut tu me dire ce que tu en pense,et sur le rapport que j'ai joint.
amicalement
Anonyme
 Posté le 03/02/2010 à 15:35
Dans Ajout/suppression de programmes, tu devrais avoir ces deux entrées :
Le poids ne s'affiche pas, c'est normal. Je n'ai rien vu d'anormal dans ton rapport. Que donne le test de FlashPlayer ici ? http://www.macromedia.com/software/flash/about/
MAXOU13
 Posté le 03/02/2010 à 17:15
RE, il y a bien Adobe Flash player 10 plugin sans taille,mais pas Adobe Flash player 10 Active X,par contre j'ai Adobe shockwave player11 taille 6,20 mo, et maintenant Adobe AIR taille 30,83mo,car je crois que j'ai fait une betise,j'ai pas bien compris le test,j'ai maintenant avatar...je suis nul..faut il garder tout ça ? surtout que les videos en sont au même point
le test été sans doute de voir les extraits correctement ? si c'est ça ils été bon.
merci pour la patience
Anonyme
 Posté le 03/02/2010 à 18:10
J'aimerais bien voir une capture d'écran de ton dossier Flash en affichage Détails (menu Affichage de la barre d'outils de l'explorateur). Aller dans C:\WINDOWS\system32\Macromed\Flash.
https://forum.pcastuces.com/sujet.asp?f=20&s=324
MAXOU13
 Posté le 03/02/2010 à 21:15
Anonyme
 Posté le 03/02/2010 à 21:34
Fermer Firefox et double-cliquer sur NPSWF32_FlashUtil.exe
MAXOU13
 Posté le 03/02/2010 à 22:31
RE, ok c'est bien arrivé ou tu ma indiqué ainsi qua ccleaner mais j'ai toujours les coupures de 4 a 7 secondes de marche et arrêt, dans les plugins de mozilla j'ai Shockwave Flash et pas flash player mais je crois qui le contient...
pour ce qui est de Adobe AIR et de avatar tu me conseille de le supprimer ou de le garder ?
bon merci ,bonne nuit , amicalement
max
Anonyme
 Posté le 04/02/2010 à 07:10
RE, ok c'est bien arrivé ou tu ma indiqué ainsi qua CCleaner mais j'ai toujours les coupures de 4 a 7 secondes de marche et arrêt,
Pas certaine que ce soit dû au Flash. Avec Internet Explorer tu as le même problème ?
dans les plugins de Mozilla j'ai Shockwave Flash et pas flash player mais je crois qui le contient...
Oui, ça c'est normal.
- Adobe AIR : http://www.clubic.com/telecharger-fiche45240-adobe-air.html
- Avatar : je ne le connais pas.
MAXOU13
 Posté le 04/02/2010 à 10:01
Bonjour, je viens de remettre IE en service par ajou/supp des composants windows,il se trouve que c'est la même chose,
pareil au même, j'ai fait un test (DXDiag-txt) pas d'anomalie ...?il faut peut être essayer a nouveau de desinstaller flash et le reinstaller je sais plus ...
Anonyme
 Posté le 04/02/2010 à 20:59
Tu peux poster une nouvelle capture d'écran de ton dossier Flash ?
MAXOU13
 Posté le 05/02/2010 à 07:29
http://i50.tinypic.com/2cxb975.jpg Bonjour,je n'arrive pas a faire fonctionner la capture d'ecran aussi je suis obligé de
prendre des photos, entre temps j'ai mis des plugins qui n'était pas a jour,il y a un léger mieux,un peu moin d'espace
d'arrêt dans les videos,
merci pour votre aide
Modifié par MAXOU13 le 05/02/2010 07:37
Anonyme
 Posté le 05/02/2010 à 09:18
Je ne pense vraiment pas que ton problème vienne de FlashPlayer. Toujours le même problème sur IE et Firefox ?
MAXOU13
 Posté le 05/02/2010 à 10:54
Oui c'est la même chose sur IE arrêt de quelque secondes puis sa repart c'est tres fatiguant,sur les videos de canal
c'est bon ..il y a quand même une amélioration, je vais faire avec ,merci pour la patience.
bon week-end
Anonyme
 Posté le 05/02/2010 à 11:18
Il peut y avoir plusieurs raisons pour ce problème :
- connexion
- toolbars
- module complémentaire qui interfère
- etc.
En tous cas, ton FlashPlayer est installé correctement.
MAXOU13
 Posté le 05/02/2010 à 13:29
Re, Tu me parle de Toolbars , il le faut ?.. je viens de regarder un peu ,il parait qu'il vaut mieux ne pas l'avoir,
pour ce qui est de la connection,de temps en temps j'ai le cadre comme quoi je ne suis pas connecté et je suis obligé de débrancher le cable sur ma box 1 seconde et c'est reparti ,il y a des jours sans et des jours ou cela se produit plusieurs fois
( a suivre)
a+ peut être
Anonyme
 Posté le 05/02/2010 à 13:31
Non, au contraire, il vaut mieux éviter d'en avoir.
MAXOU13
 Posté le 05/02/2010 à 13:41
tu parle de toolbars ? connait tu des modules qui ne sont pas compatibles entre eux ?
Anonyme
 Posté le 05/02/2010 à 15:11
Oui, les toolbars sont à éviter.
Pour les incompatibilités, non je n'ai pas d'exemple précis en tête. Tu peux par contre tester en les désactivant tous (de même que les modules complémentaires) et en les réactivant un par un, avec un nouveau test entre deux à chaque fois.
28_vicky_28
 Posté le 07/06/2010 à 20:38
Nouvelle astucienne
Comment je fait pour suprimer GetPlus+
Anonyme
 Posté le 07/06/2010 à 21:42
bonsoir 28_vicky_28 et bienvenue sur PCastuces
Voilà il faut que tu aies sur la page du forum "Sécurité" et en haut à droite tu cliques sur "Créez une nouvelle discussion", de façon à avoir une réponse plus rapidement.
Et dans ton nouveau sujet tu débutes par Bonjour et tu finis par Merci, si tu veux que les astuciens tous bénévoles, aient envie de te répondre.
Et tu viens de quel région du Canada, si tu penses que celà n'est pas indiscret?
Bonne continuation
Page 1 sur 2 [Fin]
95,89 €Ecran 24 pouces Samsung S24F354 (Full HD, PLS, 4 ms, FreeSync) à 95,89 €
Valable jusqu'au 20 Juillet
Amazon propose actuellement l'écran 24 pouces Samsung S24F354 à 95,89 € livré gratuitement alors qu'on le trouve ailleurs à partir de 120 €. Cet écran dispose d'une dalle PLS Full HD (1920x1080) et offre un temps de réponse de 4 ms. Il possède des entrées VGA et HDMI. Il possède des fonctions d'anti scintillement et anti lumière bleue.
134,48 €Ecran 27 pouces BenQ BL2780 (Full HD, IPS, 75 Hz, ajustement auto de la luminosité) à 134,48 €
Valable jusqu'au 15 Juillet
Amazon propose actuellement l'écran 27 pouces BenQ BL2780 à 134,48 € livré gratuitement alors qu'on le trouve ailleurs à plus de 179 €. Cet écran à LED dispose d'une dalle IPS Full HD (1920x1080) à contours fins, d'un temps de réponse de 5 ms et de connecteurs DP, VGA et HDMI. Cet écran dispose aussi des technologies Flicker-Free et Low Blue Light pour limiter les scintillements et les effets notifs de la lumière bleue. Il peut également adapter automatiquement la luminosité de l’écran à la lumière ambiante. Des haut-parleurs sont intégrés (2x2W).
149,99 €Ecran 24 pouces ViewSonic VX2458-C-MHD (incurvé, FullHD, 144Hz, 1ms) à 149,99 €
Valable jusqu'au 18 Juillet
Darty fait une promotion sur l'écran 24 pouces ViewSonic VX2458-C-MHD qui passe à 149,99 €. On le trouve ailleurs à partir de 170 €. Cet écran dédié aux joueurs dispose d'une dalle incurvée FullHD 1 ms à 144 Hz, un filtre lumière bleue et de la technologie anti scintillement Flicker Free. Il est compatible FreeSync, GSync et a des entrées HDMI, DP et DVI. Il intègre des haut-parleurs.
Impossible d'installer Adobe Flash Player
Flash Player Plugin
flash player plugin bloqué par firefox
plugin Adobe flash Player obsolète..
Flash player plugin
flash player plugin message d'erreurs répétitives Firefox-Mozilla
Plugin Flash Player for IE
adobe flash player installer
Flash player Adobe bloqué par Firefox
faille adobe flash player
Plus de sujets relatifs à plugin flash player impossible a installer
