 pour patogas suite 2 ème PC infectéSujet résolu
qéqécé
  Posté le 15/11/2007 @ 18:44
bonsoir patogas,
c'est encore moi, suite à la dernière "désinfection" j'ai refais aujousd'hui un scan en ligne avec kaspersky et étonnement j'ai encore des bébêtes.
je te post le rapport
mais qu'est-ce que tous cela comment ce fait-il que je sois toujours avec ces choses?
encore merci pour ton implication et ton aide
KASPERSKY ONLINE SCANNER REPORT Thursday, November 15, 2007 6:37:38 PM
Operating System: Microsoft Windows XP Home Edition, Service Pack 2 (Build 2600)
Kaspersky Online Scanner version: 5.0.98.0
Kaspersky Anti-Virus database last update: 15/11/2007
Kaspersky Anti-Virus database records: 459740
Scan Settings Scan using the following antivirus database extended Scan Archives true Scan Mail Bases true Scan Target My Computer A:\
C:\
D:\
E:\ Scan Statistics Total number of scanned objects 167263 Number of viruses found 2 Number of infected objects 4 Number of suspicious objects 0 Duration of the scan process 06:22:19
Infected Object Name Virus Name Last Action C:\Documents and Settings\LocalService\Cookies\index.dat Object is locked skipped C:\Documents and Settings\LocalService\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat Object is locked skipped C:\Documents and Settings\LocalService\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat.LOG Object is locked skipped C:\Documents and Settings\LocalService\Local Settings\Historique\History.IE5\index.dat Object is locked skipped C:\Documents and Settings\LocalService\Local Settings\Temporary Internet Files\Content.IE5\index.dat Object is locked skipped C:\Documents and Settings\LocalService\NTUSER.DAT Object is locked skipped C:\Documents and Settings\LocalService\ntuser.dat.LOG Object is locked skipped C:\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat Object is locked skipped C:\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat.LOG Object is locked skipped C:\Documents and Settings\NetworkService\NTUSER.DAT Object is locked skipped C:\Documents and Settings\NetworkService\ntuser.dat.LOG Object is locked skipped C:\Documents and Settings\Propriétaire\Application Data\Vista Start Menu\file.idx Object is locked skipped C:\Documents and Settings\Propriétaire\Application Data\Vista Start Menu\file.log Object is locked skipped C:\Documents and Settings\Propriétaire\Cookies\index.dat Object is locked skipped C:\Documents and Settings\Propriétaire\Local Settings\Application Data\Microsoft\CardSpace\CardSpace.db Object is locked skipped C:\Documents and Settings\Propriétaire\Local Settings\Application Data\Microsoft\CardSpace\CardSpace.db.shadow Object is locked skipped C:\Documents and Settings\Propriétaire\Local Settings\Application Data\Microsoft\Feeds Cache\index.dat Object is locked skipped C:\Documents and Settings\Propriétaire\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat Object is locked skipped C:\Documents and Settings\Propriétaire\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat.LOG Object is locked skipped C:\Documents and Settings\Propriétaire\Local Settings\Historique\History.IE5\index.dat Object is locked skipped C:\Documents and Settings\Propriétaire\Local Settings\Historique\History.IE5\MSHist012007111520071116\index.dat Object is locked skipped C:\Documents and Settings\Propriétaire\Local Settings\Temporary Internet Files\AntiPhishing\B3BB5BBA-E7D5-40AB-A041-A5B1C0B26C8F.dat Object is locked skipped C:\Documents and Settings\Propriétaire\Local Settings\Temporary Internet Files\Content.IE5\index.dat Object is locked skipped C:\Documents and Settings\Propriétaire\ntuser.dat Object is locked skipped C:\Documents and Settings\Propriétaire\ntuser.dat.LOG Object is locked skipped C:\Program Files\Alwil Software\Avast4\DATA\aswResp.dat Object is locked skipped C:\Program Files\Alwil Software\Avast4\DATA\Avast4.db Object is locked skipped C:\Program Files\Alwil Software\Avast4\DATA\integ\avast.int Object is locked skipped C:\Program Files\Alwil Software\Avast4\DATA\log\AshWebSv.ws Object is locked skipped C:\Program Files\Alwil Software\Avast4\DATA\log\aswMaiSv.log Object is locked skipped C:\Program Files\Alwil Software\Avast4\DATA\log\nshield.log Object is locked skipped C:\Program Files\Alwil Software\Avast4\DATA\report\Protection résidente.txt Object is locked skipped C:\System Volume Information\MountPointManagerRemoteDatabase Object is locked skipped C:\System Volume Information\\_restore{F3C7DFAB-1ACF-4E8A-8FF7-4F82BE36EB0A}\RP1061\A0134745.exe Infected: not-a-virus:RiskTool.Win32.PsKill.k skipped C:\System Volume Information\\_restore{F3C7DFAB-1ACF-4E8A-8FF7-4F82BE36EB0A}\RP1061\A0134746.exe/data0015/data0005 Infected: not-a-virus:AdWare.Win32.Shopper.l skipped C:\System Volume Information\\_restore{F3C7DFAB-1ACF-4E8A-8FF7-4F82BE36EB0A}\RP1061\A0134746.exe/data0015 Infected: not-a-virus:AdWare.Win32.Shopper.l skipped C:\System Volume Information\\_restore{F3C7DFAB-1ACF-4E8A-8FF7-4F82BE36EB0A}\RP1061\A0134746.exe NSIS: infected - 2 skipped C:\System Volume Information\\_restore{F3C7DFAB-1ACF-4E8A-8FF7-4F82BE36EB0A}\RP1062\change.log Object is locked skipped C:\WINDOWS\Debug\PASSWD.LOG Object is locked skipped C:\WINDOWS\Registration\{02D4B3F1-FD88-11D1-960D-00805FC79235}.{9C4177E9-FD39-4439-A999-F54322216C5F}.crmlog Object is locked skipped C:\WINDOWS\SchedLgU.Txt Object is locked skipped C:\WINDOWS\SoftwareDistribution\ReportingEvents.log Object is locked skipped C:\WINDOWS\Sti_Trace.log Object is locked skipped C:\WINDOWS\system32\config\Antivirus.Evt Object is locked skipped C:\WINDOWS\system32\config\AppEvent.Evt Object is locked skipped C:\WINDOWS\system32\config\default Object is locked skipped C:\WINDOWS\system32\config\default.LOG Object is locked skipped C:\WINDOWS\system32\config\Internet.evt Object is locked skipped C:\WINDOWS\system32\config\SAM Object is locked skipped C:\WINDOWS\system32\config\SAM.LOG Object is locked skipped C:\WINDOWS\system32\config\SecEvent.Evt Object is locked skipped C:\WINDOWS\system32\config\SECURITY Object is locked skipped C:\WINDOWS\system32\config\SECURITY.LOG Object is locked skipped C:\WINDOWS\system32\config\software Object is locked skipped C:\WINDOWS\system32\config\software.LOG Object is locked skipped C:\WINDOWS\system32\config\SysEvent.Evt Object is locked skipped C:\WINDOWS\system32\config\system Object is locked skipped C:\WINDOWS\system32\config\system.LOG Object is locked skipped C:\WINDOWS\system32\drivers\sptd.sys Object is locked skipped C:\WINDOWS\system32\h323log.txt Object is locked skipped C:\WINDOWS\system32\wbem\Repository\FS\INDEX.BTR Object is locked skipped C:\WINDOWS\system32\wbem\Repository\FS\INDEX.MAP Object is locked skipped C:\WINDOWS\system32\wbem\Repository\FS\MAPPING.VER Object is locked skipped C:\WINDOWS\system32\wbem\Repository\FS\MAPPING1.MAP Object is locked skipped C:\WINDOWS\system32\wbem\Repository\FS\MAPPING2.MAP Object is locked skipped C:\WINDOWS\system32\wbem\Repository\FS\OBJECTS.DATA Object is locked skipped C:\WINDOWS\system32\wbem\Repository\FS\OBJECTS.MAP Object is locked skipped C:\WINDOWS\Temp\Perflib_Perfdata_4d4.dat Object is locked skipped C:\WINDOWS\Temp\\_avast4_\Webshlock.txt Object is locked skipped C:\WINDOWS\wiadebug.log Object is locked skipped C:\WINDOWS\wiaservc.log Object is locked skipped C:\WINDOWS\WindowsUpdate.log Object is locked skipped Scan process completed.
merci et @+
Modifié par qéqécé le 15/11/2007 18:47
qéqécé
 Posté le 15/11/2007 à 18:50
Scan Settings
Scan Archives true
A:\
C:\
D:\
E:\
Scan Statistics
patogas
Bonsoir qéqécé,
Repostes comme il faut le rapport Kaspersky, c'est la prise de tête.
Pas de souçi j'ai aperçu vite faite "infected" dans volume restauration. Tu n'as pas désactivé puis réactivé et créé un point de restauration comme demandé en fin de procédure. Tout était nickel.
Ne fait pas cette manip de restauration maintenant. repostes ton scan Kaspersky.
As tu été sur la toile sur des sites particulier depuis la fin de précédente procédure?
Profites en pour reposter un scan hijacthis, on ne sait jamais.
patogas
 Posté le 15/11/2007 à 18:51
Re
Après d'avoir écrit mon message, je viens de voir que Kaspersky est OK, j'y jette un oeil mais je vais aller manger avant.
A tout à l'heure
patogas
 Posté le 15/11/2007 à 18:53
re,
Je viens d'y jeter un oeil et Bingo. Tu n'as pas fait ce que je t'ai décrit en fin de procédure pour la restauration système.
Fait comme je te l'avais mentionné en fin de la précédente procédure et le tour est joué. Là, tu pourras refaire un scan et il sera Nickel
Au plaisir
qéqécé
 Posté le 15/11/2007 à 19:09
re,
je suis très très très mauvais je n'ai pas lu ton message jusqu'au bout la dernière fois
mea culpa patogas
j'y vais et je refais un scan
désolé
et encore merci
patogas
 Posté le 15/11/2007 à 19:30
re qéqécé,
Je m'en suis douté, t'inquiètes tu n'est pas le seul.
Tu as bien fait, celà aurait été possible.
qéqécé
 Posté le 16/11/2007 à 18:45
bonsoir patogas,
suite et fin (enfin j'espès) a priori plus de bébêtes
ci-joint rappor kaspersky et hijackthis
merci encore
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 18:40:35, on 16/11/2007
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.6000.16544)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\guard.exe
C:\WINDOWS\system32\dllhost.exe
C:\Program Files\Executive Software\DiskeeperLite\DKService.exe
C:\Program Files\StudioLine Photo Basic\NMSAccess.exe
C:\Program Files\Fichiers communs\NMSAccessU.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\PnkBstrA.exe
C:\WINDOWS\system32\PnkBstrB.exe
C:\Program Files\Spyware Terminator\sp_rsser.exe
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\Program Files\Spyware Terminator\SpywareTerminatorShield.exe
C:\Program Files\Mousotron Pro\Mousotron.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
C:\Program Files\Vista Start Menu\VistaStartMenu.exe
C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
C:\WINDOWS\BricoPacks\Vista Inspirat\YzToolbar\YzToolBar.exe
C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Liens
R3 - URLSearchHook: Share Accelerator Toolbar - {f5c93451-2609-4723-a053-5c19516be1a8} - C:\Program Files\Share_Accelerator\tbShar.dll
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Fichiers communs\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O2 - BHO: (no name) - {6A87B991-A31F-4130-AE72-6D0C294BF082} - (no file)
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
O2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)
O2 - BHO: Programme d'aide de l'Assistant de connexion Windows Live - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Fichiers communs\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: (no name) - {955BE0B8-BC85-4CAF-856E-8E0D8B610560} - (no file)
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar2.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\2.0.301.7164\swg.dll
O3 - Toolbar: Easy-WebPrint - {327C2873-E90D-4c37-AA9D-10AC9BABA46C} - C:\Program Files\Canon\Easy-WebPrint\Toolband.dll
O3 - Toolbar: Yahoo! Toolbar avec bloqueur de fenêtres pop-up - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
O3 - Toolbar: Share Accelerator Toolbar - {f5c93451-2609-4723-a053-5c19516be1a8} - C:\Program Files\Share_Accelerator\tbShar.dll
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar2.dll
O3 - Toolbar: (no name) - {147D6308-0614-4112-89B1-31402F9B82C4} - (no file)
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O4 - HKLM\..\Run: [SpywareTerminator] "C:\Program Files\Spyware Terminator\SpywareTerminatorShield.exe"
O4 - HKLM\..\Run: [!AVG Anti-Spyware] "C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\avgas.exe" /minimized
O4 - HKLM\..\Run: [NeroFilterCheck] C:\Program Files\Fichiers communs\Ahead\Lib\NeroCheck.exe
O4 - HKCU\..\Run: [Mousotron] "C:\Program Files\Mousotron Pro\Mousotron.exe"
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
O4 - HKCU\..\Run: [VistaStartMenu] "C:\Program Files\Vista Start Menu\VistaStartMenu.exe"
O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
O4 - HKUS\S-1-5-18\..\Run: [Picasa Media Detector] C:\Program Files\Picasa2\PicasaMediaDetector.exe (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [Picasa Media Detector] C:\Program Files\Picasa2\PicasaMediaDetector.exe (User 'Default user')
O4 - Startup: Y'z ToolBar.lnk = C:\WINDOWS\BricoPacks\Vista Inspirat\YzToolbar\YzToolBar.exe
O9 - Extra button: Barre de recherche Encarta - {B205A35E-1FC4-4CE3-818B-899DBBB3388C} - C:\Program Files\Fichiers communs\Microsoft Shared\Encarta Search Bar\ENCSBAR.DLL
O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O14 - IERESET.INF: START_PAGE_URL=http://home.free.fr/
O15 - Trusted Zone: http://www.kaspersky.com
O16 - DPF: {0EB0E74A-2A76-4AB3-A7FB-9BD8C29F7F75} (CKAVWebScan Object) - http://www.kaspersky.com/kos/english/kavwebscan_unicode.cab
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?LinkID=39204
O16 - DPF: {5D86DDB5-BDF9-441B-9E9E-D4730F4EE499} - http://www.bitdefender.fr/scan8/oscan8.cab
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/windowsupdate/v6/V5Controls/en/x86/client/wuweb_site.cab?1132055568663
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1132507797078
O16 - DPF: {74D05D43-3236-11D4-BDCD-00C04F9A3B61} -
O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files\Fichiers communs\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - ALWIL Software - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: avast! Antivirus - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
O23 - Service: avast! Web Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
O23 - Service: AVG Anti-Spyware Guard - GRISOFT s.r.o. - C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\guard.exe
O23 - Service: Diskeeper - Executive Software International, Inc. - C:\Program Files\Executive Software\DiskeeperLite\DKService.exe
O23 - Service: FLEXnet Licensing Service - Macrovision Europe Ltd. - C:\Program Files\Fichiers communs\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Fichiers communs\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: License Management Service ESD - element5 - C:\Program Files\Fichiers communs\element5 Shared\Service\Licence Manager ESD.exe
O23 - Service: NBService - Nero AG - C:\Program Files\Nero\Nero 7\Nero BackItUp\NBService.exe
O23 - Service: NMIndexingService - Nero AG - C:\Program Files\Fichiers communs\Ahead\Lib\NMIndexingService.exe
O23 - Service: NMSAccess - Unknown owner - C:\Program Files\StudioLine Photo Basic\NMSAccess.exe
O23 - Service: NMSAccessU - Unknown owner - C:\Program Files\Fichiers communs\NMSAccessU.exe
O23 - Service: Planificateur LiveUpdate automatique - Unknown owner - C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe (file missing)
O23 - Service: PnkBstrA - Unknown owner - C:\WINDOWS\system32\PnkBstrA.exe
O23 - Service: PnkBstrB - Unknown owner - C:\WINDOWS\system32\PnkBstrB.exe
O23 - Service: Spyware Terminator Realtime Shield Service (sp_rssrv) - Crawler.com - C:\Program Files\Spyware Terminator\sp_rsser.exe
End of file - 8179 bytes
Friday, November 16, 2007 6:38:20 PM
Kaspersky Anti-Virus database last update: 16/11/2007
Kaspersky Anti-Virus database records: 460325
Scan Settings
Scan Archives true
A:\
C:\
D:\
E:\
Scan Statistics
Total number of scanned objects 147029
Number of viruses found 0
Number of infected objects 0
Duration of the scan process 04:22:56
C:\Documents and Settings\All Users\Application Data\Microsoft\Network\Downloader\qmgr0.dat Object is locked skipped
C:\Documents and Settings\All Users\Application Data\Microsoft\Network\Downloader\qmgr1.dat Object is locked skipped
C:\System Volume Information\\_restore{F3C7DFAB-1ACF-4E8A-8FF7-4F82BE36EB0A}\RP1067\change.log Object is locked skipped
C:\WINDOWS\Registration\{02D4B3F1-FD88-11D1-960D-00805FC79235}.{E5FAB750-87C2-42BD-AFE3-49086350D7B4}.crmlog Object is locked skipped
C:\WINDOWS\SoftwareDistribution\EventCache\{46130501-749D-4E2D-9F25-CD374A32A5C2}.bin Object is locked skipped
C:\WINDOWS\Temp\Perflib_Perfdata_4d8.dat Object is locked skipped
patogas
 Posté le 16/11/2007 à 21:39
Bonsoir qéqécé,
il te plaît, note ton sujet en RÉSOLU. Sur ton premier message à droite =>
ou <= à gauche en bas de la page. Merci!
A bientôt
qéqécé
 Posté le 16/11/2007 à 21:47
merci encore une fois patogas
bon week
et
patogas
 Posté le 17/11/2007 à 09:59
Bonjour qéqécé
De rien, avec plaisir.
N'oublies de voir pour ton pare feu
Bon week
13,99 €Clé USB Sandisk Ultra 64 Go à double connectique USB 3.1 Type A et C à 13,99 €
Valable jusqu'au 20 Avril
Amazon fait une promotion sur la clé USB Sandisk Ultra 64 Go à double connectique USB 3.1 Type A et C qui passe à 13,99 € alors qu'on la trouve ailleurs à plus de 25 €. Cette clé USB  dispose d'un connecteur réversible USB Type C et d'un connecteur classique de type A. Grâce à elle, transférez en toute simplicité et rapidement (jusqu'à 150 Mo/s) vos fichiers entre vos smartphones, tablettes et ordinateurs.
GratuitJeu PC The First Tree gratuit
Valable jusqu'au 22 Avril
Epic Game Store offre actuellement le jeu PC The First Tree. Un magnifique jeu d'exploration à la troisième personne avec deux histoires parallèles : un renard qui essaie de retrouver sa famille perdue et un fils reprenant contact avec son père distant qui vit en Alaska.
34,99 €Lot de 4 prises connectées Meross (16A, Alexa, Google, IFT) à 34,99 € avec le code KVALO8CD
Amazon fait une promotion sur le lot de 4 prises électriques connectées Meross qui passe à 34,99 € grâce au code promo KVALO8CD. On le trouve habituellement à 49,99 €. Ces prises 16A peuvent être contrôlées à distance avec l'application Meross dédiée mais également avec Alexa, Google Home et IFTTT. Vous pouvez programmer l'arrêt ou l'allumage des appareils branchés dessus suivant un planning et mesurer leur consommation électrique.
pc infecté !! aide pour nettoyage svp
Aide pour rapport Whocrashed suite nombreux Bluescreen
Existe t'il un tuto pour 7-Data Recovery Suite 3.0 ?
PC Infecté besoin d'aide pour un rétabliseement
Méthode pour PC infecté (téléchargements ?)
pc infecté (suite)
Appel pour désinfection suite lenteur PC
PC infecté (pour un ami)
Infecté ??? suite ouverture mail douteux !
Rapports suite à procédure diagnostic PC infecté
Plus de sujets relatifs à pour patogas suite 2 ème PC infecté
