 Probleme avec d dur réseau multimédia
praxa075
  Posté le 01/01/2009 @ 13:13
Normal 0 21 false false false FR X-NONE X-NONE MicrosoftInternetExplorer4
<!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:0; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:-1610611985 1107304683 0 0 159 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin-top:0cm; margin-right:0cm; margin-bottom:10.0pt; margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;} p {mso-style-noshow:yes; mso-style-priority:99; mso-margin-top-alt:auto; margin-right:0cm; mso-margin-bottom-alt:auto; margin-left:0cm; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman","serif"; mso-fareast-font-family:"Times New Roman";} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;} .MsoPapDefault {mso-style-type:export-only; margin-bottom:10.0pt; line-height:115%;} @page Section1 {size:595.3pt 841.9pt; margin:70.85pt 70.85pt 70.85pt 70.85pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} -->
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
je viens d acquérir un boitier réseau multimédia FG 1000 R ou j ai installé un disque dur de 600 G° à l intérieur
J'ai connecté le boitier en réseau avec mes pc sous Windows xp et sur ma tv le tout en réseau et j ai bien accès au réseau domestique de mes pc
Le problème c que j ai partagé mon disque dur de 600 G° qui est a l intérieur du boitier multimédia et j aimerai avoir accès depuis mes pc a ce disque dur de 600 G° pour pouvoir y copier des fichiers depuis n importe quel pc mais pas moyen de le voir sur mon réseau
J ai bien une adresse défini une adresse ip qui est la suivante 192.168.1.6 et quand je fais un Ping tout est correcte il le voit bien
Pour résumer
Mon boitier multimédia fonctionne correctement pour lire les fichiers sur ma tv etc.. mais impossible de copier des fichiers sur le d dur qui est a l intérieur par le réseau obliger de passer par l usb et je ne sais comment le faire apparaitre sur mes pc disque dur
Merci pour votre aide
Esclapion
 Posté le 01/01/2009 à 13:31
en-dehors de le partager et de définir les autorisations, as-tu regardé CECI ?
Lot de 4 lampes solaires d'extérieur LED avec détecteur de mouvement
15,99 € 21,99 € -27%
299,72 € 400 € -25%
Intégrale Game of Thrones en Blu-Ray
55,89 € 84,90 € -34%
PC portable 16 pouces Ninkear A15 Pro (QHD, AMD Ryzen 5 7430U, 16 Go RAM, SSD 1 To, Windows 11, Qwerty)
429 € 545 € -21%
Processeur AMD Ryzen 7 7700 (8 coeurs, 16 threads)
250,14 € 300 € -17%
Onduleur Eaton Ellipse Pro 1200 (750W, 8 prises FR, USB, UPS, Line Ineractive, AVR)
188,70 € 279,99 € -33%
Problème avec la carte réseau sans fil ou le point d’accès
Probleme avec carte reseau
probleme d'accés internet avec un reseau CPL
problème avec controleur réseau
Probleme partage reseau / multimedia ?non résolut
Problème reseau sans fil avec live box
probleme avec ma carte reseau realtek PCIe GBE fam
Problème avec le système réseau
probleme avec reseau local pour warcraft 3
Problème de réseau avec ma freebox
Plus de sujets relatifs à Probleme avec d dur réseau multimédia
