 problème avec avira....Sujet résolu
val74
  Posté le 27/06/2008 @ 16:29
à tous....voilà,j'ai avira qui délire:ça me demande de faire un "start update"et je l'ai fais...mais ça ne marche toujours pas...voici le rapport que ça m'a sorti
27.06.2008 16:19:16 - Installation Directory: C:\Program Files\Avira\AntiVir PersonalEdition Classic\
27.06.2008 16:19:16 - Backup Directory: C:\ProgramData\Avira\AntiVir PersonalEdition Classic\BACKUP\
27.06.2008 16:19:16 - Temp Directory: C:\ProgramData\Avira\AntiVir PersonalEdition Classic\Update\AVUPDATE_4864f6e3\
27.06.2008 16:19:16 - Using System's global Proxy settings
27.06.2008 16:19:16 - Start the Update GUI... Displaymode: 0
27.06.2008 16:19:16 - selftest successful: C:\Program Files\Avira\AntiVir PersonalEdition Classic\updlib.dll
27.06.2008 16:19:16 - selftest successful: C:\Program Files\Avira\AntiVir PersonalEdition Classic\updlibrc.dll
27.06.2008 16:19:16 - Avira AntiVir Personal – Free Antivirus
27.06.2008 16:19:39 - Invalid system proxy
27.06.2008 16:19:39 - Switching to next update server
27.06.2008 16:20:03 - Invalid system proxy
27.06.2008 16:20:03 - Switching to next update server
27.06.2008 16:20:24 - Invalid system proxy
27.06.2008 16:20:24 - Switching to next update server
27.06.2008 16:20:46 - Invalid system proxy
27.06.2008 16:20:46 - Switching to next update server
27.06.2008 16:21:07 - Invalid system proxy
27.06.2008 16:21:07 - Switching to next update server
27.06.2008 16:21:17 - Copy file C:\ProgramData\Avira\AntiVir PersonalEdition Classic\Update\AVUPDATE_4864f6e3\idx/master.idx to C:\ProgramData\Avira\AntiVir PersonalEdition Classic\IDX\master.idx
27.06.2008 16:21:17 - Master IDX file has changed
27.06.2008 16:21:40 - The following file could not be downloaded: http://dl3.avgate.net/idx/message.idx
27.06.2008 16:21:45 - Keyfile: OK [FULL Mode]
27.06.2008 16:22:07 - There was a problem updating from the specified server: Invalid system proxy
27.06.2008 16:22:07 - Switching to next update server
27.06.2008 16:22:34 - Registry entry created successfully: Software\Avira\AntiVir PersonalEdition Classic |UpdateInProgress
27.06.2008 16:22:34 - Critical error: Invalid system proxy
soit une erreur .....je ne comprends pas pourquoi....merci d'avance à celui qui pourra m'aider
ps:suis je encore proteger ou non???????
nenette58
 Posté le 27/06/2008 à 16:42
val74
pas de soucis, les serveurs doivent être engorgés
suis ce tuto et applique ce qui est recommandé, la mise à jour se fera manuellement
bonne fin de journée
GREENHORN
 Posté le 27/06/2008 à 16:46
Message original par val74
Bonsoir val174
La première chose à faire, si tu as ZoneAlarm comme pare-feu, c'est de supprimer TOUTES les lignes concernant Antivir et recommencer la demande de mise à jour en autorisant l'accès à l'Internet chaque fois que demandé par ZA. C'est ce que je fais quand j'ai un problème de ce genre et ça marche. Pas plus tard que ce matin, j'ai effectué la "manip" car je me suis aperçu - ô horreur ! - que les mises à jour n'avaient pas été effectuées depuis le... 24 dernier.
val74
 Posté le 27/06/2008 à 21:51
et merci à vous deux....je n'ai pas zonealarm en pare feu...mais je vais bien reussir à me debrouiller avec toutes ces infosmerci beaucoup....a+
GREENHORN
 Posté le 28/06/2008 à 09:06
Bonjour val174
Oui, je l'espère. N'abandonne pas la piste du pare-feu car, comme je disais, cela a TOUJOURS résolu mon problème. Donc à ne pas négliger de toute façon !
problème avec avira
Problème avec avscan de Avira
Problème avec Avira Antivirus
probleme virus avec avira
Problème avec Avira Antivir Premium
Probleme de scan avec Avira 10
Probleme avec Avira
Probleme avec avira antivir !!!!!!!!
Problème : l'interface Avira Free Antivirus ne s'ouvre plus ?
Problème MAJ Avira Antivirus Pro (infection détectée)
Plus de sujets relatifs à problème avec avira....
