 probleme avec wolfenstein enemy territorySujet résolu
la _squale
  Posté le 24/06/2006 @ 01:29
j'ai installé WOLFENSTEIN ENEMY TERRITORY et impossible de jouer voici le rapport d'erreur a l'ouverture du jeu : ET 2.60 win-x86 Mar 10 2005 ----- FS_Startup ----- Current search path: C:\PROGRA~1\WOLFEN~1\etmain\pak2.pk3 (22 files) C:\PROGRA~1\WOLFEN~1\etmain\pak1.pk3 (10 files) C:\PROGRA~1\WOLFEN~1\etmain\pak0.pk3 (3725 files) C:\PROGRA~1\WOLFEN~1\etmain\mp_bin.pk3 (6 files) C:\PROGRA~1\WOLFEN~1/etmain ---------------------- 3763 files in pk3 files execing default.cfg couldn't exec language.cfg couldn't exec autoexec.cfg Hunk_Clear: reset the hunk ok ...detecting CPU, found Intel Pentium III Bypassing CD checks ----- Client Initialization ----- ----- Initializing Renderer ---- ------------------------------- ----- Client Initialization Complete ----- ----- R_Init ----- Initializing OpenGL subsystem ...initializing QGL ...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded ...setting mode 4: 800 600 FS ...using desktop display depth of 32 ...calling CDS: ok ...registered window class ...created window@0,0 (800x600) Initializing OpenGL driver ...getting DC: succeeded ...GLW_ChoosePFD( 32, 24, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...GLW_ChoosePFD( 32, 24, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...failed to find an appropriate PIXELFORMAT ...restoring display settings ...WARNING: could not set the given mode (4) ...setting mode 4: 800 600 FS ...using colorsbits of 16 ...calling CDS: ok ...created window@0,0 (800x600) Initializing OpenGL driver ...getting DC: succeeded ...GLW_ChoosePFD( 16, 16, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...GLW_ChoosePFD( 16, 16, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...failed to find an appropriate PIXELFORMAT ...restoring display settings ...WARNING: could not set the given mode (3) ...shutting down QGL ...unloading OpenGL DLL ...assuming '3dfxvgl' is a standalone driver ...initializing QGL ...WARNING: missing Glide installation, assuming no 3Dfx available ...shutting down QGL ----- CL_Shutdown ----- RE_Shutdown( 1 ) ----------------------- GLW_StartOpenGL() - could not load OpenGL subsystem [boom] je ne comprend pas le probleme[boom]
Modifié par la _squale le 24/06/2006 01:34
hasdrubald
 Posté le 24/06/2006 à 09:21
mets les pilotes de ta carte graphique à jour et reviens nous dire bonjour ! p.S c'est plus facile si tu renseignes ton profil matériel .[clindoeil]
la _squale
 Posté le 26/06/2006 à 14:18
merci ça fonctionne, c'etait pas compliqué mais fallait il y penser !! encore une fois merci[bierre][hello]
VTT électrique Eleglide M1 Plus (27,5 pouces, Shimano 21 vitesses, 100 km) à 749,99 €
749,99 € 999 € -25% @Geekbuying
Chaussures PUMA Smash V2 L, Mixte à 27,95 €
27,95 € 49,95 € -44% @Amazon
Lecteur/graveur de CD/DVD externe USB à 19,55 €
19,55 € 25 € -22% @Amazon
Jeu PC Star Wars Squadrons gratuit
0 € 39,99 € -100% @Epic Games
Sélection de T-Shirts Top Gun, Minecraft, Stranger Things, Marvel, Disne, Fender à 16,99 €
16,99 € 19,99 € -15% @Epic Games
Ecran PC 24.5 pouces BenQ EX2510S (FHD, IPS, FreeSync,165Hz, 2xHP, réglable en hauteur) à 179 €
179,00 € 249 € -28% @Amazon
Lego Star Wars Diorama de la poursuite dans les tranchées de l’Étoile de la Mort (75329) à 46,99 €
46,99 € 69,99 € -33% @Amazon Allemagne
Câble RJ45 Cat6 KabelDirekt 30M, Gigabit/LAN à 13,09 €
13,09 € 20 € -35% @Amazon
Kit de 32 Go (2 x 16 Go) de mémoire DDR4 Corsair Vengeance LPX 3200 MHz à 95,99 €
95,99 € 130 € -26% @Amazon
Adaptateur Bluetooth 5.0 USB TP-Link UB500 à 10,90 €
10,90 € 15 € -27% @Amazon
Problème avec Wolfenstein Enemy territory
poser arme dans wolfenstein enemy territory
comment jouer sur Wolfenstein - Enemy Territory
Aide pour Wolfenstein enemy territory
wolfenstein enemy territory ??
Problème avec Battlefield 3 (Origin)
Problème avec Balance WII FIT plus (comment ça marche)?
Plus de sujets relatifs à probleme avec wolfenstein enemy territory
