Nouvel astucien | Bonjour,
Voilà, il se trouve que j'ai un petit souci suite à l'ajout d'un scrip pour mon forum.
En effet, j'ai inséré un script permettant de faire tomber une image répétée (de la neige en occurence) à chaque actualisation de page.
Voici le script :
[code]<SCRIPT language=JavaScript>
Snow Effect Script
Created and submitted by Altan d.o.o. (snow@altan.hr, http://www.altan.hr/snow/index.html)
EDITE SUR L'EDITEUR JAVASCRIPT
http://www.editeurjavascript.com
var snowsrc="neige.gif"
var no = 70;
var ns4up = (document.layers) ? 1 : 0;
var ie4up = (document.all) ? 1 : 0;
var nn6up = (document.getElementById) ? 1 : 0;
var dx, xp, yp;
var am, stx, sty;
var i, doc_width = 800, doc_height = 600;
if (ns4up) {
doc_width = self.innerWidth;
doc_height = self.innerHeight;
} else if (ie4up) {
doc_width = document.body.clientWidth;
doc_height = document.body.clientHeight;
} else if (nn6up) {
dx = new Array();
xp = new Array();
yp = new Array();
am = new Array();
stx = new Array();
sty = new Array();
for (i = 0; i < no; ++ i) {
dx[i] = 0;
xp[i] = Math.random()*(doc_width-50);
yp[i] = Math.random()*doc_height;
am[i] = Math.random()*20;
stx[i] = 0.02 + Math.random()/10;
sty[i] = 0.7 + Math.random();
if (ns4up) {
if (i == 0) {
document.write("<layer name=dot"+ i +" left=15 top=15 visibility=show><img src='"+snowsrc+"' border=0></layer>");
} else {
} else if (ie4up || nn6up) {
if (i == 0) { document.write("<div id=dot"+ i +" style=\"POSITION: absolute; Z-INDEX: "+ i +"; VISIBILITY: visible; TOP: 15px; LEFT: 15px;\"><img src='"+snowsrc+"' border=0></div>");
} else {
function snowNS() {
yp[i] += sty[i];
if (yp[i] > doc_height-50) {
xp[i] = Math.random()*(doc_width-am[i]-30);
yp[i] = 0;
dx[i] += stx[i];
document.layers["dot"+i].top = yp[i];
document.layers["dot"+i].left = xp[i] + am[i]*Math.sin(dx[i]);
setTimeout("snowNS()", 10);
function snowIE() {
yp[i] += sty[i];
yp[i] = 0;
dx[i] += stx[i];
document.all["dot"+i].style.pixelTop = yp[i];
document.all["dot"+i].style.pixelLeft = xp[i] + am[i]*Math.sin(dx[i]);
setTimeout("snowIE()", 10);
function snowNN6() {
yp[i] += sty[i];
yp[i] = 0;
dx[i] += stx[i];
document.getElementById("dot"+i).style.top = yp[i];
document.getElementById("dot"+i).style.left = xp[i] + am[i]*Math.sin(dx[i]);
setTimeout("snowNN6()", 10);
if (ns4up) {
snowNS();
} else if (ie4up) {
snowIE();
} else if (nn6up) {
snowNN6();
</SCRIPT>[/code]
Le problème est le suivant : lorsque la neige tombe, celle-ci s'arrête à mi-écran (même moins) au lieu de déscendre juqu'en bas...
Quelqu'un saurait-il comment résoudre le problème ?
Je tiens à préciser que ce script a été ajouté dans la page d'index de mon forum qui est elle-même en PHP.
Merci d'avance,
Yannick.
Modifié par Lord Evil Ken le 20/12/2005 14:55 | |||||||
Astucien ![]() | Slut!
Je n'ai pas vraiment le temps de vérifier ton code mais voici le mien (même source) qui fonctionne en ce moment sur mon site :
Snow Effect Script
var snowsrc="images/daccueil/neige.gif"
var no = 30;
var dx, xp, yp;
var am, stx, sty;
if (ns4up) {
} else if (ie4up) {
} else if (nn6up) {
dx = new Array();
xp = new Array();
yp = new Array();
am = new Array();
stx = new Array();
sty = new Array();
dx[i] = 0;
if (ns4up) {
if (i == 0) {
} else {
} else {
function snowNS() {
yp[i] += sty[i];
yp[i] = 0;
dx[i] += stx[i];
function snowIE() {
yp[i] += sty[i];
yp[i] = 0;
dx[i] += stx[i];
yp[i] += sty[i];
yp[i] = 0;
dx[i] += stx[i];
if (ns4up) {
snowNS();
} else if (ie4up) {
snowIE();
} else if (nn6up) {
snowNN6();
</SCRIPT>
dis moi si c'est bon.
Bye
Ogd | |||||||
Nouvel astucien | Bonsoir, et merci de ta réponse.
Hélas, rien n'y fait, la neige de descend pas jusqu'en bas. | |||||||
Petite astucienne | Bonjour, j'ai effectivement dans un premier temps mis le même script que toi et la neige s'arrête à mi chemin, j'ai demandé des explications au concepteur du script qui m'a dit qu'on ne peut faire autrement !
J'ai bien cherché et j'ai trouvé autre chose, vas voir sur mon site; si tu l'aimes je mettrai le script sur le forum ! bonne journée à tous | |||||||
Nouvel astucien | Bonjour cricounette, ton site est bien sympathique en effet, j'apprécie l'ambiance festive que l'on y voit dès à l'entrée.
Ca tombe bien, ma musique de Noël préférée, made in USA[bigsmile]
Mais pour en revenir à mon souci, pourrais-tu me montrer ce fameux script, pour voir si celui-ci résoud, ou peut résoudre mon problème.
Merci d'avance et bonne journée. Modifié par Lord Evil Ken le 21/12/2005 12:38 | |||||||
![]() ![]() | [hello]
J'ai essayé le script de ogd
il fonctionne
[url]www.ger-art.info[/url] Modifié par Super_GEGE le 21/12/2005 15:29 | |||||||
Petite astucienne | Bonjour Lord Evil Ken,
voici le script qui ne résoudra pas ton problèm mais te permettra d'avoir une neige plus fine mais qui tombe tout le long de ta page :
ceci entre head et head :
<script language="javascript">
//Rain/Snow effect- By Craig Blanchette Craiga.topcities.com
snow = true; // false-rain; true-snow
snowsym = " * " //These are the symbols for each
rainsym = " ' " //You can put images here.
howmany = 20 //How many drops/snowflakes?
/**************Do not need to change anything below***********/
if(snow){sym = snowsym; speed=1; angle=10; drops=howmany}
else{sym = rainsym; speed=50; drops=howmany; angle=6}
movex = -speed/angle; movey = speed; count = 0;
function moverain(){
for(move = 0; move < drops; move++){
xx[move]+=movex; yy[move]+=mv[move];
hmm = Math.round(Math.random()*1);
if(xx[move] < 0){xx[move] = maxx+10;}
if(yy[move] > maxy){yy[move] = 10;}
drop[move].left = xx[move]
drop[move].top = yy[move]+document.body.scrollTop;
}setTimeout('moverain()','1')}
</script>
et ceci entre body et body :
if (document.all){
drop = new Array(); xx = new Array(); yy = new Array(); mv = new Array()
ly = "document.all[\\'"; st = "\\'].style"
for(make = 0; make < drops; make++){
document.write('<div id="drop'+make+'" class=drop>'+sym+'</div>');
drop[make] = eval(ly+'drop'+make+st);
maxx = document.body.clientWidth-40
maxy = document.body.clientHeight-40
xx[make] = Math.random()*maxx;
yy[make] = -100-Math.random()*maxy;
drop[make].left = xx[make]
drop[make].top = yy[make]
mv[make] = (Math.random()*5)+speed/4;
drop[make].fontSize = (Math.random()*10)+20;
if(snow){col = 'white'}else{col = 'blue'}
drop[make].color = col;
window.onload=moverain
</script>
Si ça marche tu seras gentil de nous donner le lien vers ton site pourqu'on puisse admirer !
Bonne soirée.
Petite astucienne | euh salut
moi aussi ca m'interesse mais jy connais rien en langage htlm!!
je vous mets ma page, ou dois je mettre tous ca!!
<html>
<head><script language=javascript src=http://bklproject.free.fr/ForumActif/Scripts_v2/flocon.js></script>
<LINK REL="SHORTCUT ICON" HREF="http://www.xxxxxx.com/favicon.ico">
<meta http-equiv="content-type" content="text/html; charset=utf-8">
<title>Accueil</title>
<meta name="GENERATOR" content="Namo WebEditor v5.0">
<meta name="namo-theme" content="Theme\Theme\Salamander">
<style>
body { color:rgb(0,0,0); font-family:Arial;}
h1 { color:rgb(128,64,0); font-size:14pt; font-family:Arial;}
h2 { color:rgb(128,0,0); font-size:12pt; font-family:Arial;}
p.namo-list { color:rgb(128,0,0); font-size:12pt; font-family:Arial;}
p.namo-sublist { color:rgb(85,85,0); font-size:10pt; font-family:Arial;}
th { color:rgb(0,0,0); font-family:Arial;}
td { color:rgb(0,0,0); font-family:Arial;}
</style>
<script language="JavaScript">
function nph_open_window(url, name, feature)
window.open(url, name, feature);
</script>
</script>
</script>
function namosw_rotate_banner_go()
var targetstr = document._rotatetargets[document._rotate_no];
if (targetstr == 'blank') {
window.open(document._rotatelinks[document._rotate_no], 'win1');
} else {
var frameobj;
if (targetstr == '') targetstr = 'self';
if ((frameobj = eval(targetstr)) != null)
frameobj.location = document._rotatelinks[document._rotate_no];
function namosw_rotate_banner()
if (!document._rotateimages) {
document._rotateimages = new Array();
document._rotatelinks = new Array();
document._rotatetargets = new Array();
document._rotate_name = 'image1';
document._rotate_interval = 3000;
document._rotate_itemnum = 6;
document._rotateimages[document._rotateimages.length] = "site stef/Australie/PHOTOS AUSTR/tn/tn (66).jpg";
document._rotatelinks[document._rotatelinks.length] = "http://";
document._rotatetargets[document._rotatetargets.length] = "self";
document._rotateimages[document._rotateimages.length] = "site stef/index/nous.JPG";
document._rotateimages[document._rotateimages.length] = "site stef/Australie/PHOTOS AUSTR/cablebeach/cablebeach (8).jpg";
document._rotateimages[document._rotateimages.length] = "site stef/Australie/PHOTOS AUSTR/kangourou/kangourou.jpg";
document._rotateimages[document._rotateimages.length] = "site stef/Galerie photo/polynesie/bo19.jpg";
document._rotateimages[document._rotateimages.length] = "site stef/Galerie photo/polynesie/mo4.jpg";
setInterval("namosw_rotate_banner()", document._rotate_interval);
document._rotate_no = -1;
document._rotate_no++;
if (document._rotate_no == document._rotateimages.length)
document._rotate_no = 0;
document.images[document._rotate_name].src = document._rotateimages[document._rotate_no];
</script>
function na_change_img_src(name, nsdoc, rpath, preload)
var img = eval((navigator.appName.indexOf('Netscape', 0) != -1) ? nsdoc+'.'+name : 'document.all.'+name);
if (name == '')
return;
if (img) {
img.altsrc = img.src;
img.src = rpath;
function na_restore_img_src(name, nsdoc)
if (name == '')
return;
if (img && img.altsrc) {
img.src = img.altsrc;
img.altsrc = null;
</script>
</head>
<body bgcolor="#FF8000" text="#000000" link="yellow" vlink="gray" alink="green" background="images/nth_theme_theme_salamander_bg.gif" OnLoad="namosw_rotate_banner();">
<div align="left">
<table border="0" width="881">
<tr>
<td width="875" height="58"><font size="5" face="Accidental Presidency"><b><!--NAMO_NAVBAR_START B H C -1 91 3 5 4 6 -->
<div align="center">
<img src="nav/nav_91_index_bhb.gif" name="nav_index_BH0"
border="0" class="namo-banner" alt="1 Brin de Soleil" align="texttop"></div>
<!--NAMO_NAVBAR_END--></b></font></td>
</tr>
<tr>
<td width="875"><!--NAMO_NAVBAR_START T H C 2 92 11 102 12 1 -->
<a href="nouveau_fichier.html"
onmouseover="na_change_img_src('nav_index_TH0', 'document', 'nav/nav_92_nouveau_fichier_thr.gif', true);"
onmouseout="na_restore_img_src('nav_index_TH0', 'document');"><img src="nav/nav_92_nouveau_fichier_th.gif" name="nav_index_TH0"
border="0" class="namo-button2" alt="Carte d'identité" align="texttop"></a><a href="nouveau_fichier1.html"
onmouseover="na_change_img_src('nav_index_TH1', 'document', 'nav/nav_92_nouveau_fichier1_thr.gif', true);"
onmouseout="na_restore_img_src('nav_index_TH1', 'document');"><img src="nav/nav_92_nouveau_fichier1_th.gif" name="nav_index_TH1"
border="0" class="namo-button2" alt="Galerie photos" align="texttop"></a><a href="nouveau_fichier12.html"
onmouseover="na_change_img_src('nav_index_TH2', 'document', 'nav/nav_92_nouveau_fichier12_thr.gif', true);"
onmouseout="na_restore_img_src('nav_index_TH2', 'document');"><img src="nav/nav_92_nouveau_fichier12_th.gif" name="nav_index_TH2"
border="0" class="namo-button2" alt="Liens utiles" align="texttop"></a><a href="nouveau_fichier13.html"
onmouseover="na_change_img_src('nav_index_TH3', 'document', 'nav/nav_92_nouveau_fichier13_thr.gif', true);"
onmouseout="na_restore_img_src('nav_index_TH3', 'document');"><img src="nav/nav_92_nouveau_fichier13_th.gif" name="nav_index_TH3"
border="0" class="namo-button2" alt="Nous contacter" align="texttop"></a><a href="nouveau_fichier23.html"
onmouseover="na_change_img_src('nav_index_TH4', 'document', 'nav/nav_92_nouveau_fichier23_thr.gif', true);"
onmouseout="na_restore_img_src('nav_index_TH4', 'document');"><img src="nav/nav_92_nouveau_fichier23_th.gif" name="nav_index_TH4"
border="0" class="namo-button2" alt="Bric a Brac" align="texttop"></a><a href="nouveau_fichier24.html"
onmouseover="na_change_img_src('nav_index_TH5', 'document', 'nav/nav_92_nouveau_fichier24_thr.gif', true);"
onmouseout="na_restore_img_src('nav_index_TH5', 'document');"><img src="nav/nav_92_nouveau_fichier24_th.gif" name="nav_index_TH5"
border="0" class="namo-button2" alt="Le globe" align="texttop"></a></div>
<!--NAMO_NAVBAR_END--></td>
</tr>
</table>
<table border="0" width="883">
<tr>
<td width="877" height="356" align="left" valign="top">
<p align="left" style="line-height:100%; margin-top:0; margin-bottom:0;"> <img src="site stef/index/wwf.gif" width="468" height="60" border="0"> </p>
<p style="line-height:100%; margin-top:0; margin-bottom:0;" align="left"> </p>
<table cellspacing=0 cellpadding=0 border="0" width="765" align="center" style="line-height:100%; margin-top:0; margin-bottom:0;">
<tr>
<td width="390" valign="top">
<p align="center" style="line-height:100%; margin-top:0; margin-bottom:0;"><font face="Monotype Corsiva"><span style="font-size:18pt;">Ne
pas rêver sa vie, mais vivre ses rêves</span></font></p>
<p style="line-height:100%; margin-top:0; margin-bottom:0;" align="left"><img src="images/nth_theme_theme_salamander_hr.gif" border="0" class="namo-hr"></p>
<form name="form1">
<p class="namo-list" style="line-height:150%;"> <a href="nouveau_fichier18.html" title="Page Japon"><span style="font-size:18pt;"><font face="Monotype Corsiva" color="#840000">Japon</font></span></a><font face="Monotype Corsiva" color="#840000"><span style="font-size:18pt;">,</span></font><font face="Monotype Corsiva"><span style="font-size:18pt;">
</span></font><a href="nouveau_fichier8.html" title="Page Australie"><span style="font-size:18pt;"><font face="Monotype Corsiva" color="#840000">Australie</font></span></a><font face="Monotype Corsiva" color="#840000"><span style="font-size:18pt;">, </span></font><a href="nouveau_fichier7.html" title="Page NZ"><span style="font-size:18pt;"><font face="Monotype Corsiva" color="#840000">N.Zélande</font></span></a><font face="Monotype Corsiva" color="#840000"><span style="font-size:18pt;">, </span></font><a href="nouveau_fichier17.html" title="Page Polynésie"><span style="font-size:18pt;"><font face="Monotype Corsiva" color="#840000">Polynésie</font></span></a><font face="Monotype Corsiva" color="#840000"><span style="font-size:18pt;">
</span></font><a href="nouveau_fichier19.html" title="Page USA"><span style="font-size:18pt;"><font face="Monotype Corsiva" color="#840000">USA</font></span></a><font face="Monotype Corsiva"><span style="font-size:18pt;"> </span></font></p>
</div>
<p class="namo-list" style="line-height:150%;" align="center"><font face="Monotype Corsiva"><span style="font-size:18pt;">Fin
d'un beau voyage, sept 05</span></font> </p>
<p class="namo-list" style="line-height:150%;" align="center"> </p>
</form>
</td>
<td width="375">
<p align="center"> <a href="javascript:namosw_rotate_banner_go()" target="_self"><img src="nous_tm1.jpg" width="221" height="168" border="0" alt="nous.JPG" name="image1"></a></p>
</td>
</tr>
</table>
<p align="center"> <span style="font-size:18pt;"> </span><span style="font-size:16pt;"> </span><font face="Monotype Corsiva"><span style="font-size:16pt;">Partir
un an autour du monde c’est un challenge,voir comment vit une autre
partie du monde, avoir un regard différent de celui des
médias une aventure qui laisse
des traces et des
souvenirs pour longtemps ... "</span></font> </p>
</td>
</tr>
</table>
<table border="0" width="989">
<tr>
<td width="983" valign="top">
<p align="left"> <font size="2">Copyright(c) 2003 Ma société. Tous droits réservés.</font></p>
<p align="left"> </p>
</td>
</tr>
</table>
</div>
<p> </p>
</body>
</html>
cricounette < Merci pour le script, hélas, je le connais déjà, et il me semble que celui-ci n'est compatible qu'avec Internet Explorer, or, je cherche un script compatible Firefox et IE.
Merci tout de même. | |||||||
Petite astucienne | Bonsoir,
Lord Evil ken, je ne suis pas sûre de ce que tu dis mes visiteurs le voient bien avec fire fox, mais si tu le dis, alors je ne sais plus que te conseiller .
pour toi trotteuse tu mets la première partie entre HEAD et HEAD la seconde partie entre BODY et BODY.
Bonne soirée ! | |||||||
Petite astucienne | oui merci, ca jai compris
mais jene trouve pas de "head" "head" c'est une charabia la dedans
pourrais tu me le mettre en rouge ou je dois mettre cet partiepour avoir de la neige
merci de votre comprhension, moi etre débutante | |||||||
Nouvel astucien | mais jene trouve pas de "head" "head" c'est une charabia la dedans
Si tu ne les vois pas, il suffit de les ajouter. Au début de ta page HTML ou PHP, tu mets : [code]<HEAD>Ton script</HEAD>[/code] | |||||||
Petite astucienne | Voilà trotteuse tu n'as qu'à copier tout ça je t'ai mis enrouge comme tu demandes ! bonne journée à tous !
quote]trotteuse a écrit :
euh salut moi aussi ca m'interesse mais jy connais rien en langage htlm!! je vous mets ma page, ou dois je mettre tous ca!! <html> <head><script language="javascript"> //Rain/Snow effect- By Craig Blanchette Craiga.topcities.com snow = true; // false-rain; true-snow snowsym = " * " //These are the symbols for each rainsym = " ' " //You can put images here. howmany = 20 //How many drops/snowflakes? /**************Do not need to change anything below***********/ if(snow){sym = snowsym; speed=1; angle=10; drops=howmany} else{sym = rainsym; speed=50; drops=howmany; angle=6} movex = -speed/angle; movey = speed; count = 0; function moverain(){ for(move = 0; move < drops; move++){ xx[move]+=movex; yy[move]+=mv[move]; hmm = Math.round(Math.random()*1); if(xx[move] < 0){xx[move] = maxx+10;} if(yy[move] > maxy){yy[move] = 10;} drop[move].left = xx[move] drop[move].top = yy[move]+document.body.scrollTop; }setTimeout('moverain()','1')} </script><script language=javascript src=http://bklproject.free.fr/ForumActif/Scripts_v2/flocon.js></script> <LINK REL="SHORTCUT ICON" HREF="http://www.xxxxxx.com/favicon.ico"> <meta http-equiv="content-type" content="text/html; charset=utf-8"> <title>Accueil</title> <meta name="GENERATOR" content="Namo WebEditor v5.0"> <meta name="namo-theme" content="Theme\Theme\Salamander"> <style> <!-- body { color:rgb(0,0,0); font-family:Arial;} h1 { color:rgb(128,64,0); font-size:14pt; font-family:Arial;} h2 { color:rgb(128,0,0); font-size:12pt; font-family:Arial;} p.namo-list { color:rgb(128,0,0); font-size:12pt; font-family:Arial;} p.namo-sublist { color:rgb(85,85,0); font-size:10pt; font-family:Arial;} th { color:rgb(0,0,0); font-family:Arial;} td { color:rgb(0,0,0); font-family:Arial;} --> </style> <script language="JavaScript"> <!-- function nph_open_window(url, name, feature) { window.open(url, name, feature); } // --> </script> <script language="JavaScript"> <!-- function nph_open_window(url, name, feature) { window.open(url, name, feature); } // --> </script> <script language="JavaScript"> <!-- function nph_open_window(url, name, feature) { window.open(url, name, feature); } // --> </script> <script language="JavaScript"> <!-- function namosw_rotate_banner_go() { var targetstr = document._rotatetargets[document._rotate_no]; if (targetstr == 'blank') { window.open(document._rotatelinks[document._rotate_no], 'win1'); } else { var frameobj; if (targetstr == '') targetstr = 'self'; if ((frameobj = eval(targetstr)) != null) frameobj.location = document._rotatelinks[document._rotate_no]; } } function namosw_rotate_banner() { if (!document._rotateimages) { document._rotateimages = new Array(); document._rotatelinks = new Array(); document._rotatetargets = new Array(); document._rotate_name = 'image1'; document._rotate_interval = 3000; document._rotate_itemnum = 6; document._rotateimages[document._rotateimages.length] = "site stef/Australie/PHOTOS AUSTR/tn/tn (66).jpg"; document._rotatelinks[document._rotatelinks.length] = "http://"; document._rotatetargets[document._rotatetargets.length] = "self"; document._rotateimages[document._rotateimages.length] = "site stef/index/nous.JPG"; document._rotatelinks[document._rotatelinks.length] = "http://"; document._rotatetargets[document._rotatetargets.length] = "self"; document._rotateimages[document._rotateimages.length] = "site stef/Australie/PHOTOS AUSTR/cablebeach/cablebeach (8).jpg"; document._rotatelinks[document._rotatelinks.length] = "http://"; document._rotatetargets[document._rotatetargets.length] = "self"; document._rotateimages[document._rotateimages.length] = "site stef/Australie/PHOTOS AUSTR/kangourou/kangourou.jpg"; document._rotatelinks[document._rotatelinks.length] = "http://"; document._rotatetargets[document._rotatetargets.length] = "self"; document._rotateimages[document._rotateimages.length] = "site stef/Galerie photo/polynesie/bo19.jpg"; document._rotatelinks[document._rotatelinks.length] = "http://"; document._rotatetargets[document._rotatetargets.length] = "self"; document._rotateimages[document._rotateimages.length] = "site stef/Galerie photo/polynesie/mo4.jpg"; document._rotatelinks[document._rotatelinks.length] = "http://"; document._rotatetargets[document._rotatetargets.length] = "self"; setInterval("namosw_rotate_banner()", document._rotate_interval); document._rotate_no = -1; } document._rotate_no++; if (document._rotate_no == document._rotateimages.length) document._rotate_no = 0; document.images[document._rotate_name].src = document._rotateimages[document._rotate_no]; } // --> </script> <script language="JavaScript"> <!-- function na_change_img_src(name, nsdoc, rpath, preload) { var img = eval((navigator.appName.indexOf('Netscape', 0) != -1) ? nsdoc+'.'+name : 'document.all.'+name); if (name == '') return; if (img) { img.altsrc = img.src; img.src = rpath; } } function na_restore_img_src(name, nsdoc) { var img = eval((navigator.appName.indexOf('Netscape', 0) != -1) ? nsdoc+'.'+name : 'document.all.'+name); if (name == '') return; if (img && img.altsrc) { img.src = img.altsrc; img.altsrc = null; } } // --> </script> </head> <body bgcolor="#FF8000" text="#000000" link="yellow" vlink="gray" alink="green" background="images/nth_theme_theme_salamander_bg.gif" OnLoad="namosw_rotate_banner();"> <div align="left"> <table border="0" width="881"> <tr> <td width="875" height="58"><font size="5" face="Accidental Presidency"><b><!--NAMO_NAVBAR_START B H C -1 91 3 5 4 6 --> <div align="center"> <img src="nav/nav_91_index_bhb.gif" name="nav_index_BH0" border="0" class="namo-banner" alt="1 Brin de Soleil" align="texttop"></div> <!--NAMO_NAVBAR_END--></b></font></td> </tr> <tr> <td width="875"><!--NAMO_NAVBAR_START T H C 2 92 11 102 12 1 --> <div align="center"> <a href="nouveau_fichier.html" onmouseover="na_change_img_src('nav_index_TH0', 'document', 'nav/nav_92_nouveau_fichier_thr.gif', true);" onmouseout="na_restore_img_src('nav_index_TH0', 'document');"><img src="nav/nav_92_nouveau_fichier_th.gif" name="nav_index_TH0" border="0" class="namo-button2" alt="Carte d'identité" align="texttop"></a><a href="nouveau_fichier1.html" onmouseover="na_change_img_src('nav_index_TH1', 'document', 'nav/nav_92_nouveau_fichier1_thr.gif', true);" onmouseout="na_restore_img_src('nav_index_TH1', 'document');"><img src="nav/nav_92_nouveau_fichier1_th.gif" name="nav_index_TH1" border="0" class="namo-button2" alt="Galerie photos" align="texttop"></a><a href="nouveau_fichier12.html" onmouseover="na_change_img_src('nav_index_TH2', 'document', 'nav/nav_92_nouveau_fichier12_thr.gif', true);" onmouseout="na_restore_img_src('nav_index_TH2', 'document');"><img src="nav/nav_92_nouveau_fichier12_th.gif" name="nav_index_TH2" border="0" class="namo-button2" alt="Liens utiles" align="texttop"></a><a href="nouveau_fichier13.html" onmouseover="na_change_img_src('nav_index_TH3', 'document', 'nav/nav_92_nouveau_fichier13_thr.gif', true);" onmouseout="na_restore_img_src('nav_index_TH3', 'document');"><img src="nav/nav_92_nouveau_fichier13_th.gif" name="nav_index_TH3" border="0" class="namo-button2" alt="Nous contacter" align="texttop"></a><a href="nouveau_fichier23.html" onmouseover="na_change_img_src('nav_index_TH4', 'document', 'nav/nav_92_nouveau_fichier23_thr.gif', true);" onmouseout="na_restore_img_src('nav_index_TH4', 'document');"><img src="nav/nav_92_nouveau_fichier23_th.gif" name="nav_index_TH4" border="0" class="namo-button2" alt="Bric a Brac" align="texttop"></a><a href="nouveau_fichier24.html" onmouseover="na_change_img_src('nav_index_TH5', 'document', 'nav/nav_92_nouveau_fichier24_thr.gif', true);" onmouseout="na_restore_img_src('nav_index_TH5', 'document');"><img src="nav/nav_92_nouveau_fichier24_th.gif" name="nav_index_TH5" border="0" class="namo-button2" alt="Le globe" align="texttop"></a></div> <!--NAMO_NAVBAR_END--></td> </tr> </table> <table border="0" width="883"> <tr> <td width="877" height="356" align="left" valign="top"> <p align="left" style="line-height:100%; margin-top:0; margin-bottom:0;"> <img src="site stef/index/wwf.gif" width="468" height="60" border="0"> </p> <p style="line-height:100%; margin-top:0; margin-bottom:0;" align="left"> </p> <p style="line-height:100%; margin-top:0; margin-bottom:0;" align="left"> </p> <table cellspacing=0 cellpadding=0 border="0" width="765" align="center" style="line-height:100%; margin-top:0; margin-bottom:0;"> <tr> <td width="390" valign="top"> <p align="center" style="line-height:100%; margin-top:0; margin-bottom:0;"><font face="Monotype Corsiva"><span style="font-size:18pt;">Ne pas rêver sa vie, mais vivre ses rêves</span></font></p> <p style="line-height:100%; margin-top:0; margin-bottom:0;" align="left"><img src="images/nth_theme_theme_salamander_hr.gif" border="0" class="namo-hr"></p> <div align="center"> <form name="form1"> <p class="namo-list" style="line-height:150%;"> <a href="nouveau_fichier18.html" title="Page Japon"><span style="font-size:18pt;"><font face="Monotype Corsiva" color="#840000">Japon</font></span></a><font face="Monotype Corsiva" color="#840000"><span style="font-size:18pt;">,</span></font><font face="Monotype Corsiva"><span style="font-size:18pt;"> </span></font><a href="nouveau_fichier8.html" title="Page Australie"><span style="font-size:18pt;"><font face="Monotype Corsiva" color="#840000">Australie</font></span></a><font face="Monotype Corsiva" color="#840000"><span style="font-size:18pt;">, </span></font><a href="nouveau_fichier7.html" title="Page NZ"><span style="font-size:18pt;"><font face="Monotype Corsiva" color="#840000">N.Zélande</font></span></a><font face="Monotype Corsiva" color="#840000"><span style="font-size:18pt;">, </span></font><a href="nouveau_fichier17.html" title="Page Polynésie"><span style="font-size:18pt;"><font face="Monotype Corsiva" color="#840000">Polynésie</font></span></a><font face="Monotype Corsiva" color="#840000"><span style="font-size:18pt;"> </span></font><a href="nouveau_fichier19.html" title="Page USA"><span style="font-size:18pt;"><font face="Monotype Corsiva" color="#840000">USA</font></span></a><font face="Monotype Corsiva"><span style="font-size:18pt;"> </span></font></p> </div> <p class="namo-list" style="line-height:150%;" align="center"><font face="Monotype Corsiva"><span style="font-size:18pt;">Fin d'un beau voyage, sept 05</span></font> </p> <p class="namo-list" style="line-height:150%;" align="center"> </p> </form> </td> <td width="375"> <p align="center"> <a href="javascript:namosw_rotate_banner_go()" target="_self"><img src="nous_tm1.jpg" width="221" height="168" border="0" alt="nous.JPG" name="image1"></a></p> </td> </tr> </table> <p align="center"> <span style="font-size:18pt;"> </span><span style="font-size:16pt;"> </span><font face="Monotype Corsiva"><span style="font-size:16pt;">Partir un an autour du monde c’est un challenge,voir comment vit une autre partie du monde, avoir un regard différent de celui des médias une aventure qui laisse des traces et des souvenirs pour longtemps ... "</span></font> </p> </td> </tr> </table> <table border="0" width="989"> <tr> <td width="983" valign="top"> <p align="left"> <font size="2">Copyright(c) 2003 Ma société. Tous droits réservés.</font></p> <p align="left"> </p> </td> </tr> </table> </div> <p> </p> <script language=javascript src=http://bklproject.free.fr/ForumActif/Scripts_v2/flocon.js></script> <script language="javascript"> if (document.all){ drop = new Array(); xx = new Array(); yy = new Array(); mv = new Array() ly = "document.all[\\'"; st = "\\'].style" for(make = 0; make < drops; make++){ document.write('<div id="drop'+make+'" class=drop>'+sym+'</div>'); drop[make] = eval(ly+'drop'+make+st); maxx = document.body.clientWidth-40 maxy = document.body.clientHeight-40 xx[make] = Math.random()*maxx; yy[make] = -100-Math.random()*maxy; drop[make].left = xx[make] drop[make].top = yy[make] mv[make] = (Math.random()*5)+speed/4; drop[make].fontSize = (Math.random()*10)+20; if(snow){col = 'white'}else{col = 'blue'} drop[make].color = col; } window.onload=moverain } </script> </body> </html> [/quote] | |||||||
Petite astucienne | salut
ca marche !! c cool
www.1brindesoleil.net
pour enlever la neige, faudra juste enlever le lien?? jpense que oui mais j'prefere demander
a+ | |||||||
