 probleme installation carte son creative
bluntman
  Posté le 02/12/2009 @ 18:23
donc je n'arrive pas a installer correctement ma carte son : CREATIVE Carte son Sound Blaster X-FI Xtreme Audio PCI Express
j'obtient plein de fois ce message d'erreur : I-001
et juste apres code erreur 2147213312
doinstall fails to launch d:\ausio\cslaunch\setup.inx ( doinstall error code is 2147213312 )
donc enfaite j'ai du son ( quand meme ) cependant ma carte son ne fonctione pas a pleine capaciter ( aucun programme ne fonctionne reglage du son , activation 7.1 etc )
je suis allez fair eun tour sur le forum creative voici leur solution a mon probleme
To resolve the Installshield error I-001 "File Not Found", or I-002 "File is corrupted" while you are trying to install software applications or drivers, please follow the steps below to resolve the issue:
  1. Leave the error messages on the screen.
  2. Click on the Start button, and then click on Search.
  3. Select All files and Folders, and type INSTALL.LOG in the file name field.
  4. If more than one copy of the INSTALL.LOG is found, check on the date for each file, and open the most recent file using notepad. This should correspond to the date / time of the installation attempt.
  5. Scroll to the last 1-3 lines in this log file.
    These lines should show what installation file, Windows file, or registry component was not found by the installation.
  6. At this point, try to find the files in the installation cd of the software you are installing or from the Windows installation CD. Reinstall these files or save them into the directory where they should be as indicated in the INSTALL.LOG file.
j'ai traduit via google et essayer leur solution cependant impossible de trouver le fichier install.log
svp aidez moi je suis degouter
merci d'avance
MasterThief
 Posté le 02/12/2009 à 21:15
Donc le GP l'indique comme non fonctionnelle ?
bluntman
 Posté le 02/12/2009 à 23:37
bonsoir
pardon mais que veut dire GP ?
sinon ma carte son et bien reconnu sous windows elle fonctionne ;)
mais a cause de ces message d'erreur lors de l'instalation je ne peut pas acceder a certain programme
et du coup je doute fort d'utiliser 100% des capaciter de ma carte son ( meme sur )
MasterThief
 Posté le 03/12/2009 à 08:28
Le gestionnaire de périphériques.
Super_GEGE
 Posté le 03/12/2009 à 11:13
Je pense que c'est ton cd qui ou éventuellement ton lecteur qui commence à fatiguer.
As tu fais les mises à jour / windows update ?.
Regarde également sur le site de Créative pour récupérer les mises à jour et éventuellement de nouveaux pilotes réinstalle tout.
Actuellement, seuls les pilotes sont bien installés c'est pour cela que tu as du son mais pas toute les fonctions de ta carte.
Modifié par Super_GEGE le 03/12/2009 11:15
MasterThief
 Posté le 03/12/2009 à 12:09
c'est Vista ?
MasterThief
 Posté le 03/12/2009 à 12:10
Ou plutôt, c'est un OS plus récent que XP ?
Coffret 6 scies trépans HSS Bimétal (20/25/35/40/51/68 mm) à 52,65 €
52,65 € 63 € -16% @Amazon
SSD Crucial P3 Plus 4 To (NVMe, PCIe 4.0, M.2, 5000 Mo/s) à 330,99 €
330,99 € 379 € -13% @Amazon
Kit mémoire DDR4 G. Skill Aegis 32 Go (2x16 Go) 3200 MHz à 82,13 € livrée
82,13 € 110 € -25% @Amazon Allemagne
Coffret de 15 fraises à bois Bosch (queue de 8 mm) à 53,19 €
53,19 € 69,99 € -24% @Amazon
Souris sans fil Logitech G305 à 38,99 €
38,99 € 50 € -22% @Amazon
Bracelet connecté Xiaomi Mi Band 6 avec tracker cardiaque IP67, écran OLED et Bluetooth 5 à 23,99 €
23,99 € 42,99 € -44% @Darty
Carte Ziyituod AX210 PCIe WIFI 6E + Bluetooth 5.2 avec dissipateur à 36,90 €
36,90 € 45,39 € -19% @Amazon
Bureau métal noir (120x60x83cm, hauteur réglable, LED) à 79,99 €
79,99 € 149,99 € -47% @Cdiscount
SSD Crucial P3 Plus 1 To (NVMe, PCIe 4.0, M.2, 5000 Mo/s) à 75,13 € livré
75,13 € 420 € -82% @Amazon Allemagne
Barrette mémoire DDR5 Kingston FURY Beast 16 Go 4800 MHz CL38 à 78,88 €
78,88 € 99,99 € -21% @Amazon
Problème installation carte graphique GTX 660
problème de pilote après installation nouvelle carte
problème installation carte graphique asus
problème après installation de carte mère
Problème installation nouvelle carte graphique
Problème installation Carte graphique ATI 5670
Problème installation carte son
probleme d'installation de carte graphique
installation carte graphique = problème son
problème installation pilote carte mère
Plus de sujets relatifs à probleme installation carte son creative
