 Problème lancement Medal of Honor
shurikn04
  Posté le 22/08/2006 @ 14:44
Bonjour, je viens d'acheter Medal of Honor Débarquement allié pour jouer en réseau, je l'ai installer mais quand je le lance la console se lance et voilà ce qu'elle écrit: --- Common Initialization --- Medal of Honor Allied Assault 1.11 win-x86 Apr 20 2002 ----- FS_Startup ----- Current search path: C:\PROGRA~1\EAGAME~1\MOHDA/main C:\PROGRA~1\EAGAME~1\MOHDA\main\Pak7Fr.pk3 (82 files) C:\PROGRA~1\EAGAME~1\MOHDA\main\Pak6Fr.pk3 (610 files) C:\PROGRA~1\EAGAME~1\MOHDA\main\Pak5.pk3 (259 files) C:\PROGRA~1\EAGAME~1\MOHDA\main\Pak4.pk3 (593 files) C:\PROGRA~1\EAGAME~1\MOHDA\main\Pak3.pk3 (669 files) C:\PROGRA~1\EAGAME~1\MOHDA\main\Pak2.pk3 (4584 files) C:\PROGRA~1\EAGAME~1\MOHDA\main\Pak1.pk3 (396 files) C:\PROGRA~1\EAGAME~1\MOHDA\main\Pak0.pk3 (11174 files) ---------------------- 18367 files in pk3 files execing default.cfg execing menu.cfg execing newconfig.cfg Config: unnamedsoldier.cfg couldn't exec configs/unnamedsoldier.cfg execing newconfig.cfg couldn't exec localized.cfg execing autoexec.cfg Unknown command "fov" couldn't exec custom.cfg ...detecting CPU, found Intel Pentium III ------- Input Initialization ------- Initializing DirectInput... Couldn't set DI coop level Falling back to Win32 mouse support... ------- Input Initialization Complete ------- 259 You are now setup for easy mode. ----- Client Initialization ----- Called FadeSound with: 0.000000 ----- Initializing Renderer ---- ----- R_Init ----- Initializing OpenGL subsystem ...initializing QGL ...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded ...setting mode 3: 640 480 FS ...using colorsbits of 16 ...calling CDS: ok ...registered window class ...created window@0,0 (640x480) Initializing OpenGL driver ...getting DC: succeeded ...GLW_ChoosePFD( 16, 16, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...GLW_ChoosePFD( 16, 16, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...failed to find an appropriate PIXELFORMAT ...restoring display settings ...WARNING: could not set the given mode (3) ...shutting down QGL ...unloading OpenGL DLL ...assuming '3dfxvgl' is a standalone driver ...initializing QGL ...WARNING: missing Glide installation, assuming no 3Dfx available ...shutting down QGL GLW_StartOpenGL() - could not load OpenGL subsystem Donc pour moi il me semble qu'il y a un problème avec la carte graphique et pourtant quand je regarde au dos de la boîte du jeu ma carte graphique (Nvidia riva tnt2) est compatible, comment faire pour que le jeu se lance ?
Modifié par shurikn04 le 22/08/2006 14:47
jules08
 Posté le 22/08/2006 à 16:53
Bonjour, A mon avis il faut mettre Ó jours les pilotes de ta carte graphique + DirectX.
499 € 699 € -29%
Coffret 5 bouteilles Tabasco (5x60 mL)
18,95 € 30 € -37%
Opération BD Eté 2026 : sélection de bandes dessinées
3,99 € -1 -37%
Bouteille de Bourbon Bulleit 70 cl
18,99 € 28,55 € -33%
Robot cuiseur multifonction Moulinex Companion Pro HF850BF0
569,98 € 699,99 € -19%
Lot de 15 boîtes de 128 mouchoirs Kleenex
22,69 € 33,99 € -33%
problème medal of honor : airborne
Problème Medal Of honor L'offensive
probleme medal of honor
Problème pour jouer à medal of honor
Probleme avec Medal Of Honor
probleme avec medal of honor
Problème lancement Tortune ninja pc
Problème au lancement de Call of duty ghost
Problème de lancement sur la démo de fifa14
Plus de sujets relatifs à Problème lancement Medal of Honor
