 probleme lecture fichier
ricobaggio
  Posté le 10/03/2009 @ 15:39
slt a tous voila je c pas si j'ai poster sur le bon forum mais quand j'essai de regarder une video du net sur mon pc avec media player j'ai un message en anglais comme d'hab et je ne c pas quoi faire si quelqu'un pouvait m'aider
voici le message
0xC00D1197: Cannot play the file
Windows Media Player cannot play the file. You may encounter this error message for one of the following reasons:
  • Your computer is not connected to the local area network (LAN) or to the Internet. Connect to the network or Internet, and then try again.
  • The path to the file is not valid. If you typed a Uniform Resource Locator (URL) in the Open URL dialog box, ensure that the file name is spelled correctly and the path to the file is correct, and then try again. If you clicked a link on a Web page, the link may not be valid.
  • The server is down or busy. Try again later.
  • Some network protocols in the Player are not enabled. Enable all network protocols, and then try again.
  • The proxy server settings for the Player are not configured properly. Verify that your proxy settings are correct, and then try again.
  • To enable all network protocols
    1. On the Tools menu, click Options, and then click the Network tab.
    2. In the Streaming protocols area, select all the protocol check boxes.
    To verify your proxy server settings
    2. Verify your settings in the Streaming proxy settings area.
    Note Image  Note
  • If you do not know what your proxy server settings should be, on the Network tab, select a protocol, click Configure, and then select Autodetect proxy settings or Use proxy settings of the Web browser (available for HTTP protocol only).
  • Error ID = 0xC00D1197, Condition ID = 0x00000000
    carisa
     Posté le 10/03/2009 à 16:01
    Bonjour ricobaggio ,
    Traduction :Windows M P
    ne peut pas lire le fichier. Vous mai rencontrer ce message d'erreur pour l'une des raisons suivantes:
    Votre ordinateur n'est pas connecté au réseau local (LAN) ou à Internet. Connectez-vous au réseau ou à Internet, puis essayez à nouveau.
    Le chemin vers le fichier n'est pas valide. Si vous avez tapé une URL (Uniform Resource Locator) dans la boîte de dialogue Ouvrir une URL, assurez-vous que le nom du fichier est correctement orthographié et le chemin d'accès au fichier est correct, puis essayez à nouveau. Si vous avez cliqué sur un lien sur une page Web, le lien mai ne pas être valide.
    Le serveur est en panne ou occupé. Essayez à nouveau plus tard.
    Certains protocoles réseau dans le lecteur ne sont pas activés. Activer tous les protocoles réseau, puis essayez à nouveau.
    Les paramètres du serveur proxy pour le joueur ne sont pas configurés correctement. Vérifiez que vos paramètres de proxy sont corrects, puis réessayez.
    Pour permettre à tous les protocoles de réseau
    Dans le menu Outils, cliquez sur Options, puis cliquez sur l'onglet Réseau.
    Dans les protocoles de streaming, sélectionnez toutes les cases à cocher protocole.
    Pour vérifier vos paramètres du serveur proxy
    Vérifiez vos paramètres dans les paramètres de proxy Streaming domaine.
    Peut-être un probléme de Codec si c'est le cas : http://www.pcastuces.com/logitheque/klite_codec_pack.htm
    Modifié par carisa le 10/03/2009 16:19
    ricobaggio
     Posté le 10/03/2009 à 16:33
    merci pour cette traduction
    carisa
     Posté le 10/03/2009 à 17:32
    De rien , voila moi je peux pas d'aidé plus !!!!!!!!!!!!!!!!!!!!
    A bientôt sur PCA , carisa
    143 €SSD externe portable Samsung T7 1 To à 143 €
    Valable jusqu'au 04 Décembre
    Amazon fait une promotion sur le SSD externe portable Samsung T7 1 To qui passe à 143 € livré gratuitement alors qu'on trouve le SSD à partir de 189 € ailleurs. Son format compact vous permettra de le transporter facilement avec vous. De quoi stocker parfaitement vos fichiers et de les emporter dans vos déplacements en toute sérénité. Grâce à la technologie PCIe NVMe intégrée et au connecteur USB 3.1 Type C, bénéficiez de vitesses supérieures pouvant atteindre 1050 Mo /s ! Compatible PC, Mac et Android, il se montrera rapidement indispensable. Le disque Samsung T7 se pare d'un boîtier robuste en aluminium qui résistera aux chutes. Il embarque également un cryptage avancé avec mot de passe. La version 500 Go est également en promotion à 81 € livrée au lieu de 100 €.
    18,69 €Clé USB 3.0 SanDisk Ultra Flair 128 Go à 18,69 €
    Amazon fait une promotion sur la clé USB 3.0 SanDisk Ultra Flair 128 Go qui passe à 18,69 € alors qu'on la trouve ailleurs à plus de 25 €. Cette clé USB offre des débits jusqu'à 150 Mo/s.
    96,99 €Disque dur externe portable Seagate Expansion 5 To USB 3.0 à 96,99 €
    Valable jusqu'au 05 Décembre
    Amazon fait une promotion sur le disque dur externe portable Seagate Expansion d'une capacité de 5 To à 96,99 € livré alors qu'on le trouve ailleurs à partir de 120 €. Ce disque dur externe portable au format 2,5 pouces dispose d'une interface USB 3.0 compatible USB 2.0. Une excellente affaire pour ce disque dur qui offre des débits de 115 Mo/s. Il n'est pas soudé et est donc démontable si vous souhaitez le réutiliser ailleurs (console, NAS, PC).
    Problème lecture fichier reseau
    Problème lecture vidéo sur internet avec tablette
    Problème arrêt lecture video internet
    lecture fichier mp3 avec Firefox
    lecture d'un fichier video
    Problème fichier chrome...
    probleme lecture en streaming
    Problème de lecture sur Daily et autres...
    problème de lecture de fichiers partagés
    Problème lecture pdf sous opéra
    Plus de sujets relatifs à probleme lecture fichier
