 Problème mise à jour Vista UptadeSujet résolu
victor21
  Posté le 01/09/2008 @ 11:40
Normal 0 21 false false false FR X-NONE X-NONE MicrosoftInternetExplorer4 <!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:1; mso-generic-font-family:roman; mso-font-format:other; mso-font-pitch:variable; mso-font-signature:0 0 0 0 0 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin-top:0cm; margin-right:0cm; margin-bottom:10.0pt; margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;} p {mso-style-noshow:yes; mso-style-priority:99; mso-margin-top-alt:auto; margin-right:0cm; mso-margin-bottom-alt:auto; margin-left:0cm; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman","serif"; mso-fareast-font-family:"Times New Roman";} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;} .MsoPapDefault {mso-style-type:export-only; margin-bottom:10.0pt; line-height:115%;} @page Section1 {size:612.0pt 792.0pt; margin:70.85pt 70.85pt 70.85pt 70.85pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Depuis quelques jours, la mise à jour de sécurité pour Microsoft Office Power Point 2007 ne s'installe pas et j'obtiens ce message" Code 57 A, Windows Update a rencontré une erreur inconnue".
Conséquence : à chaque arrêt du système, la petite icône des mises à jour apparaît sur le bouton arrêt et essaie d'installer cette mise à jour, en vain.
Avec ou sans antivirus, la mise à jour ne s'installe pas et le même message d'erreur.
Pouvez-vous m'aider afin de corriger ce bug.
Merci à tous.
chaseur57150
 Posté le 01/09/2008 à 12:04
Salut victor21 A tu essayé de faire cette mise a jour via windows update?
Ou essaye en mode sans echec!
Modifié par chaseur57150 le 01/09/2008 12:05
mitou03700
 Posté le 25/11/2008 à 13:23
bien que le post soit (un peu) ancien
même ennui, précédemment j'avais "interdit" cette mise à jour dans les options de ces mises à jour en échec répétés
mais, mon (dernier ?) neurone a oublié la manip et même en bataillant depuis un bon moment je n'arrive pas à retrouver la méthode
si un bon Docteur veux bien activer mon (dernier ?) neurone
merci d'avance
chaseur57150
 Posté le 25/11/2008 à 13:55
victor21.Windows update, afficher les mises à jours, clic droit sur cette mise à jour, ensuite "masquer cette mise à jour"!
victor21
 Posté le 25/11/2008 à 14:01
c'est sympa d'avoir répondu après tant de temps. je n'ai pu résoudre le problème qu'après avoir réinstaller Vista. Tout est OK à présent.
Merci et bonne journée.
victor 21
mitou03700
 Posté le 25/11/2008 à 14:06
bonjour à tous
merci aussi,
les mises à jour (refusées) suite message (idem victor 21), sont , désormais bloquées et ne reviennent plus en propositions répétées
encore merci chasseur
bonne journée
chaseur57150
 Posté le 25/11/2008 à 15:29
De rien!
Graveuse laser ORTUR Laser Master 3 10W + plateforme de gravure à 529 €
529 € 715 € -26% @Geekbuying
Geekbuying fait une belle promotion sur l'excellente graveuse laser ORTUR Laser Master 3 10W qui passe à 529  avec le code NNNFBDTORTUR3 alors qu'on la trouve ailleurs à partir de 715 €. Cette machine de gravure laser va vous permettre de graver et découper le papier, le cuir, le bois, le bambou, la corne, le plastique, la céramique l'acrylique, ...
Une plateforme ORTU LEP1.0 qui permet de positionner correctement ses objets à graver est également offerte (valeur 85 €).
L'envoi se fait depuis un entrepôt européen. Vous êtes ainsi certains de recevoir la graveuse rapidement et sans douane.
Voir le bon plan
Batterie externe OUKITEL P2001 Ultimate 2000Wh, 2000W, LifePOE4 à 1099 €
1099 € 2199 € -50% @Geekbuying
Geekbuying fait une belle promotion sur le lancement de la station de charge portable OUKITEL P2001 Ultimate 2000W qui passe à 1300 € grâce au code promo NNNFRBEDEITOUKIT. Elle sera proposée ensuite à 2199 €.
Cette Power Station offre une capacité de 2000Wh avec une batterie LifePOE4 (plus de 3500 cycles) et 13 sorties : 3 AC Format prise Europe 220-240V jusqu'à 2000W (surtension jusqu'à 4000W)/ 1 allume-cigare 12 V/10 A / 1 sortie 12 V/10 A XT60 / 2 sorties DC5521 12V/3A pour lampes LED / 2 x USB PD-100W Type-C pour une charge rapide / 2 x USB QC3.0-18W / 2 x USB 5V/2.4A USB.
De quoi alimenter de nombreux appareils pendant des heures sans prise de courant à côté. La batterie peut être rechargée par une prise de courant, une prise allume cigare ou des panneaux solaires. Vous pouvez coupler 2 sources de charge pour aller plus vite.
La batterie peut également faire office d'onduleur UPS pour prendre le relais en cas de panne de courant.
Voir le bon plan
SSD externe NVMe Crucial X8 1 To à 83,39 €
83,39 € 100 € -17% @Amazon
Amazon fait une promotion sur le SSD externe NVMe Crucial X8 1 To qui passe à 83,39 € alors qu'on le trouve ailleurs à partir de 100 €. Il offre des vitesses de lecture jusqu'à 1050 Mo/s et résiste aux chutes jusqu'à 2 mètres, aux chocs et aux températures extrêmes. Il est fourni avec des connecteurs USB C-3.2 et USB-A (USB classique).
Voir le bon plan
SSD WD Blue SN570 1 To (NMVe M.2, 3500 Mo/s) à 53,90 €
53,90 € 80 € -33% @Amazon Belgique
Amazon Belgique fait une promotion sur le SSD WD Blue SN570 1 To (NMVe M.2) qui passe à 53,90 € alors qu'on le trouve ailleurs à partir de 80 €. Ce SSD utilise une interface M.2 NVMe PCIe Gen3 x 4 pour une connexion simple et des performances exceptionnelles : jusqu’à 3 500 Mo/s en lecture séquentielle et jusqu’à 3 000 Mo/s en écriture séquentielle.
L'offre n'est valable que pour les Belges ou les frontaliers qui peuvent se faire livrer en relais en Belgique. Pour les autres, il faudra vous tourner vers cette offre à 59,99 €.
Voir le bon plan
SSD WD Blue SN570 1 To (NMVe M.2, 3500 Mo/s) à 59,99 €
59,99 € 80 € -25% @Cdiscount
Cdiscount fait une promotion sur le SSD WD Blue SN570 1 To (NMVe M.2) qui passe à 59,99 € alors qu'on le trouve ailleurs à partir de 80 €. Ce SSD utilise une interface M.2 NVMe PCIe Gen3 x 4 pour une connexion simple et des performances exceptionnelles : jusqu’à 3 500 Mo/s en lecture séquentielle et jusqu’à 3 000 Mo/s en écriture séquentielle.
Voir le bon plan
Ecouteurs sans fil Apple AirPods 2 avec boîtier de charge à 99 €
99 € 129 € -23% @Cdiscount
Dimanche matin, Cdiscount fera une promotion pour ses membres CDAV sur les écouteurs sans fil Apple AirPods 2 avec boîtier de charge filaire à 99 € grâce à un coupon de réduction alors qu'on les trouve ailleurs à partir de 129 €.
Voir le bon plan
Problème de démarrage suite à mise à jour de winn vista
vista et mise à jour me pose probleme
probleme de mise à jour vista et restauration
probleme d ecran suite mise à jour vista
problème d'installation de mise à jour pour Vista
Problème mise à jour Vista Sp2
Problème mise a jour vista sp2 64 bits
Problème dans mise à jour de driver Vista
Plus de sujets relatifs à Problème mise à jour Vista Uptade
