Nouvel astucien | bjr,je ne sais plus graver mes dvd avec mon plextor px-800a qqun aurait il le driver ou firmware??? merci
Petite astucienne ![]() | http://www.touslesdrivers.com/index.php?v_code=602&v_page=12 peut etre que tu trouveras ici Bonne journée Modifié par ritatje le 11/04/2008 14:22 | |||||||
Nouvel astucien | je te remercie,mais je n'ai pas trouve sur ce site | |||||||
Petite astucienne ![]() | Si tu comprends l'anglais ceci pourrais t'aider http://club.cdfreaks.com/f43/plextor-px800a-problems-218453/ Re: Plextor PX800A Problems i have a plextor px800a turboplex myself and i did have that problem. what i did was uninstall the easy media creator that came with it and anything else off the disc, shut down comp then removed the drive, restarted without the drive, then reattached drive making sure it was in the correct slot, rebooted, went into bios and made sure hard drive was first boot device, hit f10 hit OK, comp restarted and recognised the drive, reinstalled programs off disc, went to plextorwebsite and searched for firmware update and installed if needed went to control panel system device manager on dvdcdrom i right clicked cliked properties and made sure region was set to where you live "new york here" so region 1 for me ok now for the final boot reboot machine and it worked since then no problems ever sorry for the long explanation but even if some are not needed its good to recheck em. the roxio easy cd creater that came with it has cineplayer but if you need a dvd decoder just google it there are allot of free ones. | |||||||
