 programmes qui se lance au demarrage[resolu]
Sdw
  Posté le 25/11/2003 @ 14:53
Dans ma liste de programme j'ai un programme que je ne connait pas:
KernelFaultCheck %systemroot%\system32\dumprep 0 -k
l'un de vous peut m'aider.
Modifié par Sdw le 27/04/2004 11:06
bay
 Posté le 25/11/2003 à 15:02
Bonjour , attention dans certains processus du virus [url="http://www.f-secure.com/v-descs/fagot.shtml"]Fagot [/url] , ce dumprep.exe est desactivé par le virus ? ou sinon
Dumprep DumpRep.exe (Microsoft) Windows Error Reporting Dump Reporting Tool. Found on Windows XP/2003. It shows as a startup item whose execution line usually reads as "KernelFaultCheck" %systemroot%\system32\dumprep 0 –k. DUMPREP creates memory dump reports that you can send to Microsoft if you answer "Yes" when prompted to send such reports. In our experience this entry only shows up for the first time after your PC has experienced a Windows XP "dump" crash, or an Office XP or Internet Explorer 6 crash where you were prompted about sending the crash results to Microsoft. Recommendation : It is our experience that having Error Reporting set to ON only causes more crashes. The mind boggles at this : in both Netscape and Internet Explorer our experience shows that if you turn error reporting ON, you will crash often in either browser, if not sometimes always !! You’ve guessed it, avoid Error Reporting like the plague. In both Windows XP and Windows 2003 turn it OFF by opening the SYSTEM icon in the Control Panel, choosing the ADVANCED tab, and then clicking on Error Reporting.
Modifié par bay le 25/11/2003 15:04
Sdw
 Posté le 25/11/2003 à 15:05
je sais pas si c'est du a un virus, car j'ai tout réinstaller ce matin (avec un formatage)
PhiloU_PoyE
 Posté le 25/11/2003 à 15:06
Task List Programs a startup item whose execution line usually reads as "KernelFaultCheck" %systemroot%\system32\dumprep 0 k. DUMPREP creates memory dump reports that you can send to Microsoft if http://www.answersthatwork.com/Tasklist_pages/tasklist_d.htm
Sdw
et je parle pas anglais :-// désolé
PhiloU_PoyE
 Posté le 25/11/2003 à 15:22
C'est un module qui sauvegarde temporaire en RAM pour pouvoir envoyer le détail de l'erreur Windows (kernel) à MICROSOFT
PhiloU_PoyE
 Posté le 25/11/2003 à 15:23
Bref, c'est pas un virus !
Sdw
 Posté le 25/11/2003 à 15:24
Ok merci [smile]
JLou
 Posté le 25/11/2003 à 15:28
Bonjour kernelfaultcheck dumprep 0 -k kernelfaultcheck dumprep 0 -u Used in connection with memory dumps - you can disable these by - right clicking on My Computer, selecting Properties and then the Advanced tab. Click on the Settings button in 'Startup and Recovery'. In the bottom pane - under 'Write debugging information' - click on the down arrow and then select 'None' - OK your way out [url]http://www.pacs-portal.co.uk/startup_pages/startup_k.php[/url] [clindoeil] Pour traduire ---> [url]http://ca-fr.altavista.com/babelfish[/url] @ +
49,90 €Microphone USB Bird UM1 à 49,90 €
Valable jusqu'au 20 Février
Amazon fait une vente flash sur le Microphone USB Bird UM1 qui passe à 49,90 € alors qu'on le trouve ailleurs à partir de 69 €. La livraison est gratuite. Le Bird UM1 est un micro de studio d'excellente qualité avec interface USB intégrée. C'est une solution idéale et tout-en-un qui évite d'avoir à acheter un préampli ou une interface audio supplémentaire.  Idéal pour le studio, YouTube ou l'animation de votre blog.
12,90 €Windows 10 Pro 32/64 bits OEM à 12,90 €
Valable jusqu'au 24 Février
Le vendeur sérieux DIGITAL FR propose sur Amazon  la clé d'activation pour Windows 10 professionnel en français 32 bits / 64 bits à 1Z,90 €. Cette clé livrée par email fonctionne avec l'outil d'installation et de création de support de Microsoft que vous pouvez télécharger ici ou directement avec l'ISO de Windows 10 Pro. De quoi installer légalement Windows 10 Pro sur un PC. Pour en savoir plus sur l'achat et l'installation d'une clé OEM de Windows 10, suivez les indications de notre dossier pratique.
GratuitJeu PC Aztez gratuit
Epic Game Store offre actuellement le jeu PC Aztez. Aztez est un jeu hybride unique, entre beat them all et stratégie au tour par tour, qui se déroule au sein de l'Empire aztèque. Mettez fin aux conflits qui ravagent votre empire en pleine expansion dans des combats beat them all en temps réel et hautement techniques.
[RESOLU] Programme Microsoft lancé au démarrage
Marre des trucs ki se lance au démarrage!![résolu]
démarrage de programmes (résolu)
Deuxième problème : démarrage programmes (résolu)
Résolu suppression de programmes au démarrage
Intérrogation ? sur fichiers dans G: programmes. Résolu merci.
Assistance de matériel qui se lance au démarrage
Programmes au démarrage?
Programmes lancés au démarrage
Suppression programmes au démarrage
Plus de sujets relatifs à programmes qui se lance au demarrage[resolu]
