 Rapport HJT apres nettoyage
raphesse
  Posté le 09/09/2009 @ 06:02
Bonjour a tous,
C'est grave docteur??
Mon ordinateur bugg de tps en tps, voici donc le rapport apres pre-nettoyage
Par avance merci de me consacrer un peu de votre temps
Bonne journée
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 20:58:29, on 08/09/2009
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v8.00 (8.00.6001.18702)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\AGRSMMSG.exe
C:\Program Files\Analog Devices\Core\smax4pnp.exe
C:\WINDOWS\system32\AccelerometerSt.exe
C:\Program Files\ATI Technologies\ATI.ACE\cli.exe
C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
C:\Program Files\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe
C:\WINDOWS\SMINST\Scheduler.exe
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\Program Files\Winamp\winampa.exe
C:\Program Files\Java\jre6\bin\jusched.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Windows Live\Messenger\msnmsgr.exe
C:\Program Files\Messenger\msmsgs.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\WIDCOMM\Logiciel Bluetooth\BTTray.exe
C:\Program Files\MagicDisc\MagicDisc.exe
C:\PROGRA~1\WIDCOMM\LOGICI~1\BTSTAC~1.EXE
C:\Program Files\OpenOffice.org 3\program\soffice.exe
C:\Program Files\OpenOffice.org 3\program\soffice.bin
C:\Program Files\WIDCOMM\Logiciel Bluetooth\bin\btwdins.exe
C:\Program Files\Java\jre6\bin\jqs.exe
C:\WINDOWS\system32\MsPMSPSv.exe
C:\WINDOWS\system32\mqsvc.exe
C:\Program Files\Hewlett-Packard\Shared\hpqwmiex.exe
C:\WINDOWS\system32\mqtgsvc.exe
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
C:\WINDOWS\system32\wbem\wmiapsrv.exe
C:\Program Files\Mozilla Firefox\firefox.exe
C:\Program Files\Windows Live\Contacts\wlcomm.exe
C:\Program Files\Vuze\Azureus.exe
C:\Documents and Settings\Raph\Bureau\Raph.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://google.com/
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://www.hp.com/
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Liens
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Fichiers communs\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: (no name) - {5C255C8A-E604-49b4-9D64-90988571CECB} - (no file)
O2 - BHO: Programme d'aide de l'Assistant de connexion Windows Live - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Fichiers communs\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.1.1309.3572\swg.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O4 - HKLM\..\Run: [MsmqIntCert] regsvr32 /s mqrt.dll
O4 - HKLM\..\Run: [AGRSMMSG] AGRSMMSG.exe
O4 - HKLM\..\Run: [SoundMAXPnP] C:\Program Files\Analog Devices\Core\smax4pnp.exe
O4 - HKLM\..\Run: [SoundMAX] C:\Program Files\Analog Devices\SoundMAX\Smax4.exe /tray
O4 - HKLM\..\Run: [AccelerometerSysTrayApplet] C:\WINDOWS\system32\AccelerometerSt.exe
O4 - HKLM\..\Run: [ATICCC] "C:\Program Files\ATI Technologies\ATI.ACE\cli.exe" runtime -Delay
O4 - HKLM\..\Run: [SynTPEnh] C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
O4 - HKLM\..\Run: [QlbCtrl] %ProgramFiles%\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe /Start
O4 - HKLM\..\Run: [Cpqset] C:\Program Files\HPQ\Default Settings\cpqset.exe
O4 - HKLM\..\Run: [Recguard] C:\WINDOWS\Sminst\Recguard.exe
O4 - HKLM\..\Run: [Reminder] C:\WINDOWS\Creator\Remind_XP.exe
O4 - HKLM\..\Run: [Scheduler] C:\WINDOWS\SMINST\Scheduler.exe
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O4 - HKLM\..\Run: [WinampAgent] "C:\Program Files\Winamp\winampa.exe"
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [AdobeCS4ServiceManager] "C:\Program Files\Fichiers communs\Adobe\CS4ServiceManager\CS4ServiceManager.exe" -launchedbylogin
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe"
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\Windows Live\Messenger\msnmsgr.exe" /background
O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SERVICE LOCAL')
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SERVICE RÉSEAU')
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user')
O4 - Startup: MagicDisc.lnk = C:\Program Files\MagicDisc\MagicDisc.exe
O4 - Startup: OpenOffice.org 3.0.lnk = C:\Program Files\OpenOffice.org 3\program\quickstart.exe
O4 - Global Startup: BTTray.lnk = ?
O8 - Extra context menu item: Ajouter la cible du lien à un fichier PDF existant - res://C:\Program Files\Fichiers communs\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
O8 - Extra context menu item: Ajouter à un fichier PDF existant - res://C:\Program Files\Fichiers communs\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convertir au format Adobe PDF - res://C:\Program Files\Fichiers communs\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convertir la cible du lien au format Adobe PDF - res://C:\Program Files\Fichiers communs\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
O8 - Extra context menu item: E&xporter vers Microsoft Excel - res://C:\PROGRA~1\MICROS~3\Office12\EXCEL.EXE/3000
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\Office12\REFIEBAR.DLL
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O10 - Unknown file in Winsock LSP: c:\windows\system32\nwprovau.dll
O14 - IERESET.INF: START_PAGE_URL=http://www.hp.com
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://www.update.microsoft.com/windowsupdate/v6/V5Controls/en/x86/client/wuweb_site.cab?1235214320250
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1235255453649
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - ALWIL Software - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: Autodesk Licensing Service - Autodesk - C:\Program Files\Fichiers communs\Autodesk Shared\Service\AdskScSrv.exe
O23 - Service: avast! Antivirus - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
O23 - Service: avast! Web Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
O23 - Service: Bluetooth Service (btwdins) - Broadcom Corporation. - C:\Program Files\WIDCOMM\Logiciel Bluetooth\bin\btwdins.exe
O23 - Service: FLEXnet Licensing Service - Acresso Software Inc. - C:\Program Files\Fichiers communs\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: Service Google Update (gupdate1c9a13568cc10b4) (gupdate1c9a13568cc10b4) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: hpqwmiex - Hewlett-Packard Development Company, L.P. - C:\Program Files\Hewlett-Packard\Shared\hpqwmiex.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - c:\Program Files\Fichiers communs\InstallShield\Driver\1050\Intel 32\IDriverT.exe
O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
O23 - Service: PC Angel (PCA) - SoftThinks - C:\WINDOWS\SMINST\PCAngel.exe
End of file - 9257 bytes
nardino
 Posté le 09/09/2009 à 10:04
Quels sont les bugs constatés ?
raphesse
 Posté le 10/09/2009 à 00:30
Lenteur au demarrage, idem a lancer les applications, surtout mozilla ou explorer, difficulter a fermer, programmes ne repondant pas...
C'est principalement ca le soucis
nardino
 Posté le 10/09/2009 à 09:08
Bonjour.
Dans Démarrer, Exécuter tu tapes cmd et clique sur OK.
-Au prompt, tu tapes chkdsk /r, tu appuies sur [Entrer] et tu redémarres, il faut laisser le scan s'effectuer jusqu'au bout.
374,99 € 499,99 € -25%
Mini PC NiPoGi E3B (AMD Ryzen 5 7430U, 16 Go DDR4, SSD 512 Go, Windows 11 Pro)
299,72 € 399 € -25%
Mini PC Blackview MP60 (Intel N150, 16 Go DDR4, SSD 512 Go, Windows 11)
179,99 € 249,99 € -28%
SSD SanDisk Plus M.2 NVMe 1 To
55,96 € 64,99 € -14%
SSD Crucial P3 Plus 1 To (NVMe, PCIe, M.2, 5000 Mo/s)
47,69 € 75 € -36%
@AliExpress
Ecran 32 pouces KTC H32T13 (QHD, IPS, 100 Hz, 1 ms, HDR10)
159,99 245 € -35%
@AliExpress
Rapport hijackthis après procédure de nettoyage
rapport hijackthis suite probleme apres nettoyage
Rapport hijackthis après nettoyage
rapport hijackthis après nettoyage
rapport hijack après nettoyage
Rapport hijack aprés nettoyage complet
rapport hjack apres nettoyage -resolu
Analyse rapport Hijack (après nettoyage)
nettoyage d'ordi après infection par virus "Bubble dock" / Nosibay
Plus de sujets relatifs à Rapport HJT apres nettoyage
