 réception de mails bizarre avec thunderbird
Pages : [1] 2 ... Fin
Page 1 sur 2 [Fin]
dede59
  Posté le 09/05/2010 @ 14:50
Bonjour à toutes et à tous.
Depuis environ trois semaines, je reçois cet E-mail que je ne comprend pas, et plusieurs fois par jour, alors que bien souvent je n'ai répondu à aucun mail.
Voici ce mail, et que puis-je faire pour y remédier
Merci d'avance
*** ATTENTION ***
Your e-mail is being returned to you because there was a problem with its
delivery. The address which was undeliverable is listed in the section
labeled: "----- The following addresses had permanent fatal errors -----".
The reason your mail is being returned to you is listed in the section
labeled: "----- Transcript of Session Follows -----".
The line beginning with "<<<" describes the specific reason your e-mail could
not be delivered. The next line contains a second error message which is a
general translation for other e-mail servers.
Please direct further questions regarding this message to the e-mail
administrator or Postmaster at that destination.
--AOL Postmaster
(reason: 554 DT:SPM mx30, UMCowKCbTQeiKuZLvU3bAA--.2444S2 1273375404
----- Transcript of session follows -----
... while talking to 163mx04.mxmail.netease.com.:
>>> DATA
<<< 554 DT:SPM mx30, UMCowKCbTQeiKuZLvU3bAA--.2444S2 1273375404
554 5.0.0 Service unavailable
Original-Recipient:
Final-Recipient: RFC822;
Action: failed
Status: 5.0.0
Remote-MTA: DNS; 163mx04.mxmail.netease.com
Diagnostic-Code: SMTP; 554 DT:SPM mx30, UMCowKCbTQeiKuZLvU3bAA--.2444S2 1273375404
Last-Attempt-Date: Sat, 8 May 2010 23:23:24 -0400
Return-Path:
Received: from mtaout-da05.r1000.mx.aol.com (mtaout-da05.r1000.mx.aol.com [172.29.51.133])
by imr-db03.mx.aol.com (8.14.1/8.14.1) with ESMTP id o493N1wq020323
for Sat, 8 May 2010 23:23:01 -0400
Message-Id:
Received: from PC-201004241650 (unknown [119.136.94.38])
by mtaout-da05.r1000.mx.aol.com (MUA/Third Party Client Interface) with ESMTPA id EF910E000116
for Sat, 8 May 2010 23:22:53 -0400 (EDT)
Subject: =?GB2312?B?wM/F89PR?=
To:
Content-Type: multipart/alternative; boundary="J=_5v3CZe97ByFQ6ZyfQq7EH8hJbgwR98F"
MIME-Version: 1.0
Date: Sun, 9 May 2010 11:22:53 +0800
x-aol-global-disposition: G
X-AOL-VSS-INFO: 5400.1158/58421
X-AOL-VSS-CODE: clean
X-AOL-SCOLL-SCORE: 0:2:269110624:93952408
X-AOL-SCOLL-URL_COUNT: 0
x-aol-sid: 3039ac1d33854be62a8d2f4c
X-AOL-IP: 119.136.94.38
Modifié par dede59 le 09/05/2010 16:04
Havok
 Posté le 09/05/2010 à 15:00
Pour commencer, supprimes ton adresse mail personnel et celle de ton destinataire sur ton post.
Car des prersonnes mal intentionner ou des robot pourrait les récupérer.
Je vais demander à la modération aussi de le faire dans le cas où tu ne lis pas ceci assez tôt.
Remplaces ton adresse par : adressemoi@...
Et celle de ton destinataire par : adressedestinataire@...
Modifié par Havok le 09/05/2010 15:08
Havok
 Posté le 09/05/2010 à 15:06
As tu un mail dans la boite d'envoi ?
Je ne parles pas des éléments envoyé.
dede59
 Posté le 09/05/2010 à 15:26
Bonjour havok
Pouvez vous supprimer mon adresse mail, ainsi que celle du destinataire, car je ne sais comment faire.
Non je n'ai aucun mail dans la boite d'envoi, dès reception de ces mails, je les supprime de suite
Merci de t'occuper de ce problème , et es-ce grave
Havok
 Posté le 09/05/2010 à 15:36
Havok
 Posté le 09/05/2010 à 15:38
Donc, il n'y a rien dans ta boite d'envoi ?
Tu l'as vérifier en l'ouvrant ?
dede59
 Posté le 09/05/2010 à 15:46
Re.
Je viens de vérifier, si il y a bien ce mail dans ma boite d'envoi ( Retourned mail:See transcript for détails, comme j'ai plusieurs adresse mails, j'avais regardé dans envoyés
Encore merci
Havok
 Posté le 09/05/2010 à 15:48
Tu le supprimes alors.
Et ton problème es résolu.
Havok
 Posté le 09/05/2010 à 15:49
L'adresse de ton destinataire est elle juste ?
Havok
 Posté le 09/05/2010 à 15:51
N'oublies pas de modifier ton post initial.
dede59
 Posté le 09/05/2010 à 15:52
Re, je ne connais pas ce destinataire
dede59
 Posté le 09/05/2010 à 15:55
J'ai modifié le post initial en supprimant mon adresse mail, c'est bon ou pas
Havok
 Posté le 09/05/2010 à 16:00
Tu l'as supprimé au lieux de le remplacer comme je te le disais, ce qui fait que si quelqu'un lit ce post il croira à une erreur profonde de thunderbird, alors qu'il n'en est rien.
Mais tu as oublier ton destinataire.
Havok
 Posté le 09/05/2010 à 16:02
Es tu ou connais tu des chinois dans tes connaissances mails ?
dede59
 Posté le 09/05/2010 à 16:07
A non je ne connais aucun chinois , et excuse moi encore de prendre de ton temps.
La j'ai supprimé le destinataire, bon ou pas, merci de jeter un coup d'oeil
Havok
 Posté le 09/05/2010 à 16:12
Plus haut je t'avais dit de faire comme cela.
Comme je le dit ici :
Si maintenant quelqu'un lit ton post il y verra deux erreurs.
Mais laisse comme cela et places ton post en résolu.
Soutenez PC Astuces
Gérer son abonnement
dede59
 Posté le 09/05/2010 à 16:14
Merci pour tout, je le met en résolu
dede59
 Posté le 13/05/2010 à 16:00
Je reviens vers vous, car j'ai déja exposé le problème dont c'est Havok, que je salut au passage, qui a voulu me le résoudre, il ma demandé de le mettre en résolu, mais le problème persiste toujours, et je reçois ce mail 7-8 fois par jour.
Je vous met le mail traduit, car il arrive en anglais
Si quelqu'un pouvait essayer de résoudre ce problème très désagréable, je lui serai très reconnaissant.
Voici ce que je reçois
ATTENTION ***
Votre adresse e-mail est retourné parce qu'il y avait un problème avec son
livraison. L'adresse qui n'a pas été remis est répertorié dans la section
étiquetés: "----- Les adresses suivantes ont permanente des erreurs fatales -----".
La raison pour laquelle le courrier est retourné est répertorié dans la section
étiquetés: "----- Transcription de la session suit -----".
La ligne commençant par "<<<" décrit la raison précise de votre e-mail peut
ne pas être remis. La ligne suivante contient un second message d'erreur qui est une
la traduction en général pour les serveurs e-mail d'autres.
S'il vous plaît directe d'autres questions concernant ce message à l'adresse e-mail
administrateur ou maître de poste de cette destination.
- Postes AOL
<xhsdc2c@163.com>
(Raison: 550 Utilisateur non trouvé: xhsdc2c@163.com)
----- Transcription de la session suivante -----
... tout en parlant à 163mx02.mxmail.netease.com.:
>>>>> Données>
<<<550 Utilisateur non trouvé: xhsdc2c@163.com
550 5.1.1 <xhsdc2c@163.com> ... User unknown
<<451 DT: SPM mx41, V8CowKD7D8mMn tLYpiRAQ - .1600S2, s'il vous plaît essayer à nouveau 1273733012 http://mail.163.com/help/help_spam_16.htm?ip=64.12.206.41&hostid=mx41&time=1273733012
tout en parlant à 163mx04.mxmail.netease.com.:
>>>>> Données>
<<<451 DT: SPM MX20, RsCowLDrR5SPn tLoNq3AA - .978S2, s'il vous plaît essayer à nouveau 1273733012 http://mail.163.com/help/help_spam_16.htm?ip=64.12.206.41&hostid=mx20&time=1273733012
... tout en parlant à 163mx01.mxmail.netease.com.:
>>>>> Données>
<<<451 DT: SPM mx40, VsCowKBby_Wbn tLzQLjAQ - .373S2, s'il vous plaît essayer à nouveau 1273733025 http://mail.163.com/help/help_spam_16.htm?ip=64.12.206.41&hostid=mx40&time=1273733025
... tout en parlant à 163mx03.mxmail.netease.com.:
>>>>> Données>
<<<451 DT: SPM MX9, Kaa tLOp O8CowLD7j9Cgn - .3373S2, s'il vous plaît essayer à nouveau 1273733030 http://mail.163.com/help/help_spam_16.htm?ip=64.12.206.41&hostid=mx9&time=1273733030
... tout en parlant à 163mx00.mxmail.netease.com.:
>>>>> Données>
<<<451 DT: SPM MX7, OcCowKDb6 tL99saAA qon - .1016S2, s'il vous plaît essayer à nouveau 1273733036 http://mail.163.com/help/help_spam_16.htm?ip=64.12.206.41&hostid=mx7&time=1273733036
<xhsc56@163.com>, <xhsanxin@163.com>, <xhs_qmg@163.com>, <xhs_hch@163.com>, <xhs@163.com>, <xhrstone@163.com>, <xhrs2006 @ 163.com> ... Différé: 451 DT: SPM MX7, OcCowKDb6 tL99saAA qon - .1016S2, s'il vous plaît essayer à nouveau 1273733036 http://mail.163.com/help/help_spam_16.htm?ip=64.12.206.41&hostid=mx7&time=1273733036
Original-bénéficiaire: rfc822; xhsdc2c@163.com
Final-bénéficiaire: RFC822; xhsdc2c@163.com
Action: failed
Statut: 5.1.1
Remote-MTA: dns; 163mx02.mxmail.netease.com
Diagnostic-Code: SMTP; 550 Utilisateur non trouvé: xhsdc2c@163.com
Dernière-Tentative-Date: Thu, 13 mai 2010 02:43:28 -0400
Return-Path: <monadresse@aol.com>
Received: from mtaout-db02.r1000.mx.aol.com ([mtaout-db02.r1000.mx.aol.com 172.29.51.194])
par imr-ma03.mx.aol.com (8.14.1/8.14.1) avec ESMTP id o4D6hIjn030037;
Thu, 13 mai 2010 02:43:18 -0400
Message-Id: <@ 201005130643.o4D6hIjn030037> imr-ma03.mx.aol.com
Received: from 20090304-0116 (inconnue [113.91.3.132])
par mtaout-db02.r1000.mx.aol.com (MUA / Tiers Client Interface) avec ESMTPA id A9AD9E000092;
Thu, 13 mai 2010 02:43:14 -0400 (EDT)
Sujet: =? GB2312? B? 1OfS1Ln9yKU1MTMxNDQzOA ==? =
Pour: xhrs2006@163.com
Content-Type: text / html
Date: Thu, 13 mai 2010 14:43:09 0800
x-AOL-global-disposition: G
X-AOL-SCOLL-SCORE: 0:2:126465096:93952408
Action: failed
Statut: 5.1.1
x-AOL-sid: 3039ac1d33c24beb9f822d6d
X-AOL-IP: 113.91.3.132
J'ai remplacé mon adresse mail, par monadresse@aol.com, mais pas ceux de ou des expéditeurs, puisque je n'en connais pas un, et vous précise comme Havok me l'avait demandé, que je ne suis pas chinois, et n'en connait aucun
Merci d'avance
Havok
 Posté le 13/05/2010 à 16:13
A qui as tu envoyé un mail juste avant ce problème ?
dede59
 Posté le 13/05/2010 à 16:22
Bonjour Havok
J'avais reformulé le problème, mais clbugnot ma dit que c'était un doublon,donc qu'il fallait le greffer sur le premier post.
En ce qui concerne à qui j'ai envoyé un mail avant ce problème, je ne saurais te le dire puisque cela fait déja un bon bout de temps que cela est arrivé, et je n'envoi des mails qu'a mes connaissance, c'est le pourquoi de cette énigme
Merci encore d'essayer de trouver une issue à ce problème énervant
Havok
 Posté le 13/05/2010 à 17:43
Il faut faire simple, je suis persuadé qu'hormis une infection (dont je ne crois absolument pas l'exstence vu le mail), ton problème vient de ta manière d'utilisé ton client de messagerie et tes contacts.
Donc, avant de se perdre dans divers coins et recoins de l'univers de l'informatique, je te dirais comme je te l'ai expliqué plus haut de vider ta boite d'envoi.
Et de noté sur papier (très très très très important) quant (et comment) et à qui tu envoies des mails.
Et ce pour pouvoir savoir ce que tu as fait exactement comme envoie juste avant que ce problème n'apparaisse.
dede59
 Posté le 13/05/2010 à 20:43
Bonsoir.
Oui je veux bien imprimer tous mes mails envoyés depuis le 24/12/2009, je pense que c'est la date que j'ai renouvelé le pc, mais je ne peu pas mettre cela sur le forum, alors comment faire, et le problème est parvenu bien après cette date, mes seuls mails envoyés sont des mails de réponses aux personnes qui me contactent pour la location d'outils, puisque je suis ancien artisan et que je possède beaucoup de matériel qui ne se trouve plus dans le commerce, ou alors des outils que les personnes regardent en plusieurs fois avant de les louer dans les enseignes de location,à un prix faisant tomber à la renverse certain, le reste ce n'est que la famille ou des essais que je fais à m'envoyer des mails pour voir si les adresses sont bien configurées, et c'est tout, j'ai regardé mail après mail si un ou plusieurs auraient pu faire défauts, mais je ne vois rien qui pourrai nuire à l'envoi ni à la réception.
Dites moi comment je dois procéder, parceque vu mon age, bientôt 66ans et seulement 6 ans à me débrouiller par mes propres moyents et les forums pour essayer de faire pas mal de chose sur le net, et je vous signale que je ne vais jamais sur des sites douteux de mauvaises réputations, c'est principalement le pourquoi de cet ennui.
A l'instant encore deux mails retourned de la même heure 20h37 comme expliqué alors que je n'en ai pas envoyé un depuis au moins une semaine
Merci de me lire, mais je suis persuadé que je vous ennui
Havok
 Posté le 13/05/2010 à 21:06
Non, je ne te demande pas de faire cela.
Je te dis pour commencer de faire ce que je t'avais dit plus, c'est à dire de vider ta boite d'envoie (ne confond pas avec les éléments envoyés).
Puis la seul chose que je te demande de faire, c'est de continuer à utiliser ton client de messagerie abituel de ta manière abituel, mais en gardant tout tes mails que tu envoies, et en notant sur du papier avec un bic quant et à qui tu envois un mail (la date, heure, et le destinataire).
Et ce jusqu'au moment où tu as denouveau ce genre de problème.
Comme cela on aurra matière à vérification, car on pourra retrouver le mail coupable.
dede59
 Posté le 13/05/2010 à 21:28
Re.
OK je vais suivre ta demande à la lettre, depuis tout à l'heure j'ai regardé dans la corbeille qui n'avait pas été vidée depuis environ deux mois, et j'ai trouvé ce premier mail en date du 23/04/2010 à 19h19, au début c'était 2-3 par jour, et cela en augmentant au fur et à mesure pour en arriver à 13 ce jour à cette heure
Merci encore et bonne soirée
Havok
 Posté le 13/05/2010 à 21:40
Ce n'est pas les mails que tu recois que tu dois gardé, mais ceux que tu envois.
dede59
 Posté le 14/05/2010 à 11:49
Bonjour.
OK, je dois garder ceux que je répond également je pense,et non ceux que j'envoi personnellement de toute manière je vais tout garder
Merci encore
Havok
 Posté le 14/05/2010 à 12:07
Quant je dis que tu dois gardé tous les mails que tu envoies c'est tous les mails que tu envoies, donc cela veut dire que tu ne dois en supprimer aucun de la boite des éléments envoyé (a ne pas confondre avec la boite d'envoie).
Car pour moi comme je te l'ai déjà dit plus haut je suis certains que c'est du à un mail que tu envoies, et donc pour le savoir tu dois tous les garder sans en oublier aucun ......
Havok
 Posté le 14/05/2010 à 13:11
Ne présumes de rien pour l'instant ce que tu donnes comme info ne prouve rien par rapport à ton problème.
Et retire cette adresse mail ce n'est pas bien par rapport au propriétaire de cette adresse car tu risque de la lui pourrir.
dede59
 Posté le 14/05/2010 à 19:12
Re.
ouf, la je pense que je fait plus de tord que de bien, donc j'arrète mes suppositions, mais comme je n'ai jamais eu de réponse, je pense que c'est une histoire oubliée
@+ et Merci
Havok
 Posté le 14/05/2010 à 19:51
Tu reviens sur ce post uniquement quant le problème reviendra, en notant évidament le ment de ce retour.
dede59
 Posté le 14/05/2010 à 20:32
Oui mais le problème revient tous les jours, ce jour 14 retours de ce mail sans avoir poster aucun mail, c'est cela que je ne comprend pas, et comme il m'arrive très rarement d'envoyer un mail, environ 5-6 par an, je ne vois pas comment l'on peu résoudre le problème, surtout que le matin en ouvrant thunderbird, il ni a quasiment que cette cochonnerie, mis à part la lettre de pcastuces et quelques autres auquels je me suis inscrit, mais que des sites corrects qui à mon avis ne devraient pas poser problèmes, je ni comprend plus rien.
Merci d'être aussi patient
Havok
 Posté le 14/05/2010 à 21:10
Quant je t'ai demandé de vidé la boite d'envoi avant de commencer à noté l'as tu fais ?
dede59
 Posté le 15/05/2010 à 19:28
Bonsoir.
Excuse moi de te répondre si tardivement, mais hier j'ai quitté l'ordi juste après mon dernier mail, vu que je devais aller à la pèche ce jour, et la j'en revient.
Oui j'ai bien vidé comme tu me l'avais demandé, mais la en ouvrant thunderbird, 18 mails retourned? ça commence à bien faire, de jour en jour, cela augmente et s'il ni a pas d'autres moyens que tu ma exposé, je pense que cela va empirer, donc je ne sais plus quoi penser
Merci encore de ta patience
Havok
 Posté le 15/05/2010 à 19:36
1-Donc tu as de nouveau le dit problème ?
2-Que disent les dit mail en question ?
3-Regardes la date et l'heure du premier des fameux 18 ?
4-Puis compare cette heure avec ta boite des éléments envoié ?
dede59
 Posté le 15/05/2010 à 19:51
Re, voila c'est toujours le même mail
*** ATTENTION ***
--AOL Postmaster
<710021@126.com>
(reason: 550 User not found: 710021@126.com)
<6c21abbf927ae6df@apps.messenger.live.com>
(reason: 550 Host unknown)
<6c796aafce5408ea@apps.messenger.live.com>
<6f296d09ee68a95b@apps.messenger.live.com>
<6f523c5041c15144@apps.messenger.live.com>
<6fb28fcae7377864@apps.messenger.live.com>
<71@hotmail.com>
(reason: 550 Requested action not taken: mailbox unavailable)
... while talking to 126mx02.mxmail.netease.com.:
>>> DATA
<<< 550 User not found: 710021@126.com
550 5.1.1 <710021@126.com>... User unknown
<<< 503 bad sequence of commands
550 5.1.2 <6fb28fcae7377864@apps.messenger.live.com>,<6f523c5041c15144@apps.messenger.live.com>,<6f296d09ee68a...nger.live.com>,<6c796aafce5408ea@apps.messenger.live.com>,<6c21abbf927ae6df@apps.messenger.live.com>... Host unknown (Name server: apps.messenger.live.com.: host not found)
... while talking to mx4.hotmail.com.:
>>> DATA
<<< 550 Requested action not taken: mailbox unavailable
550 5.1.1 <71@hotmail.com>... User unknown
<<< 503 Need Rcpt command.
Original-Recipient: rfc822;710021@126.com
Final-Recipient: RFC822; 710021@126.com
Action: failed
Status: 5.1.1
Remote-MTA: DNS; 126mx02.mxmail.netease.com
Diagnostic-Code: SMTP; 550 User not found: 710021@126.com
Last-Attempt-Date: Fri, 14 May 2010 19:23:41 -0400
Original-Recipient: rfc822;6c21abbf927ae6df@apps.messenger.live.com
Final-Recipient: RFC822; 6c21abbf927ae6df@apps.messenger.live.com
Action: failed
Status: 5.1.2
Remote-MTA: DNS; apps.messenger.live.com
Diagnostic-Code: SMTP; 550 Host unknown
Last-Attempt-Date: Fri, 14 May 2010 19:23:42 -0400
Original-Recipient: rfc822;6c796aafce5408ea@apps.messenger.live.com
Final-Recipient: RFC822; 6c796aafce5408ea@apps.messenger.live.com
Action: failed
Status: 5.1.2
Original-Recipient: rfc822;6f296d09ee68a95b@apps.messenger.live.com
Final-Recipient: RFC822; 6f296d09ee68a95b@apps.messenger.live.com
Action: failed
Status: 5.1.2
Original-Recipient: rfc822;6f523c5041c15144@apps.messenger.live.com
Final-Recipient: RFC822; 6f523c5041c15144@apps.messenger.live.com
Action: failed
Status: 5.1.2
Original-Recipient: rfc822;6fb28fcae7377864@apps.messenger.live.com
Final-Recipient: RFC822; 6fb28fcae7377864@apps.messenger.live.com
Action: failed
Status: 5.1.2
Original-Recipient: rfc822;71@hotmail.com
Final-Recipient: RFC822; 71@hotmail.com
Action: failed
Status: 5.1.1
Remote-MTA: DNS; mx4.hotmail.com
Diagnostic-Code: SMTP; 550 Requested action not taken: mailbox unavailable
Last-Attempt-Date: Fri, 14 May 2010 19:23:43 -0400
Return-Path: <moi@aol.com>
Received: from mtaout-da02.r1000.mx.aol.com (mtaout-da02.r1000.mx.aol.com [172.29.51.130])
by imr-da04.mx.aol.com (8.14.1/8.14.1) with ESMTP id o4ENNPtS003274;
Fri, 14 May 2010 19:23:25 -0400
Message-Id: <201005142323.o4ENNPtS003274@imr-da04.mx.aol.com>
Received: from PC-201004241650 (unknown [119.123.141.79])
by mtaout-da02.r1000.mx.aol.com (MUA/Third Party Client Interface) with ESMTPA id 4B442E0000E1;
Fri, 14 May 2010 19:23:19 -0400 (EDT)
Subject: ni hao ! i love you .} 51579
To: 71@hotmail.com
Content-Type: multipart/alternative; boundary="QtOUVwrYoQtohcYi=_MBokFAH5Dmz3h2Kh"
MIME-Version: 1.0
Date: Sat, 15 May 2010 07:23:10 +0800
X-AOL-VSS-INFO: 5400.1158/58601
X-AOL-SCOLL-SCORE: 0:2:203889424:93952408
x-aol-sid: 3039ac1d33824beddb6737c5
X-AOL-IP: 119.123.141.79
Havok
 Posté le 15/05/2010 à 20:43
ET le 3 et 4 ????
dede59
 Posté le 16/05/2010 à 11:27
Et le 3 le 4, je suppose que c'est la suite du mail, mais je ne l'ai pas posté puisque ce ne sont que des mails avec mon adresse mail, auquel je dois répondre à des adresses bizarre.
Aujourdh'ui nouveau mail bizarre en hotmail et en chinois?
J'ai volontairement enlevé une lettre dans leur adresse mail pour ne pas faire tord à une personne, si une personne est en cause
Voici ce mail
De postmas@hotmail.com
Sujet Delivery Status Notification (Failure)
Pour liuto96@hotmail.com
This is an automatically generated Delivery Status Notification.
Delivery to the following recipients failed.
Action: failed
Status: 5.5.0
Diagnostic-Code: smtp;550 Requested action not taken: mailbox unavailable (-853714248:3357:-2147467259)
Sujet:
///忠 //告//46282315
De :
"nonadresse"
Date :
Sat, 15 May 2010 23:28:48 +0800
Pour :
liuto96@hotmail.com
ϧ
您好!
本情公铬司空現狐有尔發十嘌黄可冤優车惠颅對威外横代喻開,代享開炔範尼圍:债商漳品包銷办售,
商兹業蹬,疼廣峻告,芽運伎輸,畏國蒲際鸥海砌運搂,其替它镣服欲務钩業,淑餐梧飲嚷業,瞄建窥築域安娩裝瞎等针。
县本丸公挑司抹鄭忽重姿承赦諾砌所便用菠嘌耀據桑均任為恍各砸單排位鹊在桃稅坤務师局笆所床申锥領蔓,可捆上
網涡查闸詢次驗监證樟.珐如岔貴厕公填司术需秤要销發忱嘌吞業轴務汀,老請谰與添我藕司啥聯访系,灸謝醛謝羡合识作貉!
&n bsp; 聯蛆系抒電焰話止:节1因3雇7刹-跺1婪5臆1退-埂4署3彩3少-汲5陵0 ∷ Q坤Q草:枫4广0辑1他5梳1雏0钝7玫9赏3
聯 温系 移人大:种歐吞武拣漢睬(测先叹生祷)
E- MAIL : owuhan23@163.com
Modifié par dede59 le 16/05/2010 11:36
Havok
 Posté le 16/05/2010 à 23:31
Regardes et dis moi si pour l'heure correspondant le dit mail envoyé est envoyé à une adresse de type *****@163.com
dede59
 Posté le 17/05/2010 à 10:29
Je ni comprend plus rien, à moins que je n'avais pas les yeux en face des trous, mais on dirai que l'adresse de l'envoyeur et du récepteur à changée
1 de posmas@hotmail.com Maintenant postmas@local
2 Sujet Delivery Status Notification (Failure)
3 pour maintenant mon nom le 16/05/2010: 12.18
J'y perd mon latin, si ça continue, je pense que je vais devoir formater
Merci, tu dois avoir une patience monstre avec un idiot comme moi
Modifié par dede59 le 17/05/2010 10:31
Havok
 Posté le 17/05/2010 à 11:28
Je vais devoir partir ce Lundi, je ne serai de retour qu'après minuit, nous pourrions continuer demain mardi après 18h si tu veux.
Expliques moi pas à pas exactement tous ce que tu fais étape par étape (numérote les) sans ne rien homettre quant tu écris un nouveau mail.
Expliques bien où tu cliques.
dede59
 Posté le 17/05/2010 à 17:08
Re bonjour.
Je n'envoi aucun mail, mais cela continue, avec une vingtaine par jour.
La seule chose que je fais, c'est poster mes journées de pèche sur un forum très sérieux qui est lespecheursunisdelille, et cela le Samedi et le Mercredi, tu peux vérifier sans crainte, mais je ne pense pas que cela soit considéré comme un mail, enfin à tout hasard je te le signale
Merci bonne soirée et à demain
Page 1 sur 2 [Fin]
24 Piles rechargeables AmazonBasics AAA 850 mAh
16,82 € 25,11 € -33%
Carte graphique AMD Radeon RX 7900XTX XFX Speedster Merc310 24 Go
829 € 899 € -8%
Carte Ziyituod AX210 PCIe WIFI 6E (5400 Mbps) + Bluetooth 5.3 avec dissipateur
27,45 € 36,90 € -26%
Mini PC BMAX B10 Pro (Intel Core i7-13620H, 24 Go RAM DDR5, SSD NVMe 1 To, WiFi 6, BT 5.2, Windows 11)
464,99 € 499 € -7%
Inhalateur Beurer IH 15
24,99 € 40 € -38%
Disque dur externe USB 3.0 Seagate 8 To
164,85 € 180 € -8%
Réception des mails impossible avec Thunderbird
reception mails impossible thunderbird
Pb envoi mails avec Thunderbird 17.0 portable
copie mails envoyés impossible avec Thunderbird
outlook et réception de mails avec mon adresse
reception de mails avec une fausse adresse
Problème réception mails avec Outlook Express
Impossible d'envoyer des mails avec Thunderbird 3
où se trouve les mails de thunderbird avec vista?
Problème réception mails sur Thunderbird
Plus de sujets relatifs à réception de mails bizarre avec thunderbird
