 [Réglé] Question bête (quoique ?) sur le WiFi
tmax
  Posté le 12/08/2007 @ 21:52
Bonsoir Smile
Je débute www.voiloo.net%2FWarez.html%26searchdate%3D12%2BAug%2B2007%2B19%253a57%253a15%253a07%26edh%3DeZGTJKJ46qk4%252bs2Bn5K8CSae6pc%253d%26ed%3Ddj0xJm10PTYmcGFyYW0xPXZhbHVlMSZwYXJhbTI9dmFsdWUy" target="_blank">tout juste dans le www.sfrentreprises.fr%252ftpe-pme%252fsolutions-data%252fsfr-global-access%252f%253fsfrcpid%253dext_ref_pay_07%26bidid%3D601082228%26searchguid%3D%259A%25E9%258C%25B3%258D%25EB%25EC%259B%25F7%25F6%258E%25EC%25F0%25B9%258A%25B8%25AC%25B6%25B0%25C2%25E5%25D0%25C7%25F8%25D5%25C3%25E4%25E9%25A4%25CD%259C%25D9%25D8%25A1%258D%25E4%26domain%3DFR%26affiliateid%3D2020%26position%3D1%26ReferralURL%3Dhttp%3A%2F%2Fwawa-mania.fr%2Fwarez%2Fviewtopic.php%3Ft%3D8042%26searchdate%3D12%2BAug%2B2007%2B19%253a52%253a45%253a13%26edh%3D3sGJ8z%252fQcn55KQ%252fEI8bvjOYKXKE%253d%26ed%3Ddj0xJm10PTMmcGFyYW0xPXZhbHVlMSZwYXJhbTI9dmFsdWUy" target="_blank">WiFi,
et je constate une chose qui me laisse perplexe :
Mon PC fixe est équipé d'un routeur WiFi sur lequel se connecte mon www.sfrentreprises.fr%252ftpe-pme%252fsolutions-voix%252f%253fsfrcpid%253dext_ref_pay_07%26bidid%3D601082347%26searchguid%3D%25C9%25ED%25DD%25BE%2588%25E8%25ED%25C6%25F7%25F1%25DC%25B0%25F6%25B9%258A%25EA%25FC%25E3%25B0%25C3%25E5%25D3%25C1%25F8%25D5%2591%25B6%25EC%25F3%2592%259A%258B%258C%25A2%2586%25BC%26domain%3DFR%26affiliateid%3D2020%26position%3D2%26ReferralURL%3Dhttp%3A%2F%2Fwww.voiloo.net%2FWarez-date_added-30.html%26searchdate%3D12%2BAug%2B2007%2B20%253a00%253a50%253a13%26edh%3DeZGTJKJ46qk4%252bs2Bn5K8CSae6pc%253d%26ed%3Ddj0xJm10PTYmcGFyYW0xPXZhbHVlMSZwYXJhbTI9dmFsdWUy" target="_blank">portable. En le plaçant juste à côté, la connexion a bien du mal à s'établir lorsque le portable est sur batterie, alors que, dès que je le branche sur le secteur, la connexion est instantanée !
C'est normal, www.pagesjaunes.fr%252fpj.cgi%253ffaire%253dinscriptions_req%2526FRM_ACTIVITE%253ddocteur%2526id_partenaire%253dmiva%26bidid%3D590486583%26searchguid%3D%251C%25D9%2582%258E%2581%25A9%25D5%25CF%2599%25E0%259E%25EE%25D8%25A6%2588%25BF%25BC%25C8%25F7%25A2%2589%25EE%25F2%25B9%25DC%25BE%25A8%25E0%25AB%259E%25B1%25D4%2597%25E3%2585%25C3%26domain%3DFR%26affiliateid%3D2020%26position%3D1%26ReferralURL%3Dhttp%3A%2F%2Fwawa-mania.fr%2Fwarez%2Fviewtopic.php%3Ft%3D15775%26searchdate%3D12%2BAug%2B2007%2B19%253a54%253a32%253a03%26edh%3D3sGJ8z%252fQcn55KQ%252fEI8bvjOYKXKE%253d%26ed%3Ddj0xJm10PTMmcGFyYW0xPXZhbHVlMSZwYXJhbTI9dmFsdWUy" target="_blank" target="_blank">docteur ? Shocked
Modifié par tmax le 14/08/2007 10:06
AngeBleu
 Posté le 12/08/2007 à 22:20
salut,
?????????? , c'est quoi tes liens, ils s'ouvrent sur rien
et regarde du coté de l'option d'alimentation, gestion de de l'alimentation.
tmax
 Posté le 13/08/2007 à 11:49
Euh... Je ne comprends pas ce qui est arrivé à mon message !!
Je reposte :
Bonsoir :)
Je débute tout juste dans le WiFi,
Mon PC fixe est équipé d'un routeur WiFi sur lequel se connecte mon portable. En le plaçant juste à côté, la connexion a bien du mal à s'établir lorsque le portable est sur batterie, alors que, dès que je le branche sur le secteur, la connexion est instantanée !
C'est normal, docteur ? :ouch:
Sylvain_07
 Posté le 13/08/2007 à 14:24
Salut,
je pense aussi que celà peu venir des utiliraires de gestion de l'alimentation .
quand le portable est sur la bâterie : l'ordinateur doit arrêter la carte réseau wiffi pour économiser de l'energie.
celon les modèle et les marques.: les portable disposent d'utilitaire spécifique qui permettent de gérer ses options.
tmax
 Posté le 14/08/2007 à 10:05
Hello !
Effectivement, en fouinant dans le Gestionnaire de Périph., j'ai pu régler la puissance d'émission de la carte WiFi, et elle se connecte à présent sans problème !
Merci à vous
87,90 €Tondeuse à gazon électrique Bosch ARM 32 à 87,90 €
Valable jusqu'au 30 Juillet
Amazon fait une promotion sur la tondeuse à gazon électrique Bosch ARM 32 qui passe à 87,90 € livrée gratuitement alors qu'on la trouve ailleurs à partir de 109,99 €.  Avec la tondeuse à gazon ARM 32 Bosch, rien de plus facile que de bien entretenir sa pelouse en un minimum de temps. Équipée d’un puissant moteur de 1 200 W, elle tond sans effort et efficacement l’herbe haute ou dense et assure une tonte parfaite.
Sa grande légèreté et sa forme compacte permettent de contourner facilement les obstacles. Son guide herbe permet une tonte au ras des murs, des parterres de fleurs et des bordures.  La hauteur de coupe est réglable de 20 à 60 mm. Bac de ramassage de 31 litres. La tondeuse à gazon ARM 32 est par ailleurs peu encombrante. Le guidon peut être replié après utilisation.
7,28 €Câble antivol Ewent EW1241 (1.5 m, à combinaison) à 7,28 €
Valable jusqu'au 26 Juillet
Amazon fait une promotion sur le câble antivol Ewent EW1241 qui passe à 7,28 € seulement au lieu de 12 €. Ce câble de 1,5 m est universel et facile à utiliser avec n'importe quel ordinateur portable ou de bureau avec un slot de sécurité. intégré. Protégez votre ordinateur contre le vol grâce à la serrure à combinaison à 4 chiffres.
Question wifi
QUESTION Carte WIFI
question sur carte wifi pc portable
question wifi
Une petite question toute bête...
Petite question un peu bête (e mails)
wifi question
Question sur Clé WiFi
Question sur la Wifi
Question sur pci carte resau WIFI
Plus de sujets relatifs à [Réglé] Question bête (quoique ?) sur le WiFi
