 scan du registre avec CC CLEANER
senorito
  Posté le 06/06/2012 @ 18:48
Bonjour- J'utilise régulièrement cc cleaner depuis longtemps- J'ai remarqué en scannant le registre que revient à chaque fois ce qui suit, après chaque scan :
ActiveX/COM inexistant ehGLID.GLIDPlugInUDCR - {C3F8B282-5B69-47F0-80C3-A22A97FF2EB5} HKCR\ehGLID.GLIDPlugInUDCR
ActiveX/COM inexistant ehGLID.GLIDPlugInUDCR.1 - {C3F8B282-5B69-47F0-80C3-A22A97FF2EB5} HKCR\ehGLID.GLIDPlugInUDCR.1
ActiveX/COM inexistant InProcServer32\C:\Windows\SysWOW64\wpcmig.dll HKCR\CLSID\{343D770D-7788-47c2-B62A-B7C4CED925CB}
ActiveX/COM inexistant InProcServer32\C:\Windows\SysWOW64\wpcumi.dll HKCR\CLSID\{DFA14C43-F385-4170-99CC-1B7765FA0E4A}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\tm20dec.ax HKCR\CLSID\{4CB63E62-C611-11D0-83AA-000092900184}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\tm20dec.ax HKCR\CLSID\{4CB63E61-C611-11D0-83AA-000092900184}
ActiveX/COM inexistant InProcServer32\%systemroot%\system32\sharemediacpl.cpl HKCR\CLSID\{B977CB2D-EC6E-4A8F-BFFE-D18682BB0D52}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\ir50_32.dll HKCR\CLSID\{E369A160-F3C2-11D0-91D4-444553540000}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\ir50_32.dll HKCR\CLSID\{C1C0FE00-F3C2-11D0-91D4-444553540000}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\ir50_32.dll HKCR\CLSID\{84725EA1-2FBC-11D1-BC86-00A0C969FC67}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\ir50_32.dll HKCR\CLSID\{665A444A-D905-11D0-A30E-444553540000}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\ir50_32.dll HKCR\CLSID\{665A4448-D905-11D0-A30E-444553540000}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\ir50_32.dll HKCR\CLSID\{665A4445-D905-11D0-A30E-444553540000}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\ir50_32.dll HKCR\CLSID\{665A4444-D905-11D0-A30E-444553540000}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\ir50_32.dll HKCR\CLSID\{665A4443-D905-11D0-A30E-444553540000}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\ir50_32.dll HKCR\CLSID\{30355649-0000-0010-8000-00AA00389B71}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\ir50_32.dll HKCR\CLSID\{2DE89781-DBF6-11D0-A30E-444553540000}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\ir50_32.dll HKCR\CLSID\{1F73E9B1-8C3A-11D0-A3BE-00A0C9244436}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\ir41_32.ax HKCR\CLSID\{BD323433-CE94-11CE-82DD-0800095A5B55}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\ir41_32.ax HKCR\CLSID\{BD323432-CE94-11CE-82DD-0800095A5B55}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\ir41_32.ax HKCR\CLSID\{BD323431-CE94-11CE-82DD-0800095A5B55}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\ir41_32.ax HKCR\CLSID\{BD323430-CE94-11CE-82DD-0800095A5B55}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\ir41_32.ax HKCR\CLSID\{A2551F60-705F-11CF-A424-00AA003735BE}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\ir41_32.ax HKCR\CLSID\{87CA6F04-49E4-11CF-A3FE-00AA003735BE}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\ir41_32.ax HKCR\CLSID\{87CA6F02-49E4-11CF-A3FE-00AA003735BE}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\ir41_32.ax HKCR\CLSID\{31345649-0000-0010-8000-00AA00389B71}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\iac25_32.ax HKCR\CLSID\{C83B5610-E0DF-11D0-9E00-00AA00AF3494}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\iac25_32.ax HKCR\CLSID\{B4CA2971-DD2B-11D0-9DFA-00AA00AF3494}
ActiveX/COM inexistant InProcServer32\C:\Windows\system32\iac25_32.ax HKCR\CLSID\{B4CA2970-DD2B-11D0-9DFA-00AA00AF3494}
Référence manquante de bibliothèques de types IRoamRemoteStore - {38e8db48-2747-444f-970d-8437534991ca} HKCR\Interface\{062c7f3f-5d6c-426b-95d9-69dddcf524ad}
Référence manquante de bibliothèques de types IRoamTokens - {38e8db48-2747-444f-970d-8437534991ca} HKCR\Interface\{3581572a-9b9e-4500-bcad-5bb5a737b0e2}
Référence manquante de bibliothèques de types IRoamLocalStore - {38e8db48-2747-444f-970d-8437534991ca} HKCR\Interface\{435eb1b8-b681-4569-b862-551e13764315}
Référence manquante de bibliothèques de types IRoamFilters - {38e8db48-2747-444f-970d-8437534991ca} HKCR\Interface\{5a36a745-8357-49ff-92ee-9a5bfe043496}
Référence manquante de bibliothèques de types IRoamConflictResolution - {38e8db48-2747-444f-970d-8437534991ca} HKCR\Interface\{5c60f565-4f7f-4894-a9c8-1c4cad355f16}
Référence manquante de bibliothèques de types IIndeoEncodeOA - {665A4446-D905-11D0-A30E-444553540000} HKCR\Interface\{665A4449-D905-11D0-A30E-444553540000}
Référence manquante de bibliothèques de types IIndeoDecodeOA - {665A4446-D905-11D0-A30E-444553540000} HKCR\Interface\{665A4447-D905-11D0-A30E-444553540000}
Emplacement d'application invalide SnippingTool.exe - %SystemRoot%\system32\SnippingTool.exe HKLM\Software\Microsoft\Windows\CurrentVersion\App Paths\SnippingTool.exe
Référence à un fichier invalide ImagePath - "c:\program files\avast software\avast\afwserv.exe" HKLM\SYSTEM\CurrentControlSet\services\avast! Firewall
Est-ce normal ou faut-il y remédier ? Si oui, comment ?
Merci pour votre aide éventuelle- Cordialement
nardino
 Posté le 06/06/2012 à 23:43
Tu espères gagner quoi en supprimant ces lignes ?
Ne me dis pas de la place, je vais pouffer.
Scan de mon PC avec ADW Cleaner.
Impossible de réaliser un scan complet avec ZHPDiag"
Résultat d'un scan avec ZHPCleaner .
Un petit souci avec ZHP cleaner
probléme avec adw cleaner
Registre bloqué sous Avira avec suspicion d'infection
Résultat scan ADW Cleaner 4.109
Utilité de scan avec son antivirus .
ADW Cleaner Problèmes de connection après scan
C Cleaner , le registre et sa sauvegarde
Plus de sujets relatifs à scan du registre avec CC CLEANER
