 Traduction doom 3 : JE DEMEANDE DE L'AIDESujet résolu
Aball
  Posté le 20/11/2006 @ 00:39
Bonjour à tous(tes), je voudrais savoir comment appliquer le fichier zpak000 pour traduire doom 3 en fr,
je l'ai placé dans la racine du jeu (base) et j'ai modifié le fichier le fichier doomconfig en remplaçant english par french et j'ai aucuns résultats , quelqu'un pourrait m'aider ?
hugoman83
 Posté le 20/11/2006 à 13:24
Message original par Aball
Bonjour Aball,
Pourtant ta manip' semble correcte.
Verifie que ton fichier DoomConfig.cfg soit bien comme ici:
// IvL/FblnaU4w6bO89mN9XIzJKwdEz1acOB3LQ6Vj2NWPrRjcMHDUWwpZzE/zePncK5OqmdhYBPxNkhO6bQA=
unbindall
bind "TAB" "_impulse19"
bind "ENTER" "_button2"
bind "ESCAPE" "togglemenu"
bind "SPACE" "_moveUp"
bind "/" "_impulse14"
bind "0" "_impulse10"
bind "1" "_impulse0"
bind "2" "_impulse1"
bind "3" "_impulse2"
bind "4" "_impulse3"
bind "5" "_impulse4"
bind "6" "_impulse5"
bind "7" "_impulse6"
bind "8" "_impulse7"
bind "9" "_impulse8"
bind "[" "_impulse15"
bind "\\" "_mlook"
bind "]" "_impulse14"
bind "a" "_left"
bind "c" "_movedown"
bind "d" "_moveRight"
bind "e" "_right"
bind "f" "_impulse11"
bind "g" "_impulse9"
bind "q" "_moveLeft"
bind "r" "_impulse13"
bind "s" "_back"
bind "t" "clientMessageMode"
bind "y" "clientMessageMode 1"
bind "z" "_forward"
bind "BACKSPACE" "clientDropWeapon"
bind "PAUSE" "pause"
bind "DOWNARROW" "_back"
bind "LEFTARROW" "_left"
bind "RIGHTARROW" "_right"
bind "ALT" "_strafe"
bind "CTRL" "_attack"
bind "SHIFT" "_speed"
bind "DEL" "_lookdown"
bind "PGDN" "_lookup"
bind "END" "_impulse18"
bind "F1" "_impulse28"
bind "F2" "_impulse29"
bind "F3" "_impulse17"
bind "F5" "savegame quick"
bind "F6" "_impulse20"
bind "F7" "_impulse22"
bind "F9" "loadgame quick"
bind "F12" "screenshot"
bind "MOUSE1" "_attack"
bind "MOUSE2" "_moveup"
bind "MOUSE3" "_zoom"
bind "MWHEELDOWN" "_impulse14"
bind "MWHEELUP" "_impulse15"
seta radiant_entityMode "0"
seta gui_mediumFontLimit "0.60"
seta gui_smallFontLimit "0.30"
seta net_socksPassword ""
seta net_socksUsername ""
seta net_socksPort "1080"
seta net_socksServer ""
seta net_socksEnabled "0"
seta win_ypos "22"
seta win_xpos "3"
seta sys_lang "french"
seta s_numberOfSpeakers "2"
seta s_doorDistanceAdd "150"
seta s_globalFraction "0.8"
seta s_subFraction "0.75"
seta s_playDefaultSound "1"
seta s_volume_dB "0"
seta s_meterTopTime "2000"
seta s_reverse "0"
seta s_spatializationDecay "2"
seta s_maxSoundsPerShader "0"
seta r_debugArrowStep "120"
seta r_debugLineWidth "1"
seta r_debugLineDepthTest "0"
seta r_cgFragmentProfile "best"
seta r_cgVertexProfile "best"
seta r_forceLoadImages "0"
seta r_shadows "1"
seta r_skipBump "0"
seta r_skipSpecular "0"
seta r_skipNewAmbient "0"
seta r_renderer "best"
seta r_brightness "1"
seta r_gamma "1"
seta r_swapInterval "0"
seta r_useIndexBuffers "0"
seta r_customHeight "486"
seta r_customWidth "720"
seta r_fullscreen "1"
seta r_mode "5"
seta r_multiSamples "0"
seta image_downSizeLimit "256"
seta image_ignoreHighQuality "0"
seta image_downSizeBumpLimit "256"
seta image_downSizeSpecularLimit "64"
seta image_downSizeBump "0"
seta image_downSizeSpecular "0"
seta image_useCache "0"
seta image_cacheMegs "20"
seta image_cacheMinK "200"
seta image_usePrecompressedTextures "0"
seta image_useNormalCompression "0"
seta image_useAllFormats "1"
seta image_useCompression "0"
seta image_roundDown "1"
seta image_forceDownSize "0"
seta image_downSize "0"
seta image_lodbias "0"
seta image_anisotropy "8"
seta image_filter "GL_LINEAR_MIPMAP_LINEAR"
seta gui_filter_gameType "0"
seta gui_filter_players "0"
seta gui_filter_password "0"
seta net_master4 ""
seta net_master3 ""
seta net_master2 ""
seta net_master1 ""
seta net_clientMaxRate "16000"
seta net_serverMaxClientRate "16000"
seta m_strafeSmooth "4"
seta m_smooth "1"
seta m_strafeScale "6.25"
seta m_yaw "0.022"
seta m_pitch "0.022"
seta sensitivity "5"
seta in_alwaysRun "0"
seta in_freeLook "1"
seta in_anglespeedkey "1.5"
seta in_pitchspeed "140"
seta in_yawspeed "140"
seta gui_configServerRate "0"
seta com_guid ""
seta com_showFPS "0"
seta com_purgeAll "0"
seta com_machineSpec "3"
seta g_decals "1"
seta g_projectileLights "1"
seta g_doubleVision "1"
seta g_muzzleFlash "1"
seta mod_validSkins "skins/characters/player/marine_mp;skins/characters/player/marine_mp_green;skins/characters/player/marine_mp_blue;skins/characters/player/marine_mp_red;skins/characters/player/marine_mp_yellow"
seta g_mapCycle "mapcycle"
seta g_voteFlags "0"
seta g_gameReviewPause "10"
seta g_countDown "10"
seta g_password ""
seta g_showBrass "1"
seta g_showProjectilePct "0"
seta g_showHud "1"
seta g_showPlayerShadow "0"
seta g_showcamerainfo "0"
seta g_healthTakeLimit "25"
seta g_healthTakeAmt "5"
seta g_healthTakeTime "5"
seta g_useDynamicProtection "1"
seta g_armorProtectionMP "0.6"
seta g_armorProtection "0.3"
seta g_damageScale "1"
seta g_nightmare "0"
seta g_bloodEffects "1"
seta ui_showGun "1"
seta ui_autoReload "1"
seta ui_autoSwitch "1"
seta ui_team "Red"
seta ui_skin "skins/characters/player/marine_mp"
seta ui_name "Hugo"
seta si_spectators "1"
seta si_usePass "0"
seta si_warmup "0"
seta si_teamDamage "0"
seta si_timeLimit "10"
seta si_fragLimit "10"
seta si_maxPlayers "4"
seta si_map "game/mp/d3dm1"
seta si_gameType "singleplayer"
seta si_name "DOOM Server"
seta g_spectatorChat "0"
a+
Modifié par hugoman83 le 20/11/2006 13:25
Aball
 Posté le 20/11/2006 à 13:44
Merci pour ta réponse mais ça ne fonctionne pas, j'ai pourtant éfféctué un copier/coller de ta source mais
le jeu redémarre toujours en englais ...
hugoman83
 Posté le 20/11/2006 à 13:48
Ce doit être au niveau de ton zpak000.pk4.
Celui que j'ai pèse 48937 ko.
Tu l'as télécharger à part du jeu ou tu l'as eu déjà dans le jeu ?
Aball
 Posté le 20/11/2006 à 14:02
ça y est ça fonctionne, j'ai dû réinstaller le fichier pak000 car je l' avais un peu trop bidouillé ...
Merci , car ensuite j'ai agis simplement en recommençant tout à zéro et en collant ta source.
hugoman83
 Posté le 20/11/2006 à 14:14
No problème
189,99 €Centrale vapeur Calor GV8962 à 189,99 €
Valable jusqu'au 20 Février
Amazon fait une vente flash sur la centrale vapeur Calor GV8962 2400W qui passe à 189,99 € livrée gratuitement au lieu de 285 €.  Vapeur haute pression 6,5 bars pour pénétrer au Cœur des tissus et vous faciliter le repassage. Cuve haute pression pour une vapeur traversant et un gain de temps. Le collecteur anti-calc emprisonne les dépôts calcaires de la cuve pour un entretien facile et efficace et une performance longue durée. Produit fabriqué en France garanti 2 ans et réparable 10 ans.
49,90 €Microphone USB Bird UM1 à 49,90 €
Valable jusqu'au 22 Février
Amazon fait une vente flash sur le Microphone USB Bird UM1 qui passe à 49,90 € alors qu'on le trouve ailleurs à partir de 69 €. La livraison est gratuite. Le Bird UM1 est un micro de studio d'excellente qualité avec interface USB intégrée. C'est une solution idéale et tout-en-un qui évite d'avoir à acheter un préampli ou une interface audio supplémentaire.  Idéal pour le studio, YouTube ou l'animation de votre blog.
329,90 €Ecran ultra large LG 34 pouces 34WL50S-B à 329,90 €
Amazon propose actuellement l'écran 34 pouces LG 34WL50S-B à 329,90 € livré gratuitement alors qu'on le trouve à partir de 400 € ailleurs. Cet écran ultra large est au format 21/9, possède une dalle IPS et offre une résolution de 2560 x 1080 pixels. Avec lui, vous pourrez bénéficier d'une plus grande immersion dans les jeux et les films. Cet écran est compatible FreeSync.
besoin d'aide pour achat pc portable pour jeux
Terraria : Multiplayer (un peu d'aide ne serait pas de refus ;)
bloquee dans candy crush sur pc, aide cheat engine
Aide concernant le choix d'un PC portable de jeu
1.6 besoin d'aide
Besoin de votre aide et avis !
[AIDE]Sa me soule !!!
fs9 aide à la navigation
Jeu SIMS 3 Mamie a besoin d aide
doom et wolfenstein sous vista 64 ???
Plus de sujets relatifs à Traduction doom 3 : JE DEMEANDE DE L''AIDE
