 Wave Corrector gratuit
Sam58
  Posté le 13/03/2018 @ 08:59
Bonjour.
Logiciel Wave Corrector standard ou pro, gratuit.
Complet (malheureusement en anglais), de nombreux tutos...
What Is Wave Corrector PE
Wave Corrector PE is the Professional Edition of Wave Corrector.
Wave Corrector is a true WYSIWYG waveform corrector that automatically removes clicks, ticks and plops from recordings of vinyl records before transfer to CD-R. It also removes hiss and corrects other audio impairments from both vinyl and tape/cassette recordings.
Unlike conventional wave editors, Wave Corrector presents the user with a graphical display of the corrected and uncorrected waveforms overlaid on each other to allow easy visual comparison. In this way, the efficacy of individual click corrections can be assessed and adjusted if necessary. Corrections can be modified or deleted and new corrections can be cued or inserted. Thus, the user has complete control over the correction process.
Wave Corrector also automatically finds track boundaries and assembles separate wave files representing each of the tracks of a multi-track source.
Wave Corrector includes the following key features:
- An intuitive user interface which allows easy before and after auditioning of individual click corrections.
- artefacts produced by the correction process to be as small as possible.
- A minimal number of user settings.
- The capability to adjust and optimise individual corrections.
- The inclusion of a range of digital filters to correct continuous noise and amplitude/frequency distortion.
- The capability to correct the audio volume of recordings.
- The capability to automatically split a wave file into separate tracks.
- Tagging and audio library support.
beorcs
 Posté le 13/03/2018 à 12:24
Message original par Sam58
Complet (malheureusement en anglais) -----> Quel dommage ! (Merci tout de même )
jujube2
 Posté le 13/03/2018 à 12:51
merci gorgle translator: https://tinyurl.com/y8uw8s58
DoubleZéro
 Posté le 13/03/2018 à 15:11
impossible de télécharger le soft. J'ai beau cliquer : que tchi !
Que se passe donc t-il ou est ce que ça vient-il d'un mer illage de ma part ?
Merci de m'éclairer (avec vos projecteurs LED).
Sam58
 Posté le 13/03/2018 à 15:34
Tu n'essaies pas de la télécharger depuis la traduction Google au moins ?
Pas de problème de téléchargement depuis le site original Wave Corrector
Patoche17
 Posté le 14/03/2018 à 09:03
Merci de l'information les amis... je vais voir s'il est plus complet que le petit logiciel propriétaire de mon préampli RIAA Terratec
J'avoue que ma dernière session de récupération de viniles, je l'ai réalisée avec Audacity...
à voir donc
7,99 €Clé USB WiFi N150 Nano Netgear à 7,99 €
Valable jusqu'au 04 Décembre
Amazon fait une offre éclair sur la clé USB WiFi TP-Link TL-WN725N qui passe à 7,99 € alors qu'on la trouve habituellement à partir de 12 €. Cette micro clé USB vous permettra d'ajouter le WiFi N150 à un ordinateur qui en est dépourvu.
18,69 €Clé USB 3.0 SanDisk Ultra Flair 128 Go à 18,69 €
Amazon fait une promotion sur la clé USB 3.0 SanDisk Ultra Flair 128 Go qui passe à 18,69 € alors qu'on la trouve ailleurs à plus de 25 €. Cette clé USB offre des débits jusqu'à 150 Mo/s.
17,99 €Carte mémoire SDXC UHS-I U3 SanDisk Extreme Plus 128 Go (jusqu'à 160 Mo/s) à 17,99 €
Valable jusqu'au 05 Décembre
Amazon fait une superbe promotion sur la carte mémoire SDXC UHS-I U3 SanDisk Extreme Plus d'une capacité de 128 Go qui passe à 17,99 € alors qu'on trouve la carte ailleurs à partir de 30 €. Cette carte mémoire offre des vitesses jusqu'à 160 Mo/s en lecture et 90 Mo/s en écriture et intègre des mécanismes afin de gérer l'usure des cellules de la carte et augmenter ainsi sa durée de vie. Une valeur sûre pour les plus exigeants. Elle résiste aux températures extrêmes, à l'eau, aux chocs et aux rayons X.
La carte est fournie avec le logiciel de récupération de données RescuePRO Deluxe qui facilite la récupération des fichiers qui ont été effacés accidentellement.
Logiciel pour éditer vidéo en français et gratuit
CyberLink PowerDirector 15 gratuit
Recherche convertisseur gratuit sans pub
site de streaming gratuit sans pub
créer diaporama gratuit avec windows 10
Logiciel gratuit pour visionner anciennes cassettes Hi8
Convertilla 0.5.1.29 GRATUIT Portable en Français
Conversion EXCEL en PDF gratuit
telechargement after shot 3 gratuit pour pas longtemps
PhotoDirector 7 Deluxe gratuit
Plus de sujets relatifs à Wave Corrector gratuit
